How to do the pedal test and what the Fault codes mean
871K views 310 replies 144 participants last post by  Pugh125k
#1 · (Edited by Moderator)
edited by pugh125k
This tutorial will tell you simply how to check any fault codes logged in your car, in a cheap cost effective way without the hassle of paying a garage £50 for a diagnostic check
Tools
No specialist tools are needed, only 2 working feet are required, 30 seconds of your time and pen & paper to write down the codes
STEP 1:
Get inside your vehicle a firmly place yourself in your seat. Once in, press both the accelerate and brake pedal together
STEP 2:
With both pedals pressed, put your key in the ignition and turn it to position 2, which is the position that switches all auxilary heating on but not the engine
STEP 3:
Once done, the spanner light will start flashing
if it flashes 10 times it means the number is '0' and any other flashes corresponds to a number with a pause between each number
for example code P0110
the light will flash ten times then pause (2sec Or 1 not sure) flash once, (2sec pause) flash once, (2 sec pause) then flash ten times
if you have more than one code it will stop for a break between each code
however if you don’t have any code stored it will start Flashing and keeps on flashing until you release the pedals
If you follow the above steps you are certain to find codes without ever having to plug an OBD equipment
Code list is here
PCM -- TCM -- BCM -- DDM -- IPC -- EBCM (ABS) -- CANBUS Messaging
P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
P0011 "A" Camshaft Position - Timing Over-Advanced (Bank 1)
P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
P0014 "B" Camshaft Position - Timing Over-Advanced (Bank 1)
P0015 "B" Camshaft Position - Timing Over-Retarded (Bank 1)
P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
P0021 "A" Camshaft Position - Timing Over-Advanced (Bank 2)
P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 "B" Camshaft Position - Actuator Circuit (Bank 2)
P0024 "B" Camshaft Position - Timing Over-Advanced (Bank 2)
P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2)
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
P0100 Mass or Volume Air Flow Circuit
P0101 Mass or Volume Air Flow Circuit Range/Performance
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit
P0111 Intake Air Temperature Circuit Range/Performance
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit
P0116 Engine Coolant Temperature Circuit Range/Performance
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0127 Intake Air Temperature Too High
P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
P0130 O2 Sensor Circuit (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit (Bank 1 Sensor 3)
P0150 O2 Sensor Circuit (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit (Bank 2 Sensor 3)
P0168 Fuel Temperature Too High
P0170 Fuel Trim (Bank 1)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor "A" Circuit
P0181 Fuel Temperature Sensor "A" Circuit Range/Performance
P0182 Fuel Temperature Sensor "A" Circuit Low Input
P0183 Fuel Temperature Sensor "A" Circuit High Input
P0184 Fuel Temperature Sensor "A" Circuit Intermittent
P0185 Fuel Temperature Sensor "B" Circuit
P0186 Fuel Temperature Sensor "B" Circuit Range/Performance
P0187 Fuel Temperature Sensor "B" Circuit Low Input
P0188 Fuel Temperature Sensor "B" Circuit High Input
P0189 Fuel Temperature Sensor "B" Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Circuit
P0196 Engine Oil Temperature Sensor Circuit Range/Performance
P0197 Engine Oil Temperature Sensor Circuit Low
P0198 Engine Oil Temperature Sensor Circuit High
P0199 Engine Oil Temperature Sensor Circuit Intermittent
P0200 Injector Circuit
P0201 Cylinder 1 - Injector Circuit
P0202 Cylinder 2 - Injector Circuit
P0203 Cylinder 3 - Injector Circuit
P0204 Cylinder 4 - Injector Circuit
P0205 Cylinder 5 - Injector Circuit
P0206 Cylinder 6 - Injector Circuit
P0207 Cylinder 7 - Injector Circuit
P0208 Cylinder 8 - Injector Circuit
P0209 Cylinder 9 - Injector Circuit
P0210 Cylinder 10 - Injector Circuit
P0211 Cylinder 11 - Injector Circuit
P0212 Cylinder 12 - Injector Circuit
P0213 Cold Start Injector 1
P0214 Cold Start Injector 2
P0215 Engine Shutoff Solenoid
P0216 Injection Timing Control Circuit
P0217 Engine Coolant Over Temperature Condition
P0218 Transmission Fluid Over Temperature Condition
P0219 Engine Over speed Condition
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit
P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance
P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch "B" Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch "C" Circuit
P0226 Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance
P0227 Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch "C" Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch "C" Circuit Intermittent
P0230 Fuel Pump Primary Circuit
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Turbo/Super Charger Over boost Condition
P0235 Turbo/Super Charger Boost Sensor "A" Circuit
P0236 Turbo/Super Charger Boost Sensor "A" Circuit Range/Performance
P0237 Turbo/Super Charger Boost Sensor "A" Circuit Low
P0238 Turbo/Super Charger Boost Sensor "A" Circuit High
P0239 Turbo/Super Charger Boost Sensor "B" Circuit
P0240 Turbo/Super Charger Boost Sensor "B" Circuit Range/Performance
P0241 Turbo/Super Charger Boost Sensor "B" Circuit Low
P0242 Turbo/Super Charger Boost Sensor "B" Circuit High
P0243 Turbo/Super Charger Wastegate Solenoid "A"
P0244 Turbo/Super Charger Wastegate Solenoid "A" Range/Performance
P0245 Turbo/Super Charger Wastegate Solenoid "A" Low
P0246 Turbo/Super Charger Wastegate Solenoid "A" High
P0247 Turbo/Super Charger Wastegate Solenoid "B"
P0248 Turbo/Super Charger Wastegate Solenoid "B" Range/Performance
P0249 Turbo/Super Charger Wastegate Solenoid "B" Low
P0250 Turbo/Super Charger Wastegate Solenoid "B" High
P0251 Injection Pump Fuel Metering Control "A" (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Balance
P0298 Engine Oil Over Temperature
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0313 Misfire Detected With Low Fuel
P0314 Single Cylinder Misfire (cylinder not specified)
P0320 Ignition/Distributor Engine Speed Input Circuit
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Input Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Input Intermittent (Bank 2)
P0335 Crankshaft Position Sensor "A" Circuit
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0337 Crankshaft Position Sensor "A" Circuit Low Input
P0338 Crankshaft Position Sensor "A" Circuit High Input
P0339 Crankshaft Position Sensor "A" Circuit Intermittent
P0340 Camshaft Position Sensor Circuit
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit
P0351 Ignition Coil "A" Primary/Secondary Circuit
P0352 Ignition Coil "B" Primary/Secondary Circuit
P0353 Ignition Coil "C" Primary/Secondary Circuit
P0354 Ignition Coil "D" Primary/Secondary Circuit
P0355 Ignition Coil "E" Primary/Secondary Circuit
P0356 Ignition Coil "F" Primary/Secondary Circuit
P0357 Ignition Coil "G" Primary/Secondary Circuit
P0358 Ignition Coil "H" Primary/Secondary Circuit
P0359 Ignition Coil "I" Primary/Secondary Circuit
P0360 Ignition Coil "J" Primary/Secondary Circuit
P0361 Ignition Coil "K" Primary/Secondary Circuit
P0362 Ignition Coil "L" Primary/Secondary Circuit
P0370 Timing Reference High Resolution Signal "A"
P0371 Timing Reference High Resolution Signal "A" Too Many Pulses
P0372 Timing Reference High Resolution Signal "A" Too Few Pulses
P0373 Timing Reference High Resolution Signal "A" Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal "A" No Pulses
P0375 Timing Reference High Resolution Signal "B"
P0376 Timing Reference High Resolution Signal "B" Too Many Pulses
P0377 Timing Reference High Resolution Signal "B" Too Few Pulses
P0378 Timing Reference High Resolution Signal "B" Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal "B" No Pulses
P0380 Glow Plug /Heater Circuit "A"
P0381 Glow Plug /Heater Indicator Circuit
P0382 Glow Plug /Heater Circuit "B"
P0385 Crankshaft Position Sensor "B" Circuit
P0386 Crankshaft Position Sensor "B" Circuit Range/Performance
P0387 Crankshaft Position Sensor "B" Circuit Low Input
P0388 Crankshaft Position Sensor "B" Circuit High Input
P0389 Crankshaft Position Sensor "B" Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit
P0404 EGR Open Valve Pintle Error
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 EGR Sensor Signal Low
P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low
P0406 Exhaust Gas Recirculation Sensor "A" Circuit High
P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low
P0408 Exhaust Gas Recirculation Sensor "B" Circuit High
P0410 Secondary Air Injection System
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve "A" Circuit
P0413 Secondary Air Injection System Switching Valve "A" Circuit Open
P0414 Secondary Air Injection System Switching Valve "A" Circuit Shorted
P0415 Secondary Air Injection System Switching Valve "B" Circuit
P0416 Secondary Air Injection System Switching Valve "B" Circuit Open
P0417 Secondary Air Injection System Switching Valve "B" Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit
P0419 Secondary Air Injection System Relay "B" Circuit
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0425 Catalyst Temperature Sensor (Bank 1)
P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)
P0427 Catalyst Temperature Sensor Low Input (Bank 1)
P0428 Catalyst Temperature Sensor High Input (Bank 1)
P0429 Catalyst Heater Control Circuit (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0435 Catalyst Temperature Sensor (Bank 2)
P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)
P0437 Catalyst Temperature Sensor Low Input (Bank 2)
P0438 Catalyst Temperature Sensor High Input (Bank 2)
P0439 Catalyst Heater Control Circuit (Bank 2)
P0440 Evaporative Emission Control System
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit
P0450 Evaporative Emission Control System Pressure Sensor
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0456 Evaporative Emission Control System Leak Detected (very small leak)
P0460 Fuel Level Sensor Circuit
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit
P0481 Cooling Fan 2 Control Circuit
P0482 Cooling Fan 3 Control Circuit
P0483 Cooling Fan Rationality Check
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit
P0491 Secondary Air Injection System (bank 1)
P0492 Secondary Air Injection System (bank 2)
P0500 Vehicle Speed Sensor
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Circuit Low Input
P0503 Vehicle Speed Sensor Intermittent / Erratic / High
P0505 Idle Control System
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch
P0512 Starter Request Circuit
P0520 Engine Oil Pressure Sensor/Switch Circuit
P0521 Engine Oil Pressure Sensor/Switch Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Low Voltage
P0523 Engine Oil Pressure Sensor/Switch High Voltage
P0524 Engine Oil Pressure Too Low
P0530 A/C Refrigerant Pressure Sensor Circuit
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 A/C Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control On Signal
P0566 Cruise Control Off Signal
P0567 Cruise Control Resume Signal
P0568 Cruise Control Set Signal
P0569 Cruise Control Coast Signal
P0570 Cruise Control Accel Signal
P0571 Cruise Control / Brake Switch "A" Circuit
P0572 Cruise Control / Brake Switch "A" Circuit Low
P0573 Cruise Control / Brake Switch "A" Circuit High
P0574 Cruise Control System - Vehicle Speed Too High
P0575 Reserved for Cruise Codes
P0576 Reserved for Cruise Codes
P0577 Reserved for Cruise Codes
P0578 Reserved for Cruise Codes
P0579 Reserved for Cruise Codes
P0580 Reserved for Cruise Codes
P0600 Serial Communication Link
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 ECM/PCM Processor
P0608 Control Module VSS Output "A"
P0609 Control Module VSS Output "B"
P0615 Starter Relay Circuit
P0616 Starter Relay Circuit Low
P0617 Starter Relay Circuit High
P0620 Generator Control Circuit
P0621 Generator "L" Terminal Control Circuit
P0622 Generator "F" Terminal Control Circuit
P0630 VIN Not Programmed or Mismatch - ECM/PCM
P0631 VIN Not Programmed or Mismatch - TCM
P0645 A/C Clutch Relay Circuit
P0650 Malfunction Indicator Lamp (MIL) Control Circuit
P0654 Engine RPM Output Circuit
P0655 Engine Hot Lamp Output Control Circuit
P0656 Fuel Level Output Circuit
P0700 Transmission Control System (will show up as PCM code, but is all TCM Related)
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch "B" Circuit
P0704 Clutch Switch Input Circuit
P0705 Transmission Range Sensor Circuit (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch "B" Circuit Low
P0720 Output Speed Sensor Circuit
P0721 Output Speed Sensor Circuit Range/Performance
P0722 Output Speed Sensor Circuit No Signal
P0723 Output Speed Sensor Circuit Intermittent
P0724 Torque Converter/Brake Switch "B" Circuit High
P0725 Engine Speed Input Circuit
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0737 TCM Engine Speed Output Circuit
P0738 TCM Engine Speed Output Circuit Low
P0739 TCM Engine Speed Output Circuit High
P0740 Torque Converter Clutch Circuit
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid "A"
P0746 Pressure Control Solenoid "A" Performance or Stuck Off
P0747 Pressure Control Solenoid "A" Stuck On
P0748 Pressure Control Solenoid "A" Electrical
P0749 Pressure Control Solenoid "A" Intermittent
P0750 Shift Solenoid "A"
P0751 Shift Solenoid "A" Performance or Stuck Off
P0752 Shift Solenoid "A" Stuck On
P0753 Shift Solenoid "A" Electrical
P0754 Shift Solenoid "A" Intermittent
P0755 Shift Solenoid "B"
P0756 Shift Solenoid "B" Performance or Stuck Off
P0757 Shift Solenoid "B" Stuck On
P0758 Shift Solenoid "B" Electrical
P0759 Shift Solenoid "B" Intermittent
P0760 Shift Solenoid "C"
P0761 Shift Solenoid "C" Performance or Stuck Off
P0762 Shift Solenoid "C" Stuck On
P0763 Shift Solenoid "C" Electrical
P0764 Shift Solenoid "C" Intermittent
P0765 Shift Solenoid "D"
P0766 Shift Solenoid "D" Performance or Stuck Off
P0767 Shift Solenoid "D" Stuck On
P0768 Shift Solenoid "D" Electrical
P0769 Shift Solenoid "D" Intermittent
P0770 Shift Solenoid "E"
P0771 Shift Solenoid "E" Performance or Stuck Off
P0772 Shift Solenoid "E" Stuck On
P0773 Shift Solenoid "E" Electrical
P0774 Shift Solenoid "E" Intermittent
P0775 Pressure Control Solenoid "B"
P0776 Pressure Control Solenoid "B" Performance or Stuck Off
P0777 Pressure Control Solenoid "B" Stuck On
P0778 Pressure Control Solenoid "B" Electrical
P0779 Pressure Control Solenoid "B" Intermittent
P0780 Shift
P0781 1-2 Shift
P0782 2-3 Shift
P0783 3-4 Shift
P0784 4-5 Shift
P0785 Shift/Timing Solenoid
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit
P0791 Intermediate Shaft Speed Sensor Circuit
P0792 Intermediate Shaft Speed Sensor Circuit Range/Performance
P0793 Intermediate Shaft Speed Sensor Circuit No Signal
P0794 Intermediate Shaft Speed Sensor Circuit Intermittent
P0795 Pressure Control Solenoid "C"
P0796 Pressure Control Solenoid "C" Performance or Stuck Off
P0797 Pressure Control Solenoid "C" Stuck On
P0798 Pressure Control Solenoid "C" Electrical
P0799 Pressure Control Solenoid "C" Intermittent
P0801 Reverse Inhibit Control Circuit
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit
P0805 Clutch Position Sensor Circuit
P0806 Clutch Position Sensor Circuit Range/Performance
P0807 Clutch Position Sensor Circuit Low
P0808 Clutch Position Sensor Circuit High
P0809 Clutch Position Sensor Circuit Intermittent
P0810 Clutch Position Control Error
P0811 Excessive Clutch Slippage
P0812 Reverse Input Circuit
P0813 Reverse Output Circuit
P0814 Transmission Range Display Circuit
P0815 Upshift Switch Circuit
P0816 Downshift Switch Circuit
P0817 Starter Disable Circuit
P0820 Gear Lever X-Y Position Sensor Circuit
P0821 Gear Lever X Position Circuit
P0822 Gear Lever Y Position Circuit
P0823 Gear Lever X Position Circuit Intermittent
P0824 Gear Lever Y Position Circuit Intermittent
P0825 Gear Lever Push-Pull Switch (Shift Anticipate)
P0830 Clutch Pedal Switch "A" Circuit
P0831 Clutch Pedal Switch "A" Circuit Low
P0832 Clutch Pedal Switch "A" Circuit High
P0833 Clutch Pedal Switch "B" Circuit
P0834 Clutch Pedal Switch "B" Circuit Low
P0835 Clutch Pedal Switch "B" Circuit High
P0840 Trans Pressure Switch Solenoid C Circuit
P0841 Trans Pressure Switch Solenoid C Circuit Stuck Open
P0842 Trans Pressure Switch Solenoid C Circuit Stuck Closed
P0843 Trans Pressure Switch Solenoid C Circuit High
P0845 Trans Pressure Switch Solenoid D Circuit
P0846 Trans Pressure Switch Solenoid D Circuit Stuck Open
P0847 Trans Pressure Switch Solenoid D Circuit Stuck Closed
P0848 Trans Pressure Switch Solenoid D Circuit High
P1101 Induction Air Measurement - Cross-check Out of Range
P1105 Secondary Vacuum Sensor Circuit
P1106 MAP Sensor Signal Intermittent High
P1107 MAP Sensor Signal Intermittent Low
P1108 MAP to BARO Correlation
P1109 Secondary Port Throttle System
P1110 Engine High Intake Air Temperature Condition
P1111 Intake Air Temperature Circuit Intermittent High
P1112 Intake Air Temperature Circuit Intermittent Low
P1114 Engine Coolant Temperature - Circuit Low Input Intermittent
P1115 Engine Coolant Temperature - Circuit High Input intermittent
P1116 Engine Coolant Temperature Signal Unstable or Intermittent
P1117 Engine Coolant Temperature Signal Out-Of-Range Low
P1118 Engine Coolant Temperature Signal Out-Of-Range High
P1119 Engine Coolant Temperature Signal Out-Of-Range with Transmission Temperature
P1120 Throttle Position Sensor "A" Circuit
P1121 Throttle Position Circuit Signal Intermittent High
P1122 Throttle Position Circuit Signal Intermittent Low
P1125 Multiple Throttle/Pedal Position Sensor
P1127 Open Loop CO Adjust Circuit
P1130 Oxygen Sensor Low Signal Variance (Bank 1 - Sensor 1)
P1131 Oxygen Sensor Low Signal Variance (Bank 1 - Sensor 2)
P1132 Oxygen Sensor Low Signal Variance (Bank 2 - Sensor 1)
P1133 Oxygen Sensor System - Too Few O2S R/L and L/R Switches . (Bank 1 - Sensor 1)
P1134 Oxygen Sensor Circuit - Transition Switch Time Ratio (Bank 1 - Sensor 1)
P1135 Oxygen Sensor Circuit - Mean Voltage Level Lean (Bank 1 - Sensor 1)
P1136 Oxygen Sensor Circuit - Mean Voltage Level Rich (Bank 1 - Sensor 1)
P1137 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 1 - Sensor 2)
P1138 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 1 - Sensor 2)
P1139 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 1 - Sensor 2)
P1140 Oxygen Sensor Circuit - Transition Switch Time Ratio (Bank 1 - Sensor 2)
P1141 Oxygen Sensor Circuit - Mean Voltage Level Lean (Bank 1 - Sensor 2)
P1142 Oxygen Sensor Circuit - Mean Voltage Level Rich (Bank 1 - Sensor 2)
P1143 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 1 - Sensor 3)
P1144 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 1 - Sensor 3)
P1145 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 1 - Sensor 3)
P1153 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 2 - Sensor 1)
P1154 Oxygen Sensor Circuit - Transition Switch Time Ratio (Bank 2 - Sensor 1)
P1155 Oxygen Sensor Circuit - Mean Voltage Level Lean (Bank 2 - Sensor 1)
P1156 Oxygen Sensor Circuit - Mean Voltage Level Rich (Bank 2 - Sensor 1)
P1157 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 2 - Sensor 2)
P1158 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 2 - Sensor 2)
P1159 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 2 - Sensor 2)
P1163 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 2 - Sensor 3)
P1164 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 2 - Sensor 3)
P1165 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 2 - Sensor 3)
P1166 Oxygen Sensor System - Low Voltage During Power Enrichment (Bank 1 - Sensor 1)
P1167 Oxygen Sensor System - High Voltage During Decel Fuel Cut Off (Bank 1 - Sensor 1)
P1168 Oxygen Sensor System - Low Voltage During Power Enrichment (Bank 2 - Sensor 1)
P1169 Oxygen Sensor System - High Voltage During Decel Fuel Cut Off (Bank 2 - Sensor 1)
P1170 Bank to Bank Fuel Trim Offset
P1171 Primary Fuel Pump Insufficient / No Fuel Flow
P1172 Secondary Fuel Pump Insufficient / No Fuel Flow
P1173 Limitation of Injection Quantity
P1180 Engine High Fuel Temperature Condition
P1190 Engine Vacuum Leak
P1191 Intake Air Duct Air Leak
P1195 Engine Low Oil Pressure Condition
P1200 Injector Circuit
P1201 Secondary Mass Air Flow Range/Performance
P1202 Secondary Mass or Volume Air Flow Circuit Low Input
P1203 Secondary Mass or Volume Air Flow Circuit High Input
P1211 Mass Air Flow Circuit Intermittent High
P1212 Mass Air Flow Circuit Intermittent Low
P1214 Injection Pump Timing Offset Error
P1215 GFD Indication
P1216 Fuel Solenoid Response Time Too Short
P1217 Fuel Solenoid Response Time Too Long
P1218 Injection Pump Calibration Resistor Error
P1219 Throttle Position Sensor Reference Voltage Error
P1220 Throttle Position Sensor "B" Circuit
P1221 Throttle Position Sensor "A/B" Range/Performance
P1222 Injector Circuit Intermittent - Cylinder 1
P1225 Injector Circuit Intermittent - Cylinder 2
P1228 Injector Circuit Intermittent - Cylinder 3
P1231 Injector Circuit Intermittent - Cylinder 4
P1234 Injector Circuit Intermittent - Cylinder 5
P1237 Injector Circuit Intermittent - Cylinder 6
P1240 Injector Circuit Intermittent - Cylinder 7
P1243 Injector Circuit Intermittent - Cylinder 8
P1245 Intake Plenum Switchover Valve Circuit
P1246 Intake Resonance Switchover Valve Circuit
P1257 Supercharger - Overboost
P1258 Engine Coolant Over - Temperature Protection
P1260 Fuel Pump Speed Control Circuit
P1270 Accelerator Pedal Position Sensor A/D Converter Error
P1271 Accelerator Pedal Position Sensors 1 & 2 Correlation Error
P1272 Accelerator Pedal Position Sensors 2 & 3 Correlation Error
P1273 Accelerator Pedal Position Sensors 1 & 3 Correlation Error
P1274 Injectors Wired Incorrectly
P1275 Accelerator Pedal Position Sensor 1 Circuit
P1276 Accelerator Pedal Position Sensor 1 Circuit Performance
P1277 Accelerator Pedal Position Sensor 1 Circuit Low Voltage
P1278 Accelerator Pedal Position Sensor 1 Circuit High Voltage
P1279 Accelerator Pedal Position Sensor 1 Circuit Intermittent
P1280 Accelerator Pedal Position Sensor 2 Circuit
P1281 Accelerator Pedal Position Sensor 2 Circuit Performance
P1282 Accelerator Pedal Position Sensor 2 Circuit Low Voltage
P1283 Accelerator Pedal Position Sensor 2 Circuit High Voltage
P1284 Accelerator Pedal Position Sensor 2 Circuit Intermittent
P1285 Accelerator Pedal Position Sensor 3 Circuit
P1286 Accelerator Pedal Position Sensor 3 Circuit Performance
P1287 Accelerator Pedal Position Sensor 3 Circuit Low Voltage
P1288 Accelerator Pedal Position Sensor 3 Circuit High Voltage
P1289 Accelerator Pedal Position Sensor 3 Circuit Intermittent
P1310 Ignition Coil Primary/Secondary Current Sense System
P1311 Ignition Coil "A" Primary/Secondary Circuit
P1312 Ignition Coil "B" Primary/Secondary Circuit
P1313 Ignition Coil "C" Primary/Secondary Circuit
P1314 Ignition Coil "D" Primary/Secondary Circuit
P1315 Ignition Coil "E" Primary/Secondary Circuit
P1316 Ignition Coil "F" Primary/Secondary Circuit
P1317 Ignition Coil "G" Primary/Secondary Circuit
P1318 Ignition Coil "H" Primary/Secondary Circuit
P1320 Distributor Signal Interrupt
P1321 DIS Fault Line
P1322 DIS EST (Extra or Missing)
P1323 Loss of High Resolution RPM Information
P1324 Crank RPM Too Low
P1326 Combustion Quality Circuit
P1336 Crankshaft Position System Variation Not Learned
P1340 Ignition System Cylinder Identifier
P1345 Crankshaft/Camshaft Correlation Error
P1350 Bypass Line Monitor
P1351 EST Output High or Pulses Detected when Grounded - Cylinder 1
P1352 EST Output High or Pulses Detected when Grounded - Cylinder 2
P1353 EST Output High or Pulses Detected when Grounded - Cylinder 3
P1354 EST Output High or Pulses Detected when Grounded - Cylinder 4
P1355 EST Output High or Pulses Detected when Grounded - Cylinder 5
P1356 EST Output High or Pulses Detected when Grounded - Cylinder 6
P1357 EST Output High or Pulses Detected when Grounded - Cylinder 7
P1358 EST Output High or Pulses Detected when Grounded - Cylinder 8
P1359 Ignition Control Circuit Group A (cylinders N, N, N, N )
P1360 Ignition Control Circuit Group B (cylinders N, N, N, N )
P1361 EST Not Toggling After Enabled - Cylinder 1
P1362 EST Not Toggling After Enabled - Cylinder 2
P1363 EST Not Toggling After Enabled - Cylinder 3
P1364 EST Not Toggling After Enabled - Cylinder 4
P1365 EST Not Toggling After Enabled - Cylinder 5
P1366 EST Not Toggling After Enabled - Cylinder 6
P1367 EST Not Toggling After Enabled - Cylinder 7
P1368 EST Not Toggling After Enabled - Cylinder 8
P1370 Too Many Low Resolution Pulses
P1371 Too Few Low Resolution Pulses
P1372 Crankshaft Position Sensor Circuits Performance
P1374 Crank to Low Resolution Correlation
P1375 No Crank Sensor A or B
P1376 Reference Low Voltage Out of Range
P1377 CAM To Reference Correlation
P1380 ABS Preventing Rough Road/Misfire Diagnostic
P1381 Serial Communication Preventing Rough Road/Misfire Diagnostic
P1382 ABS Control Module Performance (Used for 1997 Model Year only)
P1390 Wheel Speed Sensor "A" / G-Sensor Circuit
P1391 Wheel Speed Sensor "A" / G-Sensor Circuit Range/Performance
P1392 Wheel Speed Sensor "A" / G-Sensor Circuit Low Input
P1393 Wheel Speed Sensor "A" / G-Sensor Circuit High Input
P1394 Wheel Speed Sensor "A" / G-Sensor Circuit Intermittent
P1395 Wheel Speed Sensor "B" / G-Sensor Circuit
P1396 Wheel Speed Sensor "B" / G-Sensor Circuit Range/Performance
P1397 Wheel Speed Sensor "B" / G-Sensor Circuit Low Input
P1398 Wheel Speed Sensor "B" / G-Sensor Circuit High Input
P1399 Wheel Speed Sensor "B" / G-Sensor Circuit Intermittent
P1403 Exhaust Gas Recirculation Solenoid Low
P1404 EGR Closed Valve Pintle Error
P1404 Exhaust Gas Recirculation System - Closed Valve Pintle Error
P1405 Exhaust Gas Recirculation Solenoid High
P1406 EGR Pintle Position Error
P1406 Exhaust Gas Recirculation System Pintle Position Error
P1407
P1408 Exhaust Gas Recirculation Vacuum System
P1409 Exhaust Gas Recirculation Vacuum System Leak/Low Supply
P1410 Exhaust Gas Recirculation Vacuum System Restriction
P1415 Secondary Air Injection - Bank 1
P1416 Secondary Air Injection - Bank 2
P1420 Intake Air Low Pressure Switch Circuit Low Voltage
P1421 Intake Air Low Pressure Switch Circuit High Voltage
P1422 Intake Air High Pressure Switch Circuit Low Voltage
P1423 Intake Air High Pressure Switch Circuit High Voltage
P1431 Fuel Level Sensor Circuit Range/Performance (Secondary Tank)
P1432 Fuel Level Sensor Circuit Low Input (Secondary Tank)
P1433 Fuel Level Sensor Circuit High Input (Secondary Tank)
P1441 Evaporative Emission Control System Continuous Open Purge Flow
P1442 Purge Solenoid Diagnostic Vacuum Switch
P1443 Evaporative Emission Control System Purge Control Valve 2 Circuit
P1445 Fuel Heated Catalyst System Bank 1
P1450 Catalyst Heater Diagnostic
P1451 Catalyst Heater Diagnostic
P1452 Catalyst Heater Diagnostic
P1453 Catalyst Heater Diagnostic
P1454 Catalyst Heater Diagnostic
P1455 Catalyst Heater Diagnostic
P1456 Catalyst Heater Diagnostic
P1457 Catalyst Heater Diagnostic
P1458 Catalyst Heater Diagnostic
P1459 Catalyst Heater Diagnostic
P1483 Engine Cooling System Performance
P1501 Vehicle Speed Sensor Intermittent
P1504 Aux Vehicle Speed Output Circuit
P1505 Starter Relay Circuit
P1506 Starter Relay Circuit Low
P1507 Starter Relay Circuit High
P1508 Idle Control System Low/Closed
P1509 Idle Control System High/Open
P1510 Throttle Control System - In Limitation
P1511 Throttle Control System - Backup System Performance
P1512 Throttle Control System - Minimum Throttle Position
P1513 EBTCM to PCM Drag Reduction Request Input Circuit
P1514 Throttle Actuator Control (TAC) System MAF Correlation Error
P1515 Command vs. Actual Throttle Position Correlation (PCM) Error
P1516 Command vs. Actual Throttle Position Correlation (TAC Module) Error
P1517 Throttle Actuator Control (TAC) Module Processor
P1518 PCM to TAC Module Serial Data Circuit
P1519 Throttle Actuator Control (TAC) Module
P1520 Park/Neutral Discrete Error
P1521 P/N to D/R at High Throttle Angle
P1522 P/N to D/R at High RPM
P1523 Throttle Actuator Control Return Performance
P1524 Throttle Position Sensor Out of Adjustment
P1525 Throttle Body Service Required
P1526 TPS Learn Not Done After Reprogramming
P1527 Transaxle Range/Pressure Switch Comparison
P1528 Governor
P1529 Heated Windshield Request
P1530 Throttle Control System - Amplifier Adjustment
P1531 A/C Temperature Sensor Circuit
P1532 A/C Low Side Temperature Sensor Low Input
P1533 A/C Low Side Temperature Sensor High Input
P1534 A/C High Side Temperature Sensor Low Input
P1535 A/C High Side Temperature Sensor High Input
P1536 A/C Coolant Over Temperature
P1537 Very Low Refrigerant Pressure
P1538 A/C Request Shorted High
P1539 High Side Pressure Switch or A/C Relay Shorted
P1540 A/C High Pressure Condition
P1541 A/C High Side Over Temperature
P1542 A/C High Discharge Temperature/Pressure
P1543 Low Refrigerant Condition
P1544 Very Low Refrigerant Condition
P1545 A/C High Pressure Switch or A/C Clutch Relay Circuit
P1546 A/C Clutch Status Circuit Open
P1547 A/C System Performance Degraded
P1548 A/C "Mode" Circuit Low
P1549 A/C "Mode" Circuit High
P1554 Stepper Motor Cruise
P1555 Electronic Variable Orifice Output
P1558 Cruise Control - Servo Indicates Low
P1559 Cruise Control - Power Management Mode
P1560 Cruise Control - Transmission not in Drive
P1561 Cruise Control - Vent Solenoid Failure
P1562 Cruise Control - Vacuum Solenoid Failure
P1563 Cruise Control - Vehicle Speed and Set Speed Difference Too High
P1564 Cruise Control - Vehicle Acceleration Too High
P1565 Cruise Control - Servo Position Sensor Failure
P1566 Cruise Control - Engine RPM Too High
P1567 Cruise Control - Auto Brake Control Disengage
P1568 Cruise Control Servo Stroke Greater than Commanded in Cruise
P1569 Cruise Control Servo Stroke High While not in Cruise Control
P1570 Traction Control Active While in Cruise
P1571 Traction Control PWM Link
P1572 Traction Control Active Too Long
P1573 Loss of ABS Serial Data
P1574 Brake Pedal Position Switch
P1575 Additional Brake Input Diagnostic
P1576 Shorted Brake Booster Vacuum Sensor Circuit
P1577 Open Brake Booster Vacuum Sensor Circuit
P1578 Brake Booster Vacuum Too Low
P1579 High Throttle Angle on P/N to D/R Transition
P1580 Cruise Control Move Circuit - Low
P1581 Cruise Control Move Circuit - High
P1582 Cruise Control Direction Circuit - Low
P1583 Cruise Control Direction Circuit - High
P1584 Cruise Control Disabled
P1585 Cruise Inhibit Control Circuit
P1586 Brake Switch Circuit Number 3
P1599 Engine Stall Detected
P1601 Serial Communication with Device 1 (PCM, Powertrain Control Module)
P1602 Serial Communication with Device 2 (ABS, Antilock Brake System)
P1603 Serial Communication with Device 3 (SIR, Supplemental Inflatable Restraint)
P1604 Serial Communication with Device 4 (IPC, Instrument Panel Cluster)
P1605 Serial Communication with Device 5 (HVAC, Heating Ventilation and Air Conditioning)
P1606 Serial Communication with Device 6 (E&C BUSS, Entertainment and Comfort)
P1607 Serial Communication with Device 7 (MRD, Magnetic Rotation Device)
P1608 Serial Communication with Device 8 (CCM, Central Control Module) P1609 Serial Communication with Device 9 (TCS, Traction Control System)
P1610 Serial Communication with Device 10 (PZM, Platform Zone Module)
P1611 Serial Communication with Device 11 (CVRTD, Continuously Variable Real Time
Dampening)
P1612 Serial Communication with Device 12 (IPM, Instrument Panel Module)
P1613 Serial Communication with Device 13 (DIM, Driver Information Module)
P1614 Serial Communication with Device 14 (RIM, Radio Interface Module)
P1615 Serial Communication with Device 15 (VTD, Vehicle Theft Deterrent)
P1616 is Wrong Vehicle ID from Instrument Control Module C-40
P1617 Engine Oil Level Switch Circuit
P1618 Serial Peripheral Interface (SPI) PCM Internal Communication Error
P1619 Oil Change - Input
P1620 Low Coolant Circuit
P1621 Total EEPROM Failure
P1622 Cylinder Select Error (OBD1 was code 41)
P1623 Transmission Temp Pull-up Resistor
P1624 Customer Snapshot Requested
P1625 PCM System Reset
P1626 Anti-Theft Failure
P1627 A/D Failure
P1628 Engine Coolant Temperature Pull-Up Resistor Failed
P1629 Anti-Theft Device - Cranking Signal
P1630 PCM in Theft Learn Mode
P1631 Anti-Theft Device - PCM/IPC Password Error
P1632 Anti-Theft Device - Fuel Disabled
P1633 PCM Ignition Input "A"
P1634 PCM Ignition Input "B"
P1635 5 Volt Reference "A" Low
P1636 PCM Stack Overrun
P1637 Generator "L" Terminal Control Circuit
P1638 Generator "F" Terminal Control Circuit
P1639 5 Volt Reference "B" Low
P1640 Add on heater, Circuit (Circuit 1)
P1641 Add on heater, Circuit (Circuit 2)
P1642 QDM / ODM "A" - Output 2
P1643 Wait to Start Lamp Control Circuit
P1644 QDM / ODM "A" - Output 4
P1645 QDM / ODM "A" - Output 5
P1646 5Volt Reference "C" Circuit
P1647 QDM / ODM "A" - Output 7
P1648 Anti-Theft Device - Wrong Security Code
P1649 Anti-Theft Device - No Key/Security Code Programmed
P1650 QDM / ODM "B"
P1651 QDM / ODM "B" - Output 1
P1652 Chassis Pitch Status Control Circuit
P1653 Engine Oil Level "Low" Lamp Control Circuit
P1654 Service Throttle Soon Lamp Control Circuit
P1656 Second Gear Start Lamp Control Circuit
P1657 QDM / ODM "B" - Output 7
P1659 Engine Over speed Lamp Control Circuit
P1660 High Idle Lamp Control Circuit
P1661 Check Gages Lamp Control Circuit
P1662 Cruise Control Lamp Control Circuit
P1663 Engine Oil Life/Change Lamp Control Circuit
P1664 Service Vehicle Soon Lamp Control Circuit
P1665 Engine Oil Pressure Gage Output Circuit
P1666 Engine Shutdown Alarm Control Circuit
P1667 QDM / ODM "C" - Output 7
P1670 QDM / ODM "D"
P1671 QDM / ODM "D" - Output 1
P1672 QDM / ODM "D" - Output 2
P1673 QDM / ODM "D" - Output 3
P1674 QDM / ODM "D" - Output 4
P1675 QDM / ODM "D" - Output 5
P1676 QDM / ODM "D" - Output 6
P1677 QDM / ODM "D" - Output 7
P1680 Control Module Performance - APP system
P1681 Control Module Performance - TP system
P1682 Control Module Performance - Ignition Circuit
P1689 Delivered Torque Output Circuit
P1690 ECM Loop Overrun
P1691 Coolant Gage Circuit - Low
P1692 Coolant Gage Circuit - High
P1693 Tachometer Circuit - Low
P1694 Tachometer Circuit - High
P1695 Remote Keyless Entry Circuit - Low
P1696 Remote Keyless Entry Circuit - High
P1697 PZM Disabled Fuel
P1698 Class II Down Disabled Fuel
P1699 In Fail Enable Mode
P1701 Pressure Switch "C" Circuit
P1702 Pressure Switch "C" Stuck Open / Performance
P1703 Pressure Switch "C" Circuit Low / Stuck Closed
P1704 Pressure Switch "C" Circuit High
P1705 Pressure Switch "D" Circuit
P1706 Pressure Switch "D" Stuck Open / Performance
P1707 Pressure Switch "D" Circuit Low / Stuck Closed
P1708 Pressure Switch "D" Circuit High
P1709 Pressure Switch "E" Circuit
P1710 Pressure Switch "E" Stuck Open / Performance
P1711 Pressure Switch "E" Circuit Low / Stuck Closed
P1712 Pressure Switch "E" Circuit High
P1713 Pressure Switch "Reverse" Circuit
P1714 Pressure Switch "Reverse" Stuck Open / Performance
P1715 Pressure Switch "Reverse" Circuit Low / Stuck Closed
P1716 Pressure Switch "Reverse" Circuit High
P1717 Incorrect 6th Gear Ratio
P1718 Incorrect Neutral Gear Ratio
P1720 Solenoid "A" Controlled Clutch Not Engaged
P1721 Solenoid "B" Controlled Clutch Not Engaged
P1722 Manual Selector Valve Controlled Clutch Not Engaged
P1723 Solenoid "A" Controlled Clutch Engaged
P1724 Solenoid "B" Controlled Clutch Engaged
P1725 Manual Selector Valve Controlled Clutch Not Engaged
P1730 Retarder Circuit
P1731 Retarder Circuit Low
P1732 Retarder Circuit High
P1733 Retarder Temperature Sensor Low
P1734 Retarder Temperature Sensor High
P1735 Retarder Over Temperature
P1736 Service Brake Input "ON" With VSS Indicated
P1737 Kick Down Circuit
P1740 NSBU Mode "A" Circuit
P1741 NSBU Mode "A" Circuit Low
P1742 NSBU Mode "A" Circuit High
P1743 NSBU Mode "B" Circuit
P1744 NSBU Mode "B" Circuit Low
P1745 NSBU Mode "B" Circuit High
P1746 NSBU Mode "P" Circuit
P1747 NSBU Mode "P" Circuit Low
P1748 NSBU Mode "P" Circuit High
P1749 NSBU Park/Neutral Switch Compare
P1760 TCM Supply Voltage
P1780 MIL Requested By TCM
P1781 TCM MIL Request Control Circuit
P1782 MIL Requested By TCM - Data Invalid
P1785 Shift Lock Solenoid Circuit - Low Voltage
P1786 Shift Lock Solenoid Circuit - High Voltage
P1790 TCM Checksum Error
P1791 TCM Loop Error
P1792 TCM Reprogrammable Memory Error
P1793 TCM Stack Overrun
P1800 Transmission Power Relay Control Circuit
P1801 Performance Selector Switch (MLP) Failure
P1804 Ground Control Relay
P1810 Pressure Switch Manifold
P1811 Maximum Adapt and Long Shift
P1813 Torque Control
P1814 Torque Converter Overstressed
P1815 Transmission Range Switch Start in Wrong Range
P1816 Transmission Range Switch P/N W/Drive Ratio
P1817 Transmission Range Switch Rev W/Drive Ratio
P1818 Transmission Range Switch Drive W/Rev Ratio
P1820 Transmission Range Internal Mode Switch "A" Circuit Low
P1821 Internal Mode Switch Mode "B" Circuit Low
P1822 Internal Mode Switch Mode "A" Circuit High Voltage
P1823 Internal Mode Switch Mode "P" Circuit Low Voltage
P1824 Internal Mode Switch Mode "P" Circuit High Voltage
P1825 Internal Mode Switch Illegal Range
P1826 Serial Communication - DKI Failure
P1827 Serial Communication - DKP Short to Ground
P1828 Serial Communication - DKP Shorted High
P1829 Serial Communication - TI Signal Line Open
P1831 Pressure Control/Shift Lock Solenoids Power Control Circuit - Low Voltage
P1832 Pressure Control/Shift Lock Solenoids Power Control Circuit - High Voltage
P1833 TCC/Shift Solenoid Power Control Circuit - Low Voltage
P1834 TCC/Shift Solenoid Power Control Circuit - High Voltage
P1835 Kick-Down Switch
P1836 Kick-Down Switch - Failed Open
P1837 Kick-Down Switch - Failed Short
P1842 1-2 Shift Solenoid Circuit - Low Voltage
P1843 1-2 Shift Solenoid Circuit - High Voltage
P1844 TCS Torque Reduction Request Circuit
P1845 Torque Limiter
P1846 2-3 Shift Solenoid Circuit - Low Voltage
P1847 2-3 Shift Solenoid Circuit - High Voltage
P1850 Brake Band Apply Solenoid
P1851 Brake Band Apply Solenoid Range/Performance
P1852 Brake Band Apply Solenoid Low
P1853 Brake Band Apply Solenoid High
P1857 3-2 Solenoid Circuit Low Voltage
P1858 3-2 Solenoid Circuit High Voltage
P1860 Torque Converter Clutch PWM Solenoid Circuit
P1862 TCC Enable Solenoid Circuit Low Voltage
P1863 TCC Enable Solenoid Circuit High Voltage
P1864 Shift Solenoid 4-5 Circuit Low Voltage
P1865 Shift Solenoid 4-5 Circuit High Voltage
P1868 Transmission Fluid Life
P1870 Transmission Component Slipping
P1873 Torque Converter Stator Temperature Switch Circuit Low
P1874 Torque Converter Stator Temperature Switch Circuit High
P1875 4 Wheel Drive Lo Switch Circuit
P1887 Torque Clutch Converter Release Switch Circuit
P1890
P1891 Throttle Position Sensor PWM Signal Low Input
P1892 Throttle Position Sensor PWM Signal High Input
P1893 Engine Torque Signal Low Input
P1894 Engine Torque Signal High Input
P1895 TCM to ECM Torque Reduction Circuit
P1896 Transmission Downshift Switch Circuit
P1897 Transmission Upshift Switch Circuit
P1898 Manual Shift Mode Switch Circuit
B0000 Vehicle speed information circuit malfunction
B0001 Vehicle speed information circuit range/performance
B0002 Vehicle speed information circuit low
B0003 Vehicle speed information circuit high
B0004 Vehicle speed information circuit open
B0005 In "Park" switch circuit malfunction
B0006 In "Park" switch circuit range/performance
B0007 In "Park" switch circuit low
B0008 In "Park" switch circuit high
B0009 In "Park" switch circuit open
B0012 RF/Passenger frontal deployment loop (stage 2) resistance low
B0013 RF/Passenger frontal deployment loop (stage 2) open
B0014 RF/Passenger frontal deployment loop (stage 2) voltage out of range
B0015 RF/Passenger frontal deployment loop resistance high
B0016 RF/Passenger frontal deployment loop (single stage or stage 1) resistance low
B0017 RF/Passenger frontal deployment loop (single stage or stage 1) open
B0018 RF/Passenger frontal deployment loop (single stage or stage 1) short to ground/voltage
B0019 RF/Passenger frontal impact deployment loop short to battery
B0021 LF/Driver frontal deployment loop resistance high
B0022 LF/Driver frontal deployment loop (single stage or stage 1) resistance low
B0024 LF/Driver frontal deployment loop (single stage or stage 1) short to ground/voltage o
B0025 LF/Driver frontal impact deployment loop short to battery
B0026 LF/Driver frontal deployment loop (single stage or stage 1) open
B0027 RF/Passenger side deployment loop resistance high
B0028 RF/Passenger side deployment loop resistance low
B0029 RF/Passenger side deployment loop open
B0030 RF/Passenger side deployment loop short to ground/voltage out of range
B0032 RF/Passenger side impact deployment loop short to battery
B0034 Side airbag deployment commanded
B0035 ADS closed/shorted to ground
B0036 ADS open/missing/shorted to battery
B0037 AUX switch closed/shorted to ground
B0038 AUX switch open/shorted to battery
B0039 LF/Driver side deployment loop resistance high
B0040 LF/Driver side deployment loop resistance low
B0041 LF/Driver side deployment loop open
B0042 LF/Driver frontal deployment loop (stage 2) resistance low
B0043 LF/Driver frontal deployment loop (stage 2) voltage out of range
B0044 LF/Driver frontal deployment loop (stage 2) open
B0045 LF/Driver side deployment loop short to ground/voltage out of range
B0046 LF/Driver side deployment loop short to battery
B0047 Deployment commanded circuit malfunction
B0048 Deployment commanded circuit low
B0049 Deployment commanded circuit high
B0050 Deployment commanded circuit open
B0051 Deployment commanded
B0052 Passenger frontal airbag suppressed
B0053 Deployment commanded with loop malfunctions present
B0054 Passenger side airbag suppressed
B0055 Passenger pre-tensioner suppressed
B0056 RF/Passenger pre-tensioner deployment loop resistance high
B0057 RF/Passenger pre-tensioner deployment loop resistance low
B0058 RF/Passenger pre-tensioner deployment loop open
B0059 RF/Passenger pre-tensioner deployment loop short to ground/voltage out of range
B0060 RF/Passenger pre-tensioner impact deployment loop short to battery
B0061 Supplemental deployment loop #3 resistance low
B0062 Supplemental deployment loop #3 open
B0063 LF/Driver pre-tensioner deployment loop resistance high
B0064 LF/Driver pre-tensioner deployment loop resistance low
B0065 LF/Driver pre-tensioner deployment loop open
B0066 LF/Driver pre-tensioner deployment loop short to ground/voltage out of range
B0067 LF/Driver pre-tensioner impact deployment loop short to battery
B0068 Supplemental deployment loop #3 voltage out of range
B0069 Supplemental deployment loop #4 resistance low
B0070 Supplemental deployment loop #4 open
B0071 Supplemental deployment loop #4 voltage out of range
B0072 Supplemental deployment loop #1 resistance high
B0073 Supplemental deployment loop #1 resistance low
B0074 Supplemental deployment loop #1 open
B0075 Supplemental deployment loop #1 short to ground/voltage out of range
B0076 Supplemental impact deployment loop #1 short to battery
B0077 LF/Driver SIS malfunction
B0078 RF/Passenger SIS malfunction
B0079 Incorrect LF/Driver SIS installed
B0080 Discard LF/Driver SIS
B0081 Incorrect RF/Passenger SIS installed
B0082 Discard RF/Passenger SIS
B0083 RF/Passenger seat position sensor circuit malfunction
B0084 LF/Driver seat position sensor circuit malfunction
B0085 Supplemental deployment loop #2 resistance high
B0086 Supplemental deployment loop #2 resistance low
B0087 Supplemental deployment loop #2 open
B0088 Supplemental deployment loop #2 short to ground/voltage out of range
B0089 Supplemental impact deployment loop #2 short to battery
B0090 Active switch voltage out of range
B0091 Active switch: wrong state
B0092 Suppression sensor #1 circuit malfunction
B0093 Suppression sensor #2 circuit malfunction
B0094 AOS lamp circuit #1 circuit malfunction
B0095 AOS lamp circuit #2 circuit malfunction
B0096 RF/Passenger seat belt sensor circuit malfunction
B0097 LF/Driver seat belt sensor circuit malfunction
B0098 AOS controller ECU malfunction
B0099 AOS controller option configuration error
B0100 Electronic front end sensor #1 malfunction
B0101 Discard electronic front end sensor #1
B0102 Incorrect electronic front end sensor #1 installed
B0103 Electronic front end sensor #2 malfunction
B0104 Discard electronic front end sensor #2
B0105 Incorrect electronic front end sensor #2 installed
B0125 Air flow position command #1 (main/front) circuit malfunction
B0126 Air flow position command #1 (main/front) circuit range/performance
B0127 Air flow position command #1 (main/front) circuit low
B0128 Air flow position command #1 (main/front) circuit high
B0129 Air flow position command #1 (main/front) circuit open
B0130 Air flow position feedback #1 (main/front) circuit malfunction
B0131 Air flow position feedback #1 (main/front) circuit range/performance
B0132 Air flow position feedback #1 (main/front) circuit low
B0133 Air flow position feedback #1 (main/front) circuit high
B0134 Air flow position feedback #1 (main/front) circuit open
B0135 Air flow position command #2 (passenger) circuit malfunction
B0136 Air flow position command #2 (passenger) circuit range/performance
B0137 Air flow position command #2 (passenger) circuit low
B0138 Air flow position command #2 (passenger) circuit high
B0139 Air flow position command #2 (passenger) circuit open
B0140 Air flow position feedback #2 (passenger) circuit malfunction
B0141 Air flow position feedback #2 (passenger) circuit range/performance
B0142 Air flow position feedback #2 (passenger) circuit low
B0143 Air flow position feedback #2 (passenger) circuit high
B0144 Air flow position feedback #2 (passenger) circuit open
B0145 Air flow position command #3 (rear) circuit malfunction
B0146 Air flow position command #3 (rear) circuit range/performance
B0147 Air flow position command #3 (rear) circuit low
B0148 Air flow position command #3 (rear) circuit high
B0149 Air flow position command #3 (rear) circuit open
B0150 Air flow position feedback #3 (rear) circuit malfunction
B0151 Air flow position feedback #3 (rear) circuit range/performance
B0152 Air flow position feedback #3 (rear) circuit low
B0153 Air flow position feedback #3 (rear) circuit high
B0154 Air flow position feedback #3 (rear) circuit open
B0155 A/C refrigerant under pressure
B0156 A/C refrigerant overpressure
B0157
B0158 Outside air temperature sensor circuit malfunction
B0159 Outside air temperature sensor circuit range/performance
B0160 Outside air temperature sensor circuit low
B0161 Outside air temperature sensor circuit high
B0162 Outside air temperature sensor circuit open
B0163 Passenger compartment temperature sensor #1 (single sensor or LH) circuit malfunction
B0164 Passenger compartment temperature sensor #1 (single sensor or LH) circuit range/perfo
B0165 Passenger compartment temperature sensor #1 (single sensor or LH) circuit low
B0166 Passenger compartment temperature sensor #1 (single sensor or LH) circuit high
B0167 Passenger compartment temperature sensor #1 (single sensor or LH) circuit open
B0168 Passenger compartment temperature sensor #2 (RH) circuit malfunction
B0169 Passenger compartment temperature sensor #2 (RH) circuit range/performance
B0170 Passenger compartment temperature sensor #2 (RH) circuit low
B0171 Passenger compartment temperature sensor #2 (RH) circuit high
B0172 Passenger compartment temperature sensor #2 (RH) circuit open
B0173 Output air temperature sensor #1 (upper; single or LH) circuit malfunction
B0174 Output air temperature sensor #1 (upper; single or LH) circuit range/performance
B0175 Output air temperature sensor #1 (upper; single or LH) circuit low
B0176 Output air temperature sensor #1 (upper; single or LH) circuit high
B0177 Output air temperature sensor #1 (upper; single or LH) circuit open
B0178 Output air temperature sensor #2 (lower; single or LH) circuit malfunction
B0179 Output air temperature sensor #2 (lower; single or LH) circuit range/performance
B0180 Output air temperature sensor #2 (lower; single or LH) circuit low
B0181 Output air temperature sensor #2 (lower; single or LH) circuit high
B0182 Output air temperature sensor #2 (lower; single or LH) circuit open
B0183 Solar load sensor #1 (single sensor or LH) circuit malfunction
B0184 Solar load sensor #1 (single sensor or LH) circuit range/performance
B0185 Solar load sensor #1 (single sensor or LH) circuit low
B0186 Solar load sensor #1 (single sensor or LH) circuit high
B0187 Solar load sensor #1 (single sensor or LH) circuit open
B0188 Solar load sensor #2 (RH) circuit malfunction
B0189 Solar load sensor #2 (RH) circuit range/performance
B0190 Solar load sensor #2 (RH) circuit low
B0191 Solar load sensor #2 (RH) circuit high
B0192 Solar load sensor #2 (RH) circuit open
B0193 Blower motor #1 (main/primary/front) speed circuit malfunction
B0194 Blower motor #1 (main/primary/front) speed circuit range/performance
B0195 Blower motor #1 (main/primary/front) speed circuit low
B0196 Blower motor #1 (main/primary/front) speed circuit high
B0197 Blower motor #1 (main/primary/front) speed circuit open
B0198 Blower motor #1 (main/primary/front) power circuit malfunction
B0199 Blower motor #1 (main/primary/front) power circuit range/performance
B0200 Blower motor #1 (main/primary/front) power circuit low
B0201 Blower motor #1 (main/primary/front) power circuit high
B0202 Blower motor #1 (main/primary/front) power circuit open
B0203 Blower motor #1 (main/primary/front) ground circuit malfunction
B0204 Blower motor #1 (main/primary/front) ground circuit range/performance
B0205 Blower motor #1 (main/primary/front) ground circuit low
B0206 Blower motor #1 (main/primary/front) ground circuit high
B0207 Blower motor #1 (main/primary/front) ground circuit open
B0208 Blower motor #2 (aux/secondary/rear) speed circuit malfunction
B0209 Blower motor #2 (aux/secondary/rear) speed circuit range/performance
B0210 Blower motor #2 (aux/secondary/rear) speed circuit low
B0211 Blower motor #2 (aux/secondary/rear) speed circuit high
B0212 Blower motor #2 (aux/secondary/rear) speed circuit open
B0213 Blower motor #2 (aux/secondary/rear) power circuit malfunction
B0214 Blower motor #2 (aux/secondary/rear) power circuit range/performance
B0215 Blower motor #2 (aux/secondary/rear) power circuit low
B0216 Blower motor #2 (aux/secondary/rear) power circuit high
B0217 Blower motor #2 (aux/secondary/rear) power circuit open
B0218 Blower motor #2 (aux/secondary/rear) ground circuit malfunction
B0219 Blower motor #2 (aux/secondary/rear) ground circuit range/performance
B0220 Blower motor #2 (aux/secondary/rear) ground circuit low
B0221 Blower motor #2 (aux/secondary/rear) ground circuit high
B0222 Blower motor #2 (aux/secondary/rear) ground circuit open
B0223 Recirc position command circuit malfunction
B0224 Recirc position command circuit range/performance
B0225 Recirc position command circuit low
B0226 Recirc position command circuit high
B0227 Recirc position command circuit open
B0228 Recirc position feedback circuit malfunction
B0229 Recirc position feedback circuit range/performance
B0230 Recirc position feedback circuit low
B0231 Recirc position feedback circuit high
B0232 Recirc position feedback circuit open
B0233 Air flow control (general/single control) circuit malfunction
B0234 Air flow control (general/single control) circuit range/performance
B0235 Air flow control (general/single control) circuit low
B0236 Air flow control (general/single control) circuit high
B0237 Air flow control (general/single control) circuit open
B0238 Air flow control #1 (defrost) circuit malfunction
B0239 Air flow control #1 (defrost) circuit range/performance
B0240 Air flow control #1 (defrost) circuit low
B0241 Air flow control #1 (defrost) circuit high
B0242 Air flow control #1 (defrost) circuit open
B0243 Air flow control #2 (heater) circuit malfunction
B0244 Air flow control #2 (heater) circuit range/performance
B0245 Air flow control #2 (heater) circuit low
B0246 Air flow control #2 (heater) circuit high
B0247 Air flow control #2 (heater) circuit open
B0248 Air flow control #3 (blend defog/floor) circuit malfunction
B0249 Air flow control #3 (blend defog/floor) circuit range/performance
B0250 Air flow control #3 (blend defog/floor) circuit low
B0251 Air flow control #3 (blend defog/floor) circuit high
B0252 Air flow control #3 (blend defog/floor) circuit open
B0253 Air flow control #4 (blend face/floor) circuit malfunction
B0254 Air flow control #4 (blend face/floor) circuit range/performance
B0255 Air flow control #4 (blend face/floor) circuit low
B0256 Air flow control #4 (blend face/floor) circuit high
B0257 Air flow control #4 (blend face/floor) circuit open
B0258 Air flow control #5 (vent) circuit malfunction
B0259 Air flow control #5 (vent) circuit range/performance
B0260 Air flow control #5 (vent) circuit low
B0261 Air flow control #5 (vent) circuit high
B0262 Air flow control #5 (vent) circuit open
B0263 Air flow control #6 (A/C) circuit malfunction
B0264 Air flow control #6 (A/C) circuit range/performance
B0265 Air flow control #6 (A/C) circuit low
B0266 Air flow control #6 (A/C) circuit high
B0267 Air flow control #6 (A/C) circuit open
B0268 Air flow control #7 (recirc) circuit malfunction
B0269 Air flow control #7 (recirc) circuit range/performance
B0270 Air flow control #7 (recirc) circuit low
B0271 Air flow control #7 (recirc) circuit high
B0272 Air flow control #7 (recirc) circuit open
B0273 Air flow control #8 (rear defog airflow) circuit malfunction
B0274 Air flow control #8 (rear defog airflow) circuit range/performance
B0275 Air flow control #8 (rear defog airflow) circuit low
B0276 Air flow control #8 (rear defog airflow) circuit high
B0277 Air flow control #8 (rear defog airflow) circuit open
B0278 Air flow control #9 (dual zone) circuit malfunction
B0279 Air flow control #9 (dual zone) circuit range/performance
B0280 Air flow control #9 (dual zone) circuit low
B0281 Air flow control #9 (dual zone) circuit high
B0282 Air flow control #9 (dual zone) circuit open
B0283 Electric rear defrost circuit malfunction
B0284 Electric rear defrost circuit range/performance
B0285 Electric rear defrost circuit low
B0286 Electric rear defrost circuit high
B0287 Electric rear defrost circuit open
B0288 A/C request circuit malfunction
B0289 A/C request circuit range/performance
B0290 A/C request circuit low
B0291 A/C request circuit high
B0292 A/C request circuit open
B0293 Control head #1 (main/front) feedback circuit malfunction
B0294 Control head #1 (main/front) feedback circuit range/performance
B0295 Control head #1 (main/front) feedback circuit low
B0296 Control head #1 (main/front) feedback circuit high
B0297 Control head #1 (main/front) feedback circuit open
B0298 Control head #2 (passenger) feedback circuit malfunction
B0299 Control head #2 (passenger) feedback circuit range/performance
B0300 Control head #2 (passenger) feedback circuit low
B0301 Control head #2 (passenger) feedback circuit high
B0302 Control head #2 (passenger) feedback circuit open B0303 Control head #3 (rear) feedback circuit malfunction
B0304 Control head #3 (rear) feedback circuit range/performance
B0305 Control head #3 (rear) feedback circuit low
B0306 Control head #3 (rear) feedback circuit high
B0307 Control head #3 (rear) feedback circuit open
B0308 Electric windshield circuit malfunction
B0309 Electric windshield circuit range/performance
B0310 Electric windshield circuit low
B0311 Electric windshield circuit high
B0312 Electric windshield circuit open
B0313 Climate control selection switch #1 (Off) circuit malfunction
B0314 Climate control selection switch #1 (Off) circuit range/performance
B0315 Climate control selection switch #1 (Off) circuit low
B0316 Climate control selection switch #1 (Off) circuit high
B0317 Climate control selection switch #1 (Off) circuit open
B0318 Climate control selection switch #2 (A/C) circuit malfunction
B0319 Climate control selection switch #2 (A/C) circuit range/performance
B0320 Climate control selection switch #2 (A/C) circuit low
B0321 Climate control selection switch #2 (A/C) circuit high
B0322 Climate control selection switch #2 (A/C) circuit open
B0323 Climate control selection switch #3 (Recirc/Max) circuit malfunction
B0324 Climate control selection switch #3 (Recirc/Max) circuit range/performance
B0325 Climate control selection switch #3 (Recirc/Max) circuit low
B0326 Climate control selection switch #3 (Recirc/Max) circuit high
B0327 Climate control selection switch #3 (Recirc/Max) circuit open
B0328 Climate control selection switch #4 (Vent) circuit malfunction
B0329 Climate control selection switch #4 (Vent) circuit range/performance
B0330 Climate control selection switch #4 (Vent) circuit low
B0331 Climate control selection switch #4 (Vent) circuit high
B0332 Climate control selection switch #4 (Vent) circuit open
B0333 Climate control selection switch #5 (Defrost) circuit malfunction
B0334 Climate control selection switch #5 (Defrost) circuit range/performance
B0335 Climate control selection switch #5 (Defrost) circuit low
B0336 Climate control selection switch #5 (Defrost) circuit high
B0337 Climate control selection switch #5 (Defrost) circuit open
B0338 Climate control selection switch #6 (Warmer) circuit malfunction
B0339 Climate control selection switch #6 (Warmer) circuit range/performance
B0340 Climate control selection switch #6 (Warmer) circuit low
B0341 Climate control selection switch #6 (Warmer) circuit high
B0342 Climate control selection switch #6 (Warmer) circuit open
B0343 Climate control selection switch #7 (Cooler) circuit malfunction
B0344 Climate control selection switch #7 (Cooler) circuit range/performance
B0345 Climate control selection switch #7 (Cooler) circuit low
B0346 Climate control selection switch #7 (Cooler) circuit high
B0347 Climate control selection switch #7 (Cooler) circuit open
B0348 Climate control selection switch #8 (Blend #1; Face/Floor) circuit malfunction
B0349 Climate control selection switch #8 (Blend #1; Face/Floor) circuit range/performance
B0350 Climate control selection switch #8 (Blend #1; Face/Floor) circuit low
B0351 Climate control selection switch #8 (Blend #1; Face/Floor) circuit high
B0352 Climate control selection switch #8 (Blend #1; Face/Floor) circuit open
B0353 Climate control selection switch #9 (Blend #2; Defog/Floor) circuit malfunction
B0354 Climate control selection switch #9 (Blend #2; Defog/Floor) circuit range/performance
B0355 Climate control selection switch #9 (Blend #2; Defog/Floor) circuit low
B0356 Climate control selection switch #9 (Blend #2; Defog/Floor) circuit high
B0357 Climate control selection switch #9 (Blend #2; Defog/Floor) circuit open
B0358 Climate control selection switch #10 (Auto Control) circuit malfunction
B0359 Climate control selection switch #10 (Auto Control) circuit range/performance
B0360 Climate control selection switch #10 (Auto Control) circuit low
B0361 Climate control selection switch #10 (Auto Control) circuit high
B0362 Climate control selection switch #10 (Auto Control) circuit open
B0363 Climate control selection switch #11 (Dual Zone) circuit malfunction
B0364 Climate control selection switch #11 (Dual Zone) circuit range/performance
B0365 Climate control selection switch #11 (Dual Zone) circuit low
B0366 Climate control selection switch #11 (Dual Zone) circuit high
B0367 Climate control selection switch #11 (Dual Zone) circuit open
B0368 Climate control selection switch assembly circuit malfunction
B0369 Climate control selection switch assembly circuit range/performance B0370 Climate control selection switch assembly circuit low
B0371 Climate control selection switch assembly circuit high
B0372 Climate control selection switch assembly circuit open
B0373 Rear climate control selection switch #1 (Off) circuit malfunction
B0374 Rear climate control selection switch #1 (Off) circuit range/performance
B0375 Rear climate control selection switch #1 (Off) circuit low
B0376 Rear climate control selection switch #1 (Off) circuit high
B0377 Rear climate control selection switch #1 (Off) circuit open
B0378 Rear climate control selection switch #2 (A/C) circuit malfunction
B0379 Rear climate control selection switch #2 (A/C) circuit range/performance
B0380 Rear climate control selection switch #2 (A/C) circuit low
B0381 Rear climate control selection switch #2 (A/C) circuit high
B0382 Rear climate control selection switch #2 (A/C) circuit open
B0383 Rear climate control selection switch #3 (Vent) circuit malfunction
B0384 Rear climate control selection switch #3 (Vent) circuit range/performance
B0385 Rear climate control selection switch #3 (Vent) circuit low
B0386 Rear climate control selection switch #3 (Vent) circuit high
B0387 Rear climate control selection switch #3 (Vent) circuit open
B0388 Rear climate control selection switch #4 (Warmer) circuit malfunction
B0389 Rear climate control selection switch #4 (Warmer) circuit range/performance
B0390 Rear climate control selection switch #4 (Warmer) circuit low
B0391 Rear climate control selection switch #4 (Warmer) circuit high
B0392 Rear climate control selection switch #4 (Warmer) circuit open
B0393 Rear climate control selection switch #5 (Cooler) circuit malfunction
B0394 Rear climate control selection switch #5 (Cooler) circuit range/performance
B0395 Rear climate control selection switch #5 (Cooler) circuit low
B0396 Rear climate control selection switch #5 (Cooler) circuit high
B0397 Rear climate control selection switch #5 (Cooler) circuit open
B0398 Rear climate control selection switch #6 (Auto Control) circuit malfunction
B0399 Rear climate control selection switch #6 (Auto Control) circuit range/performance
B0400 Rear climate control selection switch #6 (Auto Control) circuit low
B0401 Rear climate control selection switch #6 (Auto Control) circuit high
B0402 Rear climate control selection switch #6 (Auto Control) circuit open
B0403 Rear climate control selection switch assembly circuit malfunction
B0404 Rear climate control selection switch assembly circuit range/performance
B0405 Rear climate control selection switch assembly circuit low
B0406 Rear climate control selection switch assembly circuit high
B0407 Rear climate control selection switch assembly circuit open
B0408 Temperature control #1 (main/front) circuit malfunction
B0409 Temperature control #1 (main/front) circuit range/performance
B0410 Temperature control #1 (main/front) circuit low
B0411 Temperature control #1 (main/front) circuit high
B0412 Temperature control #1 (main/front) circuit open
B0413 Temperature control #1 (main/front) feedback circuit malfunction
B0414 Temperature control #1 (main/front) feedback circuit range/performance
B0415 Temperature control #1 (main/front) feedback circuit low
B0416 Temperature control #1 (main/front) feedback circuit high
B0417 Temperature control #1 (main/front) feedback circuit open
B0418 Temperature control #2 (passenger) circuit malfunction
B0419 Temperature control #2 (passenger) circuit range/performance
B0420 Temperature control #2 (passenger) circuit low
B0421 Temperature control #2 (passenger) circuit high
B0422 Temperature control #2 (passenger) circuit open
B0423 Temperature control #2 (passenger) feedback circuit malfunction
B0424 Temperature control #2 (passenger) feedback circuit range/performance
B0425 Temperature control #2 (passenger) feedback circuit low
B0426 Temperature control #2 (passenger) feedback circuit high
B0427 Temperature control #2 (passenger) feedback circuit open
B0428 Temperature control #3 (rear) circuit malfunction
B0429 Temperature control #3 (rear) circuit range/performance
B0430 Temperature control #3 (rear) circuit low
B0431 Temperature control #3 (rear) circuit high
B0432 Temperature control #3 (rear) circuit open
B0433 Temperature control #3 (rear) feedback circuit malfunction
B0434 Temperature control #3 (rear) feedback circuit range/performance
B0435 Temperature control #3 (rear) feedback circuit low
B0436 Temperature control #3 (rear) feedback circuit high
B0437 Temperature control #3 (rear) feedback circuit open
B0438 Auxiliary heater glow plug circuit malfunction
B0439 Auxiliary heater glow plug circuit range/performance
B0440 Auxiliary heater glow plug circuit low
B0441 Auxiliary heater glow plug circuit high
B0442 Auxiliary heater glow plug circuit open
B0443 Auxiliary heater fuel pump circuit malfunction
B0444 Auxiliary heater fuel pump circuit range/performance
B0445 Auxiliary heater fuel pump circuit low
B0446 Auxiliary heater fuel pump circuit high
B0447 Auxiliary heater fuel pump circuit open
B0448 Auxiliary heater blower fan circuit malfunction
B0449 Auxiliary heater blower fan circuit range/performance
B0450 Auxiliary heater blower fan circuit low
B0451 Auxiliary heater blower fan circuit high
B0452 Auxiliary heater blower fan circuit open
B0453 Auxiliary heater coolant sensor circuit malfunction
B0454 Auxiliary heater coolant sensor circuit range/performance
B0455 Auxiliary heater coolant sensor circuit low
B0456 Auxiliary heater coolant sensor circuit high
B0457 Auxiliary heater coolant sensor circuit open
B0458 Auxiliary heater overheat sensor circuit malfunction
B0459 Auxiliary heater overheat sensor circuit range/performance
B0460 Auxiliary heater overheat sensor circuit low
B0461 Auxiliary heater overheat sensor circuit high
B0462 Auxiliary heater overheat sensor circuit open
B0463 Auxiliary heater flame sensor circuit malfunction
B0464 Auxiliary heater flame sensor circuit range/performance
B0465 Auxiliary heater flame sensor circuit low
B0466 Auxiliary heater flame sensor circuit high
B0467 Auxiliary heater flame sensor circuit open
B0468 Auxiliary heater coolant pump circuit malfunction
B0469 Auxiliary heater coolant pump circuit range/performance
B0470 Auxiliary heater coolant pump circuit low
B0471 Auxiliary heater coolant pump circuit high
B0472 Auxiliary heater coolant pump circuit open
B0473 Auxiliary heater passenger compt. fan control circuit malfunction
B0474 Auxiliary heater passenger compt. fan control circuit range/performance
B0475 Auxiliary heater passenger compt. fan control circuit low
B0476 Auxiliary heater passenger compt. fan control circuit high
B0477 Auxiliary heater passenger compt. fan control circuit open
B0478 Flame off from minimum power
B0479 Flame off from medium power
B0480 Flame off from maximum power
B0481 Overheat detected: software level
B0482 Overheat detected: hardware level
B0483 Overheat possible
B0484 Auxiliary heater system locked
B0485 Auxiliary heater start counter overrun
B0486 Auxiliary heater cold blow time exceeded
B0487 Auxiliary heater temp switch HS: no connection
B0488 Auxiliary heater overheat counter overrun
B0489 Passenger temp. control "Cooler" or "Cooler/Warmer" switch circuit malfunction
B0490 Passenger temp. control "Cooler" or "Cooler/Warmer" switch circuit range/performance
B0491 Passenger temp. control "Cooler" or "Cooler/Warmer" switch circuit low
B0492 Passenger temp. control "Cooler" or "Cooler/Warmer" switch circuit high
B0493 Passenger temp. control "Cooler" or "Cooler/Warmer" switch circuit open
B0494 Passenger temp. control "Cooler" or "Cooler/Warmer" switch feedback circuit malf
B0495 Passenger temp. control "Cooler" or "Cooler/Warmer" switch feedback circuit range/per
B0496 Passenger temp. control "Cooler" or "Cooler/Warmer" switch feedback circuit low
B0497 Passenger temp. control "Cooler" or "Cooler/Warmer" switch feedback circuit high
B0498 Passenger temp. control "Cooler" or "Cooler/Warmer" switch feedback circuit open
B0499 Passenger temp. control "Warmer" switch circuit malfunction
B0500 Passenger temp. control "Warmer" switch circuit range/performance
B0501 Passenger temp. control "Warmer" switch circuit low
B0502 Passenger temp. control "Warmer" switch circuit high
B0503 Passenger temp. control "Warmer" switch circuit open
B0504 Passenger temp. control "Warmer" switch feedback circuit malfunction
B0505 Passenger temp. control "Warmer" switch feedback circuit range/performance
B0506 Passenger temp. control "Warmer" switch feedback circuit low
B0507 Passenger temp. control "Warmer" switch feedback circuit high
B0508 Passenger temp. control "Warmer" switch feedback circuit open
B0509 Output air temperature sensor #3 (upper RH) circuit malfunction
B0510 Output air temperature sensor #3 (upper RH) circuit range/performance
B0511 Output air temperature sensor #3 (upper RH) circuit low
B0512 Output air temperature sensor #3 (upper RH) circuit high
B0513 Output air temperature sensor #3 (upper RH) circuit open
B0514 Output air temperature sensor #4 (lower RH) circuit malfunction
B0515 Output air temperature sensor #4 (lower RH) circuit range/performance
B0516 Output air temperature sensor #4 (lower RH) circuit low
B0517 Output air temperature sensor #4 (lower RH) circuit high
B0518 Output air temperature sensor #4 (lower RH) circuit open
B0519 Output air temperature sensor #5 (single rear output) circuit malfunction
B0520 Output air temperature sensor #5 (single rear output) circuit range/performance
B0521 Output air temperature sensor #5 (single rear output) circuit low
B0522 Output air temperature sensor #5 (single rear output) circuit high
B0523 Output air temperature sensor #5 (single rear output) circuit open
B0525 RH turn signal circuit malfunction
B0526 RH turn signal circuit range/performance
B0527 RH turn signal circuit low
B0528 RH turn signal circuit high
B0529 RH turn signal circuit open
B0530 LH turn signal circuit malfunction
B0531 LH turn signal circuit range/performance
B0532 LH turn signal circuit low
B0533 LH turn signal circuit high
B0534 LH turn signal circuit open
B0535 Headlamp high beam indicator circuit malfunction
B0536 Headlamp high beam indicator circuit range/performance
B0537 Headlamp high beam indicator circuit low
B0538 Headlamp high beam indicator circuit high
B0539 Headlamp high beam indicator circuit open
B0540 Speedometer circuit malfunction
B0541 Speedometer circuit range/performance
B0542 Speedometer circuit low
B0543 Speedometer circuit high
B0544 Speedometer circuit open
B0545 MPH/km/h indicator circuit malfunction
B0546 MPH/km/h indicator circuit range/performance
B0547 MPH/km/h indicator circuit low
B0548 MPH/km/h indicator circuit high
B0549 MPH/km/h indicator circuit open
B0550 Season odometer circuit malfunction
B0551 Season odometer circuit range/performance
B0552 Season odometer circuit low
B0553 Season odometer circuit high
B0554 Season odometer circuit open
B0555 Trip odometer circuit malfunction
B0556 Trip odometer circuit range/performance
B0557 Trip odometer circuit low
B0558 Trip odometer circuit high
B0559 Trip odometer circuit open
B0560 Tachometer circuit malfunction
B0561 Tachometer circuit range/performance
B0562 Tachometer circuit low
B0563 Tachometer circuit high
B0564 Tachometer circuit open
B0565 Coolant temperature indicator circuit malfunction
B0566 Coolant temperature indicator circuit range/performance
B0567 Coolant temperature indicator circuit low
B0568 Coolant temperature indicator circuit high
B0569 Coolant temperature indicator circuit open
B0570 Low coolant indicator circuit malfunction
B0571 Low coolant indicator circuit range/performance
B0572 Low coolant indicator circuit low
B0573 Low coolant indicator circuit high
B0574 Low coolant indicator circuit open
B0575 Fuel level indicator circuit malfunction
B0576 Fuel level indicator circuit range/performance
B0577 Fuel level indicator circuit low
B0578 Fuel level indicator circuit high
B0579 Fuel level indicator circuit open
B0580 Low fuel indicator circuit malfunction
B0581 Low fuel indicator circuit range/performance
B0582 Low fuel indicator circuit low
B0583 Low fuel indicator circuit high
B0584 Low fuel indicator circuit open
B0585 Alternate fuel indicator circuit malfunction
B0586 Alternate fuel indicator circuit range/performance
B0587 Alternate fuel indicator circuit low
B0588 Alternate fuel indicator circuit high
B0589 Alternate fuel indicator circuit open
B0590 Turbocharger/supercharger boost indicator circuit malfunction
B0591 Turbocharger/supercharger boost indicator circuit range/performance
B0592 Turbocharger/supercharger boost indicator circuit low
B0593 Turbocharger/supercharger boost indicator circuit high
B0594 Turbocharger/supercharger boost indicator circuit open
B0595 Fasten seatbelt indicator circuit malfunction
B0596 Fasten seatbelt indicator circuit range/performance
B0597 Fasten seatbelt indicator circuit low
B0598 Fasten seatbelt indicator circuit high
B0599 Fasten seatbelt indicator gage circuit open
B0600 Door #1 (LF) ajar indicator circuit malfunction
B0601 Door #1 (LF) ajar indicator circuit range/performance
B0602 Door #1 (LF) ajar indicator circuit low
B0603 Door #1 (LF) ajar indicator circuit high
B0604 Door #1 (LF) ajar indicator circuit open
B0605 Door #2 (RF) ajar indicator circuit malfunction
B0606 Door #2 (RF) ajar indicator circuit range/performance
B0607 Door #2 (RF) ajar indicator circuit low
B0608 Door #2 (RF) ajar indicator circuit high
B0609 Door #2 (RF) ajar indicator circuit open
B0610 Door #3 (LR pass. car or LH van sliding) ajar indicator circuit malfunction
B0611 Door #3 (LR pass. car or LH van sliding) ajar indicator circuit range/performance
B0612 Door #3 (LR pass. car or LH van sliding) ajar indicator circuit low
B0613 Door #3 (LR pass. car or LH van sliding) ajar indicator circuit high
B0614 Door #3 (LR pass. car or LH van sliding) ajar indicator circuit open
B0615 Door #4 (RR pass. car or RH van sliding) ajar indicator circuit malfunction
B0616 Door #4 (RR pass. car or RH van sliding) ajar indicator circuit range/performance
B0617 Door #4 (RR pass. car or RH van sliding) ajar indicator circuit low
B0618 Door #4 (RR pass. car or RH van sliding) ajar indicator circuit high
B0619 Door #4 (RR pass. car or RH van sliding) ajar indicator circuit open
B0620 Hood ajar indicator circuit malfunction
B0621 Hood ajar indicator circuit range/performance
B0622 Hood ajar indicator circuit low
B0623 Hood ajar indicator circuit high
B0624 Hood ajar indicator circuit open
B0625 Trunk/hatch (pass. cars) ajar indicator circuit malfunction
B0626 Trunk/hatch (pass. cars) ajar indicator circuit range/performance
B0627 Trunk/hatch (pass. cars) ajar indicator circuit low
B0628 Trunk/hatch (pass. cars) ajar indicator circuit high
B0629 Trunk/hatch (pass. cars) ajar indicator circuit open
B0630 Tailgate (pickup or util) ajar indicator circuit malfunction
B0631 Tailgate (pickup or util) ajar indicator circuit range/performance
B0632 Tailgate (pickup or util) ajar indicator circuit low
B0633 Tailgate (pickup or util) ajar indicator circuit high
B0634 Tailgate (pickup or util) ajar indicator circuit open
B0635 Cargo door #1 (LH of doubles) ajar indicator circuit malfunction
B0636 Cargo door #1 (LH of doubles) ajar indicator circuit range/performance
B0637 Cargo door #1 (LH of doubles) ajar indicator circuit low
B0638 Cargo door #1 (LH of doubles) ajar indicator circuit high
B0639 Cargo door #1 (LH of doubles) ajar indicator circuit open
B0640 Cargo door #2 (RH double) ajar indicator circuit malfunction
B0641 Cargo door #2 (RH double) ajar indicator circuit range/performance
B0642 Cargo door #2 (RH double) ajar indicator circuit low
B0643 Cargo door #2 (RH double) ajar indicator circuit high
B0644 Cargo door #2 (RH double) ajar indicator circuit open
B0645 Lift glass ajar indicator circuit malfunction
B0646 Lift glass ajar indicator circuit range/performance
B0647 Lift glass ajar indicator circuit low
B0648 Lift glass ajar indicator circuit high
B0649 Lift glass ajar indicator circuit open
B0650 Fuel filler door ajar indicator circuit malfunction
B0651 Fuel filler door ajar indicator circuit range/performance
B0652 Fuel filler door ajar indicator circuit low
B0653 Fuel filler door ajar indicator circuit high
B0654 Fuel filler door ajar indicator circuit open
B0655 Brake (hydraulics and/or park brake) indicator circuit malfunction
B0656 Brake (hydraulics and/or park brake) indicator circuit range/performance
B0657 Brake (hydraulics and/or park brake) indicator circuit low
B0658 Brake (hydraulics and/or park brake) indicator circuit high
B0659 Brake (hydraulics and/or park brake) indicator circuit open
B0660 Auto Park (Med. Truck) indicator circuit malfunction
B0661 Auto Park (Med. Truck) indicator circuit range/performance
B0662 Auto Park (Med. Truck) indicator circuit low
B0663 Auto Park (Med. Truck) indicator circuit high
B0664 Auto Park (Med. Truck) indicator circuit open
B0665 Service ABS indicator circuit malfunction
B0666 Service ABS indicator circuit range/performance
B0667 Service ABS indicator circuit low
B0668 Service ABS indicator circuit high
B0669 Service ABS indicator circuit open
B0670 Inflatable restraint system indicator #1 (main indicator) circuit malfunction
B0671 Inflatable restraint system indicator #1 (main indicator) circuit range/performance
B0672 Inflatable restraint system indicator #1 (main indicator) circuit low
B0673 Inflatable restraint system indicator #1 (main indicator) circuit high
B0674 Inflatable restraint system indicator #1 (main indicator) indicator circuit open
B0675 Inflatable restraint system indicator #2 (redundant/secondary) circuit malfunction
B0676 Inflatable restraint system indicator #2 (redundant/secondary) circuit range/performance
B0677 Inflatable restraint system indicator #2 (redundant/secondary) circuit low
B0678 Inflatable restraint system indicator #2 (redundant/secondary) circuit high
B0679 Inflatable restraint system indicator #2 (redundant/secondary) indicator circuit open
B0680 Passenger airbag disabled indicator circuit malfunction
B0681 Passenger airbag disabled indicator circuit range/performance
B0682 Passenger airbag disabled indicator circuit low
B0683 Passenger airbag disabled indicator circuit high
B0684 Passenger airbag disabled indicator circuit open
B0685 Security system indicator circuit malfunction
B0686 Security system indicator circuit range/performance
B0687 Security system indicator circuit low
B0688 Security system indicator circuit high
B0689 Security system indicator circuit open
B0690 Brake To Shift indicator circuit malfunction
B0691 Brake To Shift indicator circuit range/performance
B0692 Brake To Shift indicator circuit low
B0693 Brake To Shift indicator circuit high
B0694 Brake To Shift indicator circuit open
B0695 Low oil level indicator circuit malfunction
B0696 Low oil level indicator circuit range/performance
B0697 Low oil level indicator circuit low
B0698 Low oil level indicator circuit high
B0699 Low oil level indicator circuit open
B0700 Oil temperature indicator circuit malfunction
B0701 Oil temperature indicator circuit range/performance
B0702 Oil temperature indicator circuit low
B0703 Oil temperature indicator circuit high
B0704 Oil temperature indicator circuit open
B0705 Oil pressure indicator circuit malfunction
B0706 Oil pressure indicator circuit range/performance
B0707 Oil pressure indicator circuit low
B0708 Oil pressure indicator circuit high
B0709 Oil pressure indicator circuit open
B0710 Change oil indicator circuit malfunction
B0711 Change oil indicator circuit range/performance
B0712 Change oil indicator circuit low
B0713 Change oil indicator circuit high
B0714 Change oil indicator circuit open
B0715 Message display system (dot matrix, reconfig. TT, etc.) circuit malfunction
B0716 Message display system (dot matrix, reconfig. TT, etc.) circuit range/performance
B0717 Message display system (dot matrix, reconfig. TT, etc.) circuit low
B0718 Message display system (dot matrix, reconfig. TT, etc.) circuit high
B0719 Message display system (dot matrix, reconfig. TT, etc.) circuit open
B0720 PRNDL indicator circuit malfunction
B0721 PRNDL indicator circuit range/performance
B0722 PRNDL indicator circuit low
B0723 PRNDL indicator circuit high
B0724 PRNDL indicator circuit open
B0725 P indicator circuit malfunction
B0726 P indicator circuit range/performance
B0727 P indicator circuit low
B0728 P indicator circuit high
B0729 P indicator circuit open
B0730 R indicator circuit malfunction
B0731 R indicator circuit range/performance
B0732 R indicator circuit low
B0733 R indicator circuit high
B0734 R indicator circuit open
B0735 N indicator circuit malfunction
B0736 N indicator circuit range/performance
B0737 N indicator circuit low
B0738 N indicator circuit high
B0739 N indicator circuit open
B0740 OD indicator circuit malfunction
B0741 OD indicator circuit range/performance
B0742 OD indicator circuit low
B0743 OD indicator circuit high
B0744 OD indicator circuit open
B0745 D indicator circuit malfunction
B0746 D indicator circuit range/performance
B0747 D indicator circuit low
B0748 D indicator circuit high
B0749 D indicator circuit open
B0750 L indicator circuit malfunction
B0751 L indicator circuit range/performance
B0752 L indicator circuit low
B0753 L indicator circuit high
B0754 L indicator circuit open
B0755 Low washer fluid indicator #1 (primary/front) circuit malfunction
B0756 Low washer fluid indicator #1 (primary/front) circuit range/performance
B0757 Low washer fluid indicator #1 (primary/front) circuit low
B0758 Low washer fluid indicator #1 (primary/front) circuit high
B0759 Low washer fluid indicator #1 (primary/front) circuit open
B0760 Low washer fluid indicator #2 (secondary/rear) circuit malfunction
B0761 Low washer fluid indicator #2 (secondary/rear) circuit range/performance
B0762 Low washer fluid indicator #2 (secondary/rear) circuit low
B0763 Low washer fluid indicator #2 (secondary/rear) circuit high
B0764 Low washer fluid indicator #2 (secondary/rear) circuit open
B0765 Service AWD/4WD indicator circuit malfunction
B0766 Service AWD/4WD indicator circuit range/performance
B0767 Service AWD/4WD indicator circuit low
B0768 Service AWD/4WD indicator circuit high
B0769 Service AWD/4WD indicator circuit open
B0770 AWD/4WD indicator circuit malfunction
B0771 AWD/4WD indicator circuit range/performance
B0772 AWD/4WD indicator circuit low
B0773 AWD/4WD indicator circuit high
B0774 AWD/4WD indicator circuit open
B0775 4HI indicator circuit malfunction
B0776 4HI indicator circuit range/performance
B0777 4HI indicator circuit low
B0778 4HI indicator circuit high
B0779 4HI indicator circuit open
B0780 4LO indicator circuit malfunction
B0781 4LO indicator circuit range/performance
B0782 4LO indicator circuit low
B0783 4LO indicator circuit high
B0784 4LO indicator circuit open
B0785 2HI indicator circuit malfunction
B0786 2HI indicator circuit range/performance
B0787 2HI indicator circuit low
B0788 2HI indicator circuit high
B0789 2HI indicator circuit open
B0790 Transfer case Neutral indicator circuit malfunction
B0791 Transfer case Neutral indicator circuit range/performance
B0792 Transfer case Neutral indicator circuit low
B0793 Transfer case Neutral indicator circuit high
B0794 Transfer case Neutral indicator circuit open
B0795 Transmission temperature indicator circuit malfunction
B0796 Transmission temperature indicator circuit range/performance
B0797 Transmission temperature indicator circuit low
B0798 Transmission temperature indicator circuit high
B0799 Transmission temperature indicator circuit open
B0800 Transmission shift mode (Norm/Perf) indicator circuit malfunction
B0801 Transmission shift mode (Norm/Perf) indicator circuit range/performance
B0802 Transmission shift mode (Norm/Perf) indicator circuit low
B0803 Transmission shift mode (Norm/Perf) indicator circuit high
B0804 Transmission shift mode (Norm/Perf) indicator circuit open
B0805 One-To-Four shift mode (ZF manual trans.) indicator circuit malfunction
B0806 One-To-Four shift mode (ZF manual trans.) indicator circuit range/performance
B0807 One-To-Four shift mode (ZF manual trans.) indicator circuit low
B0808 One-To-Four shift mode (ZF manual trans.) indicator circuit high
B0809 One-To-Four shift mode (ZF manual trans.) indicator circuit open
B0810 Upshift indicator circuit malfunction
B0811 Upshift indicator circuit range/performance
B0812 Upshift indicator circuit low
B0813 Upshift indicator circuit high
B0814 Upshift indicator circuit open
B0815 Service traction control system indicator circuit malfunction
B0816 Service traction control system indicator circuit range/performance
B0817 Service traction control system indicator circuit low
B0818 Service traction control system indicator circuit high
B0819 Service traction control system indicator circuit open
B0820 Traction control system active indicator circuit malfunction
B0821 Traction control system active indicator circuit range/performance
B0822 Traction control system active indicator circuit low
B0823 Traction control system active indicator circuit high
B0824 Traction control system active indicator circuit open
B0825 Traction control system off indicator circuit malfunction
B0826 Traction control system off indicator circuit range/performance
B0827 Traction control system off indicator circuit low
B0828 Traction control system off indicator circuit high
B0829 Traction control system off indicator circuit open
B0830 Second gear start indicator circuit malfunction
B0831 Second gear start indicator circuit range/performance
B0832 Second gear start indicator circuit low
B0833 Second gear start indicator circuit high
B0834 Second gear start indicator circuit open
B0835 Cruise control system active indicator circuit malfunction
B0836 Cruise control system active indicator circuit range/performance
B0837 Cruise control system active indicator circuit low
B0838 Cruise control system active indicator circuit high
B0839 Cruise control system active indicator circuit open
B0840 Check gages indicator circuit malfunction
B0841 Check gages indicator circuit range/performance
B0842 Check gages indicator circuit low
B0843 Check gages indicator circuit high
B0844 Check gages indicator circuit open
B0845 Water in fuel indicator circuit malfunction
B0846 Water in fuel indicator circuit range/performance
B0847 Water in fuel indicator circuit low
B0848 Water in fuel indicator circuit high
B0849 Water in fuel indicator circuit open
B0850 Wait/Glow plugs indicator circuit malfunction
B0851 Wait/Glow plugs indicator circuit range/performance
B0852 Wait/Glow plugs indicator circuit low
B0853 Wait/Glow plugs indicator circuit high
B0854 Wait/Glow plugs indicator circuit open
B0855 Battery voltage indicator circuit malfunction
B0856 Battery voltage indicator circuit range/performance
B0857 Battery voltage indicator circuit low
B0858 Battery voltage indicator circuit high
B0859 Battery voltage indicator circuit open
B0860 Battery voltage high/low indicator circuit malfunction
B0861 Battery voltage high/low indicator circuit range/performance
B0862 Battery voltage high/low indicator circuit low
B0863 Battery voltage high/low indicator circuit high
B0864 Battery voltage high/low indicator circuit open
B0865 Amperage indicator circuit malfunction
B0866 Amperage indicator circuit range/performance
B0867 Amperage indicator circuit low
B0868 Amperage indicator circuit high
B0869 Amperage indicator circuit open
B0870 Low tire pressure indicator circuit malfunction
B0871 Low tire pressure indicator circuit range/performance
B0872 Low tire pressure indicator circuit low
B0873 Low tire pressure indicator circuit high
B0874 Low tire pressure indicator circuit open
B0875 Service low tire pressure system indicator circuit malfunction
B0876 Service low tire pressure system indicator circuit range/performance
B0877 Service low tire pressure system indicator circuit low
B0878 Service low tire pressure system indicator circuit high
B0879 Service low tire pressure system indicator circuit open
B0880 Chime system circuit malfunction
B0881 Chime system circuit range/performance
B0882 Chime system circuit low
B0883 Chime system circuit high
B0884 Chime system circuit open
B0885 Chime rate 0 (slow) indicator circuit malfunction
B0886 Chime rate 0 (slow) indicator circuit range/performance
B0887 Chime rate 0 (slow) indicator circuit low
B0888 Chime rate 0 (slow) indicator circuit high
B0889 Chime rate 0 (slow) indicator circuit open
B0890 Chime rate 1 (medium) indicator circuit malfunction
B0891 Chime rate 1 (medium) indicator circuit range/performance
B0892 Chime rate 1 (medium) indicator circuit low
B0893 Chime rate 1 (medium) indicator circuit high
B0894 Chime rate 1 (medium) indicator circuit open
B0895 Chime rate 2 (high) indicator circuit malfunction
B0896 Chime rate 2 (high) indicator circuit range/performance
B0897 Chime rate 2 (high) indicator circuit low
B0898 Chime rate 2 (high) indicator circuit high
B0899 Chime rate 2 (high) indicator circuit open
B0900 Chime rate 3 (single chime) indicator circuit malfunction
B0901 Chime rate 3 (single chime) indicator circuit range/performance
B0902 Chime rate 3 (single chime) indicator circuit low
B0903 Chime rate 3 (single chime) indicator circuit high
B0904 Chime rate 3 (single chime) indicator circuit open
B0905 Body computer systems indicator circuit malfunction
B0906 Body computer systems indicator circuit range/performance
B0907 Body computer systems indicator circuit low
B0908 Body computer systems indicator circuit high
B0909 Body computer systems indicator circuit open
B0910 Steering assist system (EVO, MSVA, etc.) indicator circuit malfunction
B0911 Steering assist system (EVO, MSVA, etc.) indicator circuit range/performance
B0912 Steering assist system (EVO, MSVA, etc.) indicator circuit low
B0913 Steering assist system (EVO, MSVA, etc.) indicator circuit high
B0914 Steering assist system (EVO, MSVA, etc.) indicator circuit open
B0915 Catalytic converter overtemperature (export) indicator circuit malfunction
B0916 Catalytic converter overtemperature (export) indicator circuit range/performance
B0917 Catalytic converter overtemperature (export) indicator circuit low
B0918 Catalytic converter overtemperature (export) indicator circuit high
B0919 Catalytic converter overtemperature (export) indicator circuit open
B0920 Overspeed (export) indicator circuit malfunction
B0921 Overspeed (export) indicator circuit range/performance
B0922 Overspeed (export) indicator circuit low
B0923 Overspeed (export) indicator circuit high
B0924 Overspeed (export) indicator circuit open
B0925 Reconfigurable Telltale Temperature (RTT) out of range
B0926 Service AHLD indicator circuit malfunction
B0927 Service AHLD indicator circuit range/performance
B0928 Service AHLD indicator circuit low
B0929 Service AHLD indicator circuit high
B0930 Service AHLD indicator circuit open
B0931 Compass sensor circuit malfunction
B0932 Compass sensor circuit range/performance
B0933 Compass sensor circuit low
B0934 Compass sensor circuit high
B0935 Compass sensor circuit open
B0936 Coolant level sensor circuit malfunction
B0937 Coolant level sensor circuit range/performance
B0938 Coolant level sensor circuit low
B0939 Coolant level sensor circuit high
B0940 Coolant level sensor circuit open
B0941 Level control system indicator circuit malfunction
B0942 Level control system indicator circuit range/performance
B0943 Level control system indicator circuit low
B0944 Level control system indicator circuit high
B0945 Level control system indicator circuit open
B0946 Suspension control selection indicator circuit malfunction
B0947 Suspension control selection indicator circuit range/performance
B0948 Suspension control selection indicator circuit low
B0949 Suspension control selection indicator circuit high
B0950 Suspension control selection indicator circuit open
B0951 Headlamps on indicator circuit malfunction
B1000 ECU malfunction
B1001 Option configuration error
B1002 Improper shutdown
B1004 KAM reset
B1013 Calibration ROM checksum error
B1014 Program ROM checksum error
B1015 VIN information error
B1016 VIN information not programmed
B1017 QDM / ODM 1 malfunction
B1018 QDM / ODM 2 malfunction
B1020 Auxiliary ECU malfunction
B1021 SIM card malfunction
B1022 Emergency SIM card malfunction
B1025 Audio [+] output #1 (LF) malfunction
B1026 Audio [+] output #1 (LF) circuit range/performance
B1027 Audio [+] output #1 (LF) circuit low
B1028 Audio [+] output #1 (LF) circuit high
B1029 Audio [+] output #1 (LF) circuit open
B1030 Audio [-] output #1 (LF) malfunction
B1031 Audio [-] output #1 (LF) circuit range/performance
B1032 Audio [-] output #1 (LF) circuit low
B1033 Audio [-] output #1 (LF) circuit high
B1034 Audio [-] output #1 (LF) circuit open
B1035 Audio [+] output #2 (RF) malfunction
B1036 Audio [+] output #2 (RF) circuit range/performance
B1037 Audio [+] output #2 (RF) circuit low
B1038 Audio [+] output #2 (RF) circuit high
B1039 Audio [+] output #2 (RF) circuit open
B1040 Audio [-] output #2 (RF) malfunction
B1041 Audio [-] output #2 (RF) circuit range/performance
B1042 Audio [-] output #2 (RF) circuit low
B1043 Audio [-] output #2 (RF) circuit high
B1044 Audio [-] output #2 (RF) circuit open
B1045 Audio [+] output #3 (LR) malfunction
B1046 Audio [+] output #3 (LR) circuit range/performance
B1047 Audio [+] output #3 (LR) circuit low
B1048 Audio [+] output #3 (LR) circuit high
B1049 Audio [+] output #3 (LR) circuit open
B1050 Audio [-] output #3 (LR) malfunction
B1051 Audio [-] output #3 (LR) circuit range/performance
B1052 Audio [-] output #3 (LR) circuit low
B1053 Audio [-] output #3 (LR) circuit high
B1054 Audio [-] output #3 (LR) circuit open
B1055 Audio [+] output #4 (RR) malfunction
B1056 Audio [+] output #4 (RR) circuit range/performance
B1057 Audio [+] output #4 (RR) circuit low
B1058 Audio [+] output #4 (RR) circuit high
B1059 Audio [+] output #4 (RR) circuit open
B1060 Audio [-] output #4 (RR) malfunction
B1061 Audio [-] output #4 (RR) circuit range/performance
B1062 Audio [-] output #4 (RR) circuit low
B1063 Audio [-] output #4 (RR) circuit high
B1064 Audio [-] output #4 (RR) circuit open
B1065 Audio [+] output #5 (TBD) malfunction
B1066 Audio [+] output #5 (TBD) circuit range/performance
B1067 Audio [+] output #5 (TBD) circuit low
B1068 Audio [+] output #5 (TBD) circuit high
B1069 Audio [+] output #5 (TBD) circuit open
B1070 Audio [-] output #5 (TBD) malfunction
B1071 Audio [-] output #5 (TBD) circuit range/performance
B1072 Audio [-] output #5 (TBD) circuit low
B1073 Audio [-] output #5 (TBD) circuit high
B1074 Audio [-] output #5 (TBD) circuit open
B1075 Audio [+] output #6 (TBD) malfunction
B1076 Audio [+] output #6 (TBD) circuit range/performance
B1077 Audio [+] output #6 (TBD) circuit low
B1078 Audio [+] output #6 (TBD) circuit high
B1079 Audio [+] output #6 (TBD) circuit open
B1080 Audio [-] output #6 (TBD) malfunction
B1081 Audio [-] output #6 (TBD) circuit range/performance
B1082 Audio [-] output #6 (TBD) circuit low
B1083 Audio [-] output #6 (TBD) circuit high
B1084 Audio [-] output #6 (TBD) circuit open
B1085 Audio [+] output #7 (TBD) malfunction
B1086 Audio [+] output #7 (TBD) circuit range/performance
B1087 Audio [+] output #7 (TBD) circuit low
B1088 Audio [+] output #7 (TBD) circuit high
B1089 Audio [+] output #7 (TBD) circuit open
B1090 Audio [-] output #7 (TBD) malfunction
B1091 Audio [-] output #7 (TBD) circuit range/performance
B1092 Audio [-] output #7 (TBD) circuit low
B1093 Audio [-] output #7 (TBD) circuit high
B1094 Audio [-] output #7 (TBD) circuit open
B1095 Audio [+] output #8 (TBD) malfunction
B1096 Audio [+] output #8 (TBD) circuit range/performance
B1097 Audio [+] output #8 (TBD) circuit low
B1098 Audio [+] output #8 (TBD) circuit high
B1099 Audio [+] output #8 (TBD) circuit open
B1100 Audio [-] output #8 (TBD) malfunction
B1101 Audio [-] output #8 (TBD) circuit range/performance
B1102 Audio [-] output #8 (TBD) circuit low
B1103 Audio [-] output #8 (TBD) circuit high
B1104 Audio [-] output #8 (TBD) circuit open
B1105 Audio [+] output #9 (TBD) malfunction
B1106 Audio [+] output #9 (TBD) circuit range/performance
B1107 Audio [+] output #9 (TBD) circuit low
B1108 Audio [+] output #9 (TBD) circuit high
B1109 Audio [+] output #9 (TBD) circuit open
B1110 Audio [-] output #9 (TBD) malfunction
B1111 Audio [-] output #9 (TBD) circuit range/performance
B1112 Audio [-] output #9 (TBD) circuit low
B1113 Audio [-] output #9 (TBD) circuit high
B1114 Audio [-] output #9 (TBD) circuit open
B1115 Audio [+] output #10 (TBD) malfunction
B1116 Audio [+] output #10 (TBD) circuit range/performance
B1117 Audio [+] output #10 (TBD) circuit low
B1118 Audio [+] output #10 (TBD) circuit high
B1119 Audio [+] output #10 (TBD) circuit open
B1120 Audio [-] output #10 (TBD) malfunction
B1121 Audio [-] output #10 (TBD) circuit range/performance
B1122 Audio [-] output #10 (TBD) circuit low
B1123 Audio [-] output #10 (TBD) circuit high
B1124 Audio [-] output #10 (TBD) circuit open
B1125 Audio [+] output #11 (TBD) malfunction
B1126 Audio [+] output #11 (TBD) circuit range/performance
B1127 Audio [+] output #11 (TBD) circuit low
B1128 Audio [+] output #11 (TBD) circuit high
B1129 Audio [+] output #11 (TBD) circuit open
B1130 Audio [-] output #11 (TBD) malfunction
B1131 Audio [-] output #11 (TBD) circuit range/performance
B1132 Audio [-] output #11 (TBD) circuit low
B1133 Audio [-] output #11 (TBD) circuit high
B1134 Audio [-] output #11 (TBD) circuit open
B1135 Audio [+] output #12 (TBD) malfunction
B1136 Audio [+] output #12 (TBD) circuit range/performance
B1137 Audio [+] output #12 (TBD) circuit low
B1138 Audio [+] output #12 (TBD) circuit high
B1139 Audio [+] output #12 (TBD) circuit open
B1140 Audio [-] output #12 (TBD) malfunction
B1141 Audio [-] output #12 (TBD) circuit range/performance
B1142 Audio [-] output #12 (TBD) circuit low
B1143 Audio [-] output #12 (TBD) circuit high
B1144 Audio [-] output #12 (TBD) circuit open
B1145 Audio [+] output #13 (TBD) malfunction
B1146 Audio [+] output #13 (TBD) circuit range/performance
B1147 Audio [+] output #13 (TBD) circuit low
B1148 Audio [+] output #13 (TBD) circuit high
B1149 Audio [+] output #13 (TBD) circuit open
B1150 Audio [-] output #13 (TBD) malfunction
B1151 Audio [-] output #13 (TBD) circuit range/performance
B1152 Audio [-] output #13 (TBD) circuit low
B1153 Audio [-] output #13 (TBD) circuit high
B1154 Audio [-] output #13 (TBD) circuit open
B1155 Audio [+] output #14 (TBD) malfunction
B1156 Audio [+] output #14 (TBD) circuit range/performance
B1157 Audio [+] output #14 (TBD) circuit low
B1158 Audio [+] output #14 (TBD) circuit high
B1159 Audio [+] output #14 (TBD) circuit open
B1160 Audio [-] output #14 (TBD) malfunction
B1161 Audio [-] output #14 (TBD) circuit range/performance
B1162 Audio [-] output #14 (TBD) circuit low
B1163 Audio [-] output #14 (TBD) circuit high
B1164 Audio [-] output #14 (TBD) circuit open
B1165 Audio [+] output #15 (TBD) malfunction
B1166 Audio [+] output #15 (TBD) circuit range/performance
B1167 Audio [+] output #15 (TBD) circuit low
B1168 Audio [+] output #15 (TBD) circuit high
B1169 Audio [+] output #15 (TBD) circuit open
B1170 Audio [-] output #15 (TBD) malfunction
B1171 Audio [-] output #15 (TBD) circuit range/performance
B1172 Audio [-] output #15 (TBD) circuit low
B1173 Audio [-] output #15 (TBD) circuit high
B1174 Audio [-] output #15 (TBD) circuit open
B1175 Audio [+] output #16 (TBD) malfunction
B1176 Audio [+] output #16 (TBD) circuit range/performance
B1177 Audio [+] output #16 (TBD) circuit low
B1178 Audio [+] output #16 (TBD) circuit high
B1179 Audio [+] output #16 (TBD) circuit open
B1180 Audio [-] output #16 (TBD) malfunction
B1181 Audio [-] output #16 (TBD) circuit range/performance
B1182 Audio [-] output #16 (TBD) circuit low
B1183 Audio [-] output #16 (TBD) circuit high
B1184 Audio [-] output #16 (TBD) circuit open
B1185 Audio [+] output #17 (TBD) malfunction
B1186 Audio [+] output #17 (TBD) circuit range/performance
B1187 Audio [+] output #17 (TBD) circuit low
B1188 Audio [+] output #17 (TBD) circuit high
B1189 Audio [+] output #17 (TBD) circuit open
B1190 Audio [-] output #17 (TBD) malfunction
B1191 Audio [-] output #17 (TBD) circuit range/performance
B1192 Audio [-] output #17 (TBD) circuit low
B1193 Audio [-] output #17 (TBD) circuit high
B1194 Audio [-] output #17 (TBD) circuit open
B1195 Audio [+] output #18 (TBD) malfunction
B1196 Audio [+] output #18 (TBD) circuit range/performance
B1197 Audio [+] output #18 (TBD) circuit low
B1198 Audio [+] output #18 (TBD) circuit high
B1199 Audio [+] output #18 (TBD) circuit open
B1200 Audio [-] output #18 (TBD) malfunction
B1201 Audio [-] output #18 (TBD) circuit range/performance
B1202 Audio [-] output #18 (TBD) circuit low
B1203 Audio [-] output #18 (TBD) circuit high
B1204 Audio [-] output #18 (TBD) circuit open
B1205 Audio [+] output #19 (TBD) malfunction
B1206 Audio [+] output #19 (TBD) circuit range/performance
B1207 Audio [+] output #19 (TBD) circuit low
B1208 Audio [+] output #19 (TBD) circuit high
B1209 Audio [+] output #19 (TBD) circuit open
B1210 Audio [-] output #19 (TBD) malfunction
B1211 Audio [-] output #19 (TBD) circuit range/performance
B1212 Audio [-] output #19 (TBD) circuit low
B1213 Audio [-] output #19 (TBD) circuit high
B1214 Audio [-] output #19 (TBD) circuit open
B1215 Audio [+] output #20 (TBD) malfunction
B1216 Audio [+] output #20 (TBD) circuit range/performance
B1217 Audio [+] output #20 (TBD) circuit low
B1218 Audio [+] output #20 (TBD) circuit high
B1219 Audio [+] output #20 (TBD) circuit open
B1220 Audio [-] output #20 (TBD) malfunction
B1221 Audio [-] output #20 (TBD) circuit range/performance
B1222 Audio [-] output #20 (TBD) circuit low
B1223 Audio [-] output #20 (TBD) circuit high
B1224 Audio [-] output #20 (TBD) circuit open
B1225 Tape player ON signal circuit malfunction
B1226 Tape player ON signal circuit range/performance
B1227 Tape player ON signal circuit low
B1228 Tape player ON signal circuit high
B1229 Tape player ON signal circuit open
B1230 CD player ON signal circuit malfunction
B1231 CD player ON signal circuit range/performance
B1232 CD player ON signal circuit low
B1233 CD player ON signal circuit high
B1234 CD player ON signal circuit open
B1235 Amplifier ON signal circuit malfunction
B1236 Amplifier ON signal circuit range/performance
B1237 Amplifier ON signal circuit low
B1238 Amplifier ON signal circuit high
B1239 Amplifier ON signal circuit open
B1240 CD player not responding
B1241 CD player tracking malfunction
B1242 CD player focus malfunction
B1243 CD player load/unload malfunction
B1244 CD player disk upside down
B1245 CD changer not responding
B1246 CD changer tracking malfunction
B1247 CD changer focus malfunction
B1248 CD changer load/unload malfunction
B1249 CD changer disk upside down
B1250 Cassette tape slow
B1251 Cassette tape fast
B1252 Cassette not responding
B1253 Cassette head cleaning required
B1254 Audio system security circuit malfunction
B1255 Audio system security circuit range/performance
B1256 Audio system security circuit low
B1257 Audio system security circuit high
B1258 Audio system security circuit open
B1259 Antenna ground circuit malfunction
B1260 Antenna ground circuit range/performance
B1261 Antenna ground circuit low
B1262 Antenna ground circuit high
B1263 Antenna ground circuit open
B1264 Switched antenna malfunction
B1265 Switched 14 volt malfunction
B1266 Switched internal battery malfunction
B1267 16 volt malfunction
B1268 Cassette tight tape
B1269 Cassette load/unload error
B1270 Cassette cut tape
B1271 Theft Locked
B1325 Device power #1 (low current #1) circuit malfunction
B1326 Device power #1 (low current #1) circuit range/performance
B1327 Device power #1 (low current #1) circuit low
B1328 Device power #1 (low current #1) circuit high
B1329 Device power #1 (low current #1) circuit open
B1330 Device power #2 (low current #2) circuit malfunction
B1331 Device power #2 (low current #2) circuit range/performance
B1332 Device power #2 (low current #2) circuit low
B1333 Device power #2 (low current #2) circuit high
B1334 Device power #2 (low current #2) circuit open
B1335 Device power #3 (high current #1) circuit malfunction
B1336 Device power #3 (high current #1) circuit range/performance
B1337 Device power #3 (high current #1) circuit low
B1338 Device power #3 (high current #1) circuit high
B1339 Device power #3 (high current #1) circuit open
B1340 Device power #4 (high current #2) circuit malfunction
B1341 Device power #4 (high current #2) circuit range/performance
B1342 Device power #4 (high current #2) circuit low
B1343 Device power #4 (high current #2) circuit high
B1344 Device power #4 (high current #2) circuit open
B1345 Device ground #1 (chassis gnd #1) circuit malfunction
B1346 Device ground #1 (chassis gnd #1) circuit range/performance
B1347 Device ground #1 (chassis gnd #1) circuit low
B1348 Device ground #1 (chassis gnd #1) circuit high
B1349 Device ground #1 (chassis gnd #1) circuit open
B1350 Device ground #2 (chassis gnd #2) circuit malfunction
B1351 Device ground #2 (chassis gnd #2) circuit range/performance
B1352 Device ground #2 (chassis gnd #2) circuit low
B1353 Device ground #2 (chassis gnd #2) circuit high
B1354 Device ground #2 (chassis gnd #2) circuit open
B1355 Device ground #3 (signal gnd #1) circuit malfunction
B1356 Device ground #3 (signal gnd #1) circuit range/performance
B1357 Device ground #3 (signal gnd #1) circuit low
B1358 Device ground #3 (signal gnd #1) circuit high
B1359 Device ground #3 (signal gnd #1) circuit open
B1360 Device ground #4 (signal gnd #2) circuit malfunction
B1361 Device ground #4 (signal gnd #2) circuit range/performance
B1362 Device ground #4 (signal gnd #2) circuit low
B1363 Device ground #4 (signal gnd #2) circuit high
B1364 Device ground #4 (signal gnd #2) circuit open
B1365 Device ignition 0 (UNLOCK/ON/START) circuit malfunction
B1366 Device ignition 0 (UNLOCK/ON/START) circuit range/performance
B1367 Device ignition 0 (UNLOCK/ON/START) circuit low
B1368 Device ignition 0 (UNLOCK/ON/START) circuit high
B1369 Device ignition 0 (UNLOCK/ON/START) circuit open
B1370 Device ignition 1 (ON/START) circuit malfunction
B1371 Device ignition 1 (ON/START) circuit range/performance
B1372 Device ignition 1 (ON/START) circuit low
B1373 Device ignition 1 (ON/START) circuit high
B1374 Device ignition 1 (ON/START) circuit open
B1375 Device ignition 3 (ON) circuit malfunction
B1376 Device ignition 3 (ON) circuit range/performance
B1377 Device ignition 3 (ON) circuit low
B1378 Device ignition 3 (ON) circuit high
B1379 Device ignition 3 (ON) circuit open
B1380 Device ignition ACC circuit malfunction
B1381 Device ignition ACC circuit range/performance
B1382 Device ignition ACC circuit low
B1383 Device ignition ACC circuit high
B1384 Device ignition ACC circuit open
B1385 Device ignition START circuit malfunction
B1386 Device ignition START circuit range/performance
B1387 Device ignition START circuit low
B1388 Device ignition START circuit high
B1389 Device ignition START circuit open
B1390 Device voltage reference input #1 circuit malfunction
B1391 Device voltage reference input #1 circuit range/performance
B1392 Device voltage reference input #1 circuit low
B1393 Device voltage reference input #1 circuit high
B1394 Device voltage reference input #1 circuit open
B1395 Device voltage reference output #1 circuit malfunction
B1396 Device voltage reference output #1 circuit range/performance
B1397 Device voltage reference output #1 circuit low
B1398 Device voltage reference output #1 circuit high
B1399 Device voltage reference output #1 circuit open
B1400 Device voltage reference input #2 circuit malfunction
B1401 Device voltage reference input #2 circuit range/performance
B1402 Device voltage reference input #2 circuit low
B1403 Device voltage reference input #2 circuit high
B1404 Device voltage reference input #2 circuit open
B1405 Device voltage reference output #2 circuit malfunction
B1406 Device voltage reference output #2 circuit range/performance
B1407 Device voltage reference output #2 circuit low
B1408 Device voltage reference output #2 circuit high
B1409 Device voltage reference output #2 circuit open
B1410 Device voltage reference input #3 circuit malfunction
B1411 Device voltage reference input #3 circuit range/performance
B1412 Device voltage reference input #3 circuit low
B1413 Device voltage reference input #3 circuit high
B1414 Device voltage reference input #3 circuit open
B1415 Device voltage reference output #3 circuit malfunction
B1416 Device voltage reference output #3 circuit range/performance
B1417 Device voltage reference output #3 circuit low
B1418 Device voltage reference output #3 circuit high
B1419 Device voltage reference output #3 circuit open
B1420 Device voltage malfunction
B1421 Device voltage range/performance
B1422 Device power moding malfunction
B1423 Device power and/or ground circuit malfunction
B1424 Device #1 voltage low
B1425 Device #1 voltage high
B1426 Device #2 voltage low
B1427 Device #2 voltage high
B1428 Ignition-switched power relay #1 circuit malfunction
B1429 Ignition-switched power relay #1 circuit range/performance
B1430 Ignition-switched power relay #1 circuit low
B1431 Ignition-switched power relay #1 circuit high
B1432 Ignition-switched power relay #1 circuit open
B1433 Ignition-switched power relay #2 circuit malfunction
B1434 Ignition-switched power relay #2 circuit range/performance
B1435 Ignition-switched power relay #2 circuit low
B1436 Ignition-switched power relay #2 circuit high
B1437 Ignition-switched power relay #2 circuit open
B1438 IPC high voltage output overcurrent to CCP
B1439 Intermittent device voltage range/performance
B1440 Power mode master input circuits mismatch
B1441 Device ignition OFF/RUN/CRANK circuit malfunction
B1442 Device ignition OFF/RUN/CRANK circuit low
B1443 Device ignition OFF/RUN/CRANK circuit high
B1444 Device backup power malfunction
B1445 Device voltage output #1 circuit malfunction
B1475 Retained accessory power circuit malfunction
B1476 Retained accessory power circuit range/performance
B1477 Retained accessory power circuit low
B1478 Retained accessory power circuit high
B1479 Retained accessory power circuit open
B1480 Battery rundown protection circuit malfunction
B1481 Battery rundown protection circuit range/performance
B1482 Battery rundown protection circuit low
B1483 Battery rundown protection circuit high
B1484 Battery rundown protection circuit open
B1485 Generator L-terminal circuit malfunction
B1486 Generator L-terminal circuit range/performance
B1487 Generator L-terminal circuit low
B1488 Generator L-terminal circuit high
B1489 Generator L-terminal circuit open
B1490 F-terminal circuit malfunction
B1491 F-terminal circuit range/performance
B1492 F-terminal circuit low
B1493 F-terminal circuit high
B1494 F-terminal circuit open
B1495 Exterior lamp power circuit malfunction
B1496 Exterior lamp power circuit range/performance
B1497 Exterior lamp power circuit low
B1498 Exterior lamp power circuit high
B1499 Exterior lamp power circuit open
B1500 Low power control circuit malfunction
B1501 Low power control circuit range/performance
B1502 Low power control circuit low
B1503 Low power control circuit high
B1504 Low power control circuit open
B1505 High power control circuit malfunction
B1506 High power control circuit range/performance
B1507 High power control circuit low
B1508 High power control circuit high
B1509 High power control circuit open
B1510 Storage mode entered
B1511 Battery voltage low -- generator malfunction
B1512 AD power circuit malfunction
B1513 Charging system voltage low
B1514 Charging system voltage high
B1550 Mirror LF/RF select switch circuit malfunction
B1551 Mirror LF/RF select switch circuit range/performance
B1552 Mirror LF/RF select switch circuit low
B1553 Mirror LF/RF select switch circuit high
B1554 Mirror LF/RF select switch circuit open
B1555 LF/RF mirror control switch assembly circuit malfunction
B1556 LF/RF mirror control switch assembly circuit range/performance
B1557 LF/RF mirror control switch assembly circuit low
B1558 LF/RF mirror control switch assembly circuit high
B1559 LF/RF mirror control switch assembly circuit open
B1560 Mirror right control switch circuit malfunction
B1561 Mirror right control switch circuit range/performance
B1562 Mirror right control switch circuit low
B1563 Mirror right control switch circuit high
B1564 Mirror right control switch circuit open
B1565 Mirror left control switch circuit malfunction
B1566 Mirror left control switch circuit range/performance
B1567 Mirror left control switch circuit low
B1568 Mirror left control switch circuit high
B1569 Mirror left control switch circuit open
B1570 Mirror up control switch circuit malfunction
B1571 Mirror up control switch circuit range/performance
B1572 Mirror up control switch circuit low
B1573 Mirror up control switch circuit high
B1574 Mirror up control switch circuit open
B1575 Mirror down control switch circuit malfunction
B1576 Mirror down control switch circuit range/performance
B1577 Mirror down control switch circuit low
B1578 Mirror down control switch circuit high
B1579 Mirror down control switch circuit open
B1580 LF mirror horizontal position sensor circuit malfunction
B1581 LF mirror horizontal position sensor circuit range/performance
B1582 LF mirror horizontal position sensor circuit low
B1583 LF mirror horizontal position sensor circuit high
B1584 LF mirror horizontal position sensor circuit open
B1585 LF mirror horizontal position feedback circuit malfunction
B1586 LF mirror horizontal position feedback circuit range/performance
B1587 LF mirror horizontal position feedback circuit low
B1588 LF mirror horizontal position feedback circuit high
B1589 LF mirror horizontal position feedback circuit open
B1590 LF mirror vertical position sensor circuit malfunction
B1591 LF mirror vertical position sensor circuit range/performance
B1592 LF mirror vertical position sensor circuit low
B1593 LF mirror vertical position sensor circuit high
B1594 LF mirror vertical position sensor circuit open
B1595 LF mirror vertical position feedback circuit malfunction
B1596 LF mirror vertical position feedback circuit range/performance
B1597 LF mirror vertical position feedback circuit low
B1598 LF mirror vertical position feedback circuit high
B1599 LF mirror vertical position feedback circuit open
B1600 LF mirror motor #1 (single motor or vertical) circuit malfunction
B1601 LF mirror motor #1 (single motor or vertical) circuit range/performance
B1602 LF mirror motor #1 (single motor or vertical) circuit low
B1603 LF mirror motor #1 (single motor or vertical) circuit high
B1604 LF mirror motor #1 (single motor or vertical) circuit open
B1605 LF mirror motor #2 (horizontal) circuit malfunction
B1606 LF mirror motor #2 (horizontal) circuit range/performance
B1607 LF mirror motor #2 (horizontal) circuit low
B1608 LF mirror motor #2 (horizontal) circuit high
B1609 LF mirror motor #2 (horizontal) circuit open
B1610 RF mirror horizontal position sensor circuit malfunction
B1611 RF mirror horizontal position sensor circuit range/performance
B1612 RF mirror horizontal position sensor circuit low
B1613 RF mirror horizontal position sensor circuit high
B1614 RF mirror horizontal position sensor circuit open
B1615 RF mirror horizontal position feedback circuit malfunction
B1616 RF mirror horizontal position feedback circuit range/performance
B1617 RF mirror horizontal position feedback circuit low
B1618 RF mirror horizontal position feedback circuit high
B1619 RF mirror horizontal position feedback circuit open
B1620 RF mirror vertical position sensor circuit malfunction
B1621 RF mirror vertical position sensor circuit range/performance
B1622 RF mirror vertical position sensor circuit low
B1623 RF mirror vertical position sensor circuit high
B1624 RF mirror vertical position sensor circuit open
B1625 RF mirror vertical position feedback circuit malfunction
B1626 RF mirror vertical position feedback circuit range/performance
B1627 RF mirror vertical position feedback circuit low
B1628 RF mirror vertical position feedback circuit high
B1629 RF mirror vertical position feedback circuit open
B1630 RF mirror motor #1 (single motor or vertical) circuit malfunction
B1631 RF mirror motor #1 (single motor or vertical) circuit range/performance
B1632 RF mirror motor #1 (single motor or vertical) circuit low
B1633 RF mirror motor #1 (single motor or vertical) circuit high
B1634 RF mirror motor #1 (single motor or vertical) circuit open
B1635 RF mirror motor #2 (horizontal) circuit malfunction
B1636 RF mirror motor #2 (horizontal) circuit range/performance
B1637 RF mirror motor #2 (horizontal) circuit low
B1638 RF mirror motor #2 (horizontal) circuit high
B1639 RF mirror motor #2 (horizontal) circuit open
B1640 LF mirror heater circuit malfunction
B1641 LF mirror heater circuit range/performance
B1642 LF mirror heater circuit low
B1643 LF mirror heater circuit high
B1644 LF mirror heater circuit open
B1645 RF mirror heater circuit malfunction
B1646 RF mirror heater circuit range/performance
B1647 RF mirror heater circuit low
B1648 RF mirror heater circuit high
B1649 RF mirror heater circuit open
B1650 LF mirror transmission reverse gear circuit malfunction
B1651 LF mirror transmission reverse gear circuit range/performance
B1652 LF mirror transmission reverse gear circuit low
B1653 LF mirror transmission reverse gear circuit high
B1654 LF mirror transmission reverse gear circuit open
B1655 RF mirror transmission reverse gear circuit malfunction
B1656 RF mirror transmission reverse gear circuit range/performance
B1657 RF mirror transmission reverse gear circuit low
B1658 RF mirror transmission reverse gear circuit high
B1659 RF mirror transmission reverse gear circuit open
B1660 Inside rearview mirror vertical position sensor circuit malfunction
B1661 Inside rearview mirror vertical position sensor circuit range/performance
B1662 Inside rearview mirror vertical position sensor circuit low
B1663 Inside rearview mirror vertical position sensor circuit high
B1664 Inside rearview mirror vertical position sensor circuit open
B1665 Inside rearview mirror vertical position feedback circuit malfunction
B1666 Inside rearview mirror vertical position feedback circuit range/performance
B1667 Inside rearview mirror vertical position feedback circuit low
B1668 Inside rearview mirror vertical position feedback circuit high
B1669 Inside rearview mirror vertical position feedback circuit open
B1670 Inside rearview mirror horizontal position sensor circuit malfunction
B1671 Inside rearview mirror horizontal position sensor circuit range/performance
B1672 Inside rearview mirror horizontal position sensor circuit low
B1673 Inside rearview mirror horizontal position sensor circuit high
B1674 Inside rearview mirror horizontal position sensor circuit open
B1675 Inside rearview mirror horizontal position feedback circuit malfunction
B1676 Inside rearview mirror horizontal position feedback circuit range/performance
B1677 Inside rearview mirror horizontal position feedback circuit low
B1678 Inside rearview mirror horizontal position feedback circuit high
B1679 Inside rearview mirror horizontal position feedback circuit open
B1680 Inside rearview mirror motor #1 (single motor or vertical) circuit malfunction
B1681 Inside rearview mirror motor #1 (single motor or vertical) circuit range/performance
B1682 Inside rearview mirror motor #1 (single motor or vertical) circuit low
B1683 Inside rearview mirror motor #1 (single motor or vertical) circuit high
B1684 Inside rearview mirror motor #1 (single motor or vertical) circuit open
B1685 Inside rearview mirror motor #2 (horizontal) circuit malfunction
B1686 Inside rearview mirror motor #2 (horizontal) circuit range/performance
B1687 Inside rearview mirror motor #2 (horizontal) circuit low
B1688 Inside rearview mirror motor #2 (horizontal) circuit high
B1689 Inside rearview mirror motor #2 (horizontal) circuit open
B1690 Inside rearview mirror transmission reverse gear circuit malfunction
B1691 Inside rearview mirror transmission reverse gear circuit range/performance
B1692 Inside rearview mirror transmission reverse gear circuit low
B1693 Inside rearview mirror transmission reverse gear circuit high
B1694 Inside rearview mirror transmission reverse gear circuit open
B1695 Mirror left-up control switch circuit malfunction
B1696 Mirror left-up control switch circuit range/performance
B1697 Mirror left-up control switch circuit low
B1698 Mirror left-up control switch circuit high
B1699 Mirror left-up control switch circuit open
B1700 Mirror left-down control switch circuit malfunction
B1701 Mirror left-down control switch circuit range/performance
B1702 Mirror left-down control switch circuit low
B1703 Mirror left-down control switch circuit high
B1704 Mirror left-down control switch circuit open
B1705 Mirror right-up control switch circuit malfunction
B1706 Mirror right-up control switch circuit range/performance
B1707 Mirror right-up control switch circuit low
B1708 Mirror right-up control switch circuit high
B1709 Mirror right-up control switch circuit open
B1710 Mirror right-down control switch circuit malfunction
B1711 Mirror right-down control switch circuit range/performance
B1712 Mirror right-down control switch circuit low
B1713 Mirror right-down control switch circuit high
B1714 Mirror right-down control switch circuit open
B1715 Mirror power fold control switch circuit malfunction
B1716 Mirror power fold control switch circuit range/performance
B1717 Mirror power fold control switch circuit low
B1718 Mirror power fold control switch circuit high
B1719 Mirror power fold control switch circuit open
B1720 Mirror up/down control switch circuit malfunction
B1721 Mirror left/right control switch circuit malfunction
B1722 Mirror power fold control circuit malfunction
B1723 Mirror motor control circuit #1 malfunction
B1724 Mirror motor control circuit #2 malfunction
B1725 LF/Driver seat assembly up switch circuit malfunction
B1726 LF/Driver seat assembly up switch circuit range/performance
B1727 LF/Driver seat assembly up switch circuit low
B1728 LF/Driver seat assembly up switch circuit high
B1729 LF/Driver seat assembly up switch circuit open
B1730 LF/Driver seat assembly down switch circuit malfunction
B1731 LF/Driver seat assembly down switch circuit range/performance
B1732 LF/Driver seat assembly down switch circuit low
B1733 LF/Driver seat assembly down switch circuit high
B1734 LF/Driver seat assembly down switch circuit open
B1735 LF/Driver seat front up switch circuit malfunction
B1736 LF/Driver seat front up switch circuit range/performance
B1737 LF/Driver seat front up switch circuit low
B1738 LF/Driver seat front up switch circuit high
B1739 LF/Driver seat front up switch circuit open
B1740 LF/Driver seat front down switch circuit malfunction
B1741 LF/Driver seat front down switch circuit range/performance
B1742 LF/Driver seat front down switch circuit low
B1743 LF/Driver seat front down switch circuit high
B1744 LF/Driver seat front down switch circuit open
B1745 LF/Driver seat rear up switch circuit malfunction
B1746 LF/Driver seat rear up switch circuit range/performance
B1747 LF/Driver seat rear up switch circuit low
B1748 LF/Driver seat rear up switch circuit high
B1749 LF/Driver seat rear up switch circuit open
B1750 LF/Driver seat rear down switch circuit malfunction
B1751 LF/Driver seat rear down switch circuit range/performance
B1752 LF/Driver seat rear down switch circuit low
B1753 LF/Driver seat rear down switch circuit high
B1754 LF/Driver seat rear down switch circuit open
B1755 LF/Driver seat assembly forward switch circuit malfunction
B1756 LF/Driver seat assembly forward switch circuit range/performance
B1757 LF/Driver seat assembly forward switch circuit low
B1758 LF/Driver seat assembly forward switch circuit high
B1759 LF/Driver seat assembly forward switch circuit open
B1760 LF/Driver seat assembly rearward switch circuit malfunction
B1761 LF/Driver seat assembly rearward switch circuit range/performance
B1762 LF/Driver seat assembly rearward switch circuit low
B1763 LF/Driver seat assembly rearward switch circuit high
B1764 LF/Driver seat assembly rearward switch circuit open
B1765 LF/Driver seat motor #1 (ass'y. vertical) circuit malfunction
B1766 LF/Driver seat motor #1 (ass'y. vertical) circuit range/performance
B1767 LF/Driver seat motor #1 (ass'y. vertical) circuit low
B1768 LF/Driver seat motor #1 (ass'y. vertical) circuit high
B1769 LF/Driver seat motor #1 (ass'y. vertical) circuit open
B1770 LF/Driver seat motor #2 (ass'y. horizontal) circuit malfunction
B1771 LF/Driver seat motor #2 (ass'y. horizontal) circuit range/performance
B1772 LF/Driver seat motor #2 (ass'y. horizontal) circuit low
B1773 LF/Driver seat motor #2 (ass'y. horizontal) circuit high
B1774 LF/Driver seat motor #2 (ass'y. horizontal) circuit open
B1775 LF/Driver seat motor #3 (front vertical) circuit malfunction
B1776 LF/Driver seat motor #3 (front vertical) circuit range/performance
B1777 LF/Driver seat motor #3 (front vertical) circuit low
B1778 LF/Driver seat motor #3 (front vertical) circuit high
B1779 LF/Driver seat motor #3 (front vertical) circuit open
B1780 LF/Driver seat motor #4 (rear vertical) circuit malfunction
B1781 LF/Driver seat motor #4 (rear vertical) circuit range/performance
B1782 LF/Driver seat motor #4 (rear vertical) circuit low
B1783 LF/Driver seat motor #4 (rear vertical) circuit high
B1784 LF/Driver seat motor #4 (rear vertical) circuit open
B1785 LF/Driver seat motor #5 (recline) circuit malfunction
B1786 LF/Driver seat motor #5 (recline) circuit range/performance
B1787 LF/Driver seat motor #5 (recline) circuit low
B1788 LF/Driver seat motor #5 (recline) circuit high
B1789 LF/Driver seat motor #5 (recline) circuit open
B1790 LF/Driver seat motor #6 (lumbar; single motor or horizontal) circuit malfunction
B1791 LF/Driver seat motor #6 (lumbar; single motor or horizontal) circuit range/performance
B1792 LF/Driver seat motor #6 (lumbar; single motor or horizontal) circuit low
B1793 LF/Driver seat motor #6 (lumbar; single motor or horizontal) circuit high
B1794 LF/Driver seat motor #6 (lumbar; single motor or horizontal) circuit open
B1795 LF/Driver seat motor #7 (head restraint horizontal) circuit malfunction
B1796 LF/Driver seat motor #7 (head restraint horizontal) circuit range/performance
B1797 LF/Driver seat motor #7 (head restraint horizontal) circuit low
B1798 LF/Driver seat motor #7 (head restraint horizontal) circuit high
B1799 LF/Driver seat motor #7 (head restraint horizontal) circuit open
B1800 LF/Driver seat motor #8 (head restraint vertical) circuit malfunction
B1801 LF/Driver seat motor #8 (head restraint vertical) circuit range/performance
B1802 LF/Driver seat motor #8 (head restraint vertical) circuit low
B1803 LF/Driver seat motor #8 (head restraint vertical) circuit high
B1804 LF/Driver seat motor #8 (head restraint vertical) circuit open
B1805 LF/Driver seat motor #9 (side bolster) circuit malfunction
B1806 LF/Driver seat motor #9 (side bolster) circuit range/performance
B1807 LF/Driver seat motor #9 (side bolster) circuit low
B1808 LF/Driver seat motor #9 (side bolster) circuit high
B1809 LF/Driver seat motor #9 (side bolster) circuit open
B1810 LF/Driver seat motor #10 (thigh bolster) circuit malfunction
B1811 LF/Driver seat motor #10 (thigh bolster) circuit range/performance
B1812 LF/Driver seat motor #10 (thigh bolster) circuit low
B1813 LF/Driver seat motor #10 (thigh bolster) circuit high
B1814 LF/Driver seat motor #10 (thigh bolster) circuit open
B1815 LF/Driver recline forward switch circuit malfunction
B1816 LF/Driver recline forward switch circuit range/performance
B1817 LF/Driver recline forward switch circuit low
B1818 LF/Driver recline forward switch circuit high
B1819 LF/Driver recline forward switch circuit open
B1820 LF/Driver recline rearward switch circuit malfunction
B1821 LF/Driver recline rearward switch circuit range/performance
B1822 LF/Driver recline rearward switch circuit low
B1823 LF/Driver recline rearward switch circuit high
B1824 LF/Driver recline rearward switch circuit open
B1825 LF/Driver recline sensor circuit malfunction
B1826 LF/Driver recline sensor circuit range/performance
B1827 LF/Driver recline sensor circuit low
B1828 LF/Driver recline sensor circuit high
B1829 LF/Driver recline sensor circuit open
B1830 LF/Driver lumbar forward switch circuit malfunction
B1831 LF/Driver lumbar forward switch circuit range/performance
B1832 LF/Driver lumbar forward switch circuit low
B1833 LF/Driver lumbar forward switch circuit high
B1834 LF/Driver lumbar forward switch circuit open
B1835 LF/Driver lumbar rearward switch circuit malfunction
B1836 LF/Driver lumbar rearward switch circuit range/performance
B1837 LF/Driver lumbar rearward switch circuit low
B1838 LF/Driver lumbar rearward switch circuit high
B1839 LF/Driver lumbar rearward switch circuit open
B1840 LF/Driver lumbar up switch circuit malfunction
B1841 LF/Driver lumbar up switch circuit range/performance
B1842 LF/Driver lumbar up switch circuit low
B1843 LF/Driver lumbar up switch circuit high
B1844 LF/Driver lumbar up switch circuit open
B1845 LF/Driver lumbar down switch circuit malfunction
B1846 LF/Driver lumbar down switch circuit range/performance
B1847 LF/Driver lumbar down switch circuit low
B1848 LF/Driver lumbar down switch circuit high
B1849 LF/Driver lumbar down switch circuit open
B1850 LF/Driver lumbar horizontal sensor malfunction
B1851 LF/Driver lumbar horizontal sensor range/performance
B1852 LF/Driver lumbar horizontal sensor low
B1853 LF/Driver lumbar horizontal sensor high
B1854 LF/Driver lumbar horizontal sensor open
B1855 LF/Driver lumbar horizontal feedback circuit malfunction
B1856 LF/Driver lumbar horizontal feedback circuit range/performance
B1857 LF/Driver lumbar horizontal feedback circuit low
B1858 LF/Driver lumbar horizontal feedback circuit high
B1859 LF/Driver lumbar horizontal feedback circuit open
B1860 LF/Driver lumbar vertical sensor malfunction
B1861 LF/Driver lumbar vertical sensor range/performance
B1862 LF/Driver lumbar vertical sensor low
B1863 LF/Driver lumbar vertical sensor high
B1864 LF/Driver lumbar vertical sensor open
B1865 LF/Driver lumbar vertical feedback circuit malfunction
B1866 LF/Driver lumbar vertical feedback circuit range/performance
B1867 LF/Driver lumbar vertical feedback circuit low
B1868 LF/Driver lumbar vertical feedback circuit high
B1869 LF/Driver lumbar vertical feedback circuit open
B1870 LF/Driver head restraint up switch circuit malfunction
B1871 LF/Driver head restraint up switch circuit range/performance
B1872 LF/Driver head restraint up switch circuit low
B1873 LF/Driver head restraint up switch circuit high
B1874 LF/Driver head restraint up switch circuit open
B1875 LF/Driver head restraint down switch circuit malfunction
B1876 LF/Driver head restraint down switch circuit range/performance
B1877 LF/Driver head restraint down switch circuit low
B1878 LF/Driver head restraint down switch circuit high
B1879 LF/Driver head restraint down switch circuit open
B1880 LF/Driver head restraint forward switch circuit malfunction
B1881 LF/Driver head restraint forward switch circuit range/performance
B1882 LF/Driver head restraint forward switch circuit low
B1883 LF/Driver head restraint forward switch circuit high
B1884 LF/Driver head restraint forward switch circuit open
B1885 LF/Driver head restraint rearward switch circuit malfunction
B1886 LF/Driver head restraint rearward switch circuit range/performance
B1887 LF/Driver head restraint rearward switch circuit low
B1888 LF/Driver head restraint rearward switch circuit high
B1889 LF/Driver head restraint rearward switch circuit open
B1890 LF/Driver head restraint horizontal sensor malfunction
B1891 LF/Driver head restraint horizontal sensor range/performance
B1892 LF/Driver head restraint horizontal sensor low
B1893 LF/Driver head restraint horizontal sensor high
B1894 LF/Driver head restraint horizontal sensor open
B1895 LF/Driver head restraint horizontal feedback circuit malfunction
B1896 LF/Driver head restraint horizontal feedback circuit range/performance
B1897 LF/Driver head restraint horizontal feedback circuit low
B1898 LF/Driver head restraint horizontal feedback circuit high
B1899 LF/Driver head restraint horizontal feedback circuit open
B1900 LF/Driver head restraint vertical sensor malfunction
B1901 LF/Driver head restraint vertical sensor range/performance
B1902 LF/Driver head restraint vertical sensor low
B1903 LF/Driver head restraint vertical sensor high
B1904 LF/Driver head restraint vertical sensor open
B1905 LF/Driver head restraint vertical feedback circuit malfunction
B1906 LF/Driver head restraint vertical feedback circuit range/performance
B1907 LF/Driver head restraint vertical feedback circuit low
B1908 LF/Driver head restraint vertical feedback circuit high
B1909 LF/Driver head restraint vertical feedback circuit open
B1910 LF/Driver seat heater switch #1 (whole system or "low") circuit malfunction
B1911 LF/Driver seat heater switch #1 (whole system or "low") circuit range/performance
B1912 LF/Driver seat heater switch #1 (whole system or "low") circuit low
B1913 LF/Driver seat heater switch #1 (whole system or "low") circuit high
B1914 LF/Driver seat heater switch #1 (whole system or "low") circuit open
B1915 LF/Driver seat heater switch #2 ("high") circuit malfunction
B1916 LF/Driver seat heater switch #2 ("high") circuit range/performance
B1917 LF/Driver seat heater switch #2 ("high") circuit low
B1918 LF/Driver seat heater switch #2 ("high") circuit high
B1919 LF/Driver seat heater switch #2 ("high") circuit open
B1920 LF/Driver seat heater (whole seat or seat cushion) timer circuit malfunction
B1921 LF/Driver seat heater (whole seat or seat cushion) timer circuit range/performance
B1922 LF/Driver seat heater (whole seat or seat cushion) timer circuit low
B1923 LF/Driver seat heater (whole seat or seat cushion) timer circuit high
B1924 LF/Driver seat heater (whole seat or seat cushion) timer circuit open
B1925 LF/Driver seat heater (whole seat or seat cushion) sensor malfunction
B1926 LF/Driver seat heater (whole seat or seat cushion) sensor range/performance
B1927 LF/Driver seat heater (whole seat or seat cushion) sensor low
B1928 LF/Driver seat heater (whole seat or seat cushion) sensor high
B1929 LF/Driver seat heater (whole seat or seat cushion) sensor open
B1930 LF/Driver seat heater (whole seat or seat cushion) feedback circuit malfunction
B1931 LF/Driver seat heater (whole seat or seat cushion) feedback circuit range/performance
B1932 LF/Driver seat heater (whole seat or seat cushion) feedback circuit low
B1933 LF/Driver seat heater (whole seat or seat cushion) feedback circuit high
B1934 LF/Driver seat heater (whole seat or seat cushion) feedback circuit open
B1935 LF/Driver seat back heater malfunction
B1936 LF/Driver seat back heater range/performance
B1937 LF/Driver seat back heater low
B1938 LF/Driver seat back heater high
B1939 LF/Driver seat back heater open
B1940 LF/Driver seat side bolster in switch circuit malfunction
B1941 LF/Driver seat side bolster in switch circuit range/performance
B1942 LF/Driver seat side bolster in switch circuit low
B1943 LF/Driver seat side bolster in switch circuit high
B1944 LF/Driver seat side bolster in switch circuit open
B1945 LF/Driver seat side bolster out switch circuit malfunction
B1946 LF/Driver seat side bolster out switch circuit range/performance
B1947 LF/Driver seat side bolster out switch circuit low
B1948 LF/Driver seat side bolster out switch circuit high
B1949 LF/Driver seat side bolster out switch circuit open
B1950 LF/Driver seat side bolster in circuit malfunction
B1951 LF/Driver seat side bolster in circuit range/performance
B1952 LF/Driver seat side bolster in circuit low
B1953 LF/Driver seat side bolster in circuit high
B1954 LF/Driver seat side bolster in circuit open
B1955 LF/Driver seat side bolster out circuit malfunction
B1956 LF/Driver seat side bolster out circuit range/performance
B1957 LF/Driver seat side bolster out circuit low
B1958 LF/Driver seat side bolster out circuit high
B1959 LF/Driver seat side bolster out circuit open
B1960 LF/Driver seat side bolster sensor malfunction
B1961 LF/Driver seat side bolster sensor range/performance
B1962 LF/Driver seat side bolster sensor low
B1963 LF/Driver seat side bolster sensor high
B1964 LF/Driver seat side bolster sensor open
B1965 LF/Driver seat side bolster feedback circuit malfunction
B1966 LF/Driver seat side bolster feedback circuit range/performance
B1967 LF/Driver seat side bolster feedback circuit low
B1968 LF/Driver seat side bolster feedback circuit high
B1969 LF/Driver seat side bolster feedback circuit open
B1970 RF/Passenger seat assembly up switch circuit malfunction
B1971 RF/Passenger seat assembly up switch circuit range/performance
B1972 RF/Passenger seat assembly up switch circuit low
B1973 RF/Passenger seat assembly up switch circuit high
B1974 RF/Passenger seat assembly up switch circuit open
B1975 RF/Passenger seat assembly down switch circuit malfunction
B1976 RF/Passenger seat assembly down switch circuit range/performance
B1977 RF/Passenger seat assembly down switch circuit low
B1978 RF/Passenger seat assembly down switch circuit high
B1979 RF/Passenger seat assembly down switch circuit open
B1980 RF/Passenger seat front up switch circuit malfunction
B1981 RF/Passenger seat front up switch circuit range/performance
B1982 RF/Passenger seat front up switch circuit low
B1983 RF/Passenger seat front up switch circuit high
B1984 RF/Passenger seat front up switch circuit open
B1985 RF/Passenger seat front down switch circuit malfunction
B1986 RF/Passenger seat front down switch circuit range/performance
B1987 RF/Passenger seat front down switch circuit low
B1988 RF/Passenger seat front down switch circuit high
B1989 RF/Passenger seat front down switch circuit open
B1990 RF/Passenger seat rear up switch circuit malfunction
B1991 RF/Passenger seat rear up switch circuit range/performance
B1992 RF/Passenger seat rear up switch circuit low
B1993 RF/Passenger seat rear up switch circuit high
B1994 RF/Passenger seat rear up switch circuit open
B1995 RF/Passenger seat rear down switch circuit malfunction
B1996 RF/Passenger seat rear down switch circuit range/performance
B1997 RF/Passenger seat rear down switch circuit low
B1998 RF/Passenger seat rear down switch circuit high
B1999 RF/Passenger seat rear down switch circuit open
B2000 RF/Passenger seat assembly forward switch circuit malfunction
B2001 RF/Passenger seat assembly forward switch circuit range/performance
B2002 RF/Passenger seat assembly forward switch circuit low
B2003 RF/Passenger seat assembly forward switch circuit high
B2004 RF/Passenger seat assembly forward switch circuit open
B2005 RF/Passenger seat assembly rearward switch circuit malfunction
B2006 RF/Passenger seat assembly rearward switch circuit range/performance
B2007 RF/Passenger seat assembly rearward switch circuit low
B2008 RF/Passenger seat assembly rearward switch circuit high
B2009 RF/Passenger seat assembly rearward switch circuit open
B2010 RF/Passenger seat motor #1 (ass'y. vertical) circuit malfunction
B2011 RF/Passenger seat motor #1 (ass'y. vertical) circuit range/performance
B2012 RF/Passenger seat motor #1 (ass'y. vertical) circuit low
B2013 RF/Passenger seat motor #1 (ass'y. vertical) circuit high
B2014 RF/Passenger seat motor #1 (ass'y. vertical) circuit open
B2015 RF/Passenger seat motor #2 (ass'y. horizontal) circuit malfunction
B2016 RF/Passenger seat motor #2 (ass'y. horizontal) circuit range/performance
B2017 RF/Passenger seat motor #2 (ass'y. horizontal) circuit low
B2018 RF/Passenger seat motor #2 (ass'y. horizontal) circuit high
B2019 RF/Passenger seat motor #2 (ass'y. horizontal) circuit open
B2020 RF/Passenger seat motor #3 (front vertical) circuit malfunction
B2021 RF/Passenger seat motor #3 (front vertical) circuit range/performance
B2022 RF/Passenger seat motor #3 (front vertical) circuit low
B2023 RF/Passenger seat motor #3 (front vertical) circuit high
B2024 RF/Passenger seat motor #3 (front vertical) circuit open
B2025 RF/Passenger seat motor #4 (rear vertical) circuit malfunction
B2026 RF/Passenger seat motor #4 (rear vertical) circuit range/performance
B2027 RF/Passenger seat motor #4 (rear vertical) circuit low
B2028 RF/Passenger seat motor #4 (rear vertical) circuit high
B2029 RF/Passenger seat motor #4 (rear vertical) circuit open
B2030 RF/Passenger seat motor #5 (recline) circuit malfunction
B2031 RF/Passenger seat motor #5 (recline) circuit range/performance
B2032 RF/Passenger seat motor #5 (recline) circuit low
B2033 RF/Passenger seat motor #5 (recline) circuit high
B2034 RF/Passenger seat motor #5 (recline) circuit open
B2035 RF/Passenger seat motor #6 (lumbar; single motor or horizontal) circuit malfunction
B2036 RF/Passenger seat motor #6 (lumbar; single motor or horizontal) circuit range/perform
B2037 RF/Passenger seat motor #6 (lumbar; single motor or horizontal) circuit low
B2038 RF/Passenger seat motor #6 (lumbar; single motor or horizontal) circuit high
B2039 RF/Passenger seat motor #6 (lumbar; single motor or horizontal) circuit open
B2040 RF/Passenger seat motor #7 (head restraint horizontal) circuit malfunction
B2041 RF/Passenger seat motor #7 (head restraint horizontal) circuit range/performance
B2042 RF/Passenger seat motor #7 (head restraint horizontal) circuit low
B2043 RF/Passenger seat motor #7 (head restraint horizontal) circuit high
B2044 RF/Passenger seat motor #7 (head restraint horizontal) circuit open
B2045 RF/Passenger seat motor #8 (head restraint vertical) circuit malfunction
B2046 RF/Passenger seat motor #8 (head restraint vertical) circuit range/performance
B2047 RF/Passenger seat motor #8 (head restraint vertical) circuit low
B2048 RF/Passenger seat motor #8 (head restraint vertical) circuit high
B2049 RF/Passenger seat motor #8 (head restraint vertical) circuit open
B2050 RF/Passenger seat motor #9 (side bolster) circuit malfunction
B2051 RF/Passenger seat motor #9 (side bolster) circuit range/performance
B2052 RF/Passenger seat motor #9 (side bolster) circuit low
B2053 RF/Passenger seat motor #9 (side bolster) circuit high
B2054 RF/Passenger seat motor #9 (side bolster) circuit open
B2055 RF/Passenger seat motor #10 (thigh bolster) circuit malfunction
B2056 RF/Passenger seat motor #10 (thigh bolster) circuit range/performance
B2057 RF/Passenger seat motor #10 (thigh bolster) circuit low
B2058 RF/Passenger seat motor #10 (thigh bolster) circuit high
B2059 RF/Passenger seat motor #10 (thigh bolster) circuit open
B2060 RF/Passenger recline forward switch circuit malfunction
B2061 RF/Passenger recline forward switch circuit range/performance
B2062 RF/Passenger recline forward switch circuit low
B2063 RF/Passenger recline forward switch circuit high
B2064 RF/Passenger recline forward switch circuit open
B2065 RF/Passenger recline rearward switch circuit malfunction
B2066 RF/Passenger recline rearward switch circuit range/performance
B2067 RF/Passenger recline rearward switch circuit low
B2068 RF/Passenger recline rearward switch circuit high
B2069 RF/Passenger recline rearward switch circuit open
B2070 RF/Passenger recline sensor circuit malfunction
B2071 RF/Passenger recline sensor circuit range/performance
B2072 RF/Passenger recline sensor circuit low
B2073 RF/Passenger recline sensor circuit high
B2074 RF/Passenger recline sensor circuit open
B2075 RF/Passenger lumbar forward switch circuit malfunction
B2076 RF/Passenger lumbar forward switch circuit range/performance
B2077 RF/Passenger lumbar forward switch circuit low
B2078 RF/Passenger lumbar forward switch circuit high
B2079 RF/Passenger lumbar forward switch circuit open
B2080 RF/Passenger lumbar rearward switch circuit malfunction
B2081 RF/Passenger lumbar rearward switch circuit range/performance
B2082 RF/Passenger lumbar rearward switch circuit low
B2083 RF/Passenger lumbar rearward switch circuit high
B2084 RF/Passenger lumbar rearward switch circuit open
B2085 RF/Passenger lumbar up switch circuit malfunction
B2086 RF/Passenger lumbar up switch circuit range/performance
B2087 RF/Passenger lumbar up switch circuit low
B2088 RF/Passenger lumbar up switch circuit high
B2089 RF/Passenger lumbar up switch circuit open
B2090 RF/Passenger lumbar down switch circuit malfunction
B2091 RF/Passenger lumbar down switch circuit range/performance
B2092 RF/Passenger lumbar down switch circuit low
B2093 RF/Passenger lumbar down switch circuit high
B2094 RF/Passenger lumbar down switch circuit open
B2095 RF/Passenger lumbar horizontal sensor malfunction
B2096 RF/Passenger lumbar horizontal sensor range/performance
B2097 RF/Passenger lumbar horizontal sensor low
B2098 RF/Passenger lumbar horizontal sensor high
B2099 RF/Passenger lumbar horizontal sensor open
B2100 RF/Passenger lumbar horizontal feedback circuit malfunction
B2101 RF/Passenger lumbar horizontal feedback circuit range/performance
B2102 RF/Passenger lumbar horizontal feedback circuit low
B2103 RF/Passenger lumbar horizontal feedback circuit high
B2104 RF/Passenger lumbar horizontal feedback circuit open
B2105 RF/Passenger lumbar vertical sensor malfunction
B2106 RF/Passenger lumbar vertical sensor range/performance
B2107 RF/Passenger lumbar vertical sensor low
B2108 RF/Passenger lumbar vertical sensor high
B2109 RF/Passenger lumbar vertical sensor open
B2110 RF/Passenger lumbar vertical feedback circuit malfunction
B2111 RF/Passenger lumbar vertical feedback circuit range/performance
B2112 RF/Passenger lumbar vertical feedback circuit low
B2113 RF/Passenger lumbar vertical feedback circuit high
B2114 RF/Passenger lumbar vertical feedback circuit open
B2115 RF/Passenger head restraint up switch circuit malfunction
B2116 RF/Passenger head restraint up switch circuit range/performance
B2117 RF/Passenger head restraint up switch circuit low
B2118 RF/Passenger head restraint up switch circuit high
B2119 RF/Passenger head restraint up switch circuit open
B2120 RF/Passenger head restraint down switch circuit malfunction
B2121 RF/Passenger head restraint down switch circuit range/performance
B2122 RF/Passenger head restraint down switch circuit low
B2123 RF/Passenger head restraint down switch circuit high
B2124 RF/Passenger head restraint down switch circuit open
B2125 RF/Passenger head restraint forward switch circuit malfunction
B2126 RF/Passenger head restraint forward switch circuit range/performance
B2127 RF/Passenger head restraint forward switch circuit low
B2128 RF/Passenger head restraint forward switch circuit high
B2129 RF/Passenger head restraint forward switch circuit open
B2130 RF/Passenger head restraint rearward switch circuit malfunction
B2131 RF/Passenger head restraint rearward switch circuit range/performance
B2132 RF/Passenger head restraint rearward switch circuit low
B2133 RF/Passenger head restraint rearward switch circuit high
B2134 RF/Passenger head restraint rearward switch circuit open
B2135 RF/Passenger head restraint horizontal sensor malfunction
B2136 RF/Passenger head restraint horizontal sensor range/performance
B2137 RF/Passenger head restraint horizontal sensor low
B2138 RF/Passenger head restraint horizontal sensor high
B2139 RF/Passenger head restraint horizontal sensor open
B2140 RF/Passenger head restraint horizontal feedback circuit malfunction
B2141 RF/Passenger head restraint horizontal feedback circuit range/performance
B2142 RF/Passenger head restraint horizontal feedback circuit low
B2143 RF/Passenger head restraint horizontal feedback circuit high
B2144 RF/Passenger head restraint horizontal feedback circuit open
B2145 RF/Passenger head restraint vertical sensor malfunction
B2146 RF/Passenger head restraint vertical sensor range/performance
B2147 RF/Passenger head restraint vertical sensor low
B2148 RF/Passenger head restraint vertical sensor high
B2149 RF/Passenger head restraint vertical sensor open
B2150 RF/Passenger head restraint vertical feedback circuit malfunction
B2151 RF/Passenger head restraint vertical feedback circuit range/performance
B2152 RF/Passenger head restraint vertical feedback circuit low
B2153 RF/Passenger head restraint vertical feedback circuit high
B2154 RF/Passenger head restraint vertical feedback circuit open
B2155 RF/Passenger seat heater switch #1 (whole system or "low") circuit malfunction
B2156 RF/Passenger seat heater switch #1 (whole system or "low") circuit range/performance
B2157 RF/Passenger seat heater switch #1 (whole system or "low") circuit low
B2158 RF/Passenger seat heater switch #1 (whole system or "low") circuit high
B2159 RF/Passenger seat heater switch #1 (whole system or "low") circuit open
B2160 RF/Passenger seat heater switch #2 ("high") circuit malfunction
B2161 RF/Passenger seat heater switch #2 ("high") circuit range/performance
B2162 RF/Passenger seat heater switch #2 ("high") circuit low
B2163 RF/Passenger seat heater switch #2 ("high") circuit high
B2164 RF/Passenger seat heater switch #2 ("high") circuit open
B2165 RF/Passenger seat heater (whole seat or seat cushion) timer circuit malfunction
B2166 RF/Passenger seat heater (whole seat or seat cushion) timer circuit range/performance
B2167 RF/Passenger seat heater (whole seat or seat cushion) timer circuit low
B2168 RF/Passenger seat heater (whole seat or seat cushion) timer circuit high
B2169 RF/Passenger seat heater (whole seat or seat cushion) timer circuit open
B2170 RF/Passenger seat heater (whole seat or seat cushion) sensor malfunction
B2171 RF/Passenger seat heater (whole seat or seat cushion) sensor range/performance
B2172 RF/Passenger seat heater (whole seat or seat cushion) sensor low
B2173 RF/Passenger seat heater (whole seat or seat cushion) sensor high
B2174 RF/Passenger seat heater (whole seat or seat cushion) sensor open
B2175 RF/Passenger seat heater (whole seat or seat cushion) feedback circuit malfunction
B2176 RF/Passenger seat heater (whole seat or seat cushion) feedback circuit
range/performance
B2177 RF/Passenger seat heater (whole seat or seat cushion) feedback circuit low
B2178 RF/Passenger seat heater (whole seat or seat cushion) feedback circuit high
B2179 RF/Passenger seat heater (whole seat or seat cushion) feedback circuit open
B2180 RF/Passenger seat back heater malfunction
B2181 RF/Passenger seat back heater range/performance
B2182 RF/Passenger seat back heater low
B2183 RF/Passenger seat back heater high
B2184 RF/Passenger seat back heater open
B2185 RF/Passenger seat side bolster in switch circuit malfunction
B2186 RF/Passenger seat side bolster in switch circuit range/performance
B2187 RF/Passenger seat side bolster in switch circuit low
B2188 RF/Passenger seat side bolster in switch circuit high
B2189 RF/Passenger seat side bolster in switch circuit open
B2190 RF/Passenger seat side bolster out switch circuit malfunction
B2191 RF/Passenger seat side bolster out switch circuit range/performance
B2192 RF/Passenger seat side bolster out switch circuit low
B2193 RF/Passenger seat side bolster out switch circuit high
B2194 RF/Passenger seat side bolster out switch circuit open
B2195 RF/Passenger seat side bolster in circuit malfunction
B2196 RF/Passenger seat side bolster in circuit range/performance
B2197 RF/Passenger seat side bolster in circuit low
B2198 RF/Passenger seat side bolster in circuit high
B2199 RF/Passenger seat side bolster in circuit open
B2200 RF/Passenger seat side bolster out circuit malfunction
B2201 RF/Passenger seat side bolster out circuit range/performance
B2202 RF/Passenger seat side bolster out circuit low
B2203 RF/Passenger seat side bolster out circuit high
B2204 RF/Passenger seat side bolster out circuit open
B2205 RF/Passenger seat side bolster sensor malfunction
B2206 RF/Passenger seat side bolster sensor range/performance
B2207 RF/Passenger seat side bolster sensor low
B2208 RF/Passenger seat side bolster sensor high
B2209 RF/Passenger seat side bolster sensor open
B2210 RF/Passenger seat side bolster feedback circuit malfunction
B2211 RF/Passenger seat side bolster feedback circuit range/performance
B2212 RF/Passenger seat side bolster feedback circuit low
B2213 RF/Passenger seat side bolster feedback circuit high
B2214 RF/Passenger seat side bolster feedback circuit open
B2215 LR seat assembly forward switch circuit malfunction
B2216 LR seat assembly forward switch circuit range/performance
B2217 LR seat assembly forward switch circuit low
B2218 LR seat assembly forward switch circuit high
B2219 LR seat assembly forward switch circuit open
B2220 LR seat assembly rearward switch circuit malfunction
B2221 LR seat assembly rearward switch circuit range/performance
B2222 LR seat assembly rearward switch circuit low
B2223 LR seat assembly rearward switch circuit high
B2224 LR seat assembly rearward switch circuit open
B2225 LR seat motor #1 (ass'y. horizontal) circuit malfunction
B2226 LR seat motor #1 (ass'y. horizontal) circuit range/performance
B2227 LR seat motor #1 (ass'y. horizontal) circuit low
B2228 LR seat motor #1 (ass'y. horizontal) circuit high
B2229 LR seat motor #1 (ass'y. horizontal) circuit open
B2230 LR seat motor #2 (head restraint horizontal) circuit malfunction
B2231 LR seat motor #2 (head restraint horizontal) circuit range/performance
B2232 LR seat motor #2 (head restraint horizontal) circuit low
B2233 LR seat motor #2 (head restraint horizontal) circuit high
B2234 LR seat motor #2 (head restraint horizontal) circuit open
B2235 LR seat motor #3 (head restraint vertical) circuit malfunction
B2236 LR seat motor #3 (head restraint vertical) circuit range/performance
B2237 LR seat motor #3 (head restraint vertical) circuit low
B2238 LR seat motor #3 (head restraint vertical) circuit high
B2239 LR seat motor #3 (head restraint vertical) circuit open
B2240 LR head restraint up switch circuit malfunction
B2241 LR head restraint up switch circuit range/performance
B2242 LR head restraint up switch circuit low
B2243 LR head restraint up switch circuit high
B2244 LR head restraint up switch circuit open
B2245 LR head restraint down switch circuit malfunction
B2246 LR head restraint down switch circuit range/performance
B2247 LR head restraint down switch circuit low
B2248 LR head restraint down switch circuit high
B2249 LR head restraint down switch circuit open
B2250 LR head restraint forward switch circuit malfunction
B2251 LR head restraint forward switch circuit range/performance
B2252 LR head restraint forward switch circuit low
B2253 LR head restraint forward switch circuit high
B2254 LR head restraint forward switch circuit open
B2255 LR head restraint rearward switch circuit malfunction
B2256 LR head restraint rearward switch circuit range/performance
B2257 LR head restraint rearward switch circuit low
B2258 LR head restraint rearward switch circuit high
B2259 LR head restraint rearward switch circuit open
B2260 LR seat heater switch #1 (whole system or "low") circuit malfunction
B2261 LR seat heater switch #1 (whole system or "low") circuit range/performance
B2262 LR seat heater switch #1 (whole system or "low") circuit low
B2263 LR seat heater switch #1 (whole system or "low") circuit high
B2264 LR seat heater switch #1 (whole system or "low") circuit open
B2265 LR seat heater switch #2 ("high") circuit malfunction
B2266 LR seat heater switch #2 ("high") circuit range/performance
B2267 LR seat heater switch #2 ("high") circuit low
B2268 LR seat heater switch #2 ("high") circuit high
B2269 LR seat heater switch #2 ("high") circuit open
B2270 LR seat heater sensor malfunction
B2271 LR seat heater sensor range/performance
B2272 LR seat heater sensor low
B2273 LR seat heater sensor high
B2274 LR seat heater sensor open
B2275 LR seat heater feedback circuit malfunction
B2276 LR seat heater feedback circuit range/performance
B2277 LR seat heater feedback circuit low
B2278 LR seat heater feedback circuit high
B2279 LR seat heater feedback circuit open
B2280 RR seat assembly forward switch circuit malfunction
B2281 RR seat assembly forward switch circuit range/performance
B2282 RR seat assembly forward switch circuit low
B2283 RR seat assembly forward switch circuit high
B2284 RR seat assembly forward switch circuit open
B2285 RR seat assembly rearward switch circuit malfunction
B2286 RR seat assembly rearward switch circuit range/performance
B2287 RR seat assembly rearward switch circuit low
B2288 RR seat assembly rearward switch circuit high
B2289 RR seat assembly rearward switch circuit open
B2290 RR seat motor #1 (ass'y. horizontal) circuit malfunction
B2291 RR seat motor #1 (ass'y. horizontal) circuit range/performance
B2292 RR seat motor #1 (ass'y. horizontal) circuit low
B2293 RR seat motor #1 (ass'y. horizontal) circuit high
B2294 RR seat motor #1 (ass'y. horizontal) circuit open
B2295 RR seat motor #2 (head restraint horizontal) circuit malfunction
B2296 RR seat motor #2 (head restraint horizontal) circuit range/performance
B2297 RR seat motor #2 (head restraint horizontal) circuit low
B2298 RR seat motor #2 (head restraint horizontal) circuit high
B2299 RR seat motor #2 (head restraint horizontal) circuit open
B2300 RR seat motor #3 (head restraint vertical) circuit malfunction
B2301 RR seat motor #3 (head restraint vertical) circuit range/performance
B2302 RR seat motor #3 (head restraint vertical) circuit low
B2303 RR seat motor #3 (head restraint vertical) circuit high
B2304 RR seat motor #3 (head restraint vertical) circuit open
B2305 RR head restraint up switch circuit malfunction
B2306 RR head restraint up switch circuit range/performance
B2307 RR head restraint up switch circuit low
B2308 RR head restraint up switch circuit high
B2309 RR head restraint up switch circuit open
B2310 RR head restraint down switch circuit malfunction
B2311 RR head restraint down switch circuit range/performance
B2312 RR head restraint down switch circuit low
B2313 RR head restraint down switch circuit high
B2314 RR head restraint down switch circuit open
B2315 RR head restraint forward switch circuit malfunction
B2316 RR head restraint forward switch circuit range/performance
B2317 RR head restraint forward switch circuit low
B2318 RR head restraint forward switch circuit high
B2319 RR head restraint forward switch circuit open
B2320 RR head restraint rearward switch circuit malfunction
B2321 RR head restraint rearward switch circuit range/performance
B2322 RR head restraint rearward switch circuit low
B2323 RR head restraint rearward switch circuit high
B2324 RR head restraint rearward switch circuit open
B2325 RR seat heater switch #1 (whole system or "low") circuit malfunction
B2326 RR seat heater switch #1 (whole system or "low") circuit range/performance
B2327 RR seat heater switch #1 (whole system or "low") circuit low
B2328 RR seat heater switch #1 (whole system or "low") circuit high
B2329 RR seat heater switch #1 (whole system or "low") circuit open
B2330 RR seat heater switch #2 ("high") circuit malfunction
B2331 RR seat heater switch #2 ("high") circuit range/performance
B2332 RR seat heater switch #2 ("high") circuit low
B2333 RR seat heater switch #2 ("high") circuit high
B2334 RR seat heater switch #2 ("high") circuit open
B2335 RR seat heater sensor malfunction
B2336 RR seat heater sensor range/performance
B2337 RR seat heater sensor low
B2338 RR seat heater sensor high
B2339 RR seat heater sensor open
B2340 RR seat heater feedback circuit malfunction
B2341 RR seat heater feedback circuit range/performance
B2342 RR seat heater feedback circuit low
B2343 RR seat heater feedback circuit high
B2344 RR seat heater feedback circuit open
B2345 Front seat heater disable malfunction
B2346 Front seat heater disable range/performance
B2347 Front seat heater disable low
B2348 Front seat heater disable high
B2349 Front seat heater disable open
B2350 Rear seat heater disable malfunction
B2351 Rear seat heater disable range/performance
B2352 Rear seat heater disable low
B2353 Rear seat heater disable high
B2354 Rear seat heater disable open
B2355 LF/Driver front vertical sensor malfunction
B2356 LF/Driver front vertical sensor range/performance
B2357 LF/Driver front vertical sensor low
B2358 LF/Driver front vertical sensor high
B2359 LF/Driver front vertical sensor open
B2360 LF/Driver front vertical feedback circuit malfunction
B2361 LF/Driver front vertical feedback circuit range/performance
B2362 LF/Driver front vertical feedback circuit low
B2363 LF/Driver front vertical feedback circuit high
B2364 LF/Driver front vertical feedback circuit open
B2365 LF/Driver rear vertical sensor malfunction
B2366 LF/Driver rear vertical sensor range/performance
B2367 LF/Driver rear vertical sensor low
B2368 LF/Driver rear vertical sensor high
B2369 LF/Driver rear vertical sensor open
B2370 LF/Driver rear vertical feedback circuit malfunction
B2371 LF/Driver rear vertical feedback circuit range/performance
B2372 LF/Driver rear vertical feedback circuit low
B2373 LF/Driver rear vertical feedback circuit high
B2374 LF/Driver rear vertical feedback circuit open
B2375 LF/Driver seat assembly horizontal sensor malfunction
B2376 LF/Driver seat assembly horizontal sensor range/performance
B2377 LF/Driver seat assembly horizontal sensor low
B2378 LF/Driver seat assembly horizontal sensor high
B2379 LF/Driver seat assembly horizontal sensor open
B2380 LF/Driver seat assembly horizontal feedback circuit malfunction
B2381 LF/Driver seat assembly horizontal feedback circuit range/performance
B2382 LF/Driver seat assembly horizontal feedback circuit low
B2383 LF/Driver seat assembly horizontal feedback circuit high
B2384 LF/Driver seat assembly horizontal feedback circuit open
B2385 RF/Passenger front vertical sensor malfunction
B2386 RF/Passenger front vertical sensor range/performance
B2387 RF/Passenger front vertical sensor low
B2388 RF/Passenger front vertical sensor high
B2389 RF/Passenger front vertical sensor open
B2390 RF/Passenger front vertical feedback circuit malfunction
B2391 RF/Passenger front vertical feedback circuit range/performance
B2392 RF/Passenger front vertical feedback circuit low
B2393 RF/Passenger front vertical feedback circuit high
B2394 RF/Passenger front vertical feedback circuit open
B2395 RF/Passenger rear vertical sensor malfunction
B2396 RF/Passenger rear vertical sensor range/performance
B2397 RF/Passenger rear vertical sensor low
B2398 RF/Passenger rear vertical sensor high
B2399 RF/Passenger rear vertical sensor open
B2400 RF/Passenger rear vertical feedback circuit malfunction
B2401 RF/Passenger rear vertical feedback circuit range/performance
B2402 RF/Passenger rear vertical feedback circuit low
B2403 RF/Passenger rear vertical feedback circuit high
B2404 RF/Passenger rear vertical feedback circuit open
B2405 RF/Passenger seat assembly horizontal sensor malfunction
B2406 RF/Passenger seat assembly horizontal sensor range/performance
B2407 RF/Passenger seat assembly horizontal sensor low
B2408 RF/Passenger seat assembly horizontal sensor high
B2409 RF/Passenger seat assembly horizontal sensor open
B2410 RF/Passenger seat assembly horizontal feedback circuit malfunction
B2411 RF/Passenger seat assembly horizontal feedback circuit range/performance
B2412 RF/Passenger seat assembly horizontal feedback circuit low
B2413 RF/Passenger seat assembly horizontal feedback circuit high
B2414 RF/Passenger seat assembly horizontal feedback circuit open
B2415 LF/Driver seat motor #11 (lumbar, vertical) circuit malfunction
B2416 LF/Driver seat motor #11 (lumbar, vertical) circuit range/performance
B2417 LF/Driver seat motor #11 (lumbar, vertical) circuit low
B2418 LF/Driver seat motor #11 (lumbar, vertical) circuit high
B2419 LF/Driver seat motor #11 (lumbar, vertical) circuit open
B2420 RF/Passenger seat motor #11 (lumbar, vertical) circuit malfunction
B2421 RF/Passenger seat motor #11 (lumbar, vertical) circuit range/performance
B2422 RF/Passenger seat motor #11 (lumbar, vertical) circuit low
B2423 RF/Passenger seat motor #11 (lumbar, vertical) circuit high
B2424 RF/Passenger seat motor #11 (lumbar, vertical) circuit open
B2425 LF/Driver seat heater (whole seat or cushion) circuit malfunction
B2426 LF/Driver seat heater (whole seat or cushion) circuit range/performance
B2427 LF/Driver seat heater (whole seat or cushion) circuit low
B2428 LF/Driver seat heater (whole seat or cushion) circuit high
B2429 LF/Driver seat heater (whole seat or cushion) circuit open
B2430 RF/Passenger seat heater (whole seat or cushion) circuit malfunction
B2431 RF/Passenger seat heater (whole seat or cushion) circuit range/performance
B2432 RF/Passenger seat heater (whole seat or cushion) circuit low
B2433 RF/Passenger seat heater (whole seat or cushion) circuit high
B2434 RF/Passenger seat heater (whole seat or cushion) circuit open
B2435 LF/Driver seat back heater sensor malfunction
B2436 LF/Driver seat back heater sensor range/performance
B2437 LF/Driver seat back heater sensor low
B2438 LF/Driver seat back heater sensor high
B2439 LF/Driver seat back heater sensor open
B2440 RF/Passenger seat back heater sensor malfunction
B2441 RF/Passenger seat back heater sensor range/performance
B2442 RF/Passenger seat back heater sensor low
B2443 RF/Passenger seat back heater sensor high
B2444 RF/Passenger seat back heater sensor open
B2445 LF/Driver thigh bolster sensor malfunction
B2446 LF/Driver thigh bolster sensor range/performance
B2447 LF/Driver thigh bolster sensor low
B2448 LF/Driver thigh bolster sensor high
B2449 LF/Driver thigh bolster sensor open
B2450 Cellular phone handset (in-vehicle) circuit malfunction
B2451 Cellular phone handset (in-vehicle) circuit range/performance
B2452 Cellular phone handset (in-vehicle) circuit low
B2453 Cellular phone handset (in-vehicle) circuit high
B2454 Cellular phone handset (in-vehicle) circuit open
B2455 Cellular phone microphone circuit malfunction
B2456 Cellular phone microphone circuit range/performance
B2457 Cellular phone microphone circuit low
B2458 Cellular phone microphone circuit high
B2459 Cellular phone microphone circuit open
B2460 Navigation antenna selector circuit high current
B2461 Navigation ECU synchronous signal error
B2462 GPS signal error
B2463 Navigation CD player - no disk
B2464 Navigation CD player - decoding error
B2465 Navigation CD player - data error
B2466 Navigation VICS memory error
B2467 Cellular phone portable handset malfunction
B2468 Navigation Display Unit malfunction
B2469 Cellular phone unit malfunction
B2470 Cellular phone antenna circuit malfunction
B2471 Automatic dialing malfunction
B2472 Road assistance request switch circuit malfunction
B2473 Redundant road assistance request switch circuit malfunction
B2474 NDH backlighting malfunction
B2475 NDH auxiliary input malfunction
B2476 Cellular phone select service switch malfunction
B2477 Supplemental heater enable circuit malfunction
B2478 Security system status circuit malfunction
B2525 Front foglamps circuit malfunction
B2526 Front foglamps circuit range/performance
B2527 Front foglamps circuit low
B2528 Front foglamps circuit high
B2529 Front foglamps circuit open
B2530 Front foglamps control circuit malfunction
B2531 Front foglamps control circuit range/performance
B2532 Front foglamps control circuit low
B2533 Front foglamps control circuit high
B2534 Front foglamps control circuit open
B2535 Rear foglamps circuit malfunction
B2536 Rear foglamps circuit range/performance
B2537 Rear foglamps circuit low
B2538 Rear foglamps circuit high
B2539 Rear foglamps circuit open
B2540 Rear foglamps control circuit malfunction
B2541 Rear foglamps control circuit range/performance
B2542 Rear foglamps control circuit low
B2543 Rear foglamps control circuit high
B2544 Rear foglamps control circuit open
B2545 Backup lamps circuit malfunction
B2546 Backup lamps circuit range/performance
B2547 Backup lamps circuit low
B2548 Backup lamps circuit high
B2549 Backup lamps circuit open
B2550 Backup lamps control circuit malfunction
B2551 Backup lamps control circuit range/performance
B2552 Backup lamps control circuit low
B2553 Backup lamps control circuit high
B2554 Backup lamps control circuit open
B2555 Passenger compartment lamp control circuit malfunction
B2556 Passenger compartment lamp control circuit range/performance
B2557 Passenger compartment lamp control circuit low
B2558 Passenger compartment lamp control circuit high
B2559 Passenger compartment lamp control circuit open
B2560 Cargo lamp control circuit malfunction
B2561 Cargo lamp control circuit range/performance
B2562 Cargo lamp control circuit low
B2563 Cargo lamp control circuit high
B2564 Cargo lamp control circuit open
B2565 Underhood lamp control circuit malfunction
B2566 Underhood lamp control circuit range/performance
B2567 Underhood lamp control circuit low
B2568 Underhood lamp control circuit high
B2569 Underhood lamp control circuit open
B2570 Trunk/hatch lamp control circuit malfunction
B2571 Trunk/hatch lamp control circuit range/performance
B2572 Trunk/hatch lamp control circuit low
B2573 Trunk/hatch lamp control circuit high
B2574 Trunk/hatch lamp control circuit open
B2575 Headlamp control circuit malfunction
B2576 Headlamp control circuit range/performance
B2577 Headlamp control circuit low
B2578 Headlamp control circuit high
B2579 Headlamp control circuit open
B2580 Headlamp high beam control circuit malfunction
B2581 Headlamp high beam control circuit range/performance
B2582 Headlamp high beam control circuit low
B2583 Headlamp high beam control circuit high
B2584 Headlamp high beam control circuit open
B2585 Parklamp control circuit malfunction
B2586 Parklamp control circuit range/performance
B2587 Parklamp control circuit low
B2588 Parklamp control circuit high
B2589 Parklamp control circuit open
B2590 LH cornering lamp circuit malfunction
B2591 LH cornering lamp circuit range/performance
B2592 LH cornering lamp circuit low
B2593 LH cornering lamp circuit high
B2594 LH cornering lamp circuit open
B2595 RH cornering lamp circuit malfunction
B2596 RH cornering lamp circuit range/performance
B2597 RH cornering lamp circuit low
B2598 RH cornering lamp circuit high
B2599 RH cornering lamp circuit open
B2600 Daytime running lamp control #1 (LH or system) circuit malfunction
B2601 Daytime running lamp control #1 (LH or system) circuit range/performance
B2602 Daytime running lamp control #1 (LH or system) circuit low
B2603 Daytime running lamp control #1 (LH or system) circuit high
B2604 Daytime running lamp control #1 (LH or system) circuit open
B2605 Daytime running lamp control #2 (RH) circuit malfunction
B2606 Daytime running lamp control #2 (RH) circuit range/performance
B2607 Daytime running lamp control #2 (RH) circuit low
B2608 Daytime running lamp control #2 (RH) circuit high
B2609 Daytime running lamp control #2 (RH) circuit open
B2610 Passenger compartment dimming #1 (cluster, etc.) circuit malfunction
B2611 Passenger compartment dimming #1 (cluster, etc.) circuit range/performance
B2612 Passenger compartment dimming #1 (cluster, etc.) circuit low
B2613 Passenger compartment dimming #1 (cluster, etc.) circuit high
B2614 Passenger compartment dimming #1 (cluster, etc.) circuit open
B2615 Passenger compartment dimming #2 (dome lamp, etc.) circuit malfunction
B2616 Passenger compartment dimming #2 (dome lamp, etc.) circuit range/performance
B2617 Passenger compartment dimming #2 (dome lamp, etc.) circuit low
B2618 Passenger compartment dimming #2 (dome lamp, etc.) circuit high
B2619 Passenger compartment dimming #2 (dome lamp, etc.) circuit open
B2620 Display dimming PWM input circuit malfunction
B2621 Display dimming PWM input circuit range/performance
B2622 Display dimming PWM input circuit low
B2623 Display dimming PWM input circuit high
B2624 Display dimming PWM input circuit open
B2625 Display dimming PWM output circuit malfunction
B2626 Display dimming PWM output circuit range/performance
B2627 Display dimming PWM output circuit low
B2628 Display dimming PWM output circuit high
B2629 Display dimming PWM output circuit open
B2630 Illuminated entry enable circuit malfunction
B2631 Illuminated entry enable circuit range/performance
B2632 Illuminated entry enable circuit low
B2633 Illuminated entry enable circuit high
B2634 Illuminated entry enable circuit open
B2635 Illuminated entry output circuit malfunction
B2636 Illuminated entry output circuit range/performance
B2637 Illuminated entry output circuit low
B2638 Illuminated entry output circuit high
B2639 Illuminated entry output circuit open
B2640 Delayed exterior lighting control circuit malfunction
B2641 Delayed exterior lighting control circuit range/performance
B2642 Delayed exterior lighting control circuit low
B2643 Delayed exterior lighting control circuit high
B2644 Delayed exterior lighting control circuit open
B2645 Ambient light sensor circuit malfunction
B2646 Ambient light sensor circuit range/performance
B2647 Ambient light sensor circuit low
B2648 Ambient light sensor circuit high
B2649 Ambient light sensor circuit open
B2650 LH DRL filament open
B2651 RH DRL filament open
B2652 Passenger compartment dimming #3 (dome lamp, etc.) circuit malfunction
B2653 Passenger compartment dimming #3 (dome lamp, etc.) circuit range/performance
B2654 Passenger compartment dimming #3 (dome lamp, etc.) circuit low
B2655 Passenger compartment dimming #3 (dome lamp, etc.) circuit high
B2656 Passenger compartment dimming #3 (dome lamp, etc.) circuit open
B2657 Ignition halo lamp output circuit malfunction
B2658 Ignition halo lamp output circuit range/performance
B2659 Ignition halo lamp output circuit low
B2660 Ignition halo lamp output circuit high
B2661 Ignition halo lamp output circuit open
B2662 Parklamp switch circuit malfunction
B2663 Parklamp switch circuit range/performance
B2664 Parklamp switch circuit low
B2665 Parklamp switch circuit high
B2666 Parklamp switch circuit open
B2667 AHLD LH servo driver terminal #1 circuit malfunction
B2668 AHLD LH servo driver terminal #1 circuit range/performance
B2669 AHLD LH servo driver terminal #1 circuit low
B2670 AHLD LH servo driver terminal #1 circuit high
B2671 AHLD LH servo driver terminal #1 circuit open
B2672 AHLD LH servo driver terminal #2 circuit malfunction
B2673 AHLD LH servo driver terminal #2 circuit range/performance
B2674 AHLD LH servo driver terminal #2 circuit low
B2675 AHLD LH servo driver terminal #2 circuit high
B2676 AHLD LH servo driver terminal #2 circuit open
B2677 AHLD RH servo driver terminal #1 circuit malfunction
B2678 AHLD RH servo driver terminal #1 circuit range/performance
B2679 AHLD RH servo driver terminal #1 circuit low
B2680 AHLD RH servo driver terminal #1 circuit high
B2681 AHLD RH servo driver terminal #1 circuit open
B2682 AHLD RH servo driver terminal #2 circuit malfunction
B2683 AHLD RH servo driver terminal #2 circuit range/performance
B2684 AHLD RH servo driver terminal #2 circuit low
B2685 AHLD RH servo driver terminal #2 circuit high
B2686 AHLD RH servo driver terminal #2 circuit open
B2687 AHLD LH position sensor signal circuit malfunction
B2688 AHLD LH position sensor signal circuit range/performance
B2689 AHLD LH position sensor signal circuit low
B2690 AHLD LH position sensor signal circuit high
B2691 AHLD LH position sensor signal circuit open
B2692 AHLD LH position sensor supply circuit malfunction
B2693 AHLD LH position sensor supply circuit range/performance
B2694 AHLD LH position sensor supply circuit low
B2695 AHLD LH position sensor supply circuit high
B2696 AHLD LH position sensor supply circuit open
B2697 Headlamp washer request circuit malfunction
B2700 Ignition shift interlock circuit malfunction
B2701 Ignition shift interlock circuit range/performance
B2702 Ignition shift interlock circuit low
B2703 Ignition shift interlock circuit high
B2704 Ignition shift interlock circuit open
B2705 Gearshift unlock circuit malfunction
B2706 Gearshift unlock circuit range/performance
B2707 Gearshift unlock circuit low
B2708 Gearshift unlock circuit high
B2709 Gearshift unlock circuit open
B2710 Gearshift lock circuit malfunction
B2711 Gearshift lock circuit range/performance
B2712 Gearshift lock circuit low
B2713 Gearshift lock circuit high
B2714 Gearshift lock circuit open
B2715 Gearshift override circuit malfunction
B2716 Gearshift override circuit range/performance
B2717 Gearshift override circuit low
B2718 Gearshift override circuit high
B2719 Gearshift override circuit open
B2720 Transmission preference switch circuit malfunction
B2721 Transmission preference switch circuit range/performance
B2722 Transmission preference switch circuit low
B2723 Transmission preference switch circuit high
B2724 Transmission preference switch circuit open
B2725 ATC mode switch circuit malfunction
B2726 ATC mode switch circuit range/performance
B2727 ATC mode switch circuit low
B2728 ATC mode switch circuit high
B2729 ATC mode switch circuit open
B2730 Trunk release switch circuit malfunction
B2731 Trunk release switch circuit range/performance
B2732 Trunk release switch circuit low
B2733 Trunk release switch circuit high
B2734 Trunk release switch circuit open
B2735 Fuel door release switch circuit malfunction
B2736 Fuel door release switch circuit range/performance
B2737 Fuel door release switch circuit low
B2738 Fuel door release switch circuit high
B2739 Fuel door release switch circuit open
B2740 Foglamp switch circuit malfunction
B2741 Foglamp switch circuit range/performance
B2742 Foglamp switch circuit low
B2743 Foglamp switch circuit high
B2744 Foglamp switch circuit open
B2745 Traction control switch circuit malfunction
B2746 Traction control switch circuit range/performance
B2747 Traction control switch circuit low
B2748 Traction control switch circuit high
B2749 Traction control switch circuit open
B2750 Horn relay coil circuit malfunction
B2751 Horn relay coil circuit range/performance
B2752 Horn relay coil circuit low
B2753 Horn relay coil circuit high
B2754 Horn relay coil circuit open
B2755 LF/Driver memory 1 select switch circuit malfunction
B2756 LF/Driver memory 1 select switch circuit range/performance
B2757 LF/Driver memory 1 select switch circuit low
B2758 LF/Driver memory 1 select switch circuit high
B2759 LF/Driver memory 1 select switch circuit open
B2760 LF/Driver memory 2 select switch circuit malfunction
B2761 LF/Driver memory 2 select switch circuit range/performance
B2762 LF/Driver memory 2 select switch circuit low
B2763 LF/Driver memory 2 select switch circuit high
B2764 LF/Driver memory 2 select switch circuit open
B2765 LF/Driver memory set switch circuit malfunction
B2766 LF/Driver memory set switch circuit range/performance
B2767 LF/Driver memory set switch circuit low
B2768 LF/Driver memory set switch circuit high
B2769 LF/Driver memory set switch circuit open
B2770 LF/Driver memory exit/off switch circuit malfunction
B2771 LF/Driver memory exit/off switch circuit range/performance
B2772 LF/Driver memory exit/off switch circuit low
B2773 LF/Driver memory exit/off switch circuit high
B2774 LF/Driver memory exit/off switch circuit open
B2775 RF/Passenger memory 1 select switch circuit malfunction
B2776 RF/Passenger memory 1 select switch circuit range/performance
B2777 RF/Passenger memory 1 select switch circuit low
B2778 RF/Passenger memory 1 select switch circuit high
B2779 RF/Passenger memory 1 select switch circuit open
B2780 RF/Passenger memory 2 select switch circuit malfunction
B2781 RF/Passenger memory 2 select switch circuit range/performance
B2782 RF/Passenger memory 2 select switch circuit low
B2783 RF/Passenger memory 2 select switch circuit high
B2784 RF/Passenger memory 2 select switch circuit open
B2785 RF/Passenger memory set switch circuit malfunction
B2786 RF/Passenger memory set switch circuit range/performance
B2787 RF/Passenger memory set switch circuit low
B2788 RF/Passenger memory set switch circuit high
B2789 RF/Passenger memory set switch circuit open
B2790 RF/Passenger memory exit/off switch circuit malfunction
B2791 RF/Passenger memory exit/off switch circuit range/performance
B2792 RF/Passenger memory exit/off switch circuit low
B2793 RF/Passenger memory exit/off switch circuit high
B2794 RF/Passenger memory exit/off switch circuit open
B2795 Suspension control select switch circuit malfunction
B2796 Suspension control select switch circuit range/performance
B2797 Suspension control select switch circuit low
B2798 Suspension control select switch circuit high
B2799 Suspension control select switch circuit open
B2800 Suspension control select switch feedback malfunction
B2801 Suspension control select switch feedback range/performance
B2802 Suspension control select switch feedback low
B2803 Suspension control select switch feedback high
B2804 Suspension control select switch feedback open
B2805 Steering wheel controls HVAC switch circuit malfunction
B2806 Steering wheel controls HVAC switch circuit range/performance
B2807 Steering wheel controls HVAC switch circuit low
B2808 Steering wheel controls HVAC switch circuit high
B2809 Steering wheel controls HVAC switch circuit open
B2810 Steering wheel controls entertainment circuit malfunction
B2811 Steering wheel controls entertainment circuit range/performance
B2812 Steering wheel controls entertainment circuit low
B2813 Steering wheel controls entertainment circuit high
B2814 Steering wheel controls entertainment circuit open
B2815 Steering wheel controls illegal resistance value
B2816 Low tire pressure system reset circuit malfunction
B2817 Low tire pressure system reset circuit range/performance
B2818 Low tire pressure system reset circuit low
B2819 Low tire pressure system reset circuit high
B2820 Low tire pressure system reset circuit open
B2821 Trip odometer reset switch circuit malfunction
B2822 Trip odometer reset switch circuit range/performance
B2823 Trip odometer reset switch circuit low
B2824 Trip odometer reset switch circuit high
B2825 Trip odometer reset switch circuit open
B2826 DIC fuel info switch circuit malfunction
B2827 DIC fuel info switch circuit range/performance
B2828 DIC fuel info switch circuit low
B2829 DIC fuel info switch circuit high
B2830 DIC fuel info switch circuit open
B2831 DIC gage switch circuit malfunction
B2832 DIC gage switch circuit range/performance
B2833 DIC gage switch circuit low
B2834 DIC gage switch circuit high
B2835 DIC gage switch circuit open
B2836 DIC reset switch circuit malfunction
B2837 DIC reset switch circuit range/performance
B2838 DIC reset switch circuit low
B2839 DIC reset switch circuit high
B2840 DIC reset switch circuit open
B2841 DIC English/Metric switch circuit malfunction
B2842 DIC English/Metric switch circuit range/performance
B2843 DIC English/Metric switch circuit low
B2844 DIC English/Metric switch circuit high
B2845 DIC English/Metric switch circuit open
B2846 DIC Trip/Season odometer switch circuit malfunction
B2847 DIC Trip/Season odometer switch circuit range/performance
B2848 DIC Trip/Season odometer switch circuit low
B2849 DIC Trip/Season odometer switch circuit high
B2850 Telescope forward switch circuit malfunction
B2851 Telescope forward switch circuit range/performance
B2852 Telescope forward switch circuit low
B2853 Telescope forward switch circuit high
B2854 Telescope forward switch circuit open
B2855 Telescope rearward switch circuit malfunction
B2856 Telescope rearward switch circuit range/performance
B2857 Telescope rearward switch circuit low
B2858 Telescope rearward switch circuit high
B2859 Telescope rearward switch circuit open
B2860 Telescope position sensor malfunction
B2861 Telescope position sensor range/performance
B2862 Telescope position sensor low
B2863 Telescope position sensor high
B2864 Telescope position sensor open
B2865 Telescope position feedback circuit malfunction
B2866 Telescope position feedback circuit range/performance
B2867 Telescope position feedback circuit low
B2868 Telescope position feedback circuit high
B2869 Telescope position feedback circuit open
B2870 Tilt up switch circuit malfunction
B2871 Tilt up switch circuit range/performance
B2872 Tilt up switch circuit low
B2873 Tilt up switch circuit high
B2874 Tilt up switch circuit open
B2875 Tilt down switch circuit malfunction
B2876 Tilt down switch circuit range/performance
B2877 Tilt down switch circuit low
B2878 Tilt down switch circuit high
B2879 Tilt down switch circuit open
B2880 Tilt position sensor malfunction
B2881 Tilt position sensor range/performance
B2882 Tilt position sensor low
B2883 Tilt position sensor high
B2884 Tilt position sensor open
B2885 Tilt position feedback circuit malfunction
B2886 Tilt position feedback circuit range/performance
B2887 Tilt position feedback circuit low
B2888 Tilt position feedback circuit high
B2889 Tilt position feedback circuit open
B2890 Tilt & telescope motor circuit malfunction
B2891 Tilt & telescope motor circuit range/performance
B2892 Tilt & telescope motor circuit low
B2893 Tilt & telescope motor circuit high
B2894 Tilt & telescope motor circuit open
B2895 Tilt & telescope motor overcurrent
B2896 Tilt & telescope motor protection active
B2897 Steering column lock solenoid/motor circuit malfunction
B2898 Steering column lock solenoid/motor circuit range/performance
B2899 Steering column lock solenoid/motor circuit low
B2900 Steering column lock solenoid/motor circuit high
B2901 Steering column lock solenoid/motor circuit open
B2902 Tilt & telescope 4-way position switch circuit malfunction
B2903 Tilt & telescope 4-way position switch circuit range/performance
B2904 Tilt & telescope 4-way position switch circuit low
B2905 Tilt & telescope 4-way position switch circuit high
B2906 Tilt & telescope 4-way position switch circuit open
B2925 Security system enable/arm (local) circuit malfunction
B2926 Security system enable/arm (local) circuit range/performance
B2927 Security system enable/arm (local) circuit low
B2928 Security system enable/arm (local) circuit high
B2929 Security system enable/arm (local) circuit open
B2930 Security system disable/disarm (local) circuit malfunction
B2931 Security system disable/disarm (local) circuit range/performance
B2932 Security system disable/disarm (local) circuit low
B2933 Security system disable/disarm (local) circuit high
B2934 Security system disable/disarm (local) circuit open
B2935 Security system enable/arm (remote) circuit malfunction
B2936 Security system enable/arm (remote) circuit range/performance
B2937 Security system enable/arm (remote) circuit low
B2938 Security system enable/arm (remote) circuit high
B2939 Security system enable/arm (remote) circuit open
B2940 Security system disable/disarm (remote) circuit malfunction
B2941 Security system disable/disarm (remote) circuit range/performance
B2942 Security system disable/disarm (remote) circuit low
B2943 Security system disable/disarm (remote) circuit high
B2944 Security system disable/disarm (remote) circuit open
B2945 Security system sensor (Passkey/Passlock/etc.) power circuit malfunction
B2946 Security system sensor (Passkey/Passlock/etc.) power circuit range/performance
B2947 Security system sensor (Passkey/Passlock/etc.) power circuit low
B2948 Security system sensor (Passkey/Passlock/etc.) power circuit high
B2949 Security system sensor (Passkey/Passlock/etc.) power circuit open
B2950 Security system sensor (Passkey/Passlock/etc.) ground circuit malfunction
B2951 Security system sensor (Passkey/Passlock/etc.) ground circuit range/performance
B2952 Security system sensor (Passkey/Passlock/etc.) ground circuit low
B2953 Security system sensor (Passkey/Passlock/etc.) ground circuit high
B2954 Security system sensor (Passkey/Passlock/etc.) ground circuit open
B2955 Security system sensor (Passkey/Passlock/etc.) data circuit malfunction
B2956 Security system sensor (Passkey/Passlock/etc.) data circuit range/performance
B2957 Security system sensor (Passkey/Passlock/etc.) data circuit low
B2958 Security system sensor (Passkey/Passlock/etc.) data circuit high
B2959 Security system sensor (Passkey/Passlock/etc.) data circuit open
B2960 Security system sensor (Passkey/Passlock/etc.) data incorrect but valid
B2961 Key in ignition circuit malfunction
B2962 Key in ignition circuit range/performance
B2963 Key in ignition circuit low
B2964 Key in ignition circuit high
B2965 Key in ignition circuit open
B2966 LF door handle switch circuit malfunction
B2967 LF door handle switch circuit range/performance
B2968 LF door handle switch circuit low
B2969 LF door handle switch circuit high
B2970 LF door handle switch circuit open
B2971 LF door key switch circuit malfunction
B2972 LF door key switch circuit range/performance
B2973 LF door key switch circuit low
B2974 LF door key switch circuit high
B2975 LF door key switch circuit open
B2976 LF door ajar circuit malfunction
B2977 LF door ajar circuit range/performance
B2978 LF door ajar circuit low
B2979 LF door ajar circuit high
B2980 LF door ajar circuit open
B2981 RF door handle switch circuit malfunction
B2982 RF door handle switch circuit range/performance
B2983 RF door handle switch circuit low
B2984 RF door handle switch circuit high
B2985 RF door handle switch circuit open
B2986 RF door key switch circuit malfunction
B2987 RF door key switch circuit range/performance
B2988 RF door key switch circuit low
B2989 RF door key switch circuit high
B2990 RF door key switch circuit open
B2991 RF door ajar circuit malfunction
B2992 RF door ajar circuit range/performance
B2993 RF door ajar circuit low
B2994 RF door ajar circuit high
B2995 RF door ajar circuit open
B2996 LR door ajar circuit malfunction
B2997 LR door ajar circuit range/performance
B2998 LR door ajar circuit low
B2999 LR door ajar circuit high
B3000 LR door ajar circuit open
B3001 RR door ajar circuit malfunction
B3002 RR door ajar circuit range/performance
B3003 RR door ajar circuit low
B3004 RR door ajar circuit high
B3005 RR door ajar circuit open
B3006 Hood ajar circuit malfunction
B3007 Hood ajar circuit range/performance
B3008 Hood ajar circuit low
B3009 Hood ajar circuit high
B3010 Hood ajar circuit open
B3011 Trunk/liftglass/hatch ajar circuit malfunction
B3012 Trunk/liftglass/hatch ajar circuit range/performance
B3013 Trunk/liftglass/hatch ajar circuit low
B3014 Trunk/liftglass/hatch ajar circuit high
B3015 Trunk/liftglass/hatch ajar circuit open
B3016 Door key switches (LF/RF) circuit malfunction
B3017 Door key switches (LF/RF) circuit range/performance
B3018 Door key switches (LF/RF) circuit low
B3019 Door key switches (LF/RF) circuit high
B3020 Door key switches (LF/RF) circuit open
B3021 Fuel enable circuit malfunction
B3022 Fuel enable circuit range/performance
B3023 Fuel enable circuit low
B3024 Fuel enable circuit high
B3025 Fuel enable circuit open
B3026 Starter enable circuit malfunction
B3027 Starter enable circuit range/performance
B3028 Starter enable circuit low
B3029 Starter enable circuit high
B3030 Starter enable circuit open
B3031 Security system controller in learn mode
B3032 Security system fail enable entered
B3033 Security system indicates tamper
B3034 Security system inoperative
B3035 Door handle switches (LF/RF) circuit malfunction
B3036 Door handle switches (LF/RF) circuit range/performance
B3037 Door handle switches (LF/RF) circuit low
B3038 Door handle switches (LF/RF) circuit high
B3039 Door handle switches (LF/RF) circuit open
B3040 Immobilizer-ECM communication circuit malfunction
B3041 Immobilizer-ECM communication circuit range/performance
B3042 Immobilizer-ECM communication circuit low
B3043 Immobilizer-ECM communication circuit high
B3044 Immobilizer-ECM communication circuit open
B3045 DWA-immobilizer circuit malfunction
B3046 DWA-immobilizer circuit range/performance
B3047 DWA-immobilizer circuit low
B3048 DWA-immobilizer circuit high
B3049 DWA-immobilizer circuit open
B3050 Immobilizer external relay circuit malfunction
B3051 Immobilizer external relay circuit range/performance
B3052 Immobilizer external relay circuit low
B3053 Immobilizer external relay circuit high
B3054 Immobilizer external relay circuit open
B3055 No transponder modulation/no transponder
B3056 No transponder ID code programmed
B3057 No security code programmed
B3058 No secret key programmed
B3059 No request from ECM/PCM received
B3060 Unprogrammed transponder ID code received
B3061 Disturbed transponder ID code received
B3062 RF/LF door key lock switch circuit malfunction
B3063 RF/LF door key lock switch circuit range/performance
B3064 RF/LF door key lock switch circuit low
B3065 RF/LF door key lock switch circuit high
B3066 RF/LF door key lock switch circuit open
B3067 RF/LF door key unlock switch circuit malfunction
B3068 RF/LF door key unlock switch circuit range/performance
B3069 RF/LF door key unlock switch circuit low
B3070 RF/LF door key unlock switch circuit high
B3071 RF/LF door key unlock switch circuit open
B3072 Immobilizer request input circuit malfunction
B3073 Immobilizer request input circuit range/performance
B3074 Immobilizer request input circuit low
B3075 Immobilizer request input circuit high
B3076 Immobilizer request input circuit open
B3077 Fixcode transponder detected
B3078 Security system horn output circuit malfunction
B3079 Security system horn output circuit range/performance
B3080 Security system horn output circuit low
B3081 Security system horn output circuit high
B3082 Security system horn output circuit open
B3083 Incorrect PCM security password
B3084 Security system exterior lamps control circuit malfunction
B3085 Security system exterior lamps control circuit range/performance
B3086 Security system exterior lamps control circuit low
B3087 Security system exterior lamps control circuit high
B3088 Security system exterior lamps control circuit open
B3089 Content theft system sensor (Shock/Intrusion/etc.) signal circuit malfunction
B3090 Content theft system sensor (Shock/Intrusion/etc.) signal circuit range/performance
B3091 Content theft system sensor (Shock/Intrusion/etc.) signal circuit low
B3092 Content theft system sensor (Shock/Intrusion/etc.) signal circuit high
B3093 Content theft system sensor (Shock/Intrusion/etc.) signal circuit open
B3094 No response from ECM/PCM received
B3095 Content theft system sensor (Shock/Intrusion/etc.) power circuit malfunction
B3096 Content theft system sensor (Shock/Intrusion/etc.) power circuit range/performance
B3097 Content theft system sensor (Shock/Intrusion/etc.) power circuit low
B3098 Content theft system sensor (Shock/Intrusion/etc.) power circuit high
B3099 Content theft system sensor (Shock/Intrusion/etc.) power circuit open
B3100 Keyless entry data link circuit malfunction
B3101 Keyless entry data link circuit range/performance
B3102 Keyless entry data link circuit low
B3103 Keyless entry data link circuit high
B3104 Keyless entry data link circuit open
B3105 Keyless entry system key fobs not programmed
B3106 Keyless entry data link parity error
B3107 Keyless entry invalid transmitter ID
B3108 Keyless entry transmitter synchronization failure
B3109 Keyless entry transmitter low battery
B3125 LF door only unlock circuit malfunction
B3126 LF door only unlock circuit range/performance
B3127 LF door only unlock circuit low
B3128 LF door only unlock circuit high
B3129 LF door only unlock circuit open
B3130 All door unlock circuit malfunction
B3131 All door unlock circuit range/performance
B3132 All door unlock circuit low
B3133 All door unlock circuit high
B3134 All door unlock circuit open
B3135 All door lock circuit malfunction
B3136 All door lock circuit range/performance
B3137 All door lock circuit low
B3138 All door lock circuit high
B3139 All door lock circuit open
B3140 LF unlock switch circuit malfunction
B3141 LF unlock switch circuit range/performance
B3142 LF unlock switch circuit low
B3143 LF unlock switch circuit high
B3144 LF unlock switch circuit open
B3145 RF/Passenger unlock switch circuit malfunction
B3146 RF/Passenger unlock switch circuit range/performance
B3147 RF/Passenger unlock switch circuit low
B3148 RF/Passenger unlock switch circuit high
B3149 RF/Passenger unlock switch circuit open
B3150 LF lock switch circuit malfunction
B3151 LF lock switch circuit range/performance
B3152 LF lock switch circuit low
B3153 LF lock switch circuit high
B3154 LF lock switch circuit open
B3155 RF lock switch circuit malfunction
B3156 RF lock switch circuit range/performance
B3157 RF lock switch circuit low
B3158 RF lock switch circuit high
B3159 RF lock switch circuit open
B3160 LF window up switch (at door) circuit malfunction
B3161 LF window up switch (at door) circuit range/performance
B3162 LF window up switch (at door) circuit low
B3163 LF window up switch (at door) circuit high
B3164 LF window up switch (at door) circuit open
B3165 LF window down switch (at door) circuit malfunction
B3166 LF window down switch (at door) circuit range/performance
B3167 LF window down switch (at door) circuit low
B3168 LF window down switch (at door) circuit high
B3169 LF window down switch (at door) circuit open
B3170 RF window up switch (at door) circuit malfunction
B3171 RF window up switch (at door) circuit range/performance
B3172 RF window up switch (at door) circuit low
B3173 RF window up switch (at door) circuit high
B3174 RF window up switch (at door) circuit open
B3175 RF window down switch (at door) circuit malfunction
B3176 RF window down switch (at door) circuit range/performance
B3177 RF window down switch (at door) circuit low
B3178 RF window down switch (at door) circuit high
B3179 RF window down switch (at door) circuit open
B3180 LR window up switch (at door) circuit malfunction
B3181 LR window up switch (at door) circuit range/performance
B3182 LR window up switch (at door) circuit low
B3183 LR window up switch (at door) circuit high
B3184 LR window up switch (at door) circuit open
B3185 LR window down switch (at door) circuit malfunction
B3186 LR window down switch (at door) circuit range/performance
B3187 LR window down switch (at door) circuit low
B3188 LR window down switch (at door) circuit high
B3189 LR window down switch (at door) circuit open
B3190 RR window up switch (at door) circuit malfunction
B3191 RR window up switch (at door) circuit range/performance
B3192 RR window up switch (at door) circuit low
B3193 RR window up switch (at door) circuit high
B3194 RR window up switch (at door) circuit open
B3195 RR window down switch (at door) circuit malfunction
B3196 RR window down switch (at door) circuit range/performance
B3197 RR window down switch (at door) circuit low
B3198 RR window down switch (at door) circuit high
B3199 RR window down switch (at door) circuit open
B3200 Rear window lockout switch circuit malfunction
B3201 Rear window lockout switch circuit range/performance
B3202 Rear window lockout switch circuit low
B3203 Rear window lockout switch circuit high
B3204 Rear window lockout switch circuit open
B3205 LF/Driver window motor circuit malfunction
B3206 LF/Driver window motor circuit range/performance
B3207 LF/Driver window motor circuit low
B3208 LF/Driver window motor circuit high
B3209 LF/Driver window motor circuit open
B3210 RF/Passenger window motor circuit malfunction
B3211 RF/Passenger window motor circuit range/performance
B3212 RF/Passenger window motor circuit low
B3213 RF/Passenger window motor circuit high
B3214 RF/Passenger window motor circuit open
B3215 LR window motor circuit malfunction
B3216 LR window motor circuit range/performance
B3217 LR window motor circuit low
B3218 LR window motor circuit high
B3219 LR window motor circuit open
B3220 RR window motor circuit malfunction
B3221 RR window motor circuit range/performance
B3222 RR window motor circuit low
B3223 RR window motor circuit high
B3224 RR window motor circuit open
B3225 LF lock motor circuit malfunction
B3226 LF lock motor circuit range/performance
B3227 LF lock motor circuit low
B3228 LF lock motor circuit high
B3229 LF lock motor circuit open
B3230 RF lock motor circuit malfunction
B3231 RF lock motor circuit range/performance
B3232 RF lock motor circuit low
B3233 RF lock motor circuit high
B3234 RF lock motor circuit open
B3235 LR lock motor circuit malfunction
B3236 LR lock motor circuit range/performance
B3237 LR lock motor circuit low
B3238 LR lock motor circuit high
B3239 LR lock motor circuit open
B3240 RR lock motor circuit malfunction
B3241 RR lock motor circuit range/performance
B3242 RR lock motor circuit low
B3243 RR lock motor circuit high
B3244 RR lock motor circuit open
B3245 Cargo door/liftgate lock motor circuit malfunction
B3246 Cargo door/liftgate lock motor circuit range/performance
B3247 Cargo door/liftgate lock motor circuit low
B3248 Cargo door/liftgate lock motor circuit high
B3249 Cargo door/liftgate lock motor circuit open
B3250 Power sliding door position circuit malfunction
B3251 Power sliding door position circuit range/performance
B3252 Power sliding door position circuit low
B3253 Power sliding door position circuit high
B3254 Power sliding door position circuit open
B3255 Power sliding door sensor circuit malfunction
B3256 Power sliding door sensor circuit range/performance
B3257 Power sliding door sensor circuit low
B3258 Power sliding door sensor circuit high
B3259 Power sliding door sensor circuit open
B3260 Power sliding door secondary latch circuit malfunction
B3261 Power sliding door secondary latch circuit range/performance
B3262 Power sliding door secondary latch circuit low
B3263 Power sliding door secondary latch circuit high
B3264 Power sliding door secondary latch circuit open
B3265 Trunk release output circuit malfunction
B3266 Trunk release output circuit range/performance
B3267 Trunk release output circuit low
B3268 Trunk release output circuit high
B3269 Trunk release output circuit open
B3270 RF/LF door lock/unlock switch circuit malfunction
B3271 RF/LF door lock/unlock switch circuit range/performance
B3272 RF/LF door lock/unlock switch circuit low
B3273 RF/LF door lock/unlock switch circuit high
B3274 RF/LF door lock/unlock switch circuit open
B3275 LF window express up/down circuit (at door) malfunction
B3276 LF window express up/down circuit (at door) range/performance
B3277 LF window express up/down circuit (at door) low
B3278 LF window express up/down circuit (at door) high
B3279 LF window express up/down circuit (at door) open
B3280 RF window express up/down circuit (at door) malfunction
B3281 RF window express up/down circuit (at door) range/performance
B3282 RF window express up/down circuit (at door) low
B3283 RF window express up/down circuit (at door) high
B3284 RF window express up/down circuit (at door) open
B3285 LR window express up/down circuit (at door) malfunction
B3286 LR window express up/down circuit (at door) range/performance
B3287 LR window express up/down circuit (at door) low
B3288 LR window express up/down circuit (at door) high
B3289 LR window express up/down circuit (at door) open
B3290 RR window express up/down circuit (at door) malfunction
B3291 RR window express up/down circuit (at door) range/performance
B3292 RR window express up/down circuit (at door) low
B3293 RR window express up/down circuit (at door) high
B3294 RR window express up/down circuit (at door) open
B3295 LF window express up circuit (at door) malfunction
B3296 LF window express up circuit (at door) range/performance
B3297 LF window express up circuit (at door) low
B3298 LF window express up circuit (at door) high
B3299 LF window express up circuit (at door) open
B3300 RF window express up circuit (at door) malfunction
B3301 RF window express up circuit (at door) range/performance
B3302 RF window express up circuit (at door) low
B3303 RF window express up circuit (at door) high
B3304 RF window express up circuit (at door) open
B3305 LR window express up circuit (at door) malfunction
B3306 LR window express up circuit (at door) range/performance
B3307 LR window express up circuit (at door) low
B3308 LR window express up circuit (at door) high
B3309 LR window express up circuit (at door) open
B3310 RR window express up circuit (at door) malfunction
B3311 RR window express up circuit (at door) range/performance
B3312 RR window express up circuit (at door) low
B3313 RR window express up circuit (at door) high
B3314 RR window express up circuit (at door) open
B3315 LF window express down circuit (at door) malfunction
B3316 LF window express down circuit (at door) range/performance
B3317 LF window express down circuit (at door) low
B3318 LF window express down circuit (at door) high
B3319 LF window express down circuit (at door) open
B3320 RF window express down circuit (at door) malfunction
B3321 RF window express down circuit (at door) range/performance
B3322 RF window express down circuit (at door) low
B3323 RF window express down circuit (at door) high
B3324 RF window express down circuit (at door) open
B3325 LR window express down circuit (at door) malfunction
B3326 LR window express down circuit (at door) range/performance
B3327 LR window express down circuit (at door) low
B3328 LR window express down circuit (at door) high
B3329 LR window express down circuit (at door) open
B3330 RR window express down circuit (at door) malfunction
B3331 RR window express down circuit (at door) range/performance
B3332 RR window express down circuit (at door) low
B3333 RR window express down circuit (at door) high
B3334 RR window express down circuit (at door) open
B3335 LR unlock switch circuit malfunction
B3336 LR unlock switch circuit range/performance
B3337 LR unlock switch circuit low
B3338 LR unlock switch circuit high
B3339 LR unlock switch circuit open
B3340 RR unlock switch circuit malfunction
B3341 RR unlock switch circuit range/performance
B3342 RR unlock switch circuit low
B3343 RR unlock switch circuit high
B3344 RR unlock switch circuit open
B3345 LR lock switch circuit malfunction
B3346 LR lock switch circuit range/performance
B3347 LR lock switch circuit low
B3348 LR lock switch circuit high
B3349 LR lock switch circuit open
B3350 RR lock switch circuit malfunction
B3351 RR lock switch circuit range/performance
B3352 RR lock switch circuit low
B3353 RR lock switch circuit high
B3354 RR lock switch circuit open
B3355 LF window obstruction sensor supply circuit malfunction
B3356 LF window obstruction sensor supply circuit range/performance
B3357 LF window obstruction sensor supply circuit low
B3358 LF window obstruction sensor supply circuit high
B3359 LF window obstruction sensor supply circuit open
B3360 RF window obstruction sensor supply circuit malfunction
B3361 RF window obstruction sensor supply circuit range/performance
B3362 RF window obstruction sensor supply circuit low
B3363 RF window obstruction sensor supply circuit high
B3364 RF window obstruction sensor supply circuit open
B3365 LR window obstruction sensor supply circuit malfunction
B3366 LR window obstruction sensor supply circuit range/performance
B3367 LR window obstruction sensor supply circuit low
B3368 LR window obstruction sensor supply circuit high
B3369 LR window obstruction sensor supply circuit open
B3370 RR window obstruction sensor supply circuit malfunction
B3371 RR window obstruction sensor supply circuit range/performance
B3372 RR window obstruction sensor supply circuit low
B3373 RR window obstruction sensor supply circuit high
B3374 RR window obstruction sensor supply circuit open
B3375 LF window up switch (main cntl) circuit malfunction
B3376 LF window up switch (main cntl) circuit range/performance
B3377 LF window up switch (main cntl) circuit low
B3378 LF window up switch (main cntl) circuit high
B3379 LF window up switch (main cntl) circuit open
B3380 LF window down switch (main cntl) circuit malfunction
B3381 LF window down switch (main cntl) circuit range/performance
B3382 LF window down switch (main cntl) circuit low
B3383 LF window down switch (main cntl) circuit high
B3384 LF window down switch (main cntl) circuit open
B3385 RF window up switch (main cntl) circuit malfunction
B3386 RF window up switch (main cntl) circuit range/performance
B3387 RF window up switch (main cntl) circuit low
B3388 RF window up switch (main cntl) circuit high
B3389 RF window up switch (main cntl) circuit open
B3390 RF window down switch (main cntl) circuit malfunction
B3391 RF window down switch (main cntl) circuit range/performance
B3392 RF window down switch (main cntl) circuit low
B3393 RF window down switch (main cntl) circuit high
B3394 RF window down switch (main cntl) circuit open
B3395 LR window up switch (main cntl) circuit malfunction
B3396 LR window up switch (main cntl) circuit range/performance
B3397 LR window up switch (main cntl) circuit low
B3398 LR window up switch (main cntl) circuit high
B3399 LR window up switch (main cntl) circuit open
B3400 AHLD RH position sensor signal circuit malfunction
B3401 AHLD RH position sensor signal circuit range/performance
B3402 AHLD RH position sensor signal circuit low
B3403 AHLD RH position sensor signal circuit high
B3404 AHLD RH position sensor signal circuit open
B3405 AHLD RH position sensor supply circuit malfunction
B3406 AHLD RH position sensor supply circuit range/performance
B3407 AHLD RH position sensor supply circuit low
B3408 AHLD RH position sensor supply circuit high
B3409 AHLD RH position sensor supply circuit open
B3410 AHLD front axle sensor signal circuit malfunction
B3411 AHLD front axle sensor signal circuit range/performance
B3412 AHLD front axle sensor signal circuit low
B3413 AHLD front axle sensor signal circuit high
B3414 AHLD front axle sensor signal circuit open
B3415 AHLD front axle sensor supply circuit malfunction
B3416 AHLD front axle sensor supply circuit range/performance
B3417 AHLD front axle sensor supply circuit low
B3418 AHLD front axle sensor supply circuit high
B3419 AHLD front axle sensor supply circuit open
B3420 AHLD rear axle sensor signal circuit malfunction
B3421 AHLD rear axle sensor signal circuit range/performance
B3422 AHLD rear axle sensor signal circuit low
B3423 AHLD rear axle sensor signal circuit high
B3424 AHLD rear axle sensor signal circuit open
B3425 AHLD rear axle sensor supply circuit malfunction
B3426 AHLD rear axle sensor supply circuit range/performance
B3427 AHLD rear axle sensor supply circuit low
B3428 AHLD rear axle sensor supply circuit high
B3429 AHLD rear axle sensor supply circuit open
B3430 AHLD low beam input circuit malfunction
B3431 AHLD low beam input circuit range/performance
B3432 AHLD low beam input circuit low
B3433 AHLD low beam input circuit high
B3434 AHLD low beam input circuit open
B3435 AHLD LH servo driver (#1 and/or #2) circuit malfunction
B3436 AHLD LH servo driver (#1 and/or #2) circuit range/performance
B3437 AHLD LH servo driver (#1 and/or #2) circuit low
B3438 AHLD LH servo driver (#1 and/or #2) circuit high
B3439 AHLD LH servo driver (#1 and/or #2) circuit open
B3440 AHLD RH servo driver (#1 and/or #2) circuit malfunction
B3441 AHLD RH servo driver (#1 and/or #2) circuit range/performance
B3442 AHLD RH servo driver (#1 and/or #2) circuit low
B3443 AHLD RH servo driver (#1 and/or #2) circuit high
B3444 AHLD RH servo driver (#1 and/or #2) circuit open
B3445 Stoplamp circuit malfunction
B3446 Stoplamp circuit range/performance
B3447 Stoplamp circuit low
B3448 Stoplamp circuit high
B3449 Stoplamp circuit open
B3450 LR window down switch (main cntl) circuit malfunction
B3451 LR window down switch (main cntl) circuit range/performance
B3452 LR window down switch (main cntl) circuit low
B3453 LR window down switch (main cntl) circuit high
B3454 LR window down switch (main cntl) circuit open
B3455 RR window up switch (main cntl) circuit malfunction
B3456 RR window up switch (main cntl) circuit range/performance
B3457 RR window up switch (main cntl) circuit low
B3458 RR window up switch (main cntl) circuit high
B3459 RR window up switch (main cntl) circuit open
B3460 RR window down switch (main cntl) circuit malfunction
B3461 RR window down switch (main cntl) circuit range/performance
B3462 RR window down switch (main cntl) circuit low
B3463 RR window down switch (main cntl) circuit high
B3464 RR window down switch (main cntl) circuit open
B3465 LF window express up/down circuit (main cntl) malfunction
B3466 LF window express up/down circuit (main cntl) range/performance
B3467 LF window express up/down circuit (main cntl) low
B3468 LF window express up/down circuit (main cntl) high
B3469 LF window express up/down circuit (main cntl) open
B3470 RF window express up/down circuit (main cntl) malfunction
B3471 RF window express up/down circuit (main cntl) range/performance
B3472 RF window express up/down circuit (main cntl) low
B3473 RF window express up/down circuit (main cntl) high
B3474 RF window express up/down circuit (main cntl) open
B3475 LR window express up/down circuit (main cntl) malfunction
B3476 LR window express up/down circuit (main cntl) range/performance
B3477 LR window express up/down circuit (main cntl) low
B3478 LR window express up/down circuit (main cntl) high
B3479 LR window express up/down circuit (main cntl) open
B3480 RR window express up/down circuit (main cntl) malfunction
B3481 RR window express up/down circuit (main cntl) range/performance
B3482 RR window express up/down circuit (main cntl) low
B3483 RR window express up/down circuit (main cntl) high
B3484 RR window express up/down circuit (main cntl) open
B3485 LF window express up circuit (main cntl) malfunction
B3486 LF window express up circuit (main cntl) range/performance
B3487 LF window express up circuit (main cntl) low
B3488 LF window express up circuit (main cntl) high
B3489 LF window express up circuit (main cntl) open
B3490 RF window express up circuit (main cntl) malfunction
B3491 RF window express up circuit (main cntl) range/performance
B3492 RF window express up circuit (main cntl) low
B3493 RF window express up circuit (main cntl) high
B3494 RF window express up circuit (main cntl) open
B3495 LR window express up circuit (main cntl) malfunction
B3496 LR window express up circuit (main cntl) range/performance
B3497 LR window express up circuit (main cntl) low
B3498 LR window express up circuit (main cntl) high
B3499 LR window express up circuit (main cntl) open
B3500 RR window express up circuit (main cntl) malfunction
B3501 RR window express up circuit (main cntl) range/performance
B3502 RR window express up circuit (main cntl) low
B3503 RR window express up circuit (main cntl) high
B3504 RR window express up circuit (main cntl) open
B3505 LF window express down circuit (main cntl) malfunction
B3506 LF window express down circuit (main cntl) range/performance
B3507 LF window express down circuit (main cntl) low
B3508 LF window express down circuit (main cntl) high
B3509 LF window express down circuit (main cntl) open
B3510 RF window express down circuit (main cntl) malfunction
B3511 RF window express down circuit (main cntl) range/performance
B3512 RF window express down circuit (main cntl) low
B3513 RF window express down circuit (main cntl) high
B3514 RF window express down circuit (main cntl) open
B3515 LR window express down circuit (main cntl) malfunction
B3516 LR window express down circuit (main cntl) range/performance
B3517 LR window express down circuit (main cntl) low
B3518 LR window express down circuit (main cntl) high
B3519 LR window express down circuit (main cntl) open
B3520 RR window express down circuit (main cntl) malfunction
B3521 RR window express down circuit (main cntl) range/performance
B3522 RR window express down circuit (main cntl) low
B3523 RR window express down circuit (main cntl) high
B3524 RR window express down circuit (main cntl) open
B3525 Window lockout switch circuit malfunction
B3526 Window lockout switch circuit range/performance
B3527 Window lockout switch circuit low
B3528 Window lockout switch circuit high
B3529 Window lockout switch circuit open
B3530 DIC Trip/Season odometer switch circuit open
B3531 Air flow control #10 (rear) circuit malfunction
B3532 Air flow control #10 (rear) circuit range/performance
B3533 Air flow control #10 (rear) circuit low
B3534 Air flow control #10 (rear) circuit high
B3535 Air flow control #10 (rear) circuit open
B3536 Oil life reset switch circuit malfunction
B3537 Oil life reset switch circuit range/performance
B3538 Oil life reset switch circuit low
B3539 Oil life reset switch circuit high
B3540 Oil life reset switch circuit open
B3541 DRL filament open
B3542 LF window obstruction sensor control circuit malfunction
B3543 LF window obstruction sensor control circuit range/performance
B3544 LF window obstruction sensor control circuit low
B3545 LF window obstruction sensor control circuit high
B3546 LF window obstruction sensor control circuit open
B3547 RF window obstruction sensor control circuit malfunction
B3548 RF window obstruction sensor control circuit range/performance
B3549 RF window obstruction sensor control circuit low
B3550 RF window obstruction sensor control circuit high
B3551 RF window obstruction sensor control circuit open
B3552 LR window obstruction sensor control circuit malfunction
B3553 LR window obstruction sensor control circuit range/performance
B3554 LR window obstruction sensor control circuit low
B3555 LR window obstruction sensor control circuit high
B3556 LR window obstruction sensor control circuit open
B3557 RR window obstruction sensor control circuit malfunction
B3558 RR window obstruction sensor control circuit range/performance
B3559 RR window obstruction sensor control circuit low
B3560 RR window obstruction sensor control circuit high
B3561 RR window obstruction sensor control circuit open
B3562 DIC mode switch circuit malfunction
B3563 DIC mode switch circuit range/performance
B3564 DIC mode switch circuit low
B3565 DIC mode switch circuit high
B3566 DIC mode switch circuit open
B3567 DIC select switch circuit malfunction
B3568 DIC select switch circuit range/performance
B3569 DIC select switch circuit low
B3570 DIC select switch circuit high
B3571 DIC select switch circuit open
B3572 Trip odometer A/B (trip odo 1 & 2) select switch circuit malfunction
B3573 Trip odometer A/B (trip odo 1 & 2) select switch circuit range/performance
B3574 Trip odometer A/B (trip odo 1 & 2) select switch circuit low
B3575 Trip odometer A/B (trip odo 1 & 2) select switch circuit high
B3576 Trip odometer A/B (trip odo 1 & 2) select switch circuit open
B3577 Suspension control select switch contact malfunction
B3578 Output air temperature sensor #6 (rear upper) circuit malfunction
B3579 Output air temperature sensor #6 (rear upper) circuit range/performance
B3580 Output air temperature sensor #6 (rear upper) circuit low
B3581 Output air temperature sensor #6 (rear upper) circuit high
B3582 Output air temperature sensor #6 (rear upper) circuit open
B3583 Output air temperature sensor #7 (rear lower) circuit malfunction
B3584 Output air temperature sensor #7 (rear lower) circuit range/performance
B3585 Output air temperature sensor #7 (rear lower) circuit low
B3586 Output air temperature sensor #7 (rear lower) circuit high
B3587 Output air temperature sensor #7 (rear lower) circuit open
B3588 Rear foglamp switch circuit malfunction
B3589 Rear foglamp switch circuit range/performance
B3590 Rear foglamp switch circuit low
B3591 Rear foglamp switch circuit high
B3592 Rear foglamp switch circuit open
B3700 Intermittent wiper delay input circuit malfunction
B3701 Intermittent wiper delay input circuit range/performance
B3702 Intermittent wiper delay input circuit low
B3703 Intermittent wiper delay input circuit high
B3704 Intermittent wiper delay input circuit open
B3705 Front washer motor input circuit malfunction
B3706 Front washer motor input circuit range/performance
B3707 Front washer motor input circuit low
B3708 Front washer motor input circuit high
B3709 Front washer motor input circuit open
B3710 Rear washer motor input circuit malfunction
B3711 Rear washer motor input circuit range/performance
B3712 Rear washer motor input circuit low
B3713 Rear washer motor input circuit high
B3714 Rear washer motor input circuit open
B3715 Front wiper relay drive circuit malfunction
B3716 Front wiper relay drive circuit range/performance
B3717 Front wiper relay drive circuit low
B3718 Front wiper relay drive circuit high
B3719 Front wiper relay drive circuit open
B3720 Rear wiper relay drive circuit malfunction
B3721 Rear wiper relay drive circuit range/performance
B3722 Rear wiper relay drive circuit low
B3723 Rear wiper relay drive circuit high
B3724 Rear wiper relay drive circuit open
B3725 LF/Driver seat assembly vertical control switch malfunction
B3726 LF/Driver seat front vertical control switch malfunction
B3727 LF/Driver seat rear vertical control switch malfunction
B3728 LF/Driver seat assembly horizontal control switch malfunction
B3729 LF/Driver seat recline control switch malfunction
B3730 LF/Driver seat lumbar horizontal control switch malfunction
B3731 LF/Driver seat lumbar vertical control switch malfunction
B3732 LF/Driver seat head restraint horizontal control switch malfunction
B3733 LF/Driver seat head restraint vertical control switch malfunction
B3734 RF/Passenger seat assembly vertical control switch malfunction
B3735 RF/Passenger seat front vertical control switch malfunction
B3736 RF/Passenger seat rear vertical control switch malfunction
B3737 RF/Passenger seat assembly horizontal control switch malfunction
B3738 RF/Passenger seat recline control switch malfunction
B3739 RF/Passenger seat lumbar horizontal control switch malfunction
B3740 RF/Passenger seat lumbar vertical control switch malfunction
B3741 RF/Passenger seat head restraint horizontal control switch malfunction
B3742 RF/Passenger seat head restraint vertical control switch malfunction
B3750 DIC on/off signal circuit malfunction
B3751 DIC on/off signal circuit range/performance
B3752 DIC on/off signal circuit low
B3753 DIC on/off signal circuit high
B3754 DIC on/off signal circuit open
B3755 Air flow control #1 (defrost) feedback circuit malfunction
B3756 Air flow control #1 (defrost) feedback circuit low
B3757 Air flow control #1 (defrost) feedback circuit high
B3758 Air flow control #2 (heater) feedback circuit malfunction
B3759 Air flow control #2 (heater) feedback circuit low
B3760 Air flow control #2 (heater) feedback circuit high
B3761 Air flow control #3 (blend defog/floor) feedback circuit malfunction
B3762 Air flow control #3 (blend defog/floor) feedback circuit low
B3763 Air flow control #3 (blend defog/floor) feedback circuit high
B3764 Air flow control #4 (blend face/floor) feedback circuit malfunction
B3765 Air flow control #4 (blend face/floor) feedback circuit low
B3766 Air flow control #4 (blend face/floor) feedback circuit high
B3767 Air flow control #5 (vent) feedback circuit malfunction
B3768 Air flow control #5 (vent) feedback circuit low
B3769 Air flow control #5 (vent) feedback circuit high
B3770 Air flow control #6 (A/C) feedback circuit malfunction
B3771 Air flow control #6 (A/C) feedback circuit low
B3772 Air flow control #6 (A/C) feedback circuit high
B3773 Air flow control #7 (recirc) feedback circuit malfunction
B3774 Air flow control #7 (recirc) feedback circuit low
B3775 Air flow control #7 (recirc) feedback circuit high
B3776 Air flow control #8 (rear defog airflow) feedback circuit malfunction
B3777 Air flow control #8 (rear defog airflow) feedback circuit low
B3778 Air flow control #8 (rear defog airflow) feedback circuit high
B3779 Air flow control #9 (dual zone) feedback circuit malfunction
B3780 Air flow control #9 (dual zone) feedback circuit low
B3781 Air flow control #9 (dual zone) feedback circuit high
B3782 Air flow control #10 (rear) feedback circuit malfunction
B3783 Air flow control #10 (rear) feedback circuit low
B3784 Air flow control #10 (rear) feedback circuit high
B3785 Blower Motor #1 (main/primary/front) Relay Control Circuit Malfunction
B3786 Blower Motor #1 (main/primary/front) Relay Control Circuit Range/Performance
B3787 Blower Motor #1 (main/primary/front) Relay Control Circuit Low
B3788 Blower Motor #1 (main/primary/front) Relay Control Circuit High
B3789 Blower Motor #1 (main/primary/front) Relay Control Circuit Open
B3790 LF/Driver seat side bolster control switch malfunction
B3791 LF/Driver seat thigh bolster control switch malfunction
B3792 LF/Driver seat switch circuit malfunction
B3793 Front wiper speed select circuit malfunction
B3794 Cruise control function request circuit malfunction
B3795 Left / right turn signal feedback circuit malfunction
B3796 Door lock motors circuit malfunction
B3797 All door dead lock circuit malfunction
B3798 RF / Passenger door unlock circuit malfunction
B3799 Front / rear washer rear wiper select circuit malfunction
B3800 Left / right turn signal request circuit malfunction
B3801 Passenger compartment lamp request circuit malfunction
B3802 Parklamps request circuit malfunction
B3803 All windows up circuit malfunction
B3804 LF / Driver door handle position invalid
B3805 All door unlock crash sensor circuit malfunction
B3806 Headlamps highbeam and flash to pass select circuit malfunction
B3807 Headlamp position control PWM circuit malfunction
B3808 Rear door lock relay circuit malfunction
B3809 Rear door unlock relay circuit malfunction
B3810 Headlamp washer relay circuit malfunction
B3811 Rear washer relay circuit malfunction
B3812 Content theft system sensor (Shock/Intrusion/etc.) ground circuit malfunction
B3813 Content theft system sensor (Shock/Intrusion/etc.) ground circuit range/performance
B3814 Content theft system sensor (Shock/Intrusion/etc.) ground circuit low
B3815 Content theft system sensor (Shock/Intrusion/etc.) ground circuit high
B3816 Content theft system sensor (Shock/Intrusion/etc.) ground circuit open
B3817 Door lock status circuit malfunction
B3818 Door unlock status circuit malfunction
B3819 Left rear window up control circuit malfunction
B3820 Left rear window down control circuit malfunction
B3821 Left rear window relay power circuit malfunction
B3822 Right rear window up control circuit malfunction
B3823 Right rear window down control circuit malfunction B3824 Right rear window relay power circuit malfunction
B3825 Cargo door/liftgate lock request circuit malfunction
B3826 Cargo door/liftgate unlock request circuit malfunction
B3827 Front wiper status circuit malfunction
B3828 LF/Driver belt tower up switch circuit malfunction
B3829 LF/Driver belt tower down switch circuit malfunction
B3830 LF/Driver belt tower vertical sensor circuit malfunction
B3831 LF/Driver belt tower vertical sensor circuit range/performance
C0000 Vehicle speed information circuit malfunction
C0001 Vehicle speed information circuit range/performance
C0002 Vehicle speed information circuit low
C0003 Vehicle speed information circuit high
C0004 Vehicle speed information circuit open
C0005 In "Park" switch circuit malfunction
C0006 In "Park" switch circuit range/performance
C0007 In "Park" switch circuit low
C0008 In "Park" switch circuit high
C0009 In "Park" switch circuit open
C0035 LF wheel speed sensor circuit malfunction
C0036 LF wheel speed sensor circuit range/performance
C0037 LF wheel speed sensor circuit low
C0038 LF wheel speed sensor circuit high
C0039 LF wheel speed sensor circuit open
C0040 RF wheel speed sensor circuit malfunction
C0041 RF wheel speed sensor circuit range/performance
C0042 RF wheel speed sensor circuit low
C0043 RF wheel speed sensor circuit high
C0044 RF wheel speed sensor circuit open
C0045 LR wheel speed sensor circuit malfunction
C0046 LR wheel speed sensor circuit range/performance
C0047 LR wheel speed sensor circuit low
C0048 LR wheel speed sensor circuit high
C0049 LR wheel speed sensor circuit open
C0050 RR wheel speed sensor circuit malfunction
C0051 RR wheel speed sensor circuit range/performance
C0052 RR wheel speed sensor circuit low
C0053 RR wheel speed sensor circuit high
C0054 RR wheel speed sensor circuit open
C0055 Rear wheel speed sensor (both wheels) circuit malfunction
C0056 Rear wheel speed sensor (both wheels) circuit range/performance
C0057 Rear wheel speed sensor (both wheels) circuit low
C0058 Rear wheel speed sensor (both wheels) circuit high
C0059 Rear wheel speed sensor (both wheels) circuit open
C0060 LF ABS solenoid/motor #1 circuit malfunction
C0061 LF ABS solenoid/motor #1 circuit range/performance
C0062 LF ABS solenoid/motor/ #1 circuit low
C0063 LF ABS solenoid/motor #1 circuit high
C0064 LF ABS solenoid/motor #1 circuit open
C0065 LF ABS solenoid/motor #2 circuit malfunction
C0066 LF ABS solenoid/motor #2 circuit range/performance
C0067 LF ABS solenoid/motor #2 circuit low
C0068 LF ABS solenoid/motor #2 circuit high
C0069 LF ABS solenoid/motor #2 circuit open
C0070 RF ABS solenoid/motor #1 circuit malfunction
C0071 RF ABS solenoid/motor #1 circuit range/performance
C0072 RF ABS solenoid/motor #1 circuit low
C0073 RF ABS solenoid/motor #1 circuit high
C0074 RF ABS solenoid/motor #1 circuit open
C0075 RF ABS solenoid/motor #2 circuit malfunction
C0076 RF ABS solenoid/motor #2 circuit range/performance
C0077 RF ABS solenoid/motor #2 circuit low
C0078 RF ABS solenoid/motor #2 circuit high
C0079 RF ABS solenoid/motor #2 circuit open
C0080 LR ABS solenoid/motor #1 circuit malfunction
C0081 LR ABS solenoid/motor #1 circuit range/performance
C0082 LR ABS solenoid/motor #1 circuit low
C0083 LR ABS solenoid/motor #1 circuit high
C0084 LR ABS solenoid/motor #1 circuit open
C0085 LR ABS solenoid/motor #2 circuit malfunction
C0086 LR ABS solenoid/motor #2 circuit range/performance
C0087 LR ABS solenoid/motor #2 circuit low
C0088 LR ABS solenoid/motor #2 circuit high
C0089 LR ABS solenoid/motor #2 circuit open
C0090 RR ABS solenoid/motor #1 circuit malfunction
C0091 RR ABS solenoid/motor #1 circuit range/performance
C0092 RR ABS solenoid/motor #1 circuit low
C0093 RR ABS solenoid/motor #1 circuit high
C0094 RR ABS solenoid/motor #1 circuit open
C0095 RR ABS solenoid/motor #2 circuit malfunction
C0096 RR ABS solenoid/motor #2 circuit range/performance
C0097 RR ABS solenoid/motor #2 circuit low
C0098 RR ABS solenoid/motor #2 circuit high
C0099 RR ABS solenoid/motor #2 circuit open
C0100 Rear ABS (both wheels) solenoid/motor #1 circuit malfunction
C0101 Rear ABS (both wheels) solenoid/motor #1 circuit range/performance
C0102 Rear ABS (both wheels) solenoid/motor #1 circuit low
C0103 Rear ABS (both wheels) solenoid/motor #1 circuit high
C0104 Rear ABS (both wheels) solenoid/motor #1 circuit open
C0105 Rear ABS (both wheels) solenoid/motor #2 circuit malfunction
C0106 Rear ABS (both wheels) solenoid/motor #2 circuit range/performance
C0107 Rear ABS (both wheels) solenoid/motor #2 circuit low
C0108 Rear ABS (both wheels) solenoid/motor #2 circuit high
C0109 Rear ABS (both wheels) solenoid/motor #2 circuit open
C0110 Pump motor circuit malfunction
C0111 Pump motor circuit range/performance
C0112 Pump motor circuit low
C0113 Pump motor circuit high
C0114 Pump motor circuit open
C0115 Pump motor malfunction
C0116 Pump motor relay circuit malfunction
C0117 Pump motor relay circuit range/performance
C0118 Pump motor relay circuit low
C0119 Pump motor relay circuit high
C0120 Pump motor relay circuit open
C0121 Valve relay circuit malfunction
C0122 Valve relay circuit range/performance
C0123 Valve relay circuit low
C0124 Valve relay circuit high
C0125 Valve relay circuit open
C0126 Low brake fluid circuit malfunction
C0127 Low brake fluid circuit range/performance
C0128 Low brake fluid circuit low
C0129 Low brake fluid circuit high
C0130 Low brake fluid circuit open
C0131 ABS/TCS system pressure circuit malfunction
C0132 ABS/TCS system pressure circuit range/performance
C0133 ABS/TCS system pressure circuit low
C0134 ABS/TCS system pressure circuit high
C0135 ABS/TCS system pressure circuit open
C0136 Base brake system pressure circuit malfunction
C0137 Base brake system pressure circuit range/performance
C0138 Base brake system pressure circuit low
C0139 Base brake system pressure circuit high
C0140 Base brake system pressure circuit open
C0141 LH TCS solenoid/motor #1 circuit malfunction
C0142 LH TCS solenoid/motor #1 circuit range/performance
C0143 LH TCS solenoid/motor #1 circuit low
C0144 LH TCS solenoid/motor #1 circuit high
C0145 LH TCS solenoid/motor #1 circuit open
C0146 LH TCS solenoid/motor #2 circuit malfunction
C0147 LH TCS solenoid/motor #2 circuit range/performance
C0148 LH TCS solenoid/motor #2 circuit low
C0149 LH TCS solenoid/motor #2 circuit high
C0150 LH TCS solenoid/motor #2 circuit open
C0151 RH TCS solenoid/motor #1 circuit malfunction
C0152 RH TCS solenoid/motor #1 circuit range/performance
C0153 RH TCS solenoid/motor #1 circuit low
C0154 RH TCS solenoid/motor #1 circuit high
C0155 RH TCS solenoid/motor #1 circuit open
C0156 RH TCS solenoid/motor #2 circuit malfunction
C0157 RH TCS solenoid/motor #2 circuit range/performance
C0158 RH TCS solenoid/motor #2 circuit low
C0159 RH TCS solenoid/motor #2 circuit high
C0160 RH TCS solenoid/motor #2 circuit open
C0161 ABS/TCS brake switch circuit malfunction
C0162 ABS/TCS brake switch circuit range/performance
C0163 ABS/TCS brake switch circuit low
C0164 ABS/TCS brake switch circuit high
C0165 ABS/TCS brake switch circuit open
C0166 TCS priming line valve circuit malfunction
C0167 TCS priming line valve circuit range/performance
C0168 TCS priming line valve circuit low
C0169 TCS priming line valve circuit high
C0170 TCS priming line valve circuit open
C0171 TCS pilot valve circuit malfunction
C0172 TCS pilot valve circuit range/performance
C0173 TCS pilot valve circuit low
C0174 TCS pilot valve circuit high
C0175 TCS pilot valve circuit open
C0176 System thermal malfunction
C0177 System thermal range/performance
C0178 System thermal low
C0179 System thermal high
C0180 System thermal open
C0181 Throttle reduction motor circuit malfunction
C0182 Throttle reduction motor circuit range/performance
C0183 Throttle reduction motor circuit low
C0184 Throttle reduction motor circuit high
C0185 Throttle reduction motor circuit open
C0186 Lateral accelerometer circuit malfunction
C0187 Lateral accelerometer circuit range/performance
C0188 Lateral accelerometer circuit low
C0189 Lateral accelerometer circuit high
C0190 Lateral accelerometer circuit open
C0191 4wd/AWD reference accelerometer circuit malfunction
C0192 4wd/AWD reference accelerometer circuit range/performance
C0193 4wd/AWD reference accelerometer circuit low
C0194 4wd/AWD reference accelerometer circuit high
C0195 4wd/AWD reference accelerometer circuit open
C0196 Yaw rate circuit malfunction
C0197 Yaw rate circuit range/performance
C0198 Yaw rate circuit low
C0199 Yaw rate circuit high
C0200 Yaw rate circuit open
C0201 ABS enable relay contact circuit malfunction
C0202 ABS enable relay contact circuit range/performance
C0203 ABS enable relay contact circuit low
C0204 ABS enable relay contact circuit high
C0205 ABS enable relay contact circuit open
C0206 ABS enable relay coil circuit malfunction
C0207 ABS enable relay coil circuit range/performance
C0208 ABS enable relay coil circuit low
C0209 ABS enable relay coil circuit high
C0210 ABS enable relay coil circuit open
C0211 LF ESB malfunction
C0212 LF ESB will not hold motor
C0213 RF ESB malfunction
C0214 RF ESB will not hold motor
C0215 Rear ESB (both wheels) malfunction
C0216 Rear ESB (both wheels) will not hold motor
C0217 LF ABS channel will not move
C0218 RF ABS channel will not move
C0219 Rear ABS channel will not move
C0220 LF ABS channel in release too long
C0221 RF ABS channel in release too long
C0222 Rear ABS channel in release too long
C0223 LF ABS channel motor free spins
C0224 RF ABS channel motor free spins
C0225 Rear ABS channel motor free spins
C0226 LF TCS channel will not move
C0227 RF TCS channel will not move
C0228 LR ABS channel in release too long
C0229 RR ABS channel in release too long
C0230 LF TCS channel motor free spins
C0231 RF TCS channel motor free spins
C0232 EBCM turned on red brake warning lamp
C0233 Open brake switch contacts during deceleration
C0234 Open brake switch contacts when ABS was required
C0235 C0233 or C0234 set in previous or current ignition cycle
C0236 TCS RPM signal circuit malfunction
C0237 TCS throttle position signal malfunction
C0238 TCS throttle position sensor comparison malfunction
C0239 TCS spark retard monitoring malfunction
C0240 PCM traction control not allowed
C0241 PCM indicated requested torque malfunction
C0242 PCM indicated TCS malfunction
C0243 Engine drag control malfunction
C0244 PWM delivered torque malfunction
C0245 Wheel speed sensor frequency error
C0246 Simultaneous dropout of both front wheel speed sensors
C0247 MSVA1 actuator fault (ohmic)
C0248 MSVA1 actuator fault (command vs. feedback current)
C0249 Left normal force fault
C0250 Right normal force fault
C0251 RTD indicated fault
C0252 ABC sensors uncorrelated
C0253 Centering fault
C0254 Steering sensor/lateral accelerometer bias fault
C0255 TCM to ABS/TC PWM signal malfunction
C0256 Valve relay contact circuit malfunction
C0257 Valve relay contact circuit range/performance
C0258 Valve relay contact circuit low
C0259 Valve relay contact circuit high
C0260 Valve relay contact circuit open
C0261 Valve relay coil circuit malfunction
C0262 Valve relay coil circuit range/performance
C0263 Valve relay coil circuit low
C0264 Valve relay coil circuit high
C0265 Valve relay coil circuit open
C0266 Throttle reduction motor controller malfunction
C0267 Low brake fluid indicated
C0268 Class 2 data error reported
C0269 Class 2 data invalid
C0300 Rear propshaft signal circuit malfunction
C0301 Rear propshaft signal circuit range/performance
C0302 Rear propshaft signal circuit low
C0303 Rear propshaft signal circuit high
C0304 Rear propshaft signal circuit open
C0305 Front propshaft speed sensor/system malfunction
C0306 Motor A/B circuit malfunction
C0307 Motor A/B circuit range/performance
C0308 Motor A/B circuit low
C0309 Motor A/B circuit high
C0310 Motor A/B circuit open
C0311 Motor ground circuit malfunction
C0312 Motor ground circuit range/performance
C0313 Motor ground circuit low
C0314 Motor ground circuit high C0315 Motor ground circuit open
C0316 Motor circuit malfunction
C0317 Motor circuit range/performance
C0318 Motor circuit low
C0319 Motor circuit high
C0320 Motor circuit open
C0321 Transfer case lock circuit malfunction
C0322 Transfer case lock circuit range/performance
C0323 Transfer case lock circuit low
C0324 Transfer case lock circuit high
C0325 Transfer case lock circuit open
C0326 Transfer case lock system malfunction
C0327 Encoder circuit malfunction
C0328 Encoder circuit range/performance
C0329 Encoder circuit low
C0330 Encoder circuit high
C0331 Encoder circuit open
C0332 Encoder power circuit low
C0333 Encoder ground circuit high
C0334 Encoder channel P input circuit malfunction
C0335 Encoder channel P input circuit range/performance
C0336 Encoder channel P input circuit low
C0337 Encoder channel P input circuit high
C0338 Encoder channel P input circuit open
C0339 Encoder channel C input circuit malfunction
C0340 Encoder channel C input circuit range/performance
C0341 Encoder channel C input circuit low
C0342 Encoder channel C input circuit high
C0343 Encoder channel C input circuit open
C0344 Encoder channel B input circuit malfunction
C0345 Encoder channel B input circuit range/performance
C0346 Encoder channel B input circuit low
C0347 Encoder channel B input circuit high
C0348 Encoder channel B input circuit open
C0349 Encoder channel A input circuit malfunction
C0350 Encoder channel A input circuit range/performance
C0351 Encoder channel A input circuit low
C0352 Encoder channel A input circuit high
C0353 Encoder channel A input circuit open
C0354 Park switch circuit malfunction
C0355 Park switch circuit range/performance
C0356 Park switch circuit low
C0357 Park switch circuit high
C0358 Park switch circuit open
C0359 4LO discrete output circuit malfunction
C0360 4LO discrete output circuit range/performance
C0361 4LO discrete output circuit low
C0362 4LO discrete output circuit high
C0363 4LO discrete output circuit open
C0364 Front axle control circuit malfunction
C0365 Front axle control circuit range/performance
C0366 Front axle control circuit low
C0367 Front axle control circuit high
C0368 Front axle control circuit open
C0369 ATC relay circuit malfunction
C0370 ATC relay circuit range/performance
C0371 ATC relay circuit low
C0372 ATC relay circuit high
C0373 ATC relay circuit open
C0374 General system malfunction
C0375 Intermittent system malfunction
C0376 Front/Rear propshaft speed mismatch detected
C0377 Front/Rear propshaft speed mismatch intermittent
C0378 Front axle switch circuit malfunction
C0379 Front axle system malfunction
C0380 Mode switch power circuit low
C0381 Motor system malfunction
C0382 4LO discrete input circuit malfunction
C0383 4LO discrete input circuit range/performance
C0384 4LO discrete input circuit low
C0385 4LO discrete input circuit high
C0386 4LO discrete input circuit open
C0387 Unable to complete shift
C0450 Steering assist control solenoid/motor/actuator circuit malfunction
C0451 Steering assist control solenoid/motor/actuator circuit range/performance
C0452 Steering assist control solenoid/motor/actuator circuit low
C0453 Steering assist control solenoid/motor/actuator circuit high
C0454 Steering assist control solenoid/motor/actuator circuit open
C0455 Steering position sensor circuit malfunction
C0456 Steering position sensor circuit range/performance
C0457 Steering position sensor circuit low
C0458 Steering position sensor circuit high
C0459 Steering position sensor circuit open
C0460 Steering position sensor malfunction
C0461 Steering position sensor range/performance
C0462 Steering position sensor low
C0463 Steering position sensor high
C0464 Steering position sensor open
C0465 Steering rate of change sensor circuit malfunction
C0466 Steering rate of change sensor circuit range/performance
C0467 Steering rate of change sensor circuit low
C0468 Steering rate of change sensor circuit high
C0469 Steering rate of change sensor circuit open
C0470 Steering position & rate of change sensor circuit #1 malfunction
C0471 Steering position & rate of change sensor circuit #1 range/performance
C0472 Steering position & rate of change sensor circuit #1 low
C0473 Steering position & rate of change sensor circuit #1 high
C0474 Steering position & rate of change sensor circuit #1 open
C0475 Electric steering motor circuit malfunction
C0476 Electric steering motor circuit range/performance
C0477 Electric steering motor circuit low
C0478 Electric steering motor circuit high
C0479 Electric steering motor circuit open
C0480 Electric hydraulic steering motor circuit malfunction
C0481 Electric hydraulic steering motor circuit range/performance
C0482 Electric hydraulic steering motor circuit low
C0483 Electric hydraulic steering motor circuit high
C0484 Electric hydraulic steering motor circuit open
C0485 Electric hydraulic steering temperature sensor circuit malfunction
C0486 Electric hydraulic steering temperature sensor circuit range/performance
C0487 Electric hydraulic steering temperature sensor circuit low
C0488 Electric hydraulic steering temperature sensor circuit high
C0489 Electric hydraulic steering temperature sensor circuit open
C0490 Steering column lock solenoid circuit malfunction
C0491 Steering column lock solenoid circuit range/performance
C0492 Steering column lock solenoid circuit low
C0493 Steering column lock solenoid circuit high
C0494 Steering column lock solenoid circuit open
C0495 EVO tracking error
C0496 Steering assist control solenoid/motor/actuator feed circuit malfunction
C0497 Steering assist control solenoid/motor/actuator feed circuit range/performance
C0498 Steering assist control solenoid/motor/actuator feed circuit low
C0499 Steering assist control solenoid/motor/actuator feed circuit high
C0500 Steering assist control solenoid/motor/actuator feed circuit open
C0501 Steering assist control solenoid/motor/actuator return circuit malfunction
C0502 Steering assist control solenoid/motor/actuator return circuit range/performance
C0503 Steering assist control solenoid/motor/actuator return circuit low
C0504 Steering assist control solenoid/motor/actuator return circuit high
C0505 Steering assist control solenoid/motor/actuator return circuit open
C0506 Steering position & rate of change sensor circuit #2 malfunction
C0507 Steering position & rate of change sensor circuit #2 range/performance
C0508 Steering position & rate of change sensor circuit #2 low
C0509 Steering position & rate of change sensor circuit #2 high
C0510 Steering position & rate of change sensor circuit #2 open
C0511 Steering position & rate of change sensor output circuit #1 malfunction
C0512 Steering position & rate of change sensor output circuit #1 range/performance
C0513 Steering position & rate of change sensor output circuit #1 low
C0514 Steering position & rate of change sensor output circuit #1 high
C0515 Steering position & rate of change sensor output circuit #1 open
C0516 Steering position & rate of change sensor output circuit #2 malfunction
C0517 Steering position & rate of change sensor output circuit #2 range/performance
C0518 Steering position & rate of change sensor output circuit #2 low
C0519 Steering position & rate of change sensor output circuit #2 high
C0520 Steering position & rate of change sensor output circuit #2 open
C0521 Steering position & rate of change sensors uncorrelated
C0550 ECU malfunction
C0551 Option configuration error
C0552 Improper shutdown
C0554 KAM reset
C0563 Calibration ROM checksum error
C0564 Program ROM checksum error
C0565 VIN information error
C0575 LF solenoid/motor/actuator circuit malfunction
C0576 LF solenoid/motor/actuator circuit range/performance
C0577 LF solenoid/motor/actuator circuit low
C0578 LF solenoid/motor/actuator circuit high
C0579 LF solenoid/motor/actuator circuit open
C0580 RF solenoid/motor/actuator circuit malfunction
C0581 RF solenoid/motor/actuator circuit range/performance
C0582 RF solenoid/motor/actuator circuit low
C0583 RF solenoid/motor/actuator circuit high
C0584 RF solenoid/motor/actuator circuit open
C0585 LR solenoid/motor/actuator circuit malfunction
C0586 LR solenoid/motor/actuator circuit range/performance
C0587 LR solenoid/motor/actuator circuit low
C0588 LR solenoid/motor/actuator circuit high
C0589 LR solenoid/motor/actuator circuit open
C0590 RR solenoid/motor/actuator circuit malfunction
C0591 RR solenoid/motor/actuator circuit range/performance
C0592 RR solenoid/motor/actuator circuit low
C0593 RR solenoid/motor/actuator circuit high
C0594 RR solenoid/motor/actuator circuit open
C0595 LF accelerometer circuit malfunction
C0596 LF accelerometer circuit range/performance
C0597 LF accelerometer circuit low
C0598 LF accelerometer circuit high
C0599 LF accelerometer circuit open
C0600 RF accelerometer circuit malfunction
C0601 RF accelerometer circuit range/performance
C0602 RF accelerometer circuit low
C0603 RF accelerometer circuit high
C0604 RF accelerometer circuit open
C0605 LR accelerometer circuit malfunction
C0606 LR accelerometer circuit range/performance
C0607 LR accelerometer circuit low
C0608 LR accelerometer circuit high
C0609 LR accelerometer circuit open
C0610 RR accelerometer circuit malfunction
C0611 RR accelerometer circuit range/performance
C0612 RR accelerometer circuit low
C0613 RR accelerometer circuit high
C0614 RR accelerometer circuit open
C0615 LF position sensor circuit malfunction
C0616 LF position sensor circuit range/performance
C0617 LF position sensor circuit low
C0618 LF position sensor circuit high
C0619 LF position sensor circuit open
C0620 RF position sensor circuit malfunction
C0621 RF position sensor circuit range/performance
C0622 RF position sensor circuit low
C0623 RF position sensor circuit high
C0624 RF position sensor circuit open
C0625 LR position sensor circuit malfunction
C0626 LR position sensor circuit range/performance
C0627 LR position sensor circuit low
C0628 LR position sensor circuit high
C0629 LR position sensor circuit open
C0630 RR position sensor circuit malfunction
C0631 RR position sensor circuit range/performance
C0632 RR position sensor circuit low
C0633 RR position sensor circuit high
C0634 RR position sensor circuit open
C0635 LF normal force circuit malfunction
C0636 LF normal force circuit range/performance
C0637 LF normal force circuit low
C0638 LF normal force circuit high
C0639 LF normal force circuit open
C0640 RF normal force circuit malfunction
C0641 RF normal force circuit range/performance
C0642 RF normal force circuit low
C0643 RF normal force circuit high
C0644 RF normal force circuit open
C0645 LR normal force circuit malfunction
C0646 LR normal force circuit range/performance
C0647 LR normal force circuit low
C0648 LR normal force circuit high
C0649 LR normal force circuit open
C0650 RR normal force circuit malfunction
C0651 RR normal force circuit range/performance
C0652 RR normal force circuit low
C0653 RR normal force circuit high
C0654 RR normal force circuit open
C0655 Level control compressor circuit malfunction
C0656 Level control compressor circuit range/performance
C0657 Level control compressor circuit low
C0658 Level control compressor circuit high
C0659 Level control compressor circuit open
C0660 Level control exhaust valve circuit malfunction
C0661 Level control exhaust valve circuit range/performance
C0662 Level control exhaust valve circuit low
C0663 Level control exhaust valve circuit high
C0664 Level control exhaust valve circuit open
C0665 Lift/dive signal circuit malfunction
C0666 Lift/dive signal circuit range/performance
C0667 Lift/dive signal circuit low
C0668 Lift/dive signal circuit high
C0669 Lift/dive signal circuit open
C0670 LF combination accel/position sensor circuit malfunction
C0671 LF combination accel/position sensor circuit range/performance
C0672 LF combination accel/position sensor circuit low
C0673 LF combination accel/position sensor circuit high
C0674 LF combination accel/position sensor circuit open
C0675 RF combination accel/position sensor circuit malfunction
C0676 RF combination accel/position sensor circuit range/performance
C0677 RF combination accel/position sensor circuit low
C0678 RF combination accel/position sensor circuit high
C0679 RF combination accel/position sensor circuit open
C0680 LR combination accel/position sensor circuit malfunction
C0681 LR combination accel/position sensor circuit range/performance
C0682 LR combination accel/position sensor circuit low
C0683 LR combination accel/position sensor circuit high
C0684 LR combination accel/position sensor circuit open
C0685 RR combination accel/position sensor circuit malfunction
C0686 RR combination accel/position sensor circuit range/performance
C0687 RR combination accel/position sensor circuit low
C0688 RR combination accel/position sensor circuit high
C0689 RR combination accel/position sensor circuit open
C0690 Damper control relay circuit malfunction
C0691 Damper control relay circuit range/performance
C0692 Damper control relay circuit low
C0693 Damper control relay circuit high
C0694 Damper control relay circuit open
C0695 Position sensor overcurrent (8 volt supply)
C0696 Position sensor overcurrent (5 volt supply)
C0697 Level control accessory inflator switch circuit malfunction
C0698 Level control accessory inflator switch circuit range/performance
C0699 Level control accessory inflator switch circuit low
C0700 Level control accessory inflator switch circuit high
C0701 Level control accessory inflator switch circuit open
C0702 Level control accessory valve circuit malfunction
C0703 Level control accessory valve circuit range/performance
C0704 Level control accessory valve circuit low
C0705 Level control accessory valve circuit high
C0706 Level control accessory valve circuit open
C0707 Excessive compressor activity
C0708 Excessive compressor exhaust valve activity
C0709 Excessive compressor activity, vehicle moving
C0710 Steering position signal malfunction
C0711 Level control air pressure sensor circuit malfunction
C0750 LF low tire pressure sensor malfunction
C0751 LF low tire pressure sensor range/performance
C0752 LF low tire pressure sensor low
C0753 LF low tire pressure sensor high
C0754 LF low tire pressure sensor circuit open
C0755 RF low tire pressure sensor malfunction
C0756 RF low tire pressure sensor range/performance
C0757 RF low tire pressure sensor low
C0758 RF low tire pressure sensor high
C0759 RF low tire pressure sensor circuit open
C0760 LR low tire pressure sensor malfunction
C0761 LR low tire pressure sensor range/performance
C0762 LR low tire pressure sensor low
C0763 LR low tire pressure sensor high
C0764 LR low tire pressure sensor circuit open
C0765 RR low tire pressure sensor malfunction
C0766 RR low tire pressure sensor range/performance
C0767 RR low tire pressure sensor low
C0768 RR low tire pressure sensor high
C0769 RR low tire pressure sensor circuit open
C0770 LF tire pressure low
C0771 RF tire pressure low
C0772 LR tire pressure low
C0773 RR tire pressure low
C0774 Low tire pressure system malfunction
C0775 Low tire pressure system sensors not programmed
C0776 Low tire pressure system transmitter synchronization failure
C0777 Low tire pressure system transmitter ID invalid
C0778 TIM switch circuit malfunction
C0779 TIM signal fault
C0800 Device power #1 (low current #1) circuit malfunction
C0801 Device power #1 (low current #1) circuit range/performance
C0802 Device power #1 (low current #1) circuit low
C0803 Device power #1 (low current #1) circuit high
C0804 Device power #1 (low current #1) circuit open
C0805 Device power #2 (low current #2) circuit malfunction
C0806 Device power #2 (low current #2) circuit range/performance
C0807 Device power #2 (low current #2) circuit low
C0808 Device power #2 (low current #2) circuit high
C0809 Device power #2 (low current #2) circuit open
C0810 Device power #3 (high current #1) circuit malfunction
C0811 Device power #3 (high current #1) circuit range/performance
C0812 Device power #3 (high current #1) circuit low
C0813 Device power #3 (high current #1) circuit high
C0814 Device power #3 (high current #1) circuit open
C0815 Device power #4 (high current #2) circuit malfunction
C0816 Device power #4 (high current #2) circuit range/performance
C0817 Device power #4 (high current #2) circuit low
C0818 Device power #4 (high current #2) circuit high
C0819 Device power #4 (high current #2) circuit open
C0820 Device ground #1 (chassis gnd #1) circuit malfunction
C0821 Device ground #1 (chassis gnd #1) circuit range/performance
C0822 Device ground #1 (chassis gnd #1) circuit low
C0823 Device ground #1 (chassis gnd #1) circuit high
C0824 Device ground #1 (chassis gnd #1) circuit open
C0825 Device ground #2 (chassis gnd #2) circuit malfunction
C0826 Device ground #2 (chassis gnd #2) circuit range/performance
C0827 Device ground #2 (chassis gnd #2) circuit low
C0828 Device ground #2 (chassis gnd #2) circuit high
C0829 Device ground #2 (chassis gnd #2) circuit open
C0830 Device ground #3 (signal gnd #1) circuit malfunction
C0831 Device ground #3 (signal gnd #1) circuit range/performance
C0832 Device ground #3 (signal gnd #1) circuit low
C0833 Device ground #3 (signal gnd #1) circuit high
C0834 Device ground #3 (signal gnd #1) circuit open
C0835 Device ground #4 (signal gnd #2) circuit malfunction
C0836 Device ground #4 (signal gnd #2) circuit range/performance
C0837 Device ground #4 (signal gnd #2) circuit low
C0838 Device ground #4 (signal gnd #2) circuit high
C0839 Device ground #4 (signal gnd #2) circuit open
C0840 Device ignition 0 (UNLOCK/ON/START) circuit malfunction
C0841 Device ignition 0 (UNLOCK/ON/START) circuit range/performance
C0842 Device ignition 0 (UNLOCK/ON/START) circuit low
C0843 Device ignition 0 (UNLOCK/ON/START) circuit high
C0844 Device ignition 0 (UNLOCK/ON/START) circuit open
C0845 Device ignition 1 (ON/START) circuit malfunction
C0846 Device ignition 1 (ON/START) circuit range/performance
C0847 Device ignition 1 (ON/START) circuit low
C0848 Device ignition 1 (ON/START) circuit high
C0849 Device ignition 1 (ON/START) circuit open
C0850 Device ignition 3 (ON) circuit malfunction
C0851 Device ignition 3 (ON) circuit range/performance
C0852 Device ignition 3 (ON) circuit low
C0853 Device ignition 3 (ON) circuit high
C0854 Device ignition 3 (ON) circuit open
C0855 Device ignition ACC circuit malfunction
C0856 Device ignition ACC circuit range/performance
C0857 Device ignition ACC circuit low
C0858 Device ignition ACC circuit high
C0859 Device ignition ACC circuit open
C0860 Device ignition START circuit malfunction
C0861 Device ignition START circuit range/performance
C0862 Device ignition START circuit low
C0863 Device ignition START circuit high
C0864 Device ignition START circuit open
C0865 Device voltage reference input #1 circuit malfunction
C0866 Device voltage reference input #1 circuit range/performance
C0867 Device voltage reference input #1 circuit low
C0868 Device voltage reference input #1 circuit high
C0869 Device voltage reference input #1 circuit open
C0870 Device voltage reference output #1 circuit malfunction
C0871 Device voltage reference output #1 circuit range/performance
C0872 Device voltage reference output #1 circuit low
C0873 Device voltage reference output #1 circuit high
C0874 Device voltage reference output #1 circuit open
C0875 Device voltage reference input #2 circuit malfunction
C0876 Device voltage reference input #2 circuit range/performance
C0877 Device voltage reference input #2 circuit low
C0878 Device voltage reference input #2 circuit high
C0879 Device voltage reference input #2 circuit open
C0880 Device voltage reference output #2 circuit malfunction
C0881 Device voltage reference output #2 circuit range/performance
C0882 Device voltage reference output #2 circuit low
C0883 Device voltage reference output #2 circuit high
C0884 Device voltage reference output #2 circuit open
C0885 Device voltage reference input #3 circuit malfunction
C0886 Device voltage reference input #3 circuit range/performance
C0887 Device voltage reference input #3 circuit low
C0888 Device voltage reference input #3 circuit high
C0889 Device voltage reference input #3 circuit open
C0890 Device voltage reference output #3 circuit malfunction
C0891 Device voltage reference output #3 circuit range/performance
C0892 Device voltage reference output #3 circuit low
C0893 Device voltage reference output #3 circuit high
C0894 Device voltage reference output #3 circuit open
C0895 Device voltage malfunction
C0896 Device voltage range/performance
C0897 Device power moding malfunction
C0898 Device power and/or ground circuit malfunction
C0899 Device #1 voltage low
C0900 Device #1 voltage high
C0901 Device #2 voltage low
C0902 Device #2 voltage high
C0903 Ignition-switched power relay #1 circuit malfunction
C0904 Ignition-switched power relay #1 circuit range/performance
C0905 Ignition-switched power relay #1 circuit low
C0906 Ignition-switched power relay #1 circuit high
C0907 Ignition-switched power relay #1 circuit open
C0908 Ignition-switched power relay #2 circuit malfunction
C0909 Ignition-switched power relay #2 circuit range/performance
C0910 Ignition-switched power relay #2 circuit low
C0911 Ignition-switched power relay #2 circuit high
C0912 Ignition-switched power relay #2 circuit open
C0913 Intermittent device voltage range/performance
U1000 Class 2 Data Link Malfunction
U1001 Lost communications with Powertrain Multiple Control System
U1002 Lost communications with Powertrain Multiple Control System
U1003 Lost communications with Powertrain Multiple Control System
U1004 Lost communications with Powertrain Multiple Control System
U1005 Lost communications with Powertrain Multiple Control System
U1006 Lost communications with Powertrain Multiple Control System
U1007 Lost communications with Powertrain Multiple Control System
U1008 Lost communications with Powertrain Multiple Control System
U1009 Lost communications with Powertrain Multiple Control System
U1010 Lost communications with Powertrain Multiple Control System
U1011 Lost communications with Powertrain Multiple Control System
U1012 Lost communications with Powertrain Multiple Control System
U1013 Lost communications with Powertrain Multiple Control System
U1014 Lost communications with Powertrain Multiple Control System
U1015 Lost communications with Powertrain Multiple Control System
U1016 Lost communications with Engine Control System
U1017 Lost communications with Engine Control System
U1018 Lost communications with Engine Control System
U1019 Lost communications with Engine Control System
U1020 Lost communications with Engine Control System
U1021 Lost communications with Engine Control System
U1022 Lost communications with Engine Control System
U1023 Lost communications with Engine Control System
U1024 Lost communications with Transmission Control System
U1025 Lost communications with Transmission Control System
U1026 Lost communications with Transmission Control System
U1027 Lost communications with Transmission Control System
U1028 Lost communications with Transmission Control System
U1029 Lost communications with Transmission Control System
U1030 Lost communications with Transmission Control System
U1031 Lost communications with Transmission Control System
U1032 Lost communications with Chassis Multiple Control System
U1033 Lost communications with Chassis Multiple Control System
U1034 Lost communications with Chassis Multiple Control System
U1035 Lost communications with Chassis Multiple Control System
U1036 Lost communications with Chassis Multiple Control System
U1037 Lost communications with Chassis Multiple Control System
U1038 Lost communications with Chassis Multiple Control System
U1039 Lost communications with Chassis Multiple Control System
U1040 Lost communications with Brake/Traction Control System
U1041 Lost communications with Brake/Traction Control System
U1042 Lost communications with Brake/Traction Control System
U1043 Lost communications with Brake/Traction Control System
U1044 Lost communications with Brake/Traction Control System
U1045 Lost communications with Brake/Traction Control System
U1046 Lost communications with Brake/Traction Control System
U1047 Lost communications with Brake/Traction Control System
U1048 Lost communications with Steering Control System
U1049 Lost communications with Steering Control System
U1050 Lost communications with Steering Control System
U1051 Lost communications with Steering Control System
U1052 Lost communications with Steering Control System
U1053 Lost communications with Steering Control System
U1054 Lost communications with Steering Control System
U1055 Lost communications with Steering Control System
U1056 Lost communications with Suspension Control System
U1057 Lost communications with Suspension Control System
U1058 Lost communications with Suspension Control System
U1059 Lost communications with Suspension Control System
U1060 Lost communications with Suspension Control System
U1061 Lost communications with Suspension Control System
U1062 Lost communications with Suspension Control System
U1063 Lost communications with Suspension Control System
U1064 Lost communications with Body Multiple Control System
U1065 Lost communications with Body Multiple Control System
U1066 Lost communications with Body Multiple Control System
U1067 Lost communications with Body Multiple Control System
U1068 Lost communications with Body Multiple Control System
U1069 Lost communications with Body Multiple Control System
U1070 Lost communications with Body Multiple Control System
U1071 Lost communications with Body Multiple Control System
U1072 Lost communications with Body Multiple Control System
U1073 Lost communications with Body Multiple Control System
U1074 Lost communications with Body Multiple Control System
U1075 Lost communications with Body Multiple Control System
U1076 Lost communications with Body Multiple Control System
U1077 Lost communications with Body Multiple Control System
U1078 Lost communications with Body Multiple Control System
U1079 Lost communications with Body Multiple Control System
U1080 Lost communications with Body Multiple Control System
U1081 Lost communications with Body Multiple Control System
U1082 Lost communications with Body Multiple Control System
U1083 Lost communications with Body Multiple Control System
U1084 Lost communications with Body Multiple Control System
U1085 Lost communications with Body Multiple Control System
U1086 Lost communications with Body Multiple Control System
U1087 Lost communications with Body Multiple Control System
U1088 Lost communications with Restraints Control System
U1089 Lost communications with Restraints Control System
U1090 Lost communications with Restraints Control System
U1091 Lost communications with Restraints Control System
U1092 Lost communications with Restraints Control System
U1093 Lost communications with Restraints Control System
U1094 Lost communications with Restraints Control System
U1095 Lost communications with Restraints Control System
U1096 Lost communications with Driver Information & Displays Control System
U1097 Lost communications with Driver Information & Displays Control System
U1098 Lost communications with Driver Information & Displays Control System
U1099 Lost communications with Driver Information & Displays Control System
U1100 Lost communications with Driver Information & Displays Control System
U1101 Lost communications with Driver Information & Displays Control System
U1102 Lost communications with Driver Information & Displays Control System
U1103 Lost communications with Driver Information & Displays Control System
U1104 Lost communications with Driver Information & Displays Control System
U1105 Lost communications with Driver Information & Displays Control System
U1106 Lost communications with Driver Information & Displays Control System
U1107 Lost communications with Driver Information & Displays Control System
U1108 Lost communications with Driver Information & Displays Control System
U1109 Lost communications with Driver Information & Displays Control System
U1110 Lost communications with Driver Information & Displays Control System
U1111 Lost communications with Driver Information & Displays Control System
U1112 Lost communications with Lighting Control System
U1113 Lost communications with Lighting Control System
U1114 Lost communications with Lighting Control System
U1115 Lost communications with Lighting Control System
U1116 Lost communications with Lighting Control System
U1117 Lost communications with Lighting Control System
U1118 Lost communications with Lighting Control System
U1119 Lost communications with Lighting Control System
U1120 Lost communications with Lighting Control System
U1121 Lost communications with Lighting Control System
U1122 Lost communications with Lighting Control System
U1123 Lost communications with Lighting Control System
U1124 Lost communications with Lighting Control System
U1125 Lost communications with Lighting Control System
U1126 Lost communications with Lighting Control System
U1127 Lost communications with Lighting Control System
U1128 Lost communications with Entertainment/Audio Control System
U1129 Lost communications with Entertainment/Audio Control System
U1130 Lost communications with Entertainment/Audio Control System
U1131 Lost communications with Entertainment/Audio Control System
U1132 Lost communications with Entertainment/Audio Control System
U1133 Lost communications with Entertainment/Audio Control System
U1134 Lost communications with Entertainment/Audio Control System
U1135 Lost communications with Entertainment/Audio Control System
U1136 Lost communications with Entertainment/Audio Control System
U1137 Lost communications with Entertainment/Audio Control System
U1138 Lost communications with Entertainment/Audio Control System
U1139 Lost communications with Entertainment/Audio Control System
U1140 Lost communications with Entertainment/Audio Control System
U1141 Lost communications with Entertainment/Audio Control System
U1142 Lost communications with Entertainment/Audio Control System
U1143 Lost communications with Entertainment/Audio Control System
U1144 Lost communications with Mobile Communications Control System
U1145 Lost communications with Mobile Communications Control System
U1146 Lost communications with Mobile Communications Control System
U1147 Lost communications with Mobile Communications Control System
U1148 Lost communications with Mobile Communications Control System
U1149 Lost communications with Mobile Communications Control System
U1150 Lost communications with Mobile Communications Control System
U1151 Lost communications with Mobile Communications Control System
U1152 Lost communications with HVAC Control System
U1153 Lost communications with HVAC Control System
U1154 Lost communications with HVAC Control System
U1155 Lost communications with HVAC Control System
U1156 Lost communications with HVAC Control System
U1157 Lost communications with HVAC Control System
U1158 Lost communications with HVAC Control System
U1159 Lost communications with HVAC Control System
U1160 Lost communications with Convenience Control System
U1161 Lost communications with Convenience Control System
U1162 Lost communications with Convenience Control System
U1163 Lost communications with Convenience Control System
U1164 Lost communications with Convenience Control System
U1165 Lost communications with Convenience Control System
U1166 Lost communications with Convenience Control System
U1167 Lost communications with Convenience Control System
U1168 Lost communications with Convenience Control System
U1169 Lost communications with Convenience Control System
U1170 Lost communications with Convenience Control System
U1171 Lost communications with Convenience Control System
U1172 Lost communications with Convenience Control System
U1173 Lost communications with Convenience Control System
U1174 Lost communications with Convenience Control System
U1175 Lost communications with Convenience Control System
U1176 Lost communications with Convenience Control System
U1177 Lost communications with Convenience Control System
U1178 Lost communications with Convenience Control System
U1179 Lost communications with Convenience Control System
U1180 Lost communications with Convenience Control System
U1181 Lost communications with Convenience Control System
U1182 Lost communications with Convenience Control System
U1183 Lost communications with Convenience Control System
U1184 Lost communications with Convenience Control System
U1185 Lost communications with Convenience Control System
U1186 Lost communications with Convenience Control System
U1187 Lost communications with Convenience Control System
U1188 Lost communications with Convenience Control System
U1189 Lost communications with Convenience Control System
U1190 Lost communications with Convenience Control System
U1191 Lost communications with Convenience Control System
U1192 Lost communications with Security Control System
U1193 Lost communications with Security Control System
U1194 Lost communications with Security Control System
U1195 Lost communications with Security Control System
U1196 Lost communications with Security Control System
U1197 Lost communications with Security Control System
U1198 Lost communications with Security Control System
U1199 Lost communications with Security Control System
U1300 Class 2 Data Link Low
U1301 Class 2 Data Link High
U1302 Programming request not received
U1303 Programming mode active message not received
U1304 Lost communications with UART system(s)
U1305 Class 2 Data Link Low or High
U1400 AD Link Malfunction
U1401 Lost communications between AD and ADG
U1500 Inter-device dedicated bus malfunction
U1601 Restraint system dedicated bus #1 malfunction (Suppression system bus)
U1602 Restraint system dedicated bus #2 malfunction (EFS system bus)
U1603 Restraint system dedicated bus #3 malfunction (SDM #2 system bus)
U1650 Chassis system dedicated bus controller malfunction
U1651 Chassis system dedicated bus sensor #1 malfunction
U1652 Chassis system dedicated bus sensor #2 malfunction
U2000 Invalid BFC transmitted SPI data
U2001 Invalid IPC transmitted SPI data
U2002 SPI data in low
U2003 SPI data in high
U2004 SPI data out low
U2005 SPI data out high
U2006 SPI clock out low
U2007 SPI clock out high
U2008 General SPI malfunction
U2050 SIR PPS/CPS Communications Link Malfunction
U2100 CAN bus communication malfunction
U2101 Maximum list of control modules not programmed
U2102 More controllers on bus than programmed
U2103 Fewer controllers on bus than programmed
U2104 CAN bus reset counter overrun
U2105 Lost communications with Engine Control System
U2106 Lost communications with Transmission Control System
U2107 Lost communications with Body Control System
U2108 Lost communications with ABS/TCS Control System
U2109 Lost communications with Powertrain Multiple Control System
U2110 Lost communications with Chassis Multiple Control System
U2111 Lost communications with Steering Control System U2112 Lost communications with Suspension Control System
U2113 Lost communications with Restraints Control (SDM) System
U2114 Lost communications with Restraints Control (PPS/CPS) System
U2115 Lost communications with Restraints Control (TBD) System
U2116 Lost communications with Driver Information & Displays Control (IPC) System
U2117 Lost communications with Driver Information & Displays Control (DIC) System
U2118 Lost communications with Driver Information & Displays Control (TBD) System
U2119 Lost communications with Lighting Control (DRL) System
U2120 Lost communications with Lighting Control (AHLD) System
U2121 Lost communications with Lighting Control (TBD) System
U2122 Lost communications with Entertainment/Audio Control (Radio) System
U2123 Lost communications with Entertainment/Audio Control (CDX) System
U2124 Lost communications with Entertainment/Audio Control (TBD) System
U2125 Lost communications with Mobile Communications Control (TBD) System
U2126 Lost communications with Mobile Communications Control (TBD) System
U2127 Lost communications with HVAC Control (front) System
U2128 Lost communications with HVAC Control (rear) System
U2129 Lost communications with Convenience Control (RFA) System
U2130 Lost communications with Convenience Control (DDM) System
U2131 Lost communications with Convenience Control (DSM) System
U2132 Lost communications with Convenience Control (PDM) System
U2133 Lost communications with Convenience Control (PSM) System
U2134 Lost communications with Convenience Control (RDM) System
U2135 Lost communications with Convenience Control (RIM) System
U2136 Lost communications with Convenience Control (MMM) System
U2137 Lost communications with Security Control (VTD) System
U2138 Lost communications with Security Control (TBD) System
U2139 Lost communications with Body Control (CIM) System
U2140 Lost communications with Body Control (UEC) System
U2141 Lost communications with Body Control (REC) System
U2142 Lost communications with Chassis Control (YRS) System
U2143 Lost communications with Steering Control (SAS) System
U2144 Lost communications with Powertrain Control (ACC) System
U2145 Lost communications with Convenience Control (PAS) System
U2150 Navigation ECU Gateway Communications Malfunction
U2151 Navigation ECU Communications Malfunction
U2152 Navigation Bus Request Line Circuit Low
U2153 Navigation ECU - VICS communication circuit malfunction
Note that this listing is a guideline only--not to be substituted for real Tech2 scanner
diagnostics.
See less See more
#9 ·
No need for Tech 2 or any sort of code readers and Most of Vauxhall dealers don’t know about this....
Want to read the Code well first
Take a deep breath get your car keys and get a pen and paper
When you get into the car you know the key has 3 clicks first on for whatever it is second the dash comes on third the starter kicks in
before you put the key into the ignition Make sure that you Press the Break and the Throttle to the Floor ( max
Then turn the key on until The dash board come on and DONT START THE CAR
Wait 2 sec and keep the pedals Down to the floor
the service light under the management light should start flashing
it will flash 4 times leaving 2 second space representing each number
Zero gets 10 flashes
for exampleP0110
the light will flash ten times Break (2sec Or 1 not sure) then once, (2sec) once again, then ten
if you have more than one code it will stop for a break then gives the next code
its not a very useful way but helps when you dont want to go to the dealer for a lose socket :)
this is for Corsa C the Newer models have even better way to tell you the code i think which is on your Mileage Display It will show ECN0 XXXX
which is error code Number forget the zero and the last four digits is what you want
and this works for an astra Too
ive tested this on my own corsa and worked Very well
however if you don’t have any code stored it will start Flashing and keeps on flashing until you release the paddles
#191 ·
need help
for exampleP0110
i have tryed this it does work showing me that there are no fault's
i have recently bought a 1.2 sxi 16v twinport (2005) been standing 4 3 year's
now it is back on the road car start's lovely BUT having a problem
when you put you foot down it is kind of holding back and a bit judery then take's of like it should
i have put new plugs in oil change jet cleaner fuel filter and i cant seem 2 cure the problem could any one help !!!!!
#10 ·
:doublethumbs: this does work......
although i had to get in the car, close door, lock then unlock before it would do it though....
come up with 2 codes, which both matched to a tech 2.... only problem is you cant clear them..
still, good work!:doublethumbs:
#18 ·
right i have the same problem with mine and i think it means the air mass flow meter needs to be replaced. its the one connects on between the induction kit and the pipe following into the throttle body.
do you get symptoms from the car such as sluggish performance when starting and the car dying out sometime or trying to keep itself going when revs drop significantly?
#19 ·
0170 could be the MAF yes...... if its reading incorrect air temp and level the it will over/under fuel accordingly......
im guessin you guys have induction kits???
direct engine bay hot air + oiled filter = constant MAF failure!!!
ditch the cone's, green cotton panel filter and de-restrict the airbox..... same performance gains ;)
#22 ·
Hey, I took mine to the garage and got them to look at it. Obviously they get a better and more detailed description than our code descriptions with their machine so found out it wasn't anything to do with MAF.
It was just some water had hit something when I was driving, which would make sense as it came on on motorway in the pouring rain. So just had the Fault light reset. I do admit it feels a little sluggish but they checked the MAF and said its in perfect working order.
#23 ·
I have 2 codes...
0110 - Intake Air temp high/low
0100 Mass/Volume Air Flow High/Low
I'm guessing my MAF is totally ****ed.. ther mite be light in the tunnel afterwards, hopefully not talking to fast as I hope it'll be covered by warrenty still... they're funny buggers at VX/Masterfit as the engine has been changed - the floods last year (basically either £550 excess and a claim on insurance, or £250 for engine from 06 corsa, exactly same 1.2 sxi twinport z12xep) you can guess which I did..
#24 ·
Fault codes
Has anyone seen on their clock/radio/temp/time etc display a "display safe" message??
when i start the car, it display's the station and song title etc like normal for about 20 seconds, then comes up with this "display safe". I took this back a Holden Parts and Service place to have a look at (yeah i am in Australia where i drive a Barina.. not a corsa :shrug:). they charged me $165 to tell me that they didnt know what was wrong with it, suggested a faulty board and to get it replaced ($550 brand new). I refuse to pay that much for it! Can anyone help!! PLEAAAASSEEE!! :cry:
#25 ·
Does your cd player work? that normally comes up where you type in the radio code so you can listen to the cd player
You have insufficient privileges to reply here.
