Closed Thread
Page 1 of 12 1 2 3 4 5 11 ... LastLast
Results 1 to 25 of 288
Thread: How to do the pedal test and what the Fault codes mean
    13-08-2007
    Chesterfield
    Age
    31
    1,619
    edited by pugh125k
    This tutorial will tell you simply how to check any fault codes logged in your car, in a cheap cost effective way without the hassle of paying a garage £50 for a diagnostic check
    Tools
    No specialist tools are needed, only 2 working feet are required, 30 seconds of your time and pen & paper to write down the codes
    STEP 1:
    Get inside your vehicle a firmly place yourself in your seat. Once in, press both the accelerate and brake pedal together
    STEP 2:
    With both pedals pressed, put your key in the ignition and turn it to position 2, which is the position that switches all auxilary heating on but not the engine
    STEP 3:
    Once done, the spanner light will start flashing
    if it flashes 10 times it means the number is '0' and any other flashes corresponds to a number with a pause between each number
    for example code P0110
    the light will flash ten times then pause (2sec Or 1 not sure) flash once, (2sec pause) flash once, (2 sec pause) then flash ten times
    if you have more than one code it will stop for a break between each code
    however if you don’t have any code stored it will start Flashing and keeps on flashing until you release the pedals
    If you follow the above steps you are certain to find codes without ever having to plug an OBD equipment
    Code list is here
    PCM -- TCM -- BCM -- DDM -- IPC -- EBCM (ABS) -- CANBUS Messaging
    P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
    P0011 "A" Camshaft Position - Timing Over-Advanced (Bank 1)
    P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
    P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
    P0014 "B" Camshaft Position - Timing Over-Advanced (Bank 1)
    P0015 "B" Camshaft Position - Timing Over-Retarded (Bank 1)
    P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
    P0021 "A" Camshaft Position - Timing Over-Advanced (Bank 2)
    P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
    P0023 "B" Camshaft Position - Actuator Circuit (Bank 2)
    P0024 "B" Camshaft Position - Timing Over-Advanced (Bank 2)
    P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2)
    P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
    P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
    P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
    P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
    P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
    P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
    P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
    P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
    P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
    P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
    P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
    P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
    P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
    P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
    P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
    P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
    P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
    P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
    P0100 Mass or Volume Air Flow Circuit
    P0101 Mass or Volume Air Flow Circuit Range/Performance
    P0102 Mass or Volume Air Flow Circuit Low Input
    P0103 Mass or Volume Air Flow Circuit High Input
    P0104 Mass or Volume Air Flow Circuit Intermittent
    P0105 Manifold Absolute Pressure/Barometric Pressure Circuit
    P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
    P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
    P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
    P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
    P0110 Intake Air Temperature Circuit
    P0111 Intake Air Temperature Circuit Range/Performance
    P0112 Intake Air Temperature Circuit Low Input
    P0113 Intake Air Temperature Circuit High Input
    P0114 Intake Air Temperature Circuit Intermittent
    P0115 Engine Coolant Temperature Circuit
    P0116 Engine Coolant Temperature Circuit Range/Performance
    P0117 Engine Coolant Temperature Circuit Low Input
    P0118 Engine Coolant Temperature Circuit High Input
    P0119 Engine Coolant Temperature Circuit Intermittent
    P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit
    P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
    P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
    P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
    P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent
    P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
    P0126 Insufficient Coolant Temperature for Stable Operation
    P0127 Intake Air Temperature Too High
    P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
    P0130 O2 Sensor Circuit (Bank 1 Sensor 1)
    P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
    P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
    P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
    P0135 O2 Sensor Heater Circuit (Bank 1 Sensor 1)
    P0136 O2 Sensor Circuit (Bank 1 Sensor 2)
    P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
    P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
    P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
    P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
    P0141 O2 Sensor Heater Circuit (Bank 1 Sensor 2)
    P0142 O2 Sensor Circuit (Bank 1 Sensor 3)
    P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
    P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
    P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
    P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
    P0147 O2 Sensor Heater Circuit (Bank 1 Sensor 3)
    P0150 O2 Sensor Circuit (Bank 2 Sensor 1)
    P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
    P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
    P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
    P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
    P0155 O2 Sensor Heater Circuit (Bank 2 Sensor 1)
    P0156 O2 Sensor Circuit (Bank 2 Sensor 2)
    P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
    P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
    P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
    P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
    P0161 O2 Sensor Heater Circuit (Bank 2 Sensor 2)
    P0162 O2 Sensor Circuit (Bank 2 Sensor 3)
    P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
    P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
    P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
    P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
    P0167 O2 Sensor Heater Circuit (Bank 2 Sensor 3)
    P0168 Fuel Temperature Too High
    P0170 Fuel Trim (Bank 1)
    P0171 System too Lean (Bank 1)
    P0172 System too Rich (Bank 1)
    P0173 Fuel Trim (Bank 2)
    P0174 System too Lean (Bank 2)
    P0175 System too Rich (Bank 2)
    P0176 Fuel Composition Sensor Circuit
    P0177 Fuel Composition Sensor Circuit Range/Performance
    P0178 Fuel Composition Sensor Circuit Low Input
    P0179 Fuel Composition Sensor Circuit High Input
    P0180 Fuel Temperature Sensor "A" Circuit
    P0181 Fuel Temperature Sensor "A" Circuit Range/Performance
    P0182 Fuel Temperature Sensor "A" Circuit Low Input
    P0183 Fuel Temperature Sensor "A" Circuit High Input
    P0184 Fuel Temperature Sensor "A" Circuit Intermittent
    P0185 Fuel Temperature Sensor "B" Circuit
    P0186 Fuel Temperature Sensor "B" Circuit Range/Performance
    P0187 Fuel Temperature Sensor "B" Circuit Low Input
    P0188 Fuel Temperature Sensor "B" Circuit High Input
    P0189 Fuel Temperature Sensor "B" Circuit Intermittent
    P0190 Fuel Rail Pressure Sensor Circuit
    P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
    P0192 Fuel Rail Pressure Sensor Circuit Low Input
    P0193 Fuel Rail Pressure Sensor Circuit High Input
    P0194 Fuel Rail Pressure Sensor Circuit Intermittent
    P0195 Engine Oil Temperature Sensor Circuit
    P0196 Engine Oil Temperature Sensor Circuit Range/Performance
    P0197 Engine Oil Temperature Sensor Circuit Low
    P0198 Engine Oil Temperature Sensor Circuit High
    P0199 Engine Oil Temperature Sensor Circuit Intermittent
    P0200 Injector Circuit
    P0201 Cylinder 1 - Injector Circuit
    P0202 Cylinder 2 - Injector Circuit
    P0203 Cylinder 3 - Injector Circuit
    P0204 Cylinder 4 - Injector Circuit
    P0205 Cylinder 5 - Injector Circuit
    P0206 Cylinder 6 - Injector Circuit
    P0207 Cylinder 7 - Injector Circuit
    P0208 Cylinder 8 - Injector Circuit
    P0209 Cylinder 9 - Injector Circuit
    P0210 Cylinder 10 - Injector Circuit
    P0211 Cylinder 11 - Injector Circuit
    P0212 Cylinder 12 - Injector Circuit
    P0213 Cold Start Injector 1
    P0214 Cold Start Injector 2
    P0215 Engine Shutoff Solenoid
    P0216 Injection Timing Control Circuit
    P0217 Engine Coolant Over Temperature Condition
    P0218 Transmission Fluid Over Temperature Condition
    P0219 Engine Over speed Condition
    P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit
    P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance
    P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
    P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
    P0224 Throttle/Pedal Position Sensor/Switch "B" Circuit Intermittent
    P0225 Throttle/Pedal Position Sensor/Switch "C" Circuit
    P0226 Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance
    P0227 Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input
    P0228 Throttle/Pedal Position Sensor/Switch "C" Circuit High Input
    P0229 Throttle/Pedal Position Sensor/Switch "C" Circuit Intermittent
    P0230 Fuel Pump Primary Circuit
    P0231 Fuel Pump Secondary Circuit Low
    P0232 Fuel Pump Secondary Circuit High
    P0233 Fuel Pump Secondary Circuit Intermittent
    P0234 Turbo/Super Charger Over boost Condition
    P0235 Turbo/Super Charger Boost Sensor "A" Circuit
    P0236 Turbo/Super Charger Boost Sensor "A" Circuit Range/Performance
    P0237 Turbo/Super Charger Boost Sensor "A" Circuit Low
    P0238 Turbo/Super Charger Boost Sensor "A" Circuit High
    P0239 Turbo/Super Charger Boost Sensor "B" Circuit
    P0240 Turbo/Super Charger Boost Sensor "B" Circuit Range/Performance
    P0241 Turbo/Super Charger Boost Sensor "B" Circuit Low
    P0242 Turbo/Super Charger Boost Sensor "B" Circuit High
    P0243 Turbo/Super Charger Wastegate Solenoid "A"
    P0244 Turbo/Super Charger Wastegate Solenoid "A" Range/Performance
    P0245 Turbo/Super Charger Wastegate Solenoid "A" Low
    P0246 Turbo/Super Charger Wastegate Solenoid "A" High
    P0247 Turbo/Super Charger Wastegate Solenoid "B"
    P0248 Turbo/Super Charger Wastegate Solenoid "B" Range/Performance
    P0249 Turbo/Super Charger Wastegate Solenoid "B" Low
    P0250 Turbo/Super Charger Wastegate Solenoid "B" High
    P0251 Injection Pump Fuel Metering Control "A" (Cam/Rotor/Injector)
    P0252 Injection Pump Fuel Metering Control "A" Range/Performance
    P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
    P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
    P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
    P0256 Injection Pump Fuel Metering Control "B" (Cam/Rotor/Injector)
    P0257 Injection Pump Fuel Metering Control "B" Range/Performance
    P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
    P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
    P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
    P0261 Cylinder 1 Injector Circuit Low
    P0262 Cylinder 1 Injector Circuit High
    P0263 Cylinder 1 Contribution/Balance
    P0264 Cylinder 2 Injector Circuit Low
    P0265 Cylinder 2 Injector Circuit High
    P0266 Cylinder 2 Contribution/Balance
    P0267 Cylinder 3 Injector Circuit Low
    P0268 Cylinder 3 Injector Circuit High
    P0269 Cylinder 3 Contribution/Balance
    P0270 Cylinder 4 Injector Circuit Low
    P0271 Cylinder 4 Injector Circuit High
    P0272 Cylinder 4 Contribution/Balance
    P0273 Cylinder 5 Injector Circuit Low
    P0274 Cylinder 5 Injector Circuit High
    P0275 Cylinder 5 Contribution/Balance
    P0276 Cylinder 6 Injector Circuit Low
    P0277 Cylinder 6 Injector Circuit High
    P0278 Cylinder 6 Contribution/Balance
    P0279 Cylinder 7 Injector Circuit Low
    P0280 Cylinder 7 Injector Circuit High
    P0281 Cylinder 7 Contribution/Balance
    P0282 Cylinder 8 Injector Circuit Low
    P0283 Cylinder 8 Injector Circuit High
    P0284 Cylinder 8 Contribution/Balance
    P0285 Cylinder 9 Injector Circuit Low
    P0286 Cylinder 9 Injector Circuit High
    P0287 Cylinder 9 Contribution/Balance
    P0288 Cylinder 10 Injector Circuit Low
    P0289 Cylinder 10 Injector Circuit High
    P0290 Cylinder 10 Contribution/Balance
    P0291 Cylinder 11 Injector Circuit Low
    P0292 Cylinder 11 Injector Circuit High
    P0293 Cylinder 11 Contribution/Balance
    P0294 Cylinder 12 Injector Circuit Low
    P0295 Cylinder 12 Injector Circuit High
    P0296 Cylinder 12 Contribution/Balance
    P0298 Engine Oil Over Temperature
    P0300 Random/Multiple Cylinder Misfire Detected
    P0301 Cylinder 1 Misfire Detected
    P0302 Cylinder 2 Misfire Detected
    P0303 Cylinder 3 Misfire Detected
    P0304 Cylinder 4 Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    P0306 Cylinder 6 Misfire Detected
    P0307 Cylinder 7 Misfire Detected
    P0308 Cylinder 8 Misfire Detected
    P0309 Cylinder 9 Misfire Detected
    P0310 Cylinder 10 Misfire Detected
    P0311 Cylinder 11 Misfire Detected
    P0312 Cylinder 12 Misfire Detected
    P0313 Misfire Detected With Low Fuel
    P0314 Single Cylinder Misfire (cylinder not specified)
    P0320 Ignition/Distributor Engine Speed Input Circuit
    P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
    P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
    P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
    P0325 Knock Sensor 1 Circuit (Bank 1 or Single Sensor)
    P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
    P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
    P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
    P0329 Knock Sensor 1 Circuit Input Intermittent (Bank 1 or Single Sensor)
    P0330 Knock Sensor 2 Circuit (Bank 2)
    P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
    P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
    P0333 Knock Sensor 2 Circuit High Input (Bank 2)
    P0334 Knock Sensor 2 Circuit Input Intermittent (Bank 2)
    P0335 Crankshaft Position Sensor "A" Circuit
    P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
    P0337 Crankshaft Position Sensor "A" Circuit Low Input
    P0338 Crankshaft Position Sensor "A" Circuit High Input
    P0339 Crankshaft Position Sensor "A" Circuit Intermittent
    P0340 Camshaft Position Sensor Circuit
    P0341 Camshaft Position Sensor Circuit Range/Performance
    P0342 Camshaft Position Sensor Circuit Low Input
    P0343 Camshaft Position Sensor Circuit High Input
    P0344 Camshaft Position Sensor Circuit Intermittent
    P0350 Ignition Coil Primary/Secondary Circuit
    P0351 Ignition Coil "A" Primary/Secondary Circuit
    P0352 Ignition Coil "B" Primary/Secondary Circuit
    P0353 Ignition Coil "C" Primary/Secondary Circuit
    P0354 Ignition Coil "D" Primary/Secondary Circuit
    P0355 Ignition Coil "E" Primary/Secondary Circuit
    P0356 Ignition Coil "F" Primary/Secondary Circuit
    P0357 Ignition Coil "G" Primary/Secondary Circuit
    P0358 Ignition Coil "H" Primary/Secondary Circuit
    P0359 Ignition Coil "I" Primary/Secondary Circuit
    P0360 Ignition Coil "J" Primary/Secondary Circuit
    P0361 Ignition Coil "K" Primary/Secondary Circuit
    P0362 Ignition Coil "L" Primary/Secondary Circuit
    P0370 Timing Reference High Resolution Signal "A"
    P0371 Timing Reference High Resolution Signal "A" Too Many Pulses
    P0372 Timing Reference High Resolution Signal "A" Too Few Pulses
    P0373 Timing Reference High Resolution Signal "A" Intermittent/Erratic Pulses
    P0374 Timing Reference High Resolution Signal "A" No Pulses
    P0375 Timing Reference High Resolution Signal "B"
    P0376 Timing Reference High Resolution Signal "B" Too Many Pulses
    P0377 Timing Reference High Resolution Signal "B" Too Few Pulses
    P0378 Timing Reference High Resolution Signal "B" Intermittent/Erratic Pulses
    P0379 Timing Reference High Resolution Signal "B" No Pulses
    P0380 Glow Plug /Heater Circuit "A"
    P0381 Glow Plug /Heater Indicator Circuit
    P0382 Glow Plug /Heater Circuit "B"
    P0385 Crankshaft Position Sensor "B" Circuit
    P0386 Crankshaft Position Sensor "B" Circuit Range/Performance
    P0387 Crankshaft Position Sensor "B" Circuit Low Input
    P0388 Crankshaft Position Sensor "B" Circuit High Input
    P0389 Crankshaft Position Sensor "B" Circuit Intermittent
    P0400 Exhaust Gas Recirculation Flow
    P0401 Exhaust Gas Recirculation Flow Insufficient Detected
    P0402 Exhaust Gas Recirculation Flow Excessive Detected
    P0403 Exhaust Gas Recirculation Circuit
    P0404 EGR Open Valve Pintle Error
    P0404 Exhaust Gas Recirculation Circuit Range/Performance
    P0405 EGR Sensor Signal Low
    P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low
    P0406 Exhaust Gas Recirculation Sensor "A" Circuit High
    P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low
    P0408 Exhaust Gas Recirculation Sensor "B" Circuit High
    P0410 Secondary Air Injection System
    P0411 Secondary Air Injection System Incorrect Flow Detected
    P0412 Secondary Air Injection System Switching Valve "A" Circuit
    P0413 Secondary Air Injection System Switching Valve "A" Circuit Open
    P0414 Secondary Air Injection System Switching Valve "A" Circuit Shorted
    P0415 Secondary Air Injection System Switching Valve "B" Circuit
    P0416 Secondary Air Injection System Switching Valve "B" Circuit Open
    P0417 Secondary Air Injection System Switching Valve "B" Circuit Shorted
    P0418 Secondary Air Injection System Relay "A" Circuit
    P0419 Secondary Air Injection System Relay "B" Circuit
    P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
    P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
    P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
    P0425 Catalyst Temperature Sensor (Bank 1)
    P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)
    P0427 Catalyst Temperature Sensor Low Input (Bank 1)
    P0428 Catalyst Temperature Sensor High Input (Bank 1)
    P0429 Catalyst Heater Control Circuit (Bank 1)
    P0430 Catalyst System Efficiency Below Threshold (Bank 2)
    P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
    P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
    P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
    P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
    P0435 Catalyst Temperature Sensor (Bank 2)
    P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)
    P0437 Catalyst Temperature Sensor Low Input (Bank 2)
    P0438 Catalyst Temperature Sensor High Input (Bank 2)
    P0439 Catalyst Heater Control Circuit (Bank 2)
    P0440 Evaporative Emission Control System
    P0441 Evaporative Emission Control System Incorrect Purge Flow
    P0442 Evaporative Emission Control System Leak Detected (small leak)
    P0443 Evaporative Emission Control System Purge Control Valve Circuit
    P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
    P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
    P0446 Evaporative Emission Control System Vent Control Circuit
    P0447 Evaporative Emission Control System Vent Control Circuit Open
    P0448 Evaporative Emission Control System Vent Control Circuit Shorted
    P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit
    P0450 Evaporative Emission Control System Pressure Sensor
    P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
    P0452 Evaporative Emission Control System Pressure Sensor Low Input
    P0453 Evaporative Emission Control System Pressure Sensor High Input
    P0454 Evaporative Emission Control System Pressure Sensor Intermittent
    P0455 Evaporative Emission Control System Leak Detected (gross leak)
    P0456 Evaporative Emission Control System Leak Detected (very small leak)
    P0460 Fuel Level Sensor Circuit
    P0461 Fuel Level Sensor Circuit Range/Performance
    P0462 Fuel Level Sensor Circuit Low Input
    P0463 Fuel Level Sensor Circuit High Input
    P0464 Fuel Level Sensor Circuit Intermittent
    P0465 Purge Flow Sensor Circuit
    P0466 Purge Flow Sensor Circuit Range/Performance
    P0467 Purge Flow Sensor Circuit Low Input
    P0468 Purge Flow Sensor Circuit High Input
    P0469 Purge Flow Sensor Circuit Intermittent
    P0470 Exhaust Pressure Sensor
    P0471 Exhaust Pressure Sensor Range/Performance
    P0472 Exhaust Pressure Sensor Low
    P0473 Exhaust Pressure Sensor High
    P0474 Exhaust Pressure Sensor Intermittent
    P0475 Exhaust Pressure Control Valve
    P0476 Exhaust Pressure Control Valve Range/Performance
    P0477 Exhaust Pressure Control Valve Low
    P0478 Exhaust Pressure Control Valve High
    P0479 Exhaust Pressure Control Valve Intermittent
    P0480 Cooling Fan 1 Control Circuit
    P0481 Cooling Fan 2 Control Circuit
    P0482 Cooling Fan 3 Control Circuit
    P0483 Cooling Fan Rationality Check
    P0484 Cooling Fan Circuit Over Current
    P0485 Cooling Fan Power/Ground Circuit
    P0491 Secondary Air Injection System (bank 1)
    P0492 Secondary Air Injection System (bank 2)
    P0500 Vehicle Speed Sensor
    P0501 Vehicle Speed Sensor Range/Performance
    P0502 Vehicle Speed Sensor Circuit Low Input
    P0503 Vehicle Speed Sensor Intermittent / Erratic / High
    P0505 Idle Control System
    P0506 Idle Control System RPM Lower Than Expected
    P0507 Idle Control System RPM Higher Than Expected
    P0510 Closed Throttle Position Switch
    P0512 Starter Request Circuit
    P0520 Engine Oil Pressure Sensor/Switch Circuit
    P0521 Engine Oil Pressure Sensor/Switch Range/Performance
    P0522 Engine Oil Pressure Sensor/Switch Low Voltage
    P0523 Engine Oil Pressure Sensor/Switch High Voltage
    P0524 Engine Oil Pressure Too Low
    P0530 A/C Refrigerant Pressure Sensor Circuit
    P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
    P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
    P0533 A/C Refrigerant Pressure Sensor Circuit High Input
    P0534 A/C Refrigerant Charge Loss
    P0550 Power Steering Pressure Sensor Circuit
    P0551 Power Steering Pressure Sensor Circuit Range/Performance
    P0552 Power Steering Pressure Sensor Circuit Low Input
    P0553 Power Steering Pressure Sensor Circuit High Input
    P0554 Power Steering Pressure Sensor Circuit Intermittent
    P0560 System Voltage
    P0561 System Voltage Unstable
    P0562 System Voltage Low
    P0563 System Voltage High
    P0565 Cruise Control On Signal
    P0566 Cruise Control Off Signal
    P0567 Cruise Control Resume Signal
    P0568 Cruise Control Set Signal
    P0569 Cruise Control Coast Signal
    P0570 Cruise Control Accel Signal
    P0571 Cruise Control / Brake Switch "A" Circuit
    P0572 Cruise Control / Brake Switch "A" Circuit Low
    P0573 Cruise Control / Brake Switch "A" Circuit High
    P0574 Cruise Control System - Vehicle Speed Too High
    P0575 Reserved for Cruise Codes
    P0576 Reserved for Cruise Codes
    P0577 Reserved for Cruise Codes
    P0578 Reserved for Cruise Codes
    P0579 Reserved for Cruise Codes
    P0580 Reserved for Cruise Codes
    P0600 Serial Communication Link
    P0601 Internal Control Module Memory Check Sum Error
    P0602 Control Module Programming Error
    P0603 Internal Control Module Keep Alive Memory (KAM) Error
    P0604 Internal Control Module Random Access Memory (RAM) Error
    P0605 Internal Control Module Read Only Memory (ROM) Error
    P0606 ECM/PCM Processor
    P0608 Control Module VSS Output "A"
    P0609 Control Module VSS Output "B"
    P0615 Starter Relay Circuit
    P0616 Starter Relay Circuit Low
    P0617 Starter Relay Circuit High
    P0620 Generator Control Circuit
    P0621 Generator "L" Terminal Control Circuit
    P0622 Generator "F" Terminal Control Circuit
    P0630 VIN Not Programmed or Mismatch - ECM/PCM
    P0631 VIN Not Programmed or Mismatch - TCM
    P0645 A/C Clutch Relay Circuit
    P0650 Malfunction Indicator Lamp (MIL) Control Circuit
    P0654 Engine RPM Output Circuit
    P0655 Engine Hot Lamp Output Control Circuit
    P0656 Fuel Level Output Circuit
    P0700 Transmission Control System (will show up as PCM code, but is all TCM Related)
    P0701 Transmission Control System Range/Performance
    P0702 Transmission Control System Electrical
    P0703 Torque Converter/Brake Switch "B" Circuit
    P0704 Clutch Switch Input Circuit
    P0705 Transmission Range Sensor Circuit (PRNDL Input)
    P0706 Transmission Range Sensor Circuit Range/Performance
    P0707 Transmission Range Sensor Circuit Low Input
    P0708 Transmission Range Sensor Circuit High Input
    P0709 Transmission Range Sensor Circuit Intermittent
    P0710 Transmission Fluid Temperature Sensor Circuit
    P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
    P0712 Transmission Fluid Temperature Sensor Circuit Low Input
    P0713 Transmission Fluid Temperature Sensor Circuit High Input
    P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
    P0715 Input/Turbine Speed Sensor Circuit
    P0716 Input/Turbine Speed Sensor Circuit Range/Performance
    P0717 Input/Turbine Speed Sensor Circuit No Signal
    P0718 Input/Turbine Speed Sensor Circuit Intermittent
    P0719 Torque Converter/Brake Switch "B" Circuit Low
    P0720 Output Speed Sensor Circuit
    P0721 Output Speed Sensor Circuit Range/Performance
    P0722 Output Speed Sensor Circuit No Signal
    P0723 Output Speed Sensor Circuit Intermittent
    P0724 Torque Converter/Brake Switch "B" Circuit High
    P0725 Engine Speed Input Circuit
    P0726 Engine Speed Input Circuit Range/Performance
    P0727 Engine Speed Input Circuit No Signal
    P0728 Engine Speed Input Circuit Intermittent
    P0730 Incorrect Gear Ratio
    P0731 Gear 1 Incorrect Ratio
    P0732 Gear 2 Incorrect Ratio
    P0733 Gear 3 Incorrect Ratio
    P0734 Gear 4 Incorrect Ratio
    P0735 Gear 5 Incorrect Ratio
    P0736 Reverse Incorrect Ratio
    P0737 TCM Engine Speed Output Circuit
    P0738 TCM Engine Speed Output Circuit Low
    P0739 TCM Engine Speed Output Circuit High
    P0740 Torque Converter Clutch Circuit
    P0741 Torque Converter Clutch Circuit Performance or Stuck Off
    P0742 Torque Converter Clutch Circuit Stuck On
    P0743 Torque Converter Clutch Circuit Electrical
    P0744 Torque Converter Clutch Circuit Intermittent
    P0745 Pressure Control Solenoid "A"
    P0746 Pressure Control Solenoid "A" Performance or Stuck Off
    P0747 Pressure Control Solenoid "A" Stuck On
    P0748 Pressure Control Solenoid "A" Electrical
    P0749 Pressure Control Solenoid "A" Intermittent
    P0750 Shift Solenoid "A"
    P0751 Shift Solenoid "A" Performance or Stuck Off
    P0752 Shift Solenoid "A" Stuck On
    P0753 Shift Solenoid "A" Electrical
    P0754 Shift Solenoid "A" Intermittent
    P0755 Shift Solenoid "B"
    P0756 Shift Solenoid "B" Performance or Stuck Off
    P0757 Shift Solenoid "B" Stuck On
    P0758 Shift Solenoid "B" Electrical
    P0759 Shift Solenoid "B" Intermittent
    P0760 Shift Solenoid "C"
    P0761 Shift Solenoid "C" Performance or Stuck Off
    P0762 Shift Solenoid "C" Stuck On
    P0763 Shift Solenoid "C" Electrical
    P0764 Shift Solenoid "C" Intermittent
    P0765 Shift Solenoid "D"
    P0766 Shift Solenoid "D" Performance or Stuck Off
    P0767 Shift Solenoid "D" Stuck On
    P0768 Shift Solenoid "D" Electrical
    P0769 Shift Solenoid "D" Intermittent
    P0770 Shift Solenoid "E"
    P0771 Shift Solenoid "E" Performance or Stuck Off
    P0772 Shift Solenoid "E" Stuck On
    P0773 Shift Solenoid "E" Electrical
    P0774 Shift Solenoid "E" Intermittent
    P0775 Pressure Control Solenoid "B"
    P0776 Pressure Control Solenoid "B" Performance or Stuck Off
    P0777 Pressure Control Solenoid "B" Stuck On
    P0778 Pressure Control Solenoid "B" Electrical
    P0779 Pressure Control Solenoid "B" Intermittent
    P0780 Shift
    P0781 1-2 Shift
    P0782 2-3 Shift
    P0783 3-4 Shift
    P0784 4-5 Shift
    P0785 Shift/Timing Solenoid
    P0786 Shift/Timing Solenoid Range/Performance
    P0787 Shift/Timing Solenoid Low
    P0788 Shift/Timing Solenoid High
    P0789 Shift/Timing Solenoid Intermittent
    P0790 Normal/Performance Switch Circuit
    P0791 Intermediate Shaft Speed Sensor Circuit
    P0792 Intermediate Shaft Speed Sensor Circuit Range/Performance
    P0793 Intermediate Shaft Speed Sensor Circuit No Signal
    P0794 Intermediate Shaft Speed Sensor Circuit Intermittent
    P0795 Pressure Control Solenoid "C"
    P0796 Pressure Control Solenoid "C" Performance or Stuck Off
    P0797 Pressure Control Solenoid "C" Stuck On
    P0798 Pressure Control Solenoid "C" Electrical
    P0799 Pressure Control Solenoid "C" Intermittent
    P0801 Reverse Inhibit Control Circuit
    P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit
    P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit
    P0805 Clutch Position Sensor Circuit
    P0806 Clutch Position Sensor Circuit Range/Performance
    P0807 Clutch Position Sensor Circuit Low
    P0808 Clutch Position Sensor Circuit High
    P0809 Clutch Position Sensor Circuit Intermittent
    P0810 Clutch Position Control Error
    P0811 Excessive Clutch Slippage
    P0812 Reverse Input Circuit
    P0813 Reverse Output Circuit
    P0814 Transmission Range Display Circuit
    P0815 Upshift Switch Circuit
    P0816 Downshift Switch Circuit
    P0817 Starter Disable Circuit
    P0820 Gear Lever X-Y Position Sensor Circuit
    P0821 Gear Lever X Position Circuit
    P0822 Gear Lever Y Position Circuit
    P0823 Gear Lever X Position Circuit Intermittent
    P0824 Gear Lever Y Position Circuit Intermittent
    P0825 Gear Lever Push-Pull Switch (Shift Anticipate)
    P0830 Clutch Pedal Switch "A" Circuit
    P0831 Clutch Pedal Switch "A" Circuit Low
    P0832 Clutch Pedal Switch "A" Circuit High
    P0833 Clutch Pedal Switch "B" Circuit
    P0834 Clutch Pedal Switch "B" Circuit Low
    P0835 Clutch Pedal Switch "B" Circuit High
    P0840 Trans Pressure Switch Solenoid C Circuit
    P0841 Trans Pressure Switch Solenoid C Circuit Stuck Open
    P0842 Trans Pressure Switch Solenoid C Circuit Stuck Closed
    P0843 Trans Pressure Switch Solenoid C Circuit High
    P0845 Trans Pressure Switch Solenoid D Circuit
    P0846 Trans Pressure Switch Solenoid D Circuit Stuck Open
    P0847 Trans Pressure Switch Solenoid D Circuit Stuck Closed
    P0848 Trans Pressure Switch Solenoid D Circuit High
    P1101 Induction Air Measurement - Cross-check Out of Range
    P1105 Secondary Vacuum Sensor Circuit
    P1106 MAP Sensor Signal Intermittent High
    P1107 MAP Sensor Signal Intermittent Low
    P1108 MAP to BARO Correlation
    P1109 Secondary Port Throttle System
    P1110 Engine High Intake Air Temperature Condition
    P1111 Intake Air Temperature Circuit Intermittent High
    P1112 Intake Air Temperature Circuit Intermittent Low
    P1114 Engine Coolant Temperature - Circuit Low Input Intermittent
    P1115 Engine Coolant Temperature - Circuit High Input intermittent
    P1116 Engine Coolant Temperature Signal Unstable or Intermittent
    P1117 Engine Coolant Temperature Signal Out-Of-Range Low
    P1118 Engine Coolant Temperature Signal Out-Of-Range High
    P1119 Engine Coolant Temperature Signal Out-Of-Range with Transmission Temperature
    P1120 Throttle Position Sensor "A" Circuit
    P1121 Throttle Position Circuit Signal Intermittent High
    P1122 Throttle Position Circuit Signal Intermittent Low
    P1125 Multiple Throttle/Pedal Position Sensor
    P1127 Open Loop CO Adjust Circuit
    P1130 Oxygen Sensor Low Signal Variance (Bank 1 - Sensor 1)
    P1131 Oxygen Sensor Low Signal Variance (Bank 1 - Sensor 2)
    P1132 Oxygen Sensor Low Signal Variance (Bank 2 - Sensor 1)
    P1133 Oxygen Sensor System - Too Few O2S R/L and L/R Switches . (Bank 1 - Sensor 1)
    P1134 Oxygen Sensor Circuit - Transition Switch Time Ratio (Bank 1 - Sensor 1)
    P1135 Oxygen Sensor Circuit - Mean Voltage Level Lean (Bank 1 - Sensor 1)
    P1136 Oxygen Sensor Circuit - Mean Voltage Level Rich (Bank 1 - Sensor 1)
    P1137 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 1 - Sensor 2)
    P1138 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 1 - Sensor 2)
    P1139 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 1 - Sensor 2)
    P1140 Oxygen Sensor Circuit - Transition Switch Time Ratio (Bank 1 - Sensor 2)
    P1141 Oxygen Sensor Circuit - Mean Voltage Level Lean (Bank 1 - Sensor 2)
    P1142 Oxygen Sensor Circuit - Mean Voltage Level Rich (Bank 1 - Sensor 2)
    P1143 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 1 - Sensor 3)
    P1144 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 1 - Sensor 3)
    P1145 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 1 - Sensor 3)
    P1153 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 2 - Sensor 1)
    P1154 Oxygen Sensor Circuit - Transition Switch Time Ratio (Bank 2 - Sensor 1)
    P1155 Oxygen Sensor Circuit - Mean Voltage Level Lean (Bank 2 - Sensor 1)
    P1156 Oxygen Sensor Circuit - Mean Voltage Level Rich (Bank 2 - Sensor 1)
    P1157 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 2 - Sensor 2)
    P1158 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 2 - Sensor 2)
    P1159 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 2 - Sensor 2)
    P1163 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 2 - Sensor 3)
    P1164 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 2 - Sensor 3)
    P1165 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 2 - Sensor 3)
    P1166 Oxygen Sensor System - Low Voltage During Power Enrichment (Bank 1 - Sensor 1)
    P1167 Oxygen Sensor System - High Voltage During Decel Fuel Cut Off (Bank 1 - Sensor 1)
    P1168 Oxygen Sensor System - Low Voltage During Power Enrichment (Bank 2 - Sensor 1)
    P1169 Oxygen Sensor System - High Voltage During Decel Fuel Cut Off (Bank 2 - Sensor 1)
    P1170 Bank to Bank Fuel Trim Offset
    P1171 Primary Fuel Pump Insufficient / No Fuel Flow
    P1172 Secondary Fuel Pump Insufficient / No Fuel Flow
    P1173 Limitation of Injection Quantity
    P1180 Engine High Fuel Temperature Condition
    P1190 Engine Vacuum Leak
    P1191 Intake Air Duct Air Leak
    P1195 Engine Low Oil Pressure Condition
    P1200 Injector Circuit
    P1201 Secondary Mass Air Flow Range/Performance
    P1202 Secondary Mass or Volume Air Flow Circuit Low Input
    P1203 Secondary Mass or Volume Air Flow Circuit High Input
    P1211 Mass Air Flow Circuit Intermittent High
    P1212 Mass Air Flow Circuit Intermittent Low
    P1214 Injection Pump Timing Offset Error
    P1215 GFD Indication
    P1216 Fuel Solenoid Response Time Too Short
    P1217 Fuel Solenoid Response Time Too Long
    P1218 Injection Pump Calibration Resistor Error
    P1219 Throttle Position Sensor Reference Voltage Error
    P1220 Throttle Position Sensor "B" Circuit
    P1221 Throttle Position Sensor "A/B" Range/Performance
    P1222 Injector Circuit Intermittent - Cylinder 1
    P1225 Injector Circuit Intermittent - Cylinder 2
    P1228 Injector Circuit Intermittent - Cylinder 3
    P1231 Injector Circuit Intermittent - Cylinder 4
    P1234 Injector Circuit Intermittent - Cylinder 5
    P1237 Injector Circuit Intermittent - Cylinder 6
    P1240 Injector Circuit Intermittent - Cylinder 7
    P1243 Injector Circuit Intermittent - Cylinder 8
    P1245 Intake Plenum Switchover Valve Circuit
    P1246 Intake Resonance Switchover Valve Circuit
    P1257 Supercharger - Overboost
    P1258 Engine Coolant Over - Temperature Protection
    P1260 Fuel Pump Speed Control Circuit
    P1270 Accelerator Pedal Position Sensor A/D Converter Error
    P1271 Accelerator Pedal Position Sensors 1 & 2 Correlation Error
    P1272 Accelerator Pedal Position Sensors 2 & 3 Correlation Error
    P1273 Accelerator Pedal Position Sensors 1 & 3 Correlation Error
    P1274 Injectors Wired Incorrectly
    P1275 Accelerator Pedal Position Sensor 1 Circuit
    P1276 Accelerator Pedal Position Sensor 1 Circuit Performance
    P1277 Accelerator Pedal Position Sensor 1 Circuit Low Voltage
    P1278 Accelerator Pedal Position Sensor 1 Circuit High Voltage
    P1279 Accelerator Pedal Position Sensor 1 Circuit Intermittent
    P1280 Accelerator Pedal Position Sensor 2 Circuit
    P1281 Accelerator Pedal Position Sensor 2 Circuit Performance
    P1282 Accelerator Pedal Position Sensor 2 Circuit Low Voltage
    P1283 Accelerator Pedal Position Sensor 2 Circuit High Voltage
    P1284 Accelerator Pedal Position Sensor 2 Circuit Intermittent
    P1285 Accelerator Pedal Position Sensor 3 Circuit
    P1286 Accelerator Pedal Position Sensor 3 Circuit Performance
    P1287 Accelerator Pedal Position Sensor 3 Circuit Low Voltage
    P1288 Accelerator Pedal Position Sensor 3 Circuit High Voltage
    P1289 Accelerator Pedal Position Sensor 3 Circuit Intermittent
    P1310 Ignition Coil Primary/Secondary Current Sense System
    P1311 Ignition Coil "A" Primary/Secondary Circuit
    P1312 Ignition Coil "B" Primary/Secondary Circuit
    P1313 Ignition Coil "C" Primary/Secondary Circuit
    P1314 Ignition Coil "D" Primary/Secondary Circuit
    P1315 Ignition Coil "E" Primary/Secondary Circuit
    P1316 Ignition Coil "F" Primary/Secondary Circuit
    P1317 Ignition Coil "G" Primary/Secondary Circuit
    P1318 Ignition Coil "H" Primary/Secondary Circuit
    P1320 Distributor Signal Interrupt
    P1321 DIS Fault Line
    P1322 DIS EST (Extra or Missing)
    P1323 Loss of High Resolution RPM Information
    P1324 Crank RPM Too Low
    P1326 Combustion Quality Circuit
    P1336 Crankshaft Position System Variation Not Learned
    P1340 Ignition System Cylinder Identifier
    P1345 Crankshaft/Camshaft Correlation Error
    P1350 Bypass Line Monitor
    P1351 EST Output High or Pulses Detected when Grounded - Cylinder 1
    P1352 EST Output High or Pulses Detected when Grounded - Cylinder 2
    P1353 EST Output High or Pulses Detected when Grounded - Cylinder 3
    P1354 EST Output High or Pulses Detected when Grounded - Cylinder 4
    P1355 EST Output High or Pulses Detected when Grounded - Cylinder 5
    P1356 EST Output High or Pulses Detected when Grounded - Cylinder 6
    P1357 EST Output High or Pulses Detected when Grounded - Cylinder 7
    P1358 EST Output High or Pulses Detected when Grounded - Cylinder 8
    P1359 Ignition Control Circuit Group A (cylinders N, N, N, N )
    P1360 Ignition Control Circuit Group B (cylinders N, N, N, N )
    P1361 EST Not Toggling After Enabled - Cylinder 1
    P1362 EST Not Toggling After Enabled - Cylinder 2
    P1363 EST Not Toggling After Enabled - Cylinder 3
    P1364 EST Not Toggling After Enabled - Cylinder 4
    P1365 EST Not Toggling After Enabled - Cylinder 5
    P1366 EST Not Toggling After Enabled - Cylinder 6
    P1367 EST Not Toggling After Enabled - Cylinder 7
    P1368 EST Not Toggling After Enabled - Cylinder 8
    P1370 Too Many Low Resolution Pulses
    P1371 Too Few Low Resolution Pulses
    P1372 Crankshaft Position Sensor Circuits Performance
    P1374 Crank to Low Resolution Correlation
    P1375 No Crank Sensor A or B
    P1376 Reference Low Voltage Out of Range
    P1377 CAM To Reference Correlation
    P1380 ABS Preventing Rough Road/Misfire Diagnostic
    P1381 Serial Communication Preventing Rough Road/Misfire Diagnostic
    P1382 ABS Control Module Performance (Used for 1997 Model Year only)
    P1390 Wheel Speed Sensor "A" / G-Sensor Circuit
    P1391 Wheel Speed Sensor "A" / G-Sensor Circuit Range/Performance
    P1392 Wheel Speed Sensor "A" / G-Sensor Circuit Low Input
    P1393 Wheel Speed Sensor "A" / G-Sensor Circuit High Input
    P1394 Wheel Speed Sensor "A" / G-Sensor Circuit Intermittent
    P1395 Wheel Speed Sensor "B" / G-Sensor Circuit
    P1396 Wheel Speed Sensor "B" / G-Sensor Circuit Range/Performance
    P1397 Wheel Speed Sensor "B" / G-Sensor Circuit Low Input
    P1398 Wheel Speed Sensor "B" / G-Sensor Circuit High Input
    P1399 Wheel Speed Sensor "B" / G-Sensor Circuit Intermittent
    P1403 Exhaust Gas Recirculation Solenoid Low
    P1404 EGR Closed Valve Pintle Error
    P1404 Exhaust Gas Recirculation System - Closed Valve Pintle Error
    P1405 Exhaust Gas Recirculation Solenoid High
    P1406 EGR Pintle Position Error
    P1406 Exhaust Gas Recirculation System Pintle Position Error
    P1407
    P1408 Exhaust Gas Recirculation Vacuum System
    P1409 Exhaust Gas Recirculation Vacuum System Leak/Low Supply
    P1410 Exhaust Gas Recirculation Vacuum System Restriction
    P1415 Secondary Air Injection - Bank 1
    P1416 Secondary Air Injection - Bank 2
    P1420 Intake Air Low Pressure Switch Circuit Low Voltage
    P1421 Intake Air Low Pressure Switch Circuit High Voltage
    P1422 Intake Air High Pressure Switch Circuit Low Voltage
    P1423 Intake Air High Pressure Switch Circuit High Voltage
    P1431 Fuel Level Sensor Circuit Range/Performance (Secondary Tank)
    P1432 Fuel Level Sensor Circuit Low Input (Secondary Tank)
    P1433 Fuel Level Sensor Circuit High Input (Secondary Tank)
    P1441 Evaporative Emission Control System Continuous Open Purge Flow
    P1442 Purge Solenoid Diagnostic Vacuum Switch
    P1443 Evaporative Emission Control System Purge Control Valve 2 Circuit
    P1445 Fuel Heated Catalyst System Bank 1
    P1450 Catalyst Heater Diagnostic
    P1451 Catalyst Heater Diagnostic
    P1452 Catalyst Heater Diagnostic
    P1453 Catalyst Heater Diagnostic
    P1454 Catalyst Heater Diagnostic
    P1455 Catalyst Heater Diagnostic
    P1456 Catalyst Heater Diagnostic
    P1457 Catalyst Heater Diagnostic
    P1458 Catalyst Heater Diagnostic
    P1459 Catalyst Heater Diagnostic
    P1483 Engine Cooling System Performance
    P1501 Vehicle Speed Sensor Intermittent
    P1504 Aux Vehicle Speed Output Circuit
    P1505 Starter Relay Circuit
    P1506 Starter Relay Circuit Low
    P1507 Starter Relay Circuit High
    P1508 Idle Control System Low/Closed
    P1509 Idle Control System High/Open
    P1510 Throttle Control System - In Limitation
    P1511 Throttle Control System - Backup System Performance
    P1512 Throttle Control System - Minimum Throttle Position
    P1513 EBTCM to PCM Drag Reduction Request Input Circuit
    P1514 Throttle Actuator Control (TAC) System MAF Correlation Error
    P1515 Command vs. Actual Throttle Position Correlation (PCM) Error
    P1516 Command vs. Actual Throttle Position Correlation (TAC Module) Error
    P1517 Throttle Actuator Control (TAC) Module Processor
    P1518 PCM to TAC Module Serial Data Circuit
    P1519 Throttle Actuator Control (TAC) Module
    P1520 Park/Neutral Discrete Error
    P1521 P/N to D/R at High Throttle Angle
    P1522 P/N to D/R at High RPM
    P1523 Throttle Actuator Control Return Performance
    P1524 Throttle Position Sensor Out of Adjustment
    P1525 Throttle Body Service Required
    P1526 TPS Learn Not Done After Reprogramming
    P1527 Transaxle Range/Pressure Switch Comparison
    P1528 Governor
    P1529 Heated Windshield Request
    P1530 Throttle Control System - Amplifier Adjustment
    P1531 A/C Temperature Sensor Circuit
    P1532 A/C Low Side Temperature Sensor Low Input
    P1533 A/C Low Side Temperature Sensor High Input
    P1534 A/C High Side Temperature Sensor Low Input
    P1535 A/C High Side Temperature Sensor High Input
    P1536 A/C Coolant Over Temperature
    P1537 Very Low Refrigerant Pressure
    P1538 A/C Request Shorted High
    P1539 High Side Pressure Switch or A/C Relay Shorted
    P1540 A/C High Pressure Condition
    P1541 A/C High Side Over Temperature
    P1542 A/C High Discharge Temperature/Pressure
    P1543 Low Refrigerant Condition
    P1544 Very Low Refrigerant Condition
    P1545 A/C High Pressure Switch or A/C Clutch Relay Circuit
    P1546 A/C Clutch Status Circuit Open
    P1547 A/C System Performance Degraded
    P1548 A/C "Mode" Circuit Low
    P1549 A/C "Mode" Circuit High
    P1554 Stepper Motor Cruise
    P1555 Electronic Variable Orifice Output
    P1558 Cruise Control - Servo Indicates Low
    P1559 Cruise Control - Power Management Mode
    P1560 Cruise Control - Transmission not in Drive
    P1561 Cruise Control - Vent Solenoid Failure
    P1562 Cruise Control - Vacuum Solenoid Failure
    P1563 Cruise Control - Vehicle Speed and Set Speed Difference Too High
    P1564 Cruise Control - Vehicle Acceleration Too High
    P1565 Cruise Control - Servo Position Sensor Failure
    P1566 Cruise Control - Engine RPM Too High
    P1567 Cruise Control - Auto Brake Control Disengage
    P1568 Cruise Control Servo Stroke Greater than Commanded in Cruise
    P1569 Cruise Control Servo Stroke High While not in Cruise Control
    P1570 Traction Control Active While in Cruise
    P1571 Traction Control PWM Link
    P1572 Traction Control Active Too Long
    P1573 Loss of ABS Serial Data
    P1574 Brake Pedal Position Switch
    P1575 Additional Brake Input Diagnostic
    P1576 Shorted Brake Booster Vacuum Sensor Circuit
    P1577 Open Brake Booster Vacuum Sensor Circuit
    P1578 Brake Booster Vacuum Too Low
    P1579 High Throttle Angle on P/N to D/R Transition
    P1580 Cruise Control Move Circuit - Low
    P1581 Cruise Control Move Circuit - High
    P1582 Cruise Control Direction Circuit - Low
    P1583 Cruise Control Direction Circuit - High
    P1584 Cruise Control Disabled
    P1585 Cruise Inhibit Control Circuit
    P1586 Brake Switch Circuit Number 3
    P1599 Engine Stall Detected
    P1601 Serial Communication with Device 1 (PCM, Powertrain Control Module)
    P1602 Serial Communication with Device 2 (ABS, Antilock Brake System)
    P1603 Serial Communication with Device 3 (SIR, Supplemental Inflatable Restraint)
    P1604 Serial Communication with Device 4 (IPC, Instrument Panel Cluster)
    P1605 Serial Communication with Device 5 (HVAC, Heating Ventilation and Air Conditioning)
    P1606 Serial Communication with Device 6 (E&C BUSS, Entertainment and Comfort)
    P1607 Serial Communication with Device 7 (MRD, Magnetic Rotation Device)
    P1608 Serial Communication with Device 8 (CCM, Central Control Module) P1609 Serial Communication with Device 9 (TCS, Traction Control System)
    P1610 Serial Communication with Device 10 (PZM, Platform Zone Module)
    P1611 Serial Communication with Device 11 (CVRTD, Continuously Variable Real Time
    Dampening)
    P1612 Serial Communication with Device 12 (IPM, Instrument Panel Module)
    P1613 Serial Communication with Device 13 (DIM, Driver Information Module)
    P1614 Serial Communication with Device 14 (RIM, Radio Interface Module)
    P1615 Serial Communication with Device 15 (VTD, Vehicle Theft Deterrent)
    P1616 is Wrong Vehicle ID from Instrument Control Module C-40
    P1617 Engine Oil Level Switch Circuit
    P1618 Serial Peripheral Interface (SPI) PCM Internal Communication Error
    P1619 Oil Change - Input
    P1620 Low Coolant Circuit
    P1621 Total EEPROM Failure
    P1622 Cylinder Select Error (OBD1 was code 41)
    P1623 Transmission Temp Pull-up Resistor
    P1624 Customer Snapshot Requested
    P1625 PCM System Reset
    P1626 Anti-Theft Failure
    P1627 A/D Failure
    P1628 Engine Coolant Temperature Pull-Up Resistor Failed
    P1629 Anti-Theft Device - Cranking Signal
    P1630 PCM in Theft Learn Mode
    P1631 Anti-Theft Device - PCM/IPC Password Error
    P1632 Anti-Theft Device - Fuel Disabled
    P1633 PCM Ignition Input "A"
    P1634 PCM Ignition Input "B"
    P1635 5 Volt Reference "A" Low
    P1636 PCM Stack Overrun
    P1637 Generator "L" Terminal Control Circuit
    P1638 Generator "F" Terminal Control Circuit
    P1639 5 Volt Reference "B" Low
    P1640 Add on heater, Circuit (Circuit 1)
    P1641 Add on heater, Circuit (Circuit 2)
    P1642 QDM / ODM "A" - Output 2
    P1643 Wait to Start Lamp Control Circuit
    P1644 QDM / ODM "A" - Output 4
    P1645 QDM / ODM "A" - Output 5
    P1646 5Volt Reference "C" Circuit
    P1647 QDM / ODM "A" - Output 7
    P1648 Anti-Theft Device - Wrong Security Code
    P1649 Anti-Theft Device - No Key/Security Code Programmed
    P1650 QDM / ODM "B"
    P1651 QDM / ODM "B" - Output 1
    P1652 Chassis Pitch Status Control Circuit
    P1653 Engine Oil Level "Low" Lamp Control Circuit
    P1654 Service Throttle Soon Lamp Control Circuit
    P1656 Second Gear Start Lamp Control Circuit
    P1657 QDM / ODM "B" - Output 7
    P1659 Engine Over speed Lamp Control Circuit
    P1660 High Idle Lamp Control Circuit
    P1661 Check Gages Lamp Control Circuit
    P1662 Cruise Control Lamp Control Circuit
    P1663 Engine Oil Life/Change Lamp Control Circuit
    P1664 Service Vehicle Soon Lamp Control Circuit
    P1665 Engine Oil Pressure Gage Output Circuit
    P1666 Engine Shutdown Alarm Control Circuit
    P1667 QDM / ODM "C" - Output 7
    P1670 QDM / ODM "D"
    P1671 QDM / ODM "D" - Output 1
    P1672 QDM / ODM "D" - Output 2
    P1673 QDM / ODM "D" - Output 3
    P1674 QDM / ODM "D" - Output 4
    P1675 QDM / ODM "D" - Output 5
    P1676 QDM / ODM "D" - Output 6
    P1677 QDM / ODM "D" - Output 7
    P1680 Control Module Performance - APP system
    P1681 Control Module Performance - TP system
    P1682 Control Module Performance - Ignition Circuit
    P1689 Delivered Torque Output Circuit
    P1690 ECM Loop Overrun
    P1691 Coolant Gage Circuit - Low
    P1692 Coolant Gage Circuit - High
    P1693 Tachometer Circuit - Low
    P1694 Tachometer Circuit - High
    P1695 Remote Keyless Entry Circuit - Low
    P1696 Remote Keyless Entry Circuit - High
    P1697 PZM Disabled Fuel
    P1698 Class II Down Disabled Fuel
    P1699 In Fail Enable Mode
    P1701 Pressure Switch "C" Circuit
    P1702 Pressure Switch "C" Stuck Open / Performance
    P1703 Pressure Switch "C" Circuit Low / Stuck Closed
    P1704 Pressure Switch "C" Circuit High
    P1705 Pressure Switch "D" Circuit
    P1706 Pressure Switch "D" Stuck Open / Performance
    P1707 Pressure Switch "D" Circuit Low / Stuck Closed
    P1708 Pressure Switch "D" Circuit High
    P1709 Pressure Switch "E" Circuit
    P1710 Pressure Switch "E" Stuck Open / Performance
    P1711 Pressure Switch "E" Circuit Low / Stuck Closed
    P1712 Pressure Switch "E" Circuit High
    P1713 Pressure Switch "Reverse" Circuit
    P1714 Pressure Switch "Reverse" Stuck Open / Performance
    P1715 Pressure Switch "Reverse" Circuit Low / Stuck Closed
    P1716 Pressure Switch "Reverse" Circuit High
    P1717 Incorrect 6th Gear Ratio
    P1718 Incorrect Neutral Gear Ratio
    P1720 Solenoid "A" Controlled Clutch Not Engaged
    P1721 Solenoid "B" Controlled Clutch Not Engaged
    P1722 Manual Selector Valve Controlled Clutch Not Engaged
    P1723 Solenoid "A" Controlled Clutch Engaged
    P1724 Solenoid "B" Controlled Clutch Engaged
    P1725 Manual Selector Valve Controlled Clutch Not Engaged
    P1730 Retarder Circuit
    P1731 Retarder Circuit Low
    P1732 Retarder Circuit High
    P1733 Retarder Temperature Sensor Low
    P1734 Retarder Temperature Sensor High
    P1735 Retarder Over Temperature
    P1736 Service Brake Input "ON" With VSS Indicated
    P1737 Kick Down Circuit
    P1740 NSBU Mode "A" Circuit
    P1741 NSBU Mode "A" Circuit Low
    P1742 NSBU Mode "A" Circuit High
    P1743 NSBU Mode "B" Circuit
    P1744 NSBU Mode "B" Circuit Low
    P1745 NSBU Mode "B" Circuit High
    P1746 NSBU Mode "P" Circuit
    P1747 NSBU Mode "P" Circuit Low
    P1748 NSBU Mode "P" Circuit High
    P1749 NSBU Park/Neutral Switch Compare
    P1760 TCM Supply Voltage
    P1780 MIL Requested By TCM
    P1781 TCM MIL Request Control Circuit
    P1782 MIL Requested By TCM - Data Invalid
    P1785 Shift Lock Solenoid Circuit - Low Voltage
    P1786 Shift Lock Solenoid Circuit - High Voltage
    P1790 TCM Checksum Error
    P1791 TCM Loop Error
    P1792 TCM Reprogrammable Memory Error
    P1793 TCM Stack Overrun
    P1800 Transmission Power Relay Control Circuit
    P1801 Performance Selector Switch (MLP) Failure
    P1804 Ground Control Relay
    P1810 Pressure Switch Manifold
    P1811 Maximum Adapt and Long Shift
    P1813 Torque Control
    P1814 Torque Converter Overstressed
    P1815 Transmission Range Switch Start in Wrong Range
    P1816 Transmission Range Switch P/N W/Drive Ratio
    P1817 Transmission Range Switch Rev W/Drive Ratio
    P1818 Transmission Range Switch Drive W/Rev Ratio
    P1820 Transmission Range Internal Mode Switch "A" Circuit Low
    P1821 Internal Mode Switch Mode "B" Circuit Low
    P1822 Internal Mode Switch Mode "A" Circuit High Voltage
    P1823 Internal Mode Switch Mode "P" Circuit Low Voltage
    P1824 Internal Mode Switch Mode "P" Circuit High Voltage
    P1825 Internal Mode Switch Illegal Range
    P1826 Serial Communication - DKI Failure
    P1827 Serial Communication - DKP Short to Ground
    P1828 Serial Communication - DKP Shorted High
    P1829 Serial Communication - TI Signal Line Open
    P1831 Pressure Control/Shift Lock Solenoids Power Control Circuit - Low Voltage
    P1832 Pressure Control/Shift Lock Solenoids Power Control Circuit - High Voltage
    P1833 TCC/Shift Solenoid Power Control Circuit - Low Voltage
    P1834 TCC/Shift Solenoid Power Control Circuit - High Voltage
    P1835 Kick-Down Switch
    P1836 Kick-Down Switch - Failed Open
    P1837 Kick-Down Switch - Failed Short
    P1842 1-2 Shift Solenoid Circuit - Low Voltage
    P1843 1-2 Shift Solenoid Circuit - High Voltage
    P1844 TCS Torque Reduction Request Circuit
    P1845 Torque Limiter
    P1846 2-3 Shift Solenoid Circuit - Low Voltage
    P1847 2-3 Shift Solenoid Circuit - High Voltage
    P1850 Brake Band Apply Solenoid
    P1851 Brake Band Apply Solenoid Range/Performance
    P1852 Brake Band Apply Solenoid Low
    P1853 Brake Band Apply Solenoid High
    P1857 3-2 Solenoid Circuit Low Voltage
    P1858 3-2 Solenoid Circuit High Voltage
    P1860 Torque Converter Clutch PWM Solenoid Circuit
    P1862 TCC Enable Solenoid Circuit Low Voltage
    P1863 TCC Enable Solenoid Circuit High Voltage
    P1864 Shift Solenoid 4-5 Circuit Low Voltage
    P1865 Shift Solenoid 4-5 Circuit High Voltage
    P1868 Transmission Fluid Life
    P1870 Transmission Component Slipping
    P1873 Torque Converter Stator Temperature Switch Circuit Low
    P1874 Torque Converter Stator Temperature Switch Circuit High
    P1875 4 Wheel Drive Lo Switch Circuit
    P1887 Torque Clutch Converter Release Switch Circuit
    P1890
    P1891 Throttle Position Sensor PWM Signal Low Input
    P1892 Throttle Position Sensor PWM Signal High Input
    P1893 Engine Torque Signal Low Input
    P1894 Engine Torque Signal High Input
    P1895 TCM to ECM Torque Reduction Circuit
    P1896 Transmission Downshift Switch Circuit
    P1897 Transmission Upshift Switch Circuit
    P1898 Manual Shift Mode Switch Circuit
    B0000 Vehicle speed information circuit malfunction
    B0001 Vehicle speed information circuit range/performance
    B0002 Vehicle speed information circuit low
    B0003 Vehicle speed information circuit high
    B0004 Vehicle speed information circuit open
    B0005 In "Park" switch circuit malfunction
    B0006 In "Park" switch circuit range/performance
    B0007 In "Park" switch circuit low
    B0008 In "Park" switch circuit high
    B0009 In "Park" switch circuit open
    B0012 RF/Passenger frontal deployment loop (stage 2) resistance low
    B0013 RF/Passenger frontal deployment loop (stage 2) open
    B0014 RF/Passenger frontal deployment loop (stage 2) voltage out of range
    B0015 RF/Passenger frontal deployment loop resistance high
    B0016 RF/Passenger frontal deployment loop (single stage or stage 1) resistance low
    B0017 RF/Passenger frontal deployment loop (single stage or stage 1) open
    B0018 RF/Passenger frontal deployment loop (single stage or stage 1) short to ground/voltage
    B0019 RF/Passenger frontal impact deployment loop short to battery
    B0021 LF/Driver frontal deployment loop resistance high
    B0022 LF/Driver frontal deployment loop (single stage or stage 1) resistance low
    B0024 LF/Driver frontal deployment loop (single stage or stage 1) short to ground/voltage o
    B0025 LF/Driver frontal impact deployment loop short to battery
    B0026 LF/Driver frontal deployment loop (single stage or stage 1) open
    B0027 RF/Passenger side deployment loop resistance high
    B0028 RF/Passenger side deployment loop resistance low
    B0029 RF/Passenger side deployment loop open
    B0030 RF/Passenger side deployment loop short to ground/voltage out of range
    B0032 RF/Passenger side impact deployment loop short to battery
    B0034 Side airbag deployment commanded
    B0035 ADS closed/shorted to ground
    B0036 ADS open/missing/shorted to battery
    B0037 AUX switch closed/shorted to ground
    B0038 AUX switch open/shorted to battery
    B0039 LF/Driver side deployment loop resistance high
    B0040 LF/Driver side deployment loop resistance low
    B0041 LF/Driver side deployment loop open
    B0042 LF/Driver frontal deployment loop (stage 2) resistance low
    B0043 LF/Driver frontal deployment loop (stage 2) voltage out of range
    B0044 LF/Driver frontal deployment loop (stage 2) open
    B0045 LF/Driver side deployment loop short to ground/voltage out of range
    B0046 LF/Driver side deployment loop short to battery
    B0047 Deployment commanded circuit malfunction
    B0048 Deployment commanded circuit low
    B0049 Deployment commanded circuit high
    B0050 Deployment commanded circuit open
    B0051 Deployment commanded
    B0052 Passenger frontal airbag suppressed
    B0053 Deployment commanded with loop malfunctions present
    B0054 Passenger side airbag suppressed
    B0055 Passenger pre-tensioner suppressed
    B0056 RF/Passenger pre-tensioner deployment loop resistance high
    B0057 RF/Passenger pre-tensioner deployment loop resistance low
    B0058 RF/Passenger pre-tensioner deployment loop open
    B0059 RF/Passenger pre-tensioner deployment loop short to ground/voltage out of range
    B0060 RF/Passenger pre-tensioner impact deployment loop short to battery
    B0061 Supplemental deployment loop #3 resistance low
    B0062 Supplemental deployment loop #3 open
    B0063 LF/Driver pre-tensioner deployment loop resistance high
    B0064 LF/Driver pre-tensioner deployment loop resistance low
    B0065 LF/Driver pre-tensioner deployment loop open
    B0066 LF/Driver pre-tensioner deployment loop short to ground/voltage out of range
    B0067 LF/Driver pre-tensioner impact deployment loop short to battery
    B0068 Supplemental deployment loop #3 voltage out of range
    B0069 Supplemental deployment loop #4 resistance low
    B0070 Supplemental deployment loop #4 open
    B0071 Supplemental deployment loop #4 voltage out of range
    B0072 Supplemental deployment loop #1 resistance high
    B0073 Supplemental deployment loop #1 resistance low
    B0074 Supplemental deployment loop #1 open
    B0075 Supplemental deployment loop #1 short to ground/voltage out of range
    B0076 Supplemental impact deployment loop #1 short to battery
    B0077 LF/Driver SIS malfunction
    B0078 RF/Passenger SIS malfunction
    B0079 Incorrect LF/Driver SIS installed
    B0080 Discard LF/Driver SIS
    B0081 Incorrect RF/Passenger SIS installed
    B0082 Discard RF/Passenger SIS
    B0083 RF/Passenger seat position sensor circuit malfunction
    B0084 LF/Driver seat position sensor circuit malfunction
    B0085 Supplemental deployment loop #2 resistance high
    B0086 Supplemental deployment loop #2 resistance low
    B0087 Supplemental deployment loop #2 open
    B0088 Supplemental deployment loop #2 short to ground/voltage out of range
    B0089 Supplemental impact deployment loop #2 short to battery
    B0090 Active switch voltage out of range
    B0091 Active switch: wrong state
    B0092 Suppression sensor #1 circuit malfunction
    B0093 Suppression sensor #2 circuit malfunction
    B0094 AOS lamp circuit #1 circuit malfunction
    B0095 AOS lamp circuit #2 circuit malfunction
    B0096 RF/Passenger seat belt sensor circuit malfunction
    B0097 LF/Driver seat belt sensor circuit malfunction
    B0098 AOS controller ECU malfunction
    B0099 AOS controller option configuration error
    B0100 Electronic front end sensor #1 malfunction
    B0101 Discard electronic front end sensor #1
    B0102 Incorrect electronic front end sensor #1 installed
    B0103 Electronic front end sensor #2 malfunction
    B0104 Discard electronic front end sensor #2
    B0105 Incorrect electronic front end sensor #2 installed
    B0125 Air flow position command #1 (main/front) circuit malfunction
    B0126 Air flow position command #1 (main/front) circuit range/performance
    B0127 Air flow position command #1 (main/front) circuit low
    B0128 Air flow position command #1 (main/front) circuit high
    B0129 Air flow position command #1 (main/front) circuit open
    B0130 Air flow position feedback #1 (main/front) circuit malfunction
    B0131 Air flow position feedback #1 (main/front) circuit range/performance
    B0132 Air flow position feedback #1 (main/front) circuit low
    B0133 Air flow position feedback #1 (main/front) circuit high
    B0134 Air flow position feedback #1 (main/front) circuit open
    B0135 Air flow position command #2 (passenger) circuit malfunction
    B0136 Air flow position command #2 (passenger) circuit range/performance
    B0137 Air flow position command #2 (passenger) circuit low
    B0138 Air flow position command #2 (passenger) circuit high
    B0139 Air flow position command #2 (passenger) circuit open
    B0140 Air flow position feedback #2 (passenger) circuit malfunction
    B0141 Air flow position feedback #2 (passenger) circuit range/performance
    B0142 Air flow position feedback #2 (passenger) circuit low
    B0143 Air flow position feedback #2 (passenger) circuit high
    B0144 Air flow position feedback #2 (passenger) circuit open
    B0145 Air flow position command #3 (rear) circuit malfunction
    B0146 Air flow position command #3 (rear) circuit range/performance
    B0147 Air flow position command #3 (rear) circuit low
    B0148 Air flow position command #3 (rear) circuit high
    B0149 Air flow position command #3 (rear) circuit open
    B0150 Air flow position feedback #3 (rear) circuit malfunction
    B0151 Air flow position feedback #3 (rear) circuit range/performance
    B0152 Air flow position feedback #3 (rear) circuit low
    B0153 Air flow position feedback #3 (rear) circuit high
    B0154 Air flow position feedback #3 (rear) circuit open
    B0155 A/C refrigerant under pressure
    B0156 A/C refrigerant overpressure
    B0157
    B0158 Outside air temperature sensor circuit malfunction
    B0159 Outside air temperature sensor circuit range/performance
    B0160 Outside air temperature sensor circuit low
    B0161 Outside air temperature sensor circuit high
    B0162 Outside air temperature sensor circuit open
    B0163 Passenger compartment temperature sensor #1 (single sensor or LH) circuit malfunction
    B0164 Passenger compartment temperature sensor #1 (single sensor or LH) circuit range/perfo
    B0165 Passenger compartment temperature sensor #1 (single sensor or LH) circuit low
    B0166 Passenger compartment temperature sensor #1 (single sensor or LH) circuit high
    B0167 Passenger compartment temperature sensor #1 (single sensor or LH) circuit open
    B0168 Passenger compartment temperature sensor #2 (RH) circuit malfunction
    B0169 Passenger compartment temperature sensor #2 (RH) circuit range/performance
    B0170 Passenger compartment temperature sensor #2 (RH) circuit low
    B0171 Passenger compartment temperature sensor #2 (RH) circuit high
    B0172 Passenger compartment temperature sensor #2 (RH) circuit open
    B0173 Output air temperature sensor #1 (upper; single or LH) circuit malfunction
    B0174 Output air temperature sensor #1 (upper; single or LH) circuit range/performance
    B0175 Output air temperature sensor #1 (upper; single or LH) circuit low
    B0176 Output air temperature sensor #1 (upper; single or LH) circuit high
    B0177 Output air temperature sensor #1 (upper; single or LH) circuit open
    B0178 Output air temperature sensor #2 (lower; single or LH) circuit malfunction
    B0179 Output air temperature sensor #2 (lower; single or LH) circuit range/performance
    B0180 Output air temperature sensor #2 (lower; single or LH) circuit low
    B0181 Output air temperature sensor #2 (lower; single or LH) circuit high
    B0182 Output air temperature sensor #2 (lower; single or LH) circuit open
    B0183 Solar load sensor #1 (single sensor or LH) circuit malfunction
    B0184 Solar load sensor #1 (single sensor or LH) circuit range/performance
    B0185 Solar load sensor #1 (single sensor or LH) circuit low
    B0186 Solar load sensor #1 (single sensor or LH) circuit high
    B0187 Solar load sensor #1 (single sensor or LH) circuit open
    B0188 Solar load sensor #2 (RH) circuit malfunction
    B0189 Solar load sensor #2 (RH) circuit range/performance
    B0190 Solar load sensor #2 (RH) circuit low
    B0191 Solar load sensor #2 (RH) circuit high
    B0192 Solar load sensor #2 (RH) circuit open
    B0193 Blower motor #1 (main/primary/front) speed circuit malfunction
    B0194 Blower motor #1 (main/primary/front) speed circuit range/performance
    B0195 Blower motor #1 (main/primary/front) speed circuit low
    B0196 Blower motor #1 (main/primary/front) speed circuit high
    B0197 Blower motor #1 (main/primary/front) speed circuit open
    B0198 Blower motor #1 (main/primary/front) power circuit malfunction
    B0199 Blower motor #1 (main/primary/front) power circuit range/performance
    B0200 Blower motor #1 (main/primary/front) power circuit low
    B0201 Blower motor #1 (main/primary/front) power circuit high
    B0202 Blower motor #1 (main/primary/front) power circuit open
    B0203 Blower motor #1 (main/primary/front) ground circuit malfunction
    B0204 Blower motor #1 (main/primary/front) ground circuit range/performance
    B0205 Blower motor #1 (main/primary/front) ground circuit low
    B0206 Blower motor #1 (main/primary/front) ground circuit high
    B0207 Blower motor #1 (main/primary/front) ground circuit open
    B0208 Blower motor #2 (aux/secondary/rear) speed circuit malfunction
    B0209 Blower motor #2 (aux/secondary/rear) speed circuit range/performance
    B0210 Blower motor #2 (aux/secondary/rear) speed circuit low
    B0211 Blower motor #2 (aux/secondary/rear) speed circuit high
    B0212 Blower motor #2 (aux/secondary/rear) speed circuit open
    B0213 Blower motor #2 (aux/secondary/rear) power circuit malfunction
    B0214 Blower motor #2 (aux/secondary/rear) power circuit range/performance
    B0215 Blower motor #2 (aux/secondary/rear) power circuit low
    B0216 Blower motor #2 (aux/secondary/rear) power circuit high
    B0217 Blower motor #2 (aux/secondary/rear) power circuit open
    B0218 Blower motor #2 (aux/secondary/rear) ground circuit malfunction
    B0219 Blower motor #2 (aux/secondary/rear) ground circuit range/performance
    B0220 Blower motor #2 (aux/secondary/rear) ground circuit low
    B0221 Blower motor #2 (aux/secondary/rear) ground circuit high
    B0222 Blower motor #2 (aux/secondary/rear) ground circuit open
    B0223 Recirc position command circuit malfunction
    B0224 Recirc position command circuit range/performance
    B0225 Recirc position command circuit low
    B0226 Recirc position command circuit high
    B0227 Recirc position command circuit open
    B0228 Recirc position feedback circuit malfunction
    B0229 Recirc position feedback circuit range/performance
    B0230 Recirc position feedback circuit low
    B0231 Recirc position feedback circuit high
    B0232 Recirc position feedback circuit open
    B0233 Air flow control (general/single control) circuit malfunction
    B0234 Air flow control (general/single control) circuit range/performance
    B0235 Air flow control (general/single control) circuit low
    B0236 Air flow control (general/single control) circuit high
    B0237 Air flow control (general/single control) circuit open
    B0238 Air flow control #1 (defrost) circuit malfunction
    B0239 Air flow control #1 (defrost) circuit range/performance
    B0240 Air flow control #1 (defrost) circuit low
    B0241 Air flow control #1 (defrost) circuit high
    B0242 Air flow control #1 (defrost) circuit open
    B0243 Air flow control #2 (heater) circuit malfunction
    B0244 Air flow control #2 (heater) circuit range/performance
    B0245 Air flow control #2 (heater) circuit low
    B0246 Air flow control #2 (heater) circuit high
    B0247 Air flow control #2 (heater) circuit open
    B0248 Air flow control #3 (blend defog/floor) circuit malfunction
    B0249 Air flow control #3 (blend defog/floor) circuit range/performance
    B0250 Air flow control #3 (blend defog/floor) circuit low
    B0251 Air flow control #3 (blend defog/floor) circuit high
    B0252 Air flow control #3 (blend defog/floor) circuit open
    B0253 Air flow control #4 (blend face/floor) circuit malfunction
    B0254 Air flow control #4 (blend face/floor) circuit range/performance
    B0255 Air flow control #4 (blend face/floor) circuit low
    B0256 Air flow control #4 (blend face/floor) circuit high
    B0257 Air flow control #4 (blend face/floor) circuit open
    B0258 Air flow control #5 (vent) circuit malfunction
    B0259 Air flow control #5 (vent) circuit range/performance
    B0260 Air flow control #5 (vent) circuit low
    B0261 Air flow control #5 (vent) circuit high
    B0262 Air flow control #5 (vent) circuit open
    B0263 Air flow control #6 (A/C) circuit malfunction
    B0264 Air flow control #6 (A/C) circuit range/performance
    B0265 Air flow control #6 (A/C) circuit low
    B0266 Air flow control #6 (A/C) circuit high
    B0267 Air flow control #6 (A/C) circuit open
    B0268 Air flow control #7 (recirc) circuit malfunction
    B0269 Air flow control #7 (recirc) circuit range/performance
    B0270 Air flow control #7 (recirc) circuit low
    B0271 Air flow control #7 (recirc) circuit high
    B0272 Air flow control #7 (recirc) circuit open
    B0273 Air flow control #8 (rear defog airflow) circuit malfunction
    B0274 Air flow control #8 (rear defog airflow) circuit range/performance
    B0275 Air flow control #8 (rear defog airflow) circuit low
    B0276 Air flow control #8 (rear defog airflow) circuit high
    B0277 Air flow control #8 (rear defog airflow) circuit open
    B0278 Air flow control #9 (dual zone) circuit malfunction
    B0279 Air flow control #9 (dual zone) circuit range/performance
    B0280 Air flow control #9 (dual zone) circuit low
    B0281 Air flow control #9 (dual zone) circuit high
    B0282 Air flow control #9 (dual zone) circuit open
    B0283 Electric rear defrost circuit malfunction
    B0284 Electric rear defrost circuit range/performance
    B0285 Electric rear defrost circuit low
    B0286 Electric rear defrost circuit high
    B0287 Electric rear defrost circuit open
    B0288 A/C request circuit malfunction
    B0289 A/C request circuit range/performance
    B0290 A/C request circuit low
    B0291 A/C request circuit high
    B0292 A/C request circuit open
    B0293 Control head #1 (main/front) feedback circuit malfunction
    B0294 Control head #1 (main/front) feedback circuit range/performance
    B0295 Control head #1 (main/front) feedback circuit low
    B0296 Control head #1 (main/front) feedback circuit high
    B0297 Control head #1 (main/front) feedback circuit open
    B0298 Control head #2 (passenger) feedback circuit malfunction
    B0299 Control head #2 (passenger) feedback circuit range/performance
    B0300 Control head #2 (passenger) feedback circuit low
    B0301 Control head #2 (passenger) feedback circuit high
    B0302 Control head #2 (passenger) feedback circuit open B0303 Control head #3 (rear) feedback circuit malfunction
    B0304 Control head #3 (rear) feedback circuit range/performance
    B0305 Control head #3 (rear) feedback circuit low
    B0306 Control head #3 (rear) feedback circuit high
    B0307 Control head #3 (rear) feedback circuit open
    B0308 Electric windshield circuit malfunction
    B0309 Electric windshield circuit range/performance
    B0310 Electric windshield circuit low
    B0311 Electric windshield circuit high
    B0312 Electric windshield circuit open
    B0313 Climate control selection switch #1 (Off) circuit malfunction
    B0314 Climate control selection switch #1 (Off) circuit range/performance
    B0315 Climate control selection switch #1 (Off) circuit low
    B0316 Climate control selection switch #1 (Off) circuit high
    B0317 Climate control selection switch #1 (Off) circuit open
    B0318 Climate control selection switch #2 (A/C) circuit malfunction
    B0319 Climate control selection switch #2 (A/C) circuit range/performance
    B0320 Climate control selection switch #2 (A/C) circuit low
    B0321 Climate control selection switch #2 (A/C) circuit high
    B0322 Climate control selection switch #2 (A/C) circuit open
    B0323 Climate control selection switch #3 (Recirc/Max) circuit malfunction
    B0324 Climate control selection switch #3 (Recirc/Max) circuit range/performance
    B0325 Climate control selection switch #3 (Recirc/Max) circuit low
    B0326 Climate control selection switch #3 (Recirc/Max) circuit high
    B0327 Climate control selection switch #3 (Recirc/Max) circuit open
    B0328 Climate control selection switch #4 (Vent) circuit malfunction
    B0329 Climate control selection switch #4 (Vent) circuit range/performance
    B0330 Climate control selection switch #4 (Vent) circuit low
    B0331 Climate control selection switch #4 (Vent) circuit high
    B0332 Climate control selection switch #4 (Vent) circuit open
    B0333 Climate control selection switch #5 (Defrost) circuit malfunction
    B0334 Climate control selection switch #5 (Defrost) circuit range/performance
    B0335 Climate control selection switch #5 (Defrost) circuit low
    B0336 Climate control selection switch #5 (Defrost) circuit high
    B0337 Climate control selection switch #5 (Defrost) circuit open
    B0338 Climate control selection switch #6 (Warmer) circuit malfunction
    B0339 Climate control selection switch #6 (Warmer) circuit range/performance
    B0340 Climate control selection switch #6 (Warmer) circuit low
    B0341 Climate control selection switch #6 (Warmer) circuit high
    B0342 Climate control selection switch #6 (Warmer) circuit open
    B0343 Climate control selection switch #7 (Cooler) circuit malfunction
    B0344 Climate control selection switch #7 (Cooler) circuit range/performance
    B0345 Climate control selection switch #7 (Cooler) circuit low
    B0346 Climate control selection switch #7 (Cooler) circuit high
    B0347 Climate control selection switch #7 (Cooler) circuit open
    B0348 Climate control selection switch #8 (Blend #1; Face/Floor) circuit malfunction
    B0349 Climate control selection switch #8 (Blend #1; Face/Floor) circuit range/performance
    B0350 Climate control selection switch #8 (Blend #1; Face/Floor) circuit low
    B0351 Climate control selection switch #8 (Blend #1; Face/Floor) circuit high
    B0352 Climate control selection switch #8 (Blend #1; Face/Floor) circuit open
    B0353 Climate control selection switch #9 (Blend #2; Defog/Floor) circuit malfunction
    B0354 Climate control selection switch #9 (Blend #2; Defog/Floor) circuit range/performance
    B0355 Climate control selection switch #9 (Blend #2; Defog/Floor) circuit low
    B0356 Climate control selection switch #9 (Blend #2; Defog/Floor) circuit high
    B0357 Climate control selection switch #9 (Blend #2; Defog/Floor) circuit open
    B0358 Climate control selection switch #10 (Auto Control) circuit malfunction
    B0359 Climate control selection switch #10 (Auto Control) circuit range/performance
    B0360 Climate control selection switch #10 (Auto Control) circuit low
    B0361 Climate control selection switch #10 (Auto Control) circuit high
    B0362 Climate control selection switch #10 (Auto Control) circuit open
    B0363 Climate control selection switch #11 (Dual Zone) circuit malfunction
    B0364 Climate control selection switch #11 (Dual Zone) circuit range/performance
    B0365 Climate control selection switch #11 (Dual Zone) circuit low
    B0366 Climate control selection switch #11 (Dual Zone) circuit high
    B0367 Climate control selection switch #11 (Dual Zone) circuit open
    B0368 Climate control selection switch assembly circuit malfunction
    B0369 Climate control selection switch assembly circuit range/performance B0370 Climate control selection switch assembly circuit low
    B0371 Climate control selection switch assembly circuit high
    B0372 Climate control selection switch assembly circuit open
    B0373 Rear climate control selection switch #1 (Off) circuit malfunction
    B0374 Rear climate control selection switch #1 (Off) circuit range/performance
    B0375 Rear climate control selection switch #1 (Off) circuit low
    B0376 Rear climate control selection switch #1 (Off) circuit high
    B0377 Rear climate control selection switch #1 (Off) circuit open
    B0378 Rear climate control selection switch #2 (A/C) circuit malfunction
    B0379 Rear climate control selection switch #2 (A/C) circuit range/performance
    B0380 Rear climate control selection switch #2 (A/C) circuit low
    B0381 Rear climate control selection switch #2 (A/C) circuit high
    B0382 Rear climate control selection switch #2 (A/C) circuit open
    B0383 Rear climate control selection switch #3 (Vent) circuit malfunction
    B0384 Rear climate control selection switch #3 (Vent) circuit range/performance
    B0385 Rear climate control selection switch #3 (Vent) circuit low
    B0386 Rear climate control selection switch #3 (Vent) circuit high
    B0387 Rear climate control selection switch #3 (Vent) circuit open
    B0388 Rear climate control selection switch #4 (Warmer) circuit malfunction
    B0389 Rear climate control selection switch #4 (Warmer) circuit range/performance
    B0390 Rear climate control selection switch #4 (Warmer) circuit low
    B0391 Rear climate control selection switch #4 (Warmer) circuit high
    B0392 Rear climate control selection switch #4 (Warmer) circuit open
    B0393 Rear climate control selection switch #5 (Cooler) circuit malfunction
    B0394 Rear climate control selection switch #5 (Cooler) circuit range/performance
    B0395 Rear climate control selection switch #5 (Cooler) circuit low
    B0396 Rear climate control selection switch #5 (Cooler) circuit high
    B0397 Rear climate control selection switch #5 (Cooler) circuit open
    B0398 Rear climate control selection switch #6 (Auto Control) circuit malfunction
    B0399 Rear climate control selection switch #6 (Auto Control) circuit range/performance
    B0400 Rear climate control selection switch #6 (Auto Control) circuit low
    B0401 Rear climate control selection switch #6 (Auto Control) circuit high
    B0402 Rear climate control selection switch #6 (Auto Control) circuit open
    B0403 Rear climate control selection switch assembly circuit malfunction
    B0404 Rear climate control selection switch assembly circuit range/performance
    B0405 Rear climate control selection switch assembly circuit low
    B0406 Rear climate control selection switch assembly circuit high
    B0407 Rear climate control selection switch assembly circuit open
    B0408 Temperature control #1 (main/front) circuit malfunction
    B0409 Temperature control #1 (main/front) circuit range/performance
    B0410 Temperature control #1 (main/front) circuit low
    B0411 Temperature control #1 (main/front) circuit high
    B0412 Temperature control #1 (main/front) circuit open
    B0413 Temperature control #1 (main/front) feedback circuit malfunction
    B0414 Temperature control #1 (main/front) feedback circuit range/performance
    B0415 Temperature control #1 (main/front) feedback circuit low
    B0416 Temperature control #1 (main/front) feedback circuit high
    B0417 Temperature control #1 (main/front) feedback circuit open
    B0418 Temperature control #2 (passenger) circuit malfunction
    B0419 Temperature control #2 (passenger) circuit range/performance
    B0420 Temperature control #2 (passenger) circuit low
    B0421 Temperature control #2 (passenger) circuit high
    B0422 Temperature control #2 (passenger) circuit open
    B0423 Temperature control #2 (passenger) feedback circuit malfunction
    B0424 Temperature control #2 (passenger) feedback circuit range/performance
    B0425 Temperature control #2 (passenger) feedback circuit low
    B0426 Temperature control #2 (passenger) feedback circuit high
    B0427 Temperature control #2 (passenger) feedback circuit open
    B0428 Temperature control #3 (rear) circuit malfunction
    B0429 Temperature control #3 (rear) circuit range/performance
    B0430 Temperature control #3 (rear) circuit low
    B0431 Temperature control #3 (rear) circuit high
    B0432 Temperature control #3 (rear) circuit open
    B0433 Temperature control #3 (rear) feedback circuit malfunction
    B0434 Temperature control #3 (rear) feedback circuit range/performance
    B0435 Temperature control #3 (rear) feedback circuit low
    B0436 Temperature control #3 (rear) feedback circuit high
    B0437 Temperature control #3 (rear) feedback circuit open
    B0438 Auxiliary heater glow plug circuit malfunction
    B0439 Auxiliary heater glow plug circuit range/performance
    B0440 Auxiliary heater glow plug circuit low
    B0441 Auxiliary heater glow plug circuit high
    B0442 Auxiliary heater glow plug circuit open
    B0443 Auxiliary heater fuel pump circuit malfunction
    B0444 Auxiliary heater fuel pump circuit range/performance
    B0445 Auxiliary heater fuel pump circuit low
    B0446 Auxiliary heater fuel pump circuit high
    B0447 Auxiliary heater fuel pump circuit open
    B0448 Auxiliary heater blower fan circuit malfunction
    B0449 Auxiliary heater blower fan circuit range/performance
    B0450 Auxiliary heater blower fan circuit low
    B0451 Auxiliary heater blower fan circuit high
    B0452 Auxiliary heater blower fan circuit open
    B0453 Auxiliary heater coolant sensor circuit malfunction
    B0454 Auxiliary heater coolant sensor circuit range/performance
    B0455 Auxiliary heater coolant sensor circuit low
    B0456 Auxiliary heater coolant sensor circuit high
    B0457 Auxiliary heater coolant sensor circuit open
    B0458 Auxiliary heater overheat sensor circuit malfunction
    B0459 Auxiliary heater overheat sensor circuit range/performance
    B0460 Auxiliary heater overheat sensor circuit low
    B0461 Auxiliary heater overheat sensor circuit high
    B0462 Auxiliary heater overheat sensor circuit open
    B0463 Auxiliary heater flame sensor circuit malfunction
    B0464 Auxiliary heater flame sensor circuit range/performance
    B0465 Auxiliary heater flame sensor circuit low
    B0466 Auxiliary heater flame sensor circuit high
    B0467 Auxiliary heater flame sensor circuit open
    B0468 Auxiliary heater coolant pump circuit malfunction
    B0469 Auxiliary heater coolant pump circuit range/performance
    B0470 Auxiliary heater coolant pump circuit low
    B0471 Auxiliary heater coolant pump circuit high
    B0472 Auxiliary heater coolant pump circuit open
    B0473 Auxiliary heater passenger compt. fan control circuit malfunction
    B0474 Auxiliary heater passenger compt. fan control circuit range/performance
    B0475 Auxiliary heater passenger compt. fan control circuit low
    B0476 Auxiliary heater passenger compt. fan control circuit high
    B0477 Auxiliary heater passenger compt. fan control circuit open
    B0478 Flame off from minimum power
    B0479 Flame off from medium power
    B0480 Flame off from maximum power
    B0481 Overheat detected: software level
    B0482 Overheat detected: hardware level
    B0483 Overheat possible
    B0484 Auxiliary heater system locked
    B0485 Auxiliary heater start counter overrun
    B0486 Auxiliary heater cold blow time exceeded
    B0487 Auxiliary heater temp switch HS: no connection
    B0488 Auxiliary heater overheat counter overrun
    B0489 Passenger temp. control "Cooler" or "Cooler/Warmer" switch circuit malfunction
    B0490 Passenger temp. control "Cooler" or "Cooler/Warmer" switch circuit range/performance
    B0491 Passenger temp. control "Cooler" or "Cooler/Warmer" switch circuit low
    B0492 Passenger temp. control "Cooler" or "Cooler/Warmer" switch circuit high
    B0493 Passenger temp. control "Cooler" or "Cooler/Warmer" switch circuit open
    B0494 Passenger temp. control "Cooler" or "Cooler/Warmer" switch feedback circuit malf
    B0495 Passenger temp. control "Cooler" or "Cooler/Warmer" switch feedback circuit range/per
    B0496 Passenger temp. control "Cooler" or "Cooler/Warmer" switch feedback circuit low
    B0497 Passenger temp. control "Cooler" or "Cooler/Warmer" switch feedback circuit high
    B0498 Passenger temp. control "Cooler" or "Cooler/Warmer" switch feedback circuit open
    B0499 Passenger temp. control "Warmer" switch circuit malfunction
    B0500 Passenger temp. control "Warmer" switch circuit range/performance
    B0501 Passenger temp. control "Warmer" switch circuit low
    B0502 Passenger temp. control "Warmer" switch circuit high
    B0503 Passenger temp. control "Warmer" switch circuit open
    B0504 Passenger temp. control "Warmer" switch feedback circuit malfunction
    B0505 Passenger temp. control "Warmer" switch feedback circuit range/performance
    B0506 Passenger temp. control "Warmer" switch feedback circuit low
    B0507 Passenger temp. control "Warmer" switch feedback circuit high
    B0508 Passenger temp. control "Warmer" switch feedback circuit open
    B0509 Output air temperature sensor #3 (upper RH) circuit malfunction
    B0510 Output air temperature sensor #3 (upper RH) circuit range/performance
    B0511 Output air temperature sensor #3 (upper RH) circuit low
    B0512 Output air temperature sensor #3 (upper RH) circuit high
    B0513 Output air temperature sensor #3 (upper RH) circuit open
    B0514 Output air temperature sensor #4 (lower RH) circuit malfunction
    B0515 Output air temperature sensor #4 (lower RH) circuit range/performance
    B0516 Output air temperature sensor #4 (lower RH) circuit low
    B0517 Output air temperature sensor #4 (lower RH) circuit high
    B0518 Output air temperature sensor #4 (lower RH) circuit open
    B0519 Output air temperature sensor #5 (single rear output) circuit malfunction
    B0520 Output air temperature sensor #5 (single rear output) circuit range/performance
    B0521 Output air temperature sensor #5 (single rear output) circuit low
    B0522 Output air temperature sensor #5 (single rear output) circuit high
    B0523 Output air temperature sensor #5 (single rear output) circuit open
    B0525 RH turn signal circuit malfunction
    B0526 RH turn signal circuit range/performance
    B0527 RH turn signal circuit low
    B0528 RH turn signal circuit high
    B0529 RH turn signal circuit open
    B0530 LH turn signal circuit malfunction
    B0531 LH turn signal circuit range/performance
    B0532 LH turn signal circuit low
    B0533 LH turn signal circuit high
    B0534 LH turn signal circuit open
    B0535 Headlamp high beam indicator circuit malfunction
    B0536 Headlamp high beam indicator circuit range/performance
    B0537 Headlamp high beam indicator circuit low
    B0538 Headlamp high beam indicator circuit high
    B0539 Headlamp high beam indicator circuit open
    B0540 Speedometer circuit malfunction
    B0541 Speedometer circuit range/performance
    B0542 Speedometer circuit low
    B0543 Speedometer circuit high
    B0544 Speedometer circuit open
    B0545 MPH/km/h indicator circuit malfunction
    B0546 MPH/km/h indicator circuit range/performance
    B0547 MPH/km/h indicator circuit low
    B0548 MPH/km/h indicator circuit high
    B0549 MPH/km/h indicator circuit open
    B0550 Season odometer circuit malfunction
    B0551 Season odometer circuit range/performance
    B0552 Season odometer circuit low
    B0553 Season odometer circuit high
    B0554 Season odometer circuit open
    B0555 Trip odometer circuit malfunction
    B0556 Trip odometer circuit range/performance
    B0557 Trip odometer circuit low
    B0558 Trip odometer circuit high
    B0559 Trip odometer circuit open
    B0560 Tachometer circuit malfunction
    B0561 Tachometer circuit range/performance
    B0562 Tachometer circuit low
    B0563 Tachometer circuit high
    B0564 Tachometer circuit open
    B0565 Coolant temperature indicator circuit malfunction
    B0566 Coolant temperature indicator circuit range/performance
    B0567 Coolant temperature indicator circuit low
    B0568 Coolant temperature indicator circuit high
    B0569 Coolant temperature indicator circuit open
    B0570 Low coolant indicator circuit malfunction
    B0571 Low coolant indicator circuit range/performance
    B0572 Low coolant indicator circuit low
    B0573 Low coolant indicator circuit high
    B0574 Low coolant indicator circuit open
    B0575 Fuel level indicator circuit malfunction
    B0576 Fuel level indicator circuit range/performance
    B0577 Fuel level indicator circuit low
    B0578 Fuel level indicator circuit high
    B0579 Fuel level indicator circuit open
    B0580 Low fuel indicator circuit malfunction
    B0581 Low fuel indicator circuit range/performance
    B0582 Low fuel indicator circuit low
    B0583 Low fuel indicator circuit high
    B0584 Low fuel indicator circuit open
    B0585 Alternate fuel indicator circuit malfunction
    B0586 Alternate fuel indicator circuit range/performance
    B0587 Alternate fuel indicator circuit low
    B0588 Alternate fuel indicator circuit high
    B0589 Alternate fuel indicator circuit open
    B0590 Turbocharger/supercharger boost indicator circuit malfunction
    B0591 Turbocharger/supercharger boost indicator circuit range/performance
    B0592 Turbocharger/supercharger boost indicator circuit low
    B0593 Turbocharger/supercharger boost indicator circuit high
    B0594 Turbocharger/supercharger boost indicator circuit open
    B0595 Fasten seatbelt indicator circuit malfunction
    B0596 Fasten seatbelt indicator circuit range/performance
    B0597 Fasten seatbelt indicator circuit low
    B0598 Fasten seatbelt indicator circuit high
    B0599 Fasten seatbelt indicator gage circuit open
    B0600 Door #1 (LF) ajar indicator circuit malfunction
    B0601 Door #1 (LF) ajar indicator circuit range/performance
    B0602 Door #1 (LF) ajar indicator circuit low
    B0603 Door #1 (LF) ajar indicator circuit high
    B0604 Door #1 (LF) ajar indicator circuit open
    B0605 Door #2 (RF) ajar indicator circuit malfunction
    B0606 Door #2 (RF) ajar indicator circuit range/performance
    B0607 Door #2 (RF) ajar indicator circuit low
    B0608 Door #2 (RF) ajar indicator circuit high
    B0609 Door #2 (RF) ajar indicator circuit open
    B0610 Door #3 (LR pass. car or LH van sliding) ajar indicator circuit malfunction
    B0611 Door #3 (LR pass. car or LH van sliding) ajar indicator circuit range/performance
    B0612 Door #3 (LR pass. car or LH van sliding) ajar indicator circuit low
    B0613 Door #3 (LR pass. car or LH van sliding) ajar indicator circuit high
    B0614 Door #3 (LR pass. car or LH van sliding) ajar indicator circuit open
    B0615 Door #4 (RR pass. car or RH van sliding) ajar indicator circuit malfunction
    B0616 Door #4 (RR pass. car or RH van sliding) ajar indicator circuit range/performance
    B0617 Door #4 (RR pass. car or RH van sliding) ajar indicator circuit low
    B0618 Door #4 (RR pass. car or RH van sliding) ajar indicator circuit high
    B0619 Door #4 (RR pass. car or RH van sliding) ajar indicator circuit open
    B0620 Hood ajar indicator circuit malfunction
    B0621 Hood ajar indicator circuit range/performance
    B0622 Hood ajar indicator circuit low
    B0623 Hood ajar indicator circuit high
    B0624 Hood ajar indicator circuit open
    B0625 Trunk/hatch (pass. cars) ajar indicator circuit malfunction
    B0626 Trunk/hatch (pass. cars) ajar indicator circuit range/performance
    B0627 Trunk/hatch (pass. cars) ajar indicator circuit low
    B0628 Trunk/hatch (pass. cars) ajar indicator circuit high
    B0629 Trunk/hatch (pass. cars) ajar indicator circuit open
    B0630 Tailgate (pickup or util) ajar indicator circuit malfunction
    B0631 Tailgate (pickup or util) ajar indicator circuit range/performance
    B0632 Tailgate (pickup or util) ajar indicator circuit low
    B0633 Tailgate (pickup or util) ajar indicator circuit high
    B0634 Tailgate (pickup or util) ajar indicator circuit open
    B0635 Cargo door #1 (LH of doubles) ajar indicator circuit malfunction
    B0636 Cargo door #1 (LH of doubles) ajar indicator circuit range/performance
    B0637 Cargo door #1 (LH of doubles) ajar indicator circuit low
    B0638 Cargo door #1 (LH of doubles) ajar indicator circuit high
    B0639 Cargo door #1 (LH of doubles) ajar indicator circuit open
    B0640 Cargo door #2 (RH double) ajar indicator circuit malfunction
    B0641 Cargo door #2 (RH double) ajar indicator circuit range/performance
    B0642 Cargo door #2 (RH double) ajar indicator circuit low
    B0643 Cargo door #2 (RH double) ajar indicator circuit high
    B0644 Cargo door #2 (RH double) ajar indicator circuit open
    B0645 Lift glass ajar indicator circuit malfunction
    B0646 Lift glass ajar indicator circuit range/performance
    B0647 Lift glass ajar indicator circuit low
    B0648 Lift glass ajar indicator circuit high
    B0649 Lift glass ajar indicator circuit open
    B0650 Fuel filler door ajar indicator circuit malfunction
    B0651 Fuel filler door ajar indicator circuit range/performance
    B0652 Fuel filler door ajar indicator circuit low
    B0653 Fuel filler door ajar indicator circuit high
    B0654 Fuel filler door ajar indicator circuit open
    B0655 Brake (hydraulics and/or park brake) indicator circuit malfunction
    B0656 Brake (hydraulics and/or park brake) indicator circuit range/performance
    B0657 Brake (hydraulics and/or park brake) indicator circuit low
    B0658 Brake (hydraulics and/or park brake) indicator circuit high
    B0659 Brake (hydraulics and/or park brake) indicator circuit open
    B0660 Auto Park (Med. Truck) indicator circuit malfunction
    B0661 Auto Park (Med. Truck) indicator circuit range/performance
    B0662 Auto Park (Med. Truck) indicator circuit low
    B0663 Auto Park (Med. Truck) indicator circuit high
    B0664 Auto Park (Med. Truck) indicator circuit open
    B0665 Service ABS indicator circuit malfunction
    B0666 Service ABS indicator circuit range/performance
    B0667 Service ABS indicator circuit low
    B0668 Service ABS indicator circuit high
    B0669 Service ABS indicator circuit open
    B0670 Inflatable restraint system indicator #1 (main indicator) circuit malfunction
    B0671 Inflatable restraint system indicator #1 (main indicator) circuit range/performance
    B0672 Inflatable restraint system indicator #1 (main indicator) circuit low
    B0673 Inflatable restraint system indicator #1 (main indicator) circuit high
    B0674 Inflatable restraint system indicator #1 (main indicator) indicator circuit open
    B0675 Inflatable restraint system indicator #2 (redundant/secondary) circuit malfunction
    B0676 Inflatable restraint system indicator #2 (redundant/secondary) circuit range/performance
    B0677 Inflatable restraint system indicator #2 (redundant/secondary) circuit low
    B0678 Inflatable restraint system indicator #2 (redundant/secondary) circuit high
    B0679 Inflatable restraint system indicator #2 (redundant/secondary) indicator circuit open
    B0680 Passenger airbag disabled indicator circuit malfunction
    B0681 Passenger airbag disabled indicator circuit range/performance
    B0682 Passenger airbag disabled indicator circuit low
    B0683 Passenger airbag disabled indicator circuit high
    B0684 Passenger airbag disabled indicator circuit open
    B0685 Security system indicator circuit malfunction
    B0686 Security system indicator circuit range/performance
    B0687 Security system indicator circuit low
    B0688 Security system indicator circuit high
    B0689 Security system indicator circuit open
    B0690 Brake To Shift indicator circuit malfunction
    B0691 Brake To Shift indicator circuit range/performance
    B0692 Brake To Shift indicator circuit low
    B0693 Brake To Shift indicator circuit high
    B0694 Brake To Shift indicator circuit open
    B0695 Low oil level indicator circuit malfunction
    B0696 Low oil level indicator circuit range/performance
    B0697 Low oil level indicator circuit low
    B0698 Low oil level indicator circuit high
    B0699 Low oil level indicator circuit open
    B0700 Oil temperature indicator circuit malfunction
    B0701 Oil temperature indicator circuit range/performance
    B0702 Oil temperature indicator circuit low
    B0703 Oil temperature indicator circuit high
    B0704 Oil temperature indicator circuit open
    B0705 Oil pressure indicator circuit malfunction
    B0706 Oil pressure indicator circuit range/performance
    B0707 Oil pressure indicator circuit low
    B0708 Oil pressure indicator circuit high
    B0709 Oil pressure indicator circuit open
    B0710 Change oil indicator circuit malfunction
    B0711 Change oil indicator circuit range/performance
    B0712 Change oil indicator circuit low
    B0713 Change oil indicator circuit high
    B0714 Change oil indicator circuit open
    B0715 Message display system (dot matrix, reconfig. TT, etc.) circuit malfunction
    B0716 Message display system (dot matrix, reconfig. TT, etc.) circuit range/performance
    B0717 Message display system (dot matrix, reconfig. TT, etc.) circuit low
    B0718 Message display system (dot matrix, reconfig. TT, etc.) circuit high
    B0719 Message display system (dot matrix, reconfig. TT, etc.) circuit open
    B0720 PRNDL indicator circuit malfunction
    B0721 PRNDL indicator circuit range/performance
    B0722 PRNDL indicator circuit low
    B0723 PRNDL indicator circuit high
    B0724 PRNDL indicator circuit open
    B0725 P indicator circuit malfunction
    B0726 P indicator circuit range/performance
    B0727 P indicator circuit low
    B0728 P indicator circuit high
    B0729 P indicator circuit open
    B0730 R indicator circuit malfunction
    B0731 R indicator circuit range/performance
    B0732 R indicator circuit low
    B0733 R indicator circuit high
    B0734 R indicator circuit open
    B0735 N indicator circuit malfunction
    B0736 N indicator circuit range/performance
    B0737 N indicator circuit low
    B0738 N indicator circuit high
    B0739 N indicator circuit open
    B0740 OD indicator circuit malfunction
    B0741 OD indicator circuit range/performance
    B0742 OD indicator circuit low
    B0743 OD indicator circuit high
    B0744 OD indicator circuit open
    B0745 D indicator circuit malfunction
    B0746 D indicator circuit range/performance
    B0747 D indicator circuit low
    B0748 D indicator circuit high
    B0749 D indicator circuit open
    B0750 L indicator circuit malfunction
    B0751 L indicator circuit range/performance
    B0752 L indicator circuit low
    B0753 L indicator circuit high
    B0754 L indicator circuit open
    B0755 Low washer fluid indicator #1 (primary/front) circuit malfunction
    B0756 Low washer fluid indicator #1 (primary/front) circuit range/performance
    B0757 Low washer fluid indicator #1 (primary/front) circuit low
    B0758 Low washer fluid indicator #1 (primary/front) circuit high
    B0759 Low washer fluid indicator #1 (primary/front) circuit open
    B0760 Low washer fluid indicator #2 (secondary/rear) circuit malfunction
    B0761 Low washer fluid indicator #2 (secondary/rear) circuit range/performance
    B0762 Low washer fluid indicator #2 (secondary/rear) circuit low
    B0763 Low washer fluid indicator #2 (secondary/rear) circuit high
    B0764 Low washer fluid indicator #2 (secondary/rear) circuit open
    B0765 Service AWD/4WD indicator circuit malfunction
    B0766 Service AWD/4WD indicator circuit range/performance
    B0767 Service AWD/4WD indicator circuit low
    B0768 Service AWD/4WD indicator circuit high
    B0769 Service AWD/4WD indicator circuit open
    B0770 AWD/4WD indicator circuit malfunction
    B0771 AWD/4WD indicator circuit range/performance
    B0772 AWD/4WD indicator circuit low
    B0773 AWD/4WD indicator circuit high
    B0774 AWD/4WD indicator circuit open
    B0775 4HI indicator circuit malfunction
    B0776 4HI indicator circuit range/performance
    B0777 4HI indicator circuit low
    B0778 4HI indicator circuit high
    B0779 4HI indicator circuit open
    B0780 4LO indicator circuit malfunction
    B0781 4LO indicator circuit range/performance
    B0782 4LO indicator circuit low
    B0783 4LO indicator circuit high
    B0784 4LO indicator circuit open
    B0785 2HI indicator circuit malfunction
    B0786 2HI indicator circuit range/performance
    B0787 2HI indicator circuit low
    B0788 2HI indicator circuit high
    B0789 2HI indicator circuit open
    B0790 Transfer case Neutral indicator circuit malfunction
    B0791 Transfer case Neutral indicator circuit range/performance
    B0792 Transfer case Neutral indicator circuit low
    B0793 Transfer case Neutral indicator circuit high
    B0794 Transfer case Neutral indicator circuit open
    B0795 Transmission temperature indicator circuit malfunction
    B0796 Transmission temperature indicator circuit range/performance
    B0797 Transmission temperature indicator circuit low
    B0798 Transmission temperature indicator circuit high
    B0799 Transmission temperature indicator circuit open
    B0800 Transmission shift mode (Norm/Perf) indicator circuit malfunction
    B0801 Transmission shift mode (Norm/Perf) indicator circuit range/performance
    B0802 Transmission shift mode (Norm/Perf) indicator circuit low
    B0803 Transmission shift mode (Norm/Perf) indicator circuit high
    B0804 Transmission shift mode (Norm/Perf) indicator circuit open
    B0805 One-To-Four shift mode (ZF manual trans.) indicator circuit malfunction
    B0806 One-To-Four shift mode (ZF manual trans.) indicator circuit range/performance
    B0807 One-To-Four shift mode (ZF manual trans.) indicator circuit low
    B0808 One-To-Four shift mode (ZF manual trans.) indicator circuit high
    B0809 One-To-Four shift mode (ZF manual trans.) indicator circuit open
    B0810 Upshift indicator circuit malfunction
    B0811 Upshift indicator circuit range/performance
    B0812 Upshift indicator circuit low
    B0813 Upshift indicator circuit high
    B0814 Upshift indicator circuit open
    B0815 Service traction control system indicator circuit malfunction
    B0816 Service traction control system indicator circuit range/performance
    B0817 Service traction control system indicator circuit low
    B0818 Service traction control system indicator circuit high
    B0819 Service traction control system indicator circuit open
    B0820 Traction control system active indicator circuit malfunction
    B0821 Traction control system active indicator circuit range/performance
    B0822 Traction control system active indicator circuit low
    B0823 Traction control system active indicator circuit high
    B0824 Traction control system active indicator circuit open
    B0825 Traction control system off indicator circuit malfunction
    B0826 Traction control system off indicator circuit range/performance
    B0827 Traction control system off indicator circuit low
    B0828 Traction control system off indicator circuit high
    B0829 Traction control system off indicator circuit open
    B0830 Second gear start indicator circuit malfunction
    B0831 Second gear start indicator circuit range/performance
    B0832 Second gear start indicator circuit low
    B0833 Second gear start indicator circuit high
    B0834 Second gear start indicator circuit open
    B0835 Cruise control system active indicator circuit malfunction
    B0836 Cruise control system active indicator circuit range/performance
    B0837 Cruise control system active indicator circuit low
    B0838 Cruise control system active indicator circuit high
    B0839 Cruise control system active indicator circuit open
    B0840 Check gages indicator circuit malfunction
    B0841 Check gages indicator circuit range/performance
    B0842 Check gages indicator circuit low
    B0843 Check gages indicator circuit high
    B0844 Check gages indicator circuit open
    B0845 Water in fuel indicator circuit malfunction
    B0846 Water in fuel indicator circuit range/performance
    B0847 Water in fuel indicator circuit low
    B0848 Water in fuel indicator circuit high
    B0849 Water in fuel indicator circuit open
    B0850 Wait/Glow plugs indicator circuit malfunction
    B0851 Wait/Glow plugs indicator circuit range/performance
    B0852 Wait/Glow plugs indicator circuit low
    B0853 Wait/Glow plugs indicator circuit high
    B0854 Wait/Glow plugs indicator circuit open
    B0855 Battery voltage indicator circuit malfunction
    B0856 Battery voltage indicator circuit range/performance
    B0857 Battery voltage indicator circuit low
    B0858 Battery voltage indicator circuit high
    B0859 Battery voltage indicator circuit open
    B0860 Battery voltage high/low indicator circuit malfunction
    B0861 Battery voltage high/low indicator circuit range/performance
    B0862 Battery voltage high/low indicator circuit low
    B0863 Battery voltage high/low indicator circuit high
    B0864 Battery voltage high/low indicator circuit open
    B0865 Amperage indicator circuit malfunction
    B0866 Amperage indicator circuit range/performance
    B0867 Amperage indicator circuit low
    B0868 Amperage indicator circuit high
    B0869 Amperage indicator circuit open
    B0870 Low tire pressure indicator circuit malfunction
    B0871 Low tire pressure indicator circuit range/performance
    B0872 Low tire pressure indicator circuit low
    B0873 Low tire pressure indicator circuit high
    B0874 Low tire pressure indicator circuit open
    B0875 Service low tire pressure system indicator circuit malfunction
    B0876 Service low tire pressure system indicator circuit range/performance
    B0877 Service low tire pressure system indicator circuit low
    B0878 Service low tire pressure system indicator circuit high
    B0879 Service low tire pressure system indicator circuit open
    B0880 Chime system circuit malfunction
    B0881 Chime system circuit range/performance
    B0882 Chime system circuit low
    B0883 Chime system circuit high
    B0884 Chime system circuit open
    B0885 Chime rate 0 (slow) indicator circuit malfunction
    B0886 Chime rate 0 (slow) indicator circuit range/performance
    B0887 Chime rate 0 (slow) indicator circuit low
    B0888 Chime rate 0 (slow) indicator circuit high
    B0889 Chime rate 0 (slow) indicator circuit open
    B0890 Chime rate 1 (medium) indicator circuit malfunction
    B0891 Chime rate 1 (medium) indicator circuit range/performance
    B0892 Chime rate 1 (medium) indicator circuit low
    B0893 Chime rate 1 (medium) indicator circuit high
    B0894 Chime rate 1 (medium) indicator circuit open
    B0895 Chime rate 2 (high) indicator circuit malfunction
    B0896 Chime rate 2 (high) indicator circuit range/performance
    B0897 Chime rate 2 (high) indicator circuit low
    B0898 Chime rate 2 (high) indicator circuit high
    B0899 Chime rate 2 (high) indicator circuit open
    B0900 Chime rate 3 (single chime) indicator circuit malfunction
    B0901 Chime rate 3 (single chime) indicator circuit range/performance
    B0902 Chime rate 3 (single chime) indicator circuit low
    B0903 Chime rate 3 (single chime) indicator circuit high
    B0904 Chime rate 3 (single chime) indicator circuit open
    B0905 Body computer systems indicator circuit malfunction
    B0906 Body computer systems indicator circuit range/performance
    B0907 Body computer systems indicator circuit low
    B0908 Body computer systems indicator circuit high
    B0909 Body computer systems indicator circuit open
    B0910 Steering assist system (EVO, MSVA, etc.) indicator circuit malfunction
    B0911 Steering assist system (EVO, MSVA, etc.) indicator circuit range/performance
    B0912 Steering assist system (EVO, MSVA, etc.) indicator circuit low
    B0913 Steering assist system (EVO, MSVA, etc.) indicator circuit high
    B0914 Steering assist system (EVO, MSVA, etc.) indicator circuit open
    B0915 Catalytic converter overtemperature (export) indicator circuit malfunction
    B0916 Catalytic converter overtemperature (export) indicator circuit range/performance
    B0917 Catalytic converter overtemperature (export) indicator circuit low
    B0918 Catalytic converter overtemperature (export) indicator circuit high
    B0919 Catalytic converter overtemperature (export) indicator circuit open
    B0920 Overspeed (export) indicator circuit malfunction
    B0921 Overspeed (export) indicator circuit range/performance
    B0922 Overspeed (export) indicator circuit low
    B0923 Overspeed (export) indicator circuit high
    B0924 Overspeed (export) indicator circuit open
    B0925 Reconfigurable Telltale Temperature (RTT) out of range
    B0926 Service AHLD indicator circuit malfunction
    B0927 Service AHLD indicator circuit range/performance
    B0928 Service AHLD indicator circuit low
    B0929 Service AHLD indicator circuit high
    B0930 Service AHLD indicator circuit open
    B0931 Compass sensor circuit malfunction
    B0932 Compass sensor circuit range/performance
    B0933 Compass sensor circuit low
    B0934 Compass sensor circuit high
    B0935 Compass sensor circuit open
    B0936 Coolant level sensor circuit malfunction
    B0937 Coolant level sensor circuit range/performance
    B0938 Coolant level sensor circuit low
    B0939 Coolant level sensor circuit high
    B0940 Coolant level sensor circuit open
    B0941 Level control system indicator circuit malfunction
    B0942 Level control system indicator circuit range/performance
    B0943 Level control system indicator circuit low
    B0944 Level control system indicator circuit high
    B0945 Level control system indicator circuit open
    B0946 Suspension control selection indicator circuit malfunction
    B0947 Suspension control selection indicator circuit range/performance
    B0948 Suspension control selection indicator circuit low
    B0949 Suspension control selection indicator circuit high
    B0950 Suspension control selection indicator circuit open
    B0951 Headlamps on indicator circuit malfunction
    B1000 ECU malfunction
    B1001 Option configuration error
    B1002 Improper shutdown
    B1004 KAM reset
    B1013 Calibration ROM checksum error
    B1014 Program ROM checksum error
    B1015 VIN information error
    B1016 VIN information not programmed
    B1017 QDM / ODM 1 malfunction
    B1018 QDM / ODM 2 malfunction
    B1020 Auxiliary ECU malfunction
    B1021 SIM card malfunction
    B1022 Emergency SIM card malfunction
    B1025 Audio [+] output #1 (LF) malfunction
    B1026 Audio [+] output #1 (LF) circuit range/performance
    B1027 Audio [+] output #1 (LF) circuit low
    B1028 Audio [+] output #1 (LF) circuit high
    B1029 Audio [+] output #1 (LF) circuit open
    B1030 Audio [-] output #1 (LF) malfunction
    B1031 Audio [-] output #1 (LF) circuit range/performance
    B1032 Audio [-] output #1 (LF) circuit low
    B1033 Audio [-] output #1 (LF) circuit high
    B1034 Audio [-] output #1 (LF) circuit open
    B1035 Audio [+] output #2 (RF) malfunction
    B1036 Audio [+] output #2 (RF) circuit range/performance
    B1037 Audio [+] output #2 (RF) circuit low
    B1038 Audio [+] output #2 (RF) circuit high
    B1039 Audio [+] output #2 (RF) circuit open
    B1040 Audio [-] output #2 (RF) malfunction
    B1041 Audio [-] output #2 (RF) circuit range/performance
    B1042 Audio [-] output #2 (RF) circuit low
    B1043 Audio [-] output #2 (RF) circuit high
    B1044 Audio [-] output #2 (RF) circuit open
    B1045 Audio [+] output #3 (LR) malfunction
    B1046 Audio [+] output #3 (LR) circuit range/performance
    B1047 Audio [+] output #3 (LR) circuit low
    B1048 Audio [+] output #3 (LR) circuit high
    B1049 Audio [+] output #3 (LR) circuit open
    B1050 Audio [-] output #3 (LR) malfunction
    B1051 Audio [-] output #3 (LR) circuit range/performance
    B1052 Audio [-] output #3 (LR) circuit low
    B1053 Audio [-] output #3 (LR) circuit high
    B1054 Audio [-] output #3 (LR) circuit open
    B1055 Audio [+] output #4 (RR) malfunction
    B1056 Audio [+] output #4 (RR) circuit range/performance
    B1057 Audio [+] output #4 (RR) circuit low
    B1058 Audio [+] output #4 (RR) circuit high
    B1059 Audio [+] output #4 (RR) circuit open
    B1060 Audio [-] output #4 (RR) malfunction
    B1061 Audio [-] output #4 (RR) circuit range/performance
    B1062 Audio [-] output #4 (RR) circuit low
    B1063 Audio [-] output #4 (RR) circuit high
    B1064 Audio [-] output #4 (RR) circuit open
    B1065 Audio [+] output #5 (TBD) malfunction
    B1066 Audio [+] output #5 (TBD) circuit range/performance
    B1067 Audio [+] output #5 (TBD) circuit low
    B1068 Audio [+] output #5 (TBD) circuit high
    B1069 Audio [+] output #5 (TBD) circuit open
    B1070 Audio [-] output #5 (TBD) malfunction
    B1071 Audio [-] output #5 (TBD) circuit range/performance
    B1072 Audio [-] output #5 (TBD) circuit low
    B1073 Audio [-] output #5 (TBD) circuit high
    B1074 Audio [-] output #5 (TBD) circuit open
    B1075 Audio [+] output #6 (TBD) malfunction
    B1076 Audio [+] output #6 (TBD) circuit range/performance
    B1077 Audio [+] output #6 (TBD) circuit low
    B1078 Audio [+] output #6 (TBD) circuit high
    B1079 Audio [+] output #6 (TBD) circuit open
    B1080 Audio [-] output #6 (TBD) malfunction
    B1081 Audio [-] output #6 (TBD) circuit range/performance
    B1082 Audio [-] output #6 (TBD) circuit low
    B1083 Audio [-] output #6 (TBD) circuit high
    B1084 Audio [-] output #6 (TBD) circuit open
    B1085 Audio [+] output #7 (TBD) malfunction
    B1086 Audio [+] output #7 (TBD) circuit range/performance
    B1087 Audio [+] output #7 (TBD) circuit low
    B1088 Audio [+] output #7 (TBD) circuit high
    B1089 Audio [+] output #7 (TBD) circuit open
    B1090 Audio [-] output #7 (TBD) malfunction
    B1091 Audio [-] output #7 (TBD) circuit range/performance
    B1092 Audio [-] output #7 (TBD) circuit low
    B1093 Audio [-] output #7 (TBD) circuit high
    B1094 Audio [-] output #7 (TBD) circuit open
    B1095 Audio [+] output #8 (TBD) malfunction
    B1096 Audio [+] output #8 (TBD) circuit range/performance
    B1097 Audio [+] output #8 (TBD) circuit low
    B1098 Audio [+] output #8 (TBD) circuit high
    B1099 Audio [+] output #8 (TBD) circuit open
    B1100 Audio [-] output #8 (TBD) malfunction
    B1101 Audio [-] output #8 (TBD) circuit range/performance
    B1102 Audio [-] output #8 (TBD) circuit low
    B1103 Audio [-] output #8 (TBD) circuit high
    B1104 Audio [-] output #8 (TBD) circuit open
    B1105 Audio [+] output #9 (TBD) malfunction
    B1106 Audio [+] output #9 (TBD) circuit range/performance
    B1107 Audio [+] output #9 (TBD) circuit low
    B1108 Audio [+] output #9 (TBD) circuit high
    B1109 Audio [+] output #9 (TBD) circuit open
    B1110 Audio [-] output #9 (TBD) malfunction
    B1111 Audio [-] output #9 (TBD) circuit range/performance
    B1112 Audio [-] output #9 (TBD) circuit low
    B1113 Audio [-] output #9 (TBD) circuit high
    B1114 Audio [-] output #9 (TBD) circuit open
    B1115 Audio [+] output #10 (TBD) malfunction
    B1116 Audio [+] output #10 (TBD) circuit range/performance
    B1117 Audio [+] output #10 (TBD) circuit low
    B1118 Audio [+] output #10 (TBD) circuit high
    B1119 Audio [+] output #10 (TBD) circuit open
    B1120 Audio [-] output #10 (TBD) malfunction
    B1121 Audio [-] output #10 (TBD) circuit range/performance
    B1122 Audio [-] output #10 (TBD) circuit low
    B1123 Audio [-] output #10 (TBD) circuit high
    B1124 Audio [-] output #10 (TBD) circuit open
    B1125 Audio [+] output #11 (TBD) malfunction
    B1126 Audio [+] output #11 (TBD) circuit range/performance
    B1127 Audio [+] output #11 (TBD) circuit low
    B1128 Audio [+] output #11 (TBD) circuit high
    B1129 Audio [+] output #11 (TBD) circuit open
    B1130 Audio [-] output #11 (TBD) malfunction
    B1131 Audio [-] output #11 (TBD) circuit range/performance
    B1132 Audio [-] output #11 (TBD) circuit low
    B1133 Audio [-] output #11 (TBD) circuit high
    B1134 Audio [-] output #11 (TBD) circuit open
    B1135 Audio [+] output #12 (TBD) malfunction
    B1136 Audio [+] output #12 (TBD) circuit range/performance
    B1137 Audio [+] output #12 (TBD) circuit low
    B1138 Audio [+] output #12 (TBD) circuit high
    B1139 Audio [+] output #12 (TBD) circuit open
    B1140 Audio [-] output #12 (TBD) malfunction
    B1141 Audio [-] output #12 (TBD) circuit range/performance
    B1142 Audio [-] output #12 (TBD) circuit low
    B1143 Audio [-] output #12 (TBD) circuit high
    B1144 Audio [-] output #12 (TBD) circuit open
    B1145 Audio [+] output #13 (TBD) malfunction
    B1146 Audio [+] output #13 (TBD) circuit range/performance
    B1147 Audio [+] output #13 (TBD) circuit low
    B1148 Audio [+] output #13 (TBD) circuit high
    B1149 Audio [+] output #13 (TBD) circuit open
    B1150 Audio [-] output #13 (TBD) malfunction
    B1151 Audio [-] output #13 (TBD) circuit range/performance
    B1152 Audio [-] output #13 (TBD) circuit low
    B1153 Audio [-] output #13 (TBD) circuit high
    B1154 Audio [-] output #13 (TBD) circuit open
    B1155 Audio [+] output #14 (TBD) malfunction
    B1156 Audio [+] output #14 (TBD) circuit range/performance
    B1157 Audio [+] output #14 (TBD) circuit low
    B1158 Audio [+] output #14 (TBD) circuit high
    B1159 Audio [+] output #14 (TBD) circuit open
    B1160 Audio [-] output #14 (TBD) malfunction
    B1161 Audio [-] output #14 (TBD) circuit range/performance
    B1162 Audio [-] output #14 (TBD) circuit low
    B1163 Audio [-] output #14 (TBD) circuit high
    B1164 Audio [-] output #14 (TBD) circuit open
    B1165 Audio [+] output #15 (TBD) malfunction
    B1166 Audio [+] output #15 (TBD) circuit range/performance
    B1167 Audio [+] output #15 (TBD) circuit low
    B1168 Audio [+] output #15 (TBD) circuit high
    B1169 Audio [+] output #15 (TBD) circuit open
    B1170 Audio [-] output #15 (TBD) malfunction
    B1171 Audio [-] output #15 (TBD) circuit range/performance
    B1172 Audio [-] output #15 (TBD) circuit low
    B1173 Audio [-] output #15 (TBD) circuit high
    B1174 Audio [-] output #15 (TBD) circuit open
    B1175 Audio [+] output #16 (TBD) malfunction
    B1176 Audio [+] output #16 (TBD) circuit range/performance
    B1177 Audio [+] output #16 (TBD) circuit low
    B1178 Audio [+] output #16 (TBD) circuit high
    B1179 Audio [+] output #16 (TBD) circuit open
    B1180 Audio [-] output #16 (TBD) malfunction
    B1181 Audio [-] output #16 (TBD) circuit range/performance
    B1182 Audio [-] output #16 (TBD) circuit low
    B1183 Audio [-] output #16 (TBD) circuit high
    B1184 Audio [-] output #16 (TBD) circuit open
    B1185 Audio [+] output #17 (TBD) malfunction
    B1186 Audio [+] output #17 (TBD) circuit range/performance
    B1187 Audio [+] output #17 (TBD) circuit low
    B1188 Audio [+] output #17 (TBD) circuit high
    B1189 Audio [+] output #17 (TBD) circuit open
    B1190 Audio [-] output #17 (TBD) malfunction
    B1191 Audio [-] output #17 (TBD) circuit range/performance
    B1192 Audio [-] output #17 (TBD) circuit low
    B1193 Audio [-] output #17 (TBD) circuit high
    B1194 Audio [-] output #17 (TBD) circuit open
    B1195 Audio [+] output #18 (TBD) malfunction
    B1196 Audio [+] output #18 (TBD) circuit range/performance
    B1197 Audio [+] output #18 (TBD) circuit low
    B1198 Audio [+] output #18 (TBD) circuit high
    B1199 Audio [+] output #18 (TBD) circuit open
    B1200 Audio [-] output #18 (TBD) malfunction
    B1201 Audio [-] output #18 (TBD) circuit range/performance
    B1202 Audio [-] output #18 (TBD) circuit low
    B1203 Audio [-] output #18 (TBD) circuit high
    B1204 Audio [-] output #18 (TBD) circuit open
    B1205 Audio [+] output #19 (TBD) malfunction
    B1206 Audio [+] output #19 (TBD) circuit range/performance
    B1207 Audio [+] output #19 (TBD) circuit low
    B1208 Audio [+] output #19 (TBD) circuit high
    B1209 Audio [+] output #19 (TBD) circuit open
    B1210 Audio [-] output #19 (TBD) malfunction
    B1211 Audio [-] output #19 (TBD) circuit range/performance
    B1212 Audio [-] output #19 (TBD) circuit low
    B1213 Audio [-] output #19 (TBD) circuit high
    B1214 Audio [-] output #19 (TBD) circuit open
    B1215 Audio [+] output #20 (TBD) malfunction
    B1216 Audio [+] output #20 (TBD) circuit range/performance
    B1217 Audio [+] output #20 (TBD) circuit low
    B1218 Audio [+] output #20 (TBD) circuit high
    B1219 Audio [+] output #20 (TBD) circuit open
    B1220 Audio [-] output #20 (TBD) malfunction
    B1221 Audio [-] output #20 (TBD) circuit range/performance
    B1222 Audio [-] output #20 (TBD) circuit low
    B1223 Audio [-] output #20 (TBD) circuit high
    B1224 Audio [-] output #20 (TBD) circuit open
    B1225 Tape player ON signal circuit malfunction
    B1226 Tape player ON signal circuit range/performance
    B1227 Tape player ON signal circuit low
    B1228 Tape player ON signal circuit high
    B1229 Tape player ON signal circuit open
    B1230 CD player ON signal circuit malfunction
    B1231 CD player ON signal circuit range/performance
    B1232 CD player ON signal circuit low
    B1233 CD player ON signal circuit high
    B1234 CD player ON signal circuit open
    B1235 Amplifier ON signal circuit malfunction
    B1236 Amplifier ON signal circuit range/performance
    B1237 Amplifier ON signal circuit low
    B1238 Amplifier ON signal circuit high
    B1239 Amplifier ON signal circuit open
    B1240 CD player not responding
    B1241 CD player tracking malfunction
    B1242 CD player focus malfunction
    B1243 CD player load/unload malfunction
    B1244 CD player disk upside down
    B1245 CD changer not responding
    B1246 CD changer tracking malfunction
    B1247 CD changer focus malfunction
    B1248 CD changer load/unload malfunction
    B1249 CD changer disk upside down
    B1250 Cassette tape slow
    B1251 Cassette tape fast
    B1252 Cassette not responding
    B1253 Cassette head cleaning required
    B1254 Audio system security circuit malfunction
    B1255 Audio system security circuit range/performance
    B1256 Audio system security circuit low
    B1257 Audio system security circuit high
    B1258 Audio system security circuit open
    B1259 Antenna ground circuit malfunction
    B1260 Antenna ground circuit range/performance
    B1261 Antenna ground circuit low
    B1262 Antenna ground circuit high
    B1263 Antenna ground circuit open
    B1264 Switched antenna malfunction
    B1265 Switched 14 volt malfunction
    B1266 Switched internal battery malfunction
    B1267 16 volt malfunction
    B1268 Cassette tight tape
    B1269 Cassette load/unload error
    B1270 Cassette cut tape
    B1271 Theft Locked
    B1325 Device power #1 (low current #1) circuit malfunction
    B1326 Device power #1 (low current #1) circuit range/performance
    B1327 Device power #1 (low current #1) circuit low
    B1328 Device power #1 (low current #1) circuit high
    B1329 Device power #1 (low current #1) circuit open
    B1330 Device power #2 (low current #2) circuit malfunction
    B1331 Device power #2 (low current #2) circuit range/performance
    B1332 Device power #2 (low current #2) circuit low
    B1333 Device power #2 (low current #2) circuit high
    B1334 Device power #2 (low current #2) circuit open
    B1335 Device power #3 (high current #1) circuit malfunction
    B1336 Device power #3 (high current #1) circuit range/performance
    B1337 Device power #3 (high current #1) circuit low
    B1338 Device power #3 (high current #1) circuit high
    B1339 Device power #3 (high current #1) circuit open
    B1340 Device power #4 (high current #2) circuit malfunction
    B1341 Device power #4 (high current #2) circuit range/performance
    B1342 Device power #4 (high current #2) circuit low
    B1343 Device power #4 (high current #2) circuit high
    B1344 Device power #4 (high current #2) circuit open
    B1345 Device ground #1 (chassis gnd #1) circuit malfunction
    B1346 Device ground #1 (chassis gnd #1) circuit range/performance
    B1347 Device ground #1 (chassis gnd #1) circuit low
    B1348 Device ground #1 (chassis gnd #1) circuit high
    B1349 Device ground #1 (chassis gnd #1) circuit open
    B1350 Device ground #2 (chassis gnd #2) circuit malfunction
    B1351 Device ground #2 (chassis gnd #2) circuit range/performance
    B1352 Device ground #2 (chassis gnd #2) circuit low
    B1353 Device ground #2 (chassis gnd #2) circuit high
    B1354 Device ground #2 (chassis gnd #2) circuit open
    B1355 Device ground #3 (signal gnd #1) circuit malfunction
    B1356 Device ground #3 (signal gnd #1) circuit range/performance
    B1357 Device ground #3 (signal gnd #1) circuit low
    B1358 Device ground #3 (signal gnd #1) circuit high
    B1359 Device ground #3 (signal gnd #1) circuit open
    B1360 Device ground #4 (signal gnd #2) circuit malfunction
    B1361 Device ground #4 (signal gnd #2) circuit range/performance
    B1362 Device ground #4 (signal gnd #2) circuit low
    B1363 Device ground #4 (signal gnd #2) circuit high
    B1364 Device ground #4 (signal gnd #2) circuit open
    B1365 Device ignition 0 (UNLOCK/ON/START) circuit malfunction
    B1366 Device ignition 0 (UNLOCK/ON/START) circuit range/performance
    B1367 Device ignition 0 (UNLOCK/ON/START) circuit low
    B1368 Device ignition 0 (UNLOCK/ON/START) circuit high
    B1369 Device ignition 0 (UNLOCK/ON/START) circuit open
    B1370 Device ignition 1 (ON/START) circuit malfunction
    B1371 Device ignition 1 (ON/START) circuit range/performance
    B1372 Device ignition 1 (ON/START) circuit low
    B1373 Device ignition 1 (ON/START) circuit high
    B1374 Device ignition 1 (ON/START) circuit open
    B1375 Device ignition 3 (ON) circuit malfunction
    B1376 Device ignition 3 (ON) circuit range/performance
    B1377 Device ignition 3 (ON) circuit low
    B1378 Device ignition 3 (ON) circuit high
    B1379 Device ignition 3 (ON) circuit open
    B1380 Device ignition ACC circuit malfunction
    B1381 Device ignition ACC circuit range/performance
    B1382 Device ignition ACC circuit low
    B1383 Device ignition ACC circuit high
    B1384 Device ignition ACC circuit open
    B1385 Device ignition START circuit malfunction
    B1386 Device ignition START circuit range/performance
    B1387 Device ignition START circuit low
    B1388 Device ignition START circuit high
    B1389 Device ignition START circuit open
    B1390 Device voltage reference input #1 circuit malfunction
    B1391 Device voltage reference input #1 circuit range/performance
    B1392 Device voltage reference input #1 circuit low
    B1393 Device voltage reference input #1 circuit high
    B1394 Device voltage reference input #1 circuit open
    B1395 Device voltage reference output #1 circuit malfunction
    B1396 Device voltage reference output #1 circuit range/performance
    B1397 Device voltage reference output #1 circuit low
    B1398 Device voltage reference output #1 circuit high
    B1399 Device voltage reference output #1 circuit open
    B1400 Device voltage reference input #2 circuit malfunction
    B1401 Device voltage reference input #2 circuit range/performance
    B1402 Device voltage reference input #2 circuit low
    B1403 Device voltage reference input #2 circuit high
    B1404 Device voltage reference input #2 circuit open
    B1405 Device voltage reference output #2 circuit malfunction
    B1406 Device voltage reference output #2 circuit range/performance
    B1407 Device voltage reference output #2 circuit low
    B1408 Device voltage reference output #2 circuit high
    B1409 Device voltage reference output #2 circuit open
    B1410 Device voltage reference input #3 circuit malfunction
    B1411 Device voltage reference input #3 circuit range/performance
    B1412 Device voltage reference input #3 circuit low
    B1413 Device voltage reference input #3 circuit high
    B1414 Device voltage reference input #3 circuit open
    B1415 Device voltage reference output #3 circuit malfunction
    B1416 Device voltage reference output #3 circuit range/performance
    B1417 Device voltage reference output #3 circuit low
    B1418 Device voltage reference output #3 circuit high
    B1419 Device voltage reference output #3 circuit open
    B1420 Device voltage malfunction
    B1421 Device voltage range/performance
    B1422 Device power moding malfunction
    B1423 Device power and/or ground circuit malfunction
    B1424 Device #1 voltage low
    B1425 Device #1 voltage high
    B1426 Device #2 voltage low
    B1427 Device #2 voltage high
    B1428 Ignition-switched power relay #1 circuit malfunction
    B1429 Ignition-switched power relay #1 circuit range/performance
    B1430 Ignition-switched power relay #1 circuit low
    B1431 Ignition-switched power relay #1 circuit high
    B1432 Ignition-switched power relay #1 circuit open
    B1433 Ignition-switched power relay #2 circuit malfunction
    B1434 Ignition-switched power relay #2 circuit range/performance
    B1435 Ignition-switched power relay #2 circuit low
    B1436 Ignition-switched power relay #2 circuit high
    B1437 Ignition-switched power relay #2 circuit open
    B1438 IPC high voltage output overcurrent to CCP
    B1439 Intermittent device voltage range/performance
    B1440 Power mode master input circuits mismatch
    B1441 Device ignition OFF/RUN/CRANK circuit malfunction
    B1442 Device ignition OFF/RUN/CRANK circuit low
    B1443 Device ignition OFF/RUN/CRANK circuit high
    B1444 Device backup power malfunction
    B1445 Device voltage output #1 circuit malfunction
    B1475 Retained accessory power circuit malfunction
    B1476 Retained accessory power circuit range/performance
    B1477 Retained accessory power circuit low
    B1478 Retained accessory power circuit high
    B1479 Retained accessory power circuit open
    B1480 Battery rundown protection circuit malfunction
    B1481 Battery rundown protection circuit range/performance
    B1482 Battery rundown protection circuit low
    B1483 Battery rundown protection circuit high
    B1484 Battery rundown protection circuit open
    B1485 Generator L-terminal circuit malfunction
    B1486 Generator L-terminal circuit range/performance
    B1487 Generator L-terminal circuit low
    B1488 Generator L-terminal circuit high
    B1489 Generator L-terminal circuit open
    B1490 F-terminal circuit malfunction
    B1491 F-terminal circuit range/performance
    B1492 F-terminal circuit low
    B1493 F-terminal circuit high
    B1494 F-terminal circuit open
    B1495 Exterior lamp power circuit malfunction
    B1496 Exterior lamp power circuit range/performance
    B1497 Exterior lamp power circuit low
    B1498 Exterior lamp power circuit high
    B1499 Exterior lamp power circuit open
    B1500 Low power control circuit malfunction
    B1501 Low power control circuit range/performance
    B1502 Low power control circuit low
    B1503 Low power control circuit high
    B1504 Low power control circuit open
    B1505 High power control circuit malfunction
    B1506 High power control circuit range/performance
    B1507 High power control circuit low
    B1508 High power control circuit high
    B1509 High power control circuit open
    B1510 Storage mode entered
    B1511 Battery voltage low -- generator malfunction
    B1512 AD power circuit malfunction
    B1513 Charging system voltage low
    B1514 Charging system voltage high
    B1550 Mirror LF/RF select switch circuit malfunction
    B1551 Mirror LF/RF select switch circuit range/performance
    B1552 Mirror LF/RF select switch circuit low
    B1553 Mirror LF/RF select switch circuit high
    B1554 Mirror LF/RF select switch circuit open
    B1555 LF/RF mirror control switch assembly circuit malfunction
    B1556 LF/RF mirror control switch assembly circuit range/performance
    B1557 LF/RF mirror control switch assembly circuit low
    B1558 LF/RF mirror control switch assembly circuit high
    B1559 LF/RF mirror control switch assembly circuit open
    B1560 Mirror right control switch circuit malfunction
    B1561 Mirror right control switch circuit range/performance
    B1562 Mirror right control switch circuit low
    B1563 Mirror right control switch circuit high
    B1564 Mirror right control switch circuit open
    B1565 Mirror left control switch circuit malfunction
    B1566 Mirror left control switch circuit range/performance
    B1567 Mirror left control switch circuit low
    B1568 Mirror left control switch circuit high
    B1569 Mirror left control switch circuit open
    B1570 Mirror up control switch circuit malfunction
    B1571 Mirror up control switch circuit range/performance
    B1572 Mirror up control switch circuit low
    B1573 Mirror up control switch circuit high
    B1574 Mirror up control switch circuit open
    B1575 Mirror down control switch circuit malfunction
    B1576 Mirror down control switch circuit range/performance
    B1577 Mirror down control switch circuit low
    B1578 Mirror down control switch circuit high
    B1579 Mirror down control switch circuit open
    B1580 LF mirror horizontal position sensor circuit malfunction
    B1581 LF mirror horizontal position sensor circuit range/performance
    B1582 LF mirror horizontal position sensor circuit low
    B1583 LF mirror horizontal position sensor circuit high
    B1584 LF mirror horizontal position sensor circuit open
    B1585 LF mirror horizontal position feedback circuit malfunction
    B1586 LF mirror horizontal position feedback circuit range/performance
    B1587 LF mirror horizontal position feedback circuit low
    B1588 LF mirror horizontal position feedback circuit high
    B1589 LF mirror horizontal position feedback circuit open
    B1590 LF mirror vertical position sensor circuit malfunction
    B1591 LF mirror vertical position sensor circuit range/performance
    B1592 LF mirror vertical position sensor circuit low
    B1593 LF mirror vertical position sensor circuit high
    B1594 LF mirror vertical position sensor circuit open
    B1595 LF mirror vertical position feedback circuit malfunction
    B1596 LF mirror vertical position feedback circuit range/performance
    B1597 LF mirror vertical position feedback circuit low
    B1598 LF mirror vertical position feedback circuit high
    B1599 LF mirror vertical position feedback circuit open
    B1600 LF mirror motor #1 (single motor or vertical) circuit malfunction
    B1601 LF mirror motor #1 (single motor or vertical) circuit range/performance
    B1602 LF mirror motor #1 (single motor or vertical) circuit low
    B1603 LF mirror motor #1 (single motor or vertical) circuit high
    B1604 LF mirror motor #1 (single motor or vertical) circuit open
    B1605 LF mirror motor #2 (horizontal) circuit malfunction
    B1606 LF mirror motor #2 (horizontal) circuit range/performance
    B1607 LF mirror motor #2 (horizontal) circuit low
    B1608 LF mirror motor #2 (horizontal) circuit high
    B1609 LF mirror motor #2 (horizontal) circuit open
    B1610 RF mirror horizontal position sensor circuit malfunction
    B1611 RF mirror horizontal position sensor circuit range/performance
    B1612 RF mirror horizontal position sensor circuit low
    B1613 RF mirror horizontal position sensor circuit high
    B1614 RF mirror horizontal position sensor circuit open
    B1615 RF mirror horizontal position feedback circuit malfunction
    B1616 RF mirror horizontal position feedback circuit range/performance
    B1617 RF mirror horizontal position feedback circuit low
    B1618 RF mirror horizontal position feedback circuit high
    B1619 RF mirror horizontal position feedback circuit open
    B1620 RF mirror vertical position sensor circuit malfunction
    B1621 RF mirror vertical position sensor circuit range/performance
    B1622 RF mirror vertical position sensor circuit low
    B1623 RF mirror vertical position sensor circuit high
    B1624 RF mirror vertical position sensor circuit open
    B1625 RF mirror vertical position feedback circuit malfunction
    B1626 RF mirror vertical position feedback circuit range/performance
    B1627 RF mirror vertical position feedback circuit low
    B1628 RF mirror vertical position feedback circuit high
    B1629 RF mirror vertical position feedback circuit open
    B1630 RF mirror motor #1 (single motor or vertical) circuit malfunction
    B1631 RF mirror motor #1 (single motor or vertical) circuit range/performance
    B1632 RF mirror motor #1 (single motor or vertical) circuit low
    B1633 RF mirror motor #1 (single motor or vertical) circuit high
    B1634 RF mirror motor #1 (single motor or vertical) circuit open
    B1635 RF mirror motor #2 (horizontal) circuit malfunction
    B1636 RF mirror motor #2 (horizontal) circuit range/performance
    B1637 RF mirror motor #2 (horizontal) circuit low
    B1638 RF mirror motor #2 (horizontal) circuit high
    B1639 RF mirror motor #2 (horizontal) circuit open
    B1640 LF mirror heater circuit malfunction
    B1641 LF mirror heater circuit range/performance
    B1642 LF mirror heater circuit low
    B1643 LF mirror heater circuit high
    B1644 LF mirror heater circuit open
    B1645 RF mirror heater circuit malfunction
    B1646 RF mirror heater circuit range/performance
    B1647 RF mirror heater circuit low
    B1648 RF mirror heater circuit high
    B1649 RF mirror heater circuit open
    B1650 LF mirror transmission reverse gear circuit malfunction
    B1651 LF mirror transmission reverse gear circuit range/performance
    B1652 LF mirror transmission reverse gear circuit low
    B1653 LF mirror transmission reverse gear circuit high
    B1654 LF mirror transmission reverse gear circuit open
    B1655 RF mirror transmission reverse gear circuit malfunction
    B1656 RF mirror transmission reverse gear circuit range/performance
    B1657 RF mirror transmission reverse gear circuit low
    B1658 RF mirror transmission reverse gear circuit high
    B1659 RF mirror transmission reverse gear circuit open
    B1660 Inside rearview mirror vertical position sensor circuit malfunction
    B1661 Inside rearview mirror vertical position sensor circuit range/performance
    B1662 Inside rearview mirror vertical position sensor circuit low
    B1663 Inside rearview mirror vertical position sensor circuit high
    B1664 Inside rearview mirror vertical position sensor circuit open
    B1665 Inside rearview mirror vertical position feedback circuit malfunction
    B1666 Inside rearview mirror vertical position feedback circuit range/performance
    B1667 Inside rearview mirror vertical position feedback circuit low
    B1668 Inside rearview mirror vertical position feedback circuit high
    B1669 Inside rearview mirror vertical position feedback circuit open
    B1670 Inside rearview mirror horizontal position sensor circuit malfunction
    B1671 Inside rearview mirror horizontal position sensor circuit range/performance
    B1672 Inside rearview mirror horizontal position sensor circuit low
    B1673 Inside rearview mirror horizontal position sensor circuit high
    B1674 Inside rearview mirror horizontal position sensor circuit open
    B1675 Inside rearview mirror horizontal position feedback circuit malfunction
    B1676 Inside rearview mirror horizontal position feedback circuit range/performance
    B1677 Inside rearview mirror horizontal position feedback circuit low
    B1678 Inside rearview mirror horizontal position feedback circuit high
    B1679 Inside rearview mirror horizontal position feedback circuit open
    B1680 Inside rearview mirror motor #1 (single motor or vertical) circuit malfunction
    B1681 Inside rearview mirror motor #1 (single motor or vertical) circuit range/performance
    B1682 Inside rearview mirror motor #1 (single motor or vertical) circuit low
    B1683 Inside rearview mirror motor #1 (single motor or vertical) circuit high
    B1684 Inside rearview mirror motor #1 (single motor or vertical) circuit open
    B1685 Inside rearview mirror motor #2 (horizontal) circuit malfunction
    B1686 Inside rearview mirror motor #2 (horizontal) circuit range/performance
    B1687 Inside rearview mirror motor #2 (horizontal) circuit low
    B1688 Inside rearview mirror motor #2 (horizontal) circuit high
    B1689 Inside rearview mirror motor #2 (horizontal) circuit open
    B1690 Inside rearview mirror transmission reverse gear circuit malfunction
    B1691 Inside rearview mirror transmission reverse gear circuit range/performance
    B1692 Inside rearview mirror transmission reverse gear circuit low
    B1693 Inside rearview mirror transmission reverse gear circuit high
    B1694 Inside rearview mirror transmission reverse gear circuit open
    B1695 Mirror left-up control switch circuit malfunction
    B1696 Mirror left-up control switch circuit range/performance
    B1697 Mirror left-up control switch circuit low
    B1698 Mirror left-up control switch circuit high
    B1699 Mirror left-up control switch circuit open
    B1700 Mirror left-down control switch circuit malfunction
    B1701 Mirror left-down control switch circuit range/performance
    B1702 Mirror left-down control switch circuit low
    B1703 Mirror left-down control switch circuit high
    B1704 Mirror left-down control switch circuit open
    B1705 Mirror right-up control switch circuit malfunction
    B1706 Mirror right-up control switch circuit range/performance
    B1707 Mirror right-up control switch circuit low
    B1708 Mirror right-up control switch circuit high
    B1709 Mirror right-up control switch circuit open
    B1710 Mirror right-down control switch circuit malfunction
    B1711 Mirror right-down control switch circuit range/performance
    B1712 Mirror right-down control switch circuit low
    B1713 Mirror right-down control switch circuit high
    B1714 Mirror right-down control switch circuit open
    B1715 Mirror power fold control switch circuit malfunction
    B1716 Mirror power fold control switch circuit range/performance
    B1717 Mirror power fold control switch circuit low
    B1718 Mirror power fold control switch circuit high
    B1719 Mirror power fold control switch circuit open
    B1720 Mirror up/down control switch circuit malfunction
    B1721 Mirror left/right control switch circuit malfunction
    B1722 Mirror power fold control circuit malfunction
    B1723 Mirror motor control circuit #1 malfunction
    B1724 Mirror motor control circuit #2 malfunction
    B1725 LF/Driver seat assembly up switch circuit malfunction
    B1726 LF/Driver seat assembly up switch circuit range/performance
    B1727 LF/Driver seat assembly up switch circuit low
    B1728 LF/Driver seat assembly up switch circuit high
    B1729 LF/Driver seat assembly up switch circuit open
    B1730 LF/Driver seat assembly down switch circuit malfunction
    B1731 LF/Driver seat assembly down switch circuit range/performance
    B1732 LF/Driver seat assembly down switch circuit low
    B1733 LF/Driver seat assembly down switch circuit high
    B1734 LF/Driver seat assembly down switch circuit open
    B1735 LF/Driver seat front up switch circuit malfunction
    B1736 LF/Driver seat front up switch circuit range/performance
    B1737 LF/Driver seat front up switch circuit low
    B1738 LF/Driver seat front up switch circuit high
    B1739 LF/Driver seat front up switch circuit open
    B1740 LF/Driver seat front down switch circuit malfunction
    B1741 LF/Driver seat front down switch circuit range/performance
    B1742 LF/Driver seat front down switch circuit low
    B1743 LF/Driver seat front down switch circuit high
    B1744 LF/Driver seat front down switch circuit open
    B1745 LF/Driver seat rear up switch circuit malfunction
    B1746 LF/Driver seat rear up switch circuit range/performance
    B1747 LF/Driver seat rear up switch circuit low
    B1748 LF/Driver seat rear up switch circuit high
    B1749 LF/Driver seat rear up switch circuit open
    B1750 LF/Driver seat rear down switch circuit malfunction
    B1751 LF/Driver seat rear down switch circuit range/performance
    B1752 LF/Driver seat rear down switch circuit low
    B1753 LF/Driver seat rear down switch circuit high
    B1754 LF/Driver seat rear down switch circuit open
    B1755 LF/Driver seat assembly forward switch circuit malfunction
    B1756 LF/Driver seat assembly forward switch circuit range/performance
    B1757 LF/Driver seat assembly forward switch circuit low
    B1758 LF/Driver seat assembly forward switch circuit high
    B1759 LF/Driver seat assembly forward switch circuit open
    B1760 LF/Driver seat assembly rearward switch circuit malfunction
    B1761 LF/Driver seat assembly rearward switch circuit range/performance
    B1762 LF/Driver seat assembly rearward switch circuit low
    B1763 LF/Driver seat assembly rearward switch circuit high
    B1764 LF/Driver seat assembly rearward switch circuit open
    B1765 LF/Driver seat motor #1 (ass'y. vertical) circuit malfunction
    B1766 LF/Driver seat motor #1 (ass'y. vertical) circuit range/performance
    B1767 LF/Driver seat motor #1 (ass'y. vertical) circuit low
    B1768 LF/Driver seat motor #1 (ass'y. vertical) circuit high
    B1769 LF/Driver seat motor #1 (ass'y. vertical) circuit open
    B1770 LF/Driver seat motor #2 (ass'y. horizontal) circuit malfunction
    B1771 LF/Driver seat motor #2 (ass'y. horizontal) circuit range/performance
    B1772 LF/Driver seat motor #2 (ass'y. horizontal) circuit low
    B1773 LF/Driver seat motor #2 (ass'y. horizontal) circuit high
    B1774 LF/Driver seat motor #2 (ass'y. horizontal) circuit open
    B1775 LF/Driver seat motor #3 (front vertical) circuit malfunction
    B1776 LF/Driver seat motor #3 (front vertical) circuit range/performance
    B1777 LF/Driver seat motor #3 (front vertical) circuit low
    B1778 LF/Driver seat motor #3 (front vertical) circuit high
    B1779 LF/Driver seat motor #3 (front vertical) circuit open
    B1780 LF/Driver seat motor #4 (rear vertical) circuit malfunction
    B1781 LF/Driver seat motor #4 (rear vertical) circuit range/performance
    B1782 LF/Driver seat motor #4 (rear vertical) circuit low
    B1783 LF/Driver seat motor #4 (rear vertical) circuit high
    B1784 LF/Driver seat motor #4 (rear vertical) circuit open
    B1785 LF/Driver seat motor #5 (recline) circuit malfunction
    B1786 LF/Driver seat motor #5 (recline) circuit range/performance
    B1787 LF/Driver seat motor #5 (recline) circuit low
    B1788 LF/Driver seat motor #5 (recline) circuit high
    B1789 LF/Driver seat motor #5 (recline) circuit open
    B1790 LF/Driver seat motor #6 (lumbar; single motor or horizontal) circuit malfunction
    B1791 LF/Driver seat motor #6 (lumbar; single motor or horizontal) circuit range/performance
    B1792 LF/Driver seat motor #6 (lumbar; single motor or horizontal) circuit low
    B1793 LF/Driver seat motor #6 (lumbar; single motor or horizontal) circuit high
    B1794 LF/Driver seat motor #6 (lumbar; single motor or horizontal) circuit open
    B1795 LF/Driver seat motor #7 (head restraint horizontal) circuit malfunction
    B1796 LF/Driver seat motor #7 (head restraint horizontal) circuit range/performance
    B1797 LF/Driver seat motor #7 (head restraint horizontal) circuit low
    B1798 LF/Driver seat motor #7 (head restraint horizontal) circuit high
    B1799 LF/Driver seat motor #7 (head restraint horizontal) circuit open
    B1800 LF/Driver seat motor #8 (head restraint vertical) circuit malfunction
    B1801 LF/Driver seat motor #8 (head restraint vertical) circuit range/performance
    B1802 LF/Driver seat motor #8 (head restraint vertical) circuit low
    B1803 LF/Driver seat motor #8 (head restraint vertical) circuit high
    B1804 LF/Driver seat motor #8 (head restraint vertical) circuit open
    B1805 LF/Driver seat motor #9 (side bolster) circuit malfunction
    B1806 LF/Driver seat motor #9 (side bolster) circuit range/performance
    B1807 LF/Driver seat motor #9 (side bolster) circuit low
    B1808 LF/Driver seat motor #9 (side bolster) circuit high
    B1809 LF/Driver seat motor #9 (side bolster) circuit open
    B1810 LF/Driver seat motor #10 (thigh bolster) circuit malfunction
    B1811 LF/Driver seat motor #10 (thigh bolster) circuit range/performance
    B1812 LF/Driver seat motor #10 (thigh bolster) circuit low
    B1813 LF/Driver seat motor #10 (thigh bolster) circuit high
    B1814 LF/Driver seat motor #10 (thigh bolster) circuit open
    B1815 LF/Driver recline forward switch circuit malfunction
    B1816 LF/Driver recline forward switch circuit range/performance
    B1817 LF/Driver recline forward switch circuit low
    B1818 LF/Driver recline forward switch circuit high
    B1819 LF/Driver recline forward switch circuit open
    B1820 LF/Driver recline rearward switch circuit malfunction
    B1821 LF/Driver recline rearward switch circuit range/performance
    B1822 LF/Driver recline rearward switch circuit low
    B1823 LF/Driver recline rearward switch circuit high
    B1824 LF/Driver recline rearward switch circuit open
    B1825 LF/Driver recline sensor circuit malfunction
    B1826 LF/Driver recline sensor circuit range/performance
    B1827 LF/Driver recline sensor circuit low
    B1828 LF/Driver recline sensor circuit high
    B1829 LF/Driver recline sensor circuit open
    B1830 LF/Driver lumbar forward switch circuit malfunction
    B1831 LF/Driver lumbar forward switch circuit range/performance
    B1832 LF/Driver lumbar forward switch circuit low
    B1833 LF/Driver lumbar forward switch circuit high
    B1834 LF/Driver lumbar forward switch circuit open
    B1835 LF/Driver lumbar rearward switch circuit malfunction
    B1836 LF/Driver lumbar rearward switch circuit range/performance
    B1837 LF/Driver lumbar rearward switch circuit low
    B1838 LF/Driver lumbar rearward switch circuit high
    B1839 LF/Driver lumbar rearward switch circuit open
    B1840 LF/Driver lumbar up switch circuit malfunction
    B1841 LF/Driver lumbar up switch circuit range/performance
    B1842 LF/Driver lumbar up switch circuit low
    B1843 LF/Driver lumbar up switch circuit high
    B1844 LF/Driver lumbar up switch circuit open
    B1845 LF/Driver lumbar down switch circuit malfunction
    B1846 LF/Driver lumbar down switch circuit range/performance
    B1847 LF/Driver lumbar down switch circuit low
    B1848 LF/Driver lumbar down switch circuit high
    B1849 LF/Driver lumbar down switch circuit open
    B1850 LF/Driver lumbar horizontal sensor malfunction
    B1851 LF/Driver lumbar horizontal sensor range/performance
    B1852 LF/Driver lumbar horizontal sensor low
    B1853 LF/Driver lumbar horizontal sensor high
    B1854 LF/Driver lumbar horizontal sensor open
    B1855 LF/Driver lumbar horizontal feedback circuit malfunction
    B1856 LF/Driver lumbar horizontal feedback circuit range/performance
    B1857 LF/Driver lumbar horizontal feedback circuit low
    B1858 LF/Driver lumbar horizontal feedback circuit high
    B1859 LF/Driver lumbar horizontal feedback circuit open
    B1860 LF/Driver lumbar vertical sensor malfunction
    B1861 LF/Driver lumbar vertical sensor range/performance
    B1862 LF/Driver lumbar vertical sensor low
    B1863 LF/Driver lumbar vertical sensor high
    B1864 LF/Driver lumbar vertical sensor open
    B1865 LF/Driver lumbar vertical feedback circuit malfunction
    B1866 LF/Driver lumbar vertical feedback circuit range/performance
    B1867 LF/Driver lumbar vertical feedback circuit low
    B1868 LF/Driver lumbar vertical feedback circuit high
    B1869 LF/Driver lumbar vertical feedback circuit open
    B1870 LF/Driver head restraint up switch circuit malfunction
    B1871 LF/Driver head restraint up switch circuit range/performance
    B1872 LF/Driver head restraint up switch circuit low
    B1873 LF/Driver head restraint up switch circuit high
    B1874 LF/Driver head restraint up switch circuit open
    B1875 LF/Driver head restraint down switch circuit malfunction
    B1876 LF/Driver head restraint down switch circuit range/performance
    B1877 LF/Driver head restraint down switch circuit low
    B1878 LF/Driver head restraint down switch circuit high
    B1879 LF/Driver head restraint down switch circuit open
    B1880 LF/Driver head restraint forward switch circuit malfunction
    B1881 LF/Driver head restraint forward switch circuit range/performance
    B1882 LF/Driver head restraint forward switch circuit low
    B1883 LF/Driver head restraint forward switch circuit high
    B1884 LF/Driver head restraint forward switch circuit open
    B1885 LF/Driver head restraint rearward switch circuit malfunction
    B1886 LF/Driver head restraint rearward switch circuit range/performance
    B1887 LF/Driver head restraint rearward switch circuit low
    B1888 LF/Driver head restraint rearward switch circuit high
    B1889 LF/Driver head restraint rearward switch circuit open
    B1890 LF/Driver head restraint horizontal sensor malfunction
    B1891 LF/Driver head restraint horizontal sensor range/performance
    B1892 LF/Driver head restraint horizontal sensor low
    B1893 LF/Driver head restraint horizontal sensor high
    B1894 LF/Driver head restraint horizontal sensor open
    B1895 LF/Driver head restraint horizontal feedback circuit malfunction
    B1896 LF/Driver head restraint horizontal feedback circuit range/performance
    B1897 LF/Driver head restraint horizontal feedback circuit low
    B1898 LF/Driver head restraint horizontal feedback circuit high
    B1899 LF/Driver head restraint horizontal feedback circuit open
    B1900 LF/Driver head restraint vertical sensor malfunction
    B1901 LF/Driver head restraint vertical sensor range/performance
    B1902 LF/Driver head restraint vertical sensor low
    B1903 LF/Driver head restraint vertical sensor high
    B1904 LF/Driver head restraint vertical sensor open
    B1905 LF/Driver head restraint vertical feedback circuit malfunction
    B1906 LF/Driver head restraint vertical feedback circuit range/performance
    B1907 LF/Driver head restraint vertical feedback circuit low
    B1908 LF/Driver head restraint vertical feedback circuit high
    B1909 LF/Driver head restraint vertical feedback circuit open
    B1910 LF/Driver seat heater switch #1 (whole system or "low") circuit malfunction
    B1911 LF/Driver seat heater switch #1 (whole system or "low") circuit range/performance
    B1912 LF/Driver seat heater switch #1 (whole system or "low") circuit low
    B1913 LF/Driver seat heater switch #1 (whole system or "low") circuit high
    B1914 LF/Driver seat heater switch #1 (whole system or "low") circuit open
    B1915 LF/Driver seat heater switch #2 ("high") circuit malfunction
    B1916 LF/Driver seat heater switch #2 ("high") circuit range/performance
    B1917 LF/Driver seat heater switch #2 ("high") circuit low
    B1918 LF/Driver seat heater switch #2 ("high") circuit high
    B1919 LF/Driver seat heater switch #2 ("high") circuit open
    B1920 LF/Driver seat heater (whole seat or seat cushion) timer circuit malfunction
    B1921 LF/Driver seat heater (whole seat or seat cushion) timer circuit range/performance
    B1922 LF/Driver seat heater (whole seat or seat cushion) timer circuit low
    B1923 LF/Driver seat heater (whole seat or seat cushion) timer circuit high
    B1924 LF/Driver seat heater (whole seat or seat cushion) timer circuit open
    B1925 LF/Driver seat heater (whole seat or seat cushion) sensor malfunction
    B1926 LF/Driver seat heater (whole seat or seat cushion) sensor range/performance
    B1927 LF/Driver seat heater (whole seat or seat cushion) sensor low
    B1928 LF/Driver seat heater (whole seat or seat cushion) sensor high
    B1929 LF/Driver seat heater (whole seat or seat cushion) sensor open
    B1930 LF/Driver seat heater (whole seat or seat cushion) feedback circuit malfunction
    B1931 LF/Driver seat heater (whole seat or seat cushion) feedback circuit range/performance
    B1932 LF/Driver seat heater (whole seat or seat cushion) feedback circuit low
    B1933 LF/Driver seat heater (whole seat or seat cushion) feedback circuit high
    B1934 LF/Driver seat heater (whole seat or seat cushion) feedback circuit open
    B1935 LF/Driver seat back heater malfunction
    B1936 LF/Driver seat back heater range/performance
    B1937 LF/Driver seat back heater low
    B1938 LF/Driver seat back heater high
    B1939 LF/Driver seat back heater open
    B1940 LF/Driver seat side bolster in switch circuit malfunction
    B1941 LF/Driver seat side bolster in switch circuit range/performance
    B1942 LF/Driver seat side bolster in switch circuit low
    B1943 LF/Driver seat side bolster in switch circuit high
    B1944 LF/Driver seat side bolster in switch circuit open
    B1945 LF/Driver seat side bolster out switch circuit malfunction
    B1946 LF/Driver seat side bolster out switch circuit range/performance
    B1947 LF/Driver seat side bolster out switch circuit low
    B1948 LF/Driver seat side bolster out switch circuit high
    B1949 LF/Driver seat side bolster out switch circuit open
    B1950 LF/Driver seat side bolster in circuit malfunction
    B1951 LF/Driver seat side bolster in circuit range/performance
    B1952 LF/Driver seat side bolster in circuit low
    B1953 LF/Driver seat side bolster in circuit high
    B1954 LF/Driver seat side bolster in circuit open
    B1955 LF/Driver seat side bolster out circuit malfunction
    B1956 LF/Driver seat side bolster out circuit range/performance
    B1957 LF/Driver seat side bolster out circuit low
    B1958 LF/Driver seat side bolster out circuit high
    B1959 LF/Driver seat side bolster out circuit open
    B1960 LF/Driver seat side bolster sensor malfunction
    B1961 LF/Driver seat side bolster sensor range/performance
    B1962 LF/Driver seat side bolster sensor low
    B1963 LF/Driver seat side bolster sensor high
    B1964 LF/Driver seat side bolster sensor open
    B1965 LF/Driver seat side bolster feedback circuit malfunction
    B1966 LF/Driver seat side bolster feedback circuit range/performance
    B1967 LF/Driver seat side bolster feedback circuit low
    B1968 LF/Driver seat side bolster feedback circuit high
    B1969 LF/Driver seat side bolster feedback circuit open
    B1970 RF/Passenger seat assembly up switch circuit malfunction
    B1971 RF/Passenger seat assembly up switch circuit range/performance
    B1972 RF/Passenger seat assembly up switch circuit low
    B1973 RF/Passenger seat assembly up switch circuit high
    B1974 RF/Passenger seat assembly up switch circuit open
    B1975 RF/Passenger seat assembly down switch circuit malfunction
    B1976 RF/Passenger seat assembly down switch circuit range/performance
    B1977 RF/Passenger seat assembly down switch circuit low
    B1978 RF/Passenger seat assembly down switch circuit high
    B1979 RF/Passenger seat assembly down switch circuit open
    B1980 RF/Passenger seat front up switch circuit malfunction
    B1981 RF/Passenger seat front up switch circuit range/performance
    B1982 RF/Passenger seat front up switch circuit low
    B1983 RF/Passenger seat front up switch circuit high
    B1984 RF/Passenger seat front up switch circuit open
    B1985 RF/Passenger seat front down switch circuit malfunction
    B1986 RF/Passenger seat front down switch circuit range/performance
    B1987 RF/Passenger seat front down switch circuit low
    B1988 RF/Passenger seat front down switch circuit high
    B1989 RF/Passenger seat front down switch circuit open
    B1990 RF/Passenger seat rear up switch circuit malfunction
    B1991 RF/Passenger seat rear up switch circuit range/performance
    B1992 RF/Passenger seat rear up switch circuit low
    B1993 RF/Passenger seat rear up switch circuit high
    B1994 RF/Passenger seat rear up switch circuit open
    B1995 RF/Passenger seat rear down switch circuit malfunction
    B1996 RF/Passenger seat rear down switch circuit range/performance
    B1997 RF/Passenger seat rear down switch circuit low
    B1998 RF/Passenger seat rear down switch circuit high
    B1999 RF/Passenger seat rear down switch circuit open
    B2000 RF/Passenger seat assembly forward switch circuit malfunction
    B2001 RF/Passenger seat assembly forward switch circuit range/performance
    B2002 RF/Passenger seat assembly forward switch circuit low
    B2003 RF/Passenger seat assembly forward switch circuit high
    B2004 RF/Passenger seat assembly forward switch circuit open
    B2005 RF/Passenger seat assembly rearward switch circuit malfunction
    B2006 RF/Passenger seat assembly rearward switch circuit range/performance
    B2007 RF/Passenger seat assembly rearward switch circuit low
    B2008 RF/Passenger seat assembly rearward switch circuit high
    B2009 RF/Passenger seat assembly rearward switch circuit open
    B2010 RF/Passenger seat motor #1 (ass'y. vertical) circuit malfunction
    B2011 RF/Passenger seat motor #1 (ass'y. vertical) circuit range/performance
    B2012 RF/Passenger seat motor #1 (ass'y. vertical) circuit low
    B2013 RF/Passenger seat motor #1 (ass'y. vertical) circuit high
    B2014 RF/Passenger seat motor #1 (ass'y. vertical) circuit open
    B2015 RF/Passenger seat motor #2 (ass'y. horizontal) circuit malfunction
    B2016 RF/Passenger seat motor #2 (ass'y. horizontal) circuit range/performance
    B2017 RF/Passenger seat motor #2 (ass'y. horizontal) circuit low
    B2018 RF/Passenger seat motor #2 (ass'y. horizontal) circuit high
    B2019 RF/Passenger seat motor #2 (ass'y. horizontal) circuit open
    B2020 RF/Passenger seat motor #3 (front vertical) circuit malfunction
    B2021 RF/Passenger seat motor #3 (front vertical) circuit range/performance
    B2022 RF/Passenger seat motor #3 (front vertical) circuit low
    B2023 RF/Passenger seat motor #3 (front vertical) circuit high
    B2024 RF/Passenger seat motor #3 (front vertical) circuit open
    B2025 RF/Passenger seat motor #4 (rear vertical) circuit malfunction
    B2026 RF/Passenger seat motor #4 (rear vertical) circuit range/performance
    B2027 RF/Passenger seat motor #4 (rear vertical) circuit low
    B2028 RF/Passenger seat motor #4 (rear vertical) circuit high
    B2029 RF/Passenger seat motor #4 (rear vertical) circuit open
    B2030 RF/Passenger seat motor #5 (recline) circuit malfunction
    B2031 RF/Passenger seat motor #5 (recline) circuit range/performance
    B2032 RF/Passenger seat motor #5 (recline) circuit low
    B2033 RF/Passenger seat motor #5 (recline) circuit high
    B2034 RF/Passenger seat motor #5 (recline) circuit open
    B2035 RF/Passenger seat motor #6 (lumbar; single motor or horizontal) circuit malfunction
    B2036 RF/Passenger seat motor #6 (lumbar; single motor or horizontal) circuit range/perform
    B2037 RF/Passenger seat motor #6 (lumbar; single motor or horizontal) circuit low
    B2038 RF/Passenger seat motor #6 (lumbar; single motor or horizontal) circuit high
    B2039 RF/Passenger seat motor #6 (lumbar; single motor or horizontal) circuit open
    B2040 RF/Passenger seat motor #7 (head restraint horizontal) circuit malfunction
    B2041 RF/Passenger seat motor #7 (head restraint horizontal) circuit range/performance
    B2042 RF/Passenger seat motor #7 (head restraint horizontal) circuit low
    B2043 RF/Passenger seat motor #7 (head restraint horizontal) circuit high
    B2044 RF/Passenger seat motor #7 (head restraint horizontal) circuit open
    B2045 RF/Passenger seat motor #8 (head restraint vertical) circuit malfunction
    B2046 RF/Passenger seat motor #8 (head restraint vertical) circuit range/performance
    B2047 RF/Passenger seat motor #8 (head restraint vertical) circuit low
    B2048 RF/Passenger seat motor #8 (head restraint vertical) circuit high
    B2049 RF/Passenger seat motor #8 (head restraint vertical) circuit open
    B2050 RF/Passenger seat motor #9 (side bolster) circuit malfunction
    B2051 RF/Passenger seat motor #9 (side bolster) circuit range/performance
    B2052 RF/Passenger seat motor #9 (side bolster) circuit low
    B2053 RF/Passenger seat motor #9 (side bolster) circuit high
    B2054 RF/Passenger seat motor #9 (side bolster) circuit open
    B2055 RF/Passenger seat motor #10 (thigh bolster) circuit malfunction
    B2056 RF/Passenger seat motor #10 (thigh bolster) circuit range/performance
    B2057 RF/Passenger seat motor #10 (thigh bolster) circuit low
    B2058 RF/Passenger seat motor #10 (thigh bolster) circuit high
    B2059 RF/Passenger seat motor #10 (thigh bolster) circuit open
    B2060 RF/Passenger recline forward switch circuit malfunction
    B2061 RF/Passenger recline forward switch circuit range/performance
    B2062 RF/Passenger recline forward switch circuit low
    B2063 RF/Passenger recline forward switch circuit high
    B2064 RF/Passenger recline forward switch circuit open
    B2065 RF/Passenger recline rearward switch circuit malfunction
    B2066 RF/Passenger recline rearward switch circuit range/performance
    B2067 RF/Passenger recline rearward switch circuit low
    B2068 RF/Passenger recline rearward switch circuit high
    B2069 RF/Passenger recline rearward switch circuit open
    B2070 RF/Passenger recline sensor circuit malfunction
    B2071 RF/Passenger recline sensor circuit range/performance
    B2072 RF/Passenger recline sensor circuit low
    B2073 RF/Passenger recline sensor circuit high
    B2074 RF/Passenger recline sensor circuit open
    B2075 RF/Passenger lumbar forward switch circuit malfunction
    B2076 RF/Passenger lumbar forward switch circuit range/performance
    B2077 RF/Passenger lumbar forward switch circuit low
    B2078 RF/Passenger lumbar forward switch circuit high
    B2079 RF/Passenger lumbar forward switch circuit open
    B2080 RF/Passenger lumbar rearward switch circuit malfunction
    B2081 RF/Passenger lumbar rearward switch circuit range/performance
    B2082 RF/Passenger lumbar rearward switch circuit low
    B2083 RF/Passenger lumbar rearward switch circuit high
    B2084 RF/Passenger lumbar rearward switch circuit open
    B2085 RF/Passenger lumbar up switch circuit malfunction
    B2086 RF/Passenger lumbar up switch circuit range/performance
    B2087 RF/Passenger lumbar up switch circuit low
    B2088 RF/Passenger lumbar up switch circuit high
    B2089 RF/Passenger lumbar up switch circuit open
    B2090 RF/Passenger lumbar down switch circuit malfunction
    B2091 RF/Passenger lumbar down switch circuit range/performance
    B2092 RF/Passenger lumbar down switch circuit low
    B2093 RF/Passenger lumbar down switch circuit high
    B2094 RF/Passenger lumbar down switch circuit open
    B2095 RF/Passenger lumbar horizontal sensor malfunction
    B2096 RF/Passenger lumbar horizontal sensor range/performance
    B2097 RF/Passenger lumbar horizontal sensor low
    B2098 RF/Passenger lumbar horizontal sensor high
    B2099 RF/Passenger lumbar horizontal sensor open
    B2100 RF/Passenger lumbar horizontal feedback circuit malfunction
    B2101 RF/Passenger lumbar horizontal feedback circuit range/performance
    B2102 RF/Passenger lumbar horizontal feedback circuit low
    B2103 RF/Passenger lumbar horizontal feedback circuit high
    B2104 RF/Passenger lumbar horizontal feedback circuit open
    B2105 RF/Passenger lumbar vertical sensor malfunction
    B2106 RF/Passenger lumbar vertical sensor range/performance
    B2107 RF/Passenger lumbar vertical sensor low
    B2108 RF/Passenger lumbar vertical sensor high
    B2109 RF/Passenger lumbar vertical sensor open
    B2110 RF/Passenger lumbar vertical feedback circuit malfunction
    B2111 RF/Passenger lumbar vertical feedback circuit range/performance
    B2112 RF/Passenger lumbar vertical feedback circuit low
    B2113 RF/Passenger lumbar vertical feedback circuit high
    B2114 RF/Passenger lumbar vertical feedback circuit open
    B2115 RF/Passenger head restraint up switch circuit malfunction
    B2116 RF/Passenger head restraint up switch circuit range/performance
    B2117 RF/Passenger head restraint up switch circuit low
    B2118 RF/Passenger head restraint up switch circuit high
    B2119 RF/Passenger head restraint up switch circuit open
    B2120 RF/Passenger head restraint down switch circuit malfunction
    B2121 RF/Passenger head restraint down switch circuit range/performance
    B2122 RF/Passenger head restraint down switch circuit low
    B2123 RF/Passenger head restraint down switch circuit high
    B2124 RF/Passenger head restraint down switch circuit open
    B2125 RF/Passenger head restraint forward switch circuit malfunction
    B2126 RF/Passenger head restraint forward switch circuit range/performance
    B2127 RF/Passenger head restraint forward switch circuit low
    B2128 RF/Passenger head restraint forward switch circuit high
    B2129 RF/Passenger head restraint forward switch circuit open
    B2130 RF/Passenger head restraint rearward switch circuit malfunction
    B2131 RF/Passenger head restraint rearward switch circuit range/performance
    B2132 RF/Passenger head restraint rearward switch circuit low
    B2133 RF/Passenger head restraint rearward switch circuit high
    B2134 RF/Passenger head restraint rearward switch circuit open
    B2135 RF/Passenger head restraint horizontal sensor malfunction
    B2136 RF/Passenger head restraint horizontal sensor range/performance
    B2137 RF/Passenger head restraint horizontal sensor low
    B2138 RF/Passenger head restraint horizontal sensor high
    B2139 RF/Passenger head restraint horizontal sensor open
    B2140 RF/Passenger head restraint horizontal feedback circuit malfunction
    B2141 RF/Passenger head restraint horizontal feedback circuit range/performance
    B2142 RF/Passenger head restraint horizontal feedback circuit low
    B2143 RF/Passenger head restraint horizontal feedback circuit high
    B2144 RF/Passenger head restraint horizontal feedback circuit open
    B2145 RF/Passenger head restraint vertical sensor malfunction
    B2146 RF/Passenger head restraint vertical sensor range/performance
    B2147 RF/Passenger head restraint vertical sensor low
    B2148 RF/Passenger head restraint vertical sensor high
    B2149 RF/Passenger head restraint vertical sensor open
    B2150 RF/Passenger head restraint vertical feedback circuit malfunction
    B2151 RF/Passenger head restraint vertical feedback circuit range/performance
    B2152 RF/Passenger head restraint vertical feedback circuit low
    B2153 RF/Passenger head restraint vertical feedback circuit high
    B2154 RF/Passenger head restraint vertical feedback circuit open
    B2155 RF/Passenger seat heater switch #1 (whole system or "low") circuit malfunction
    B2156 RF/Passenger seat heater switch #1 (whole system or "low") circuit range/performance
    B2157 RF/Passenger seat heater switch #1 (whole system or "low") circuit low
    B2158 RF/Passenger seat heater switch #1 (whole system or "low") circuit high
    B2159 RF/Passenger seat heater switch #1 (whole system or "low") circuit open
    B2160 RF/Passenger seat heater switch #2 ("high") circuit malfunction
    B2161 RF/Passenger seat heater switch #2 ("high") circuit range/performance
    B2162 RF/Passenger seat heater switch #2 ("high") circuit low
    B2163 RF/Passenger seat heater switch #2 ("high") circuit high
    B2164 RF/Passenger seat heater switch #2 ("high") circuit open
    B2165 RF/Passenger seat heater (whole seat or seat cushion) timer circuit malfunction
    B2166 RF/Passenger seat heater (whole seat or seat cushion) timer circuit range/performance
    B2167 RF/Passenger seat heater (whole seat or seat cushion) timer circuit low
    B2168 RF/Passenger seat heater (whole seat or seat cushion) timer circuit high
    B2169 RF/Passenger seat heater (whole seat or seat cushion) timer circuit open
    B2170 RF/Passenger seat heater (whole seat or seat cushion) sensor malfunction
    B2171 RF/Passenger seat heater (whole seat or seat cushion) sensor range/performance
    B2172 RF/Passenger seat heater (whole seat or seat cushion) sensor low
    B2173 RF/Passenger seat heater (whole seat or seat cushion) sensor high
    B2174 RF/Passenger seat heater (whole seat or seat cushion) sensor open
    B2175 RF/Passenger seat heater (whole seat or seat cushion) feedback circuit malfunction
    B2176 RF/Passenger seat heater (whole seat or seat cushion) feedback circuit
    range/performance
    B2177 RF/Passenger seat heater (whole seat or seat cushion) feedback circuit low
    B2178 RF/Passenger seat heater (whole seat or seat cushion) feedback circuit high
    B2179 RF/Passenger seat heater (whole seat or seat cushion) feedback circuit open
    B2180 RF/Passenger seat back heater malfunction
    B2181 RF/Passenger seat back heater range/performance
    B2182 RF/Passenger seat back heater low
    B2183 RF/Passenger seat back heater high
    B2184 RF/Passenger seat back heater open
    B2185 RF/Passenger seat side bolster in switch circuit malfunction
    B2186 RF/Passenger seat side bolster in switch circuit range/performance
    B2187 RF/Passenger seat side bolster in switch circuit low
    B2188 RF/Passenger seat side bolster in switch circuit high
    B2189 RF/Passenger seat side bolster in switch circuit open
    B2190 RF/Passenger seat side bolster out switch circuit malfunction
    B2191 RF/Passenger seat side bolster out switch circuit range/performance
    B2192 RF/Passenger seat side bolster out switch circuit low
    B2193 RF/Passenger seat side bolster out switch circuit high
    B2194 RF/Passenger seat side bolster out switch circuit open
    B2195 RF/Passenger seat side bolster in circuit malfunction
    B2196 RF/Passenger seat side bolster in circuit range/performance
    B2197 RF/Passenger seat side bolster in circuit low
    B2198 RF/Passenger seat side bolster in circuit high
    B2199 RF/Passenger seat side bolster in circuit open
    B2200 RF/Passenger seat side bolster out circuit malfunction
    B2201 RF/Passenger seat side bolster out circuit range/performance
    B2202 RF/Passenger seat side bolster out circuit low
    B2203 RF/Passenger seat side bolster out circuit high
    B2204 RF/Passenger seat side bolster out circuit open
    B2205 RF/Passenger seat side bolster sensor malfunction
    B2206 RF/Passenger seat side bolster sensor range/performance
    B2207 RF/Passenger seat side bolster sensor low
    B2208 RF/Passenger seat side bolster sensor high
    B2209 RF/Passenger seat side bolster sensor open
    B2210 RF/Passenger seat side bolster feedback circuit malfunction
    B2211 RF/Passenger seat side bolster feedback circuit range/performance
    B2212 RF/Passenger seat side bolster feedback circuit low
    B2213 RF/Passenger seat side bolster feedback circuit high
    B2214 RF/Passenger seat side bolster feedback circuit open
    B2215 LR seat assembly forward switch circuit malfunction
    B2216 LR seat assembly forward switch circuit range/performance
    B2217 LR seat assembly forward switch circuit low
    B2218 LR seat assembly forward switch circuit high
    B2219 LR seat assembly forward switch circuit open
    B2220 LR seat assembly rearward switch circuit malfunction
    B2221 LR seat assembly rearward switch circuit range/performance
    B2222 LR seat assembly rearward switch circuit low
    B2223 LR seat assembly rearward switch circuit high
    B2224 LR seat assembly rearward switch circuit open
    B2225 LR seat motor #1 (ass'y. horizontal) circuit malfunction
    B2226 LR seat motor #1 (ass'y. horizontal) circuit range/performance
    B2227 LR seat motor #1 (ass'y. horizontal) circuit low
    B2228 LR seat motor #1 (ass'y. horizontal) circuit high
    B2229 LR seat motor #1 (ass'y. horizontal) circuit open
    B2230 LR seat motor #2 (head restraint horizontal) circuit malfunction
    B2231 LR seat motor #2 (head restraint horizontal) circuit range/performance
    B2232 LR seat motor #2 (head restraint horizontal) circuit low
    B2233 LR seat motor #2 (head restraint horizontal) circuit high
    B2234 LR seat motor #2 (head restraint horizontal) circuit open
    B2235 LR seat motor #3 (head restraint vertical) circuit malfunction
    B2236 LR seat motor #3 (head restraint vertical) circuit range/performance
    B2237 LR seat motor #3 (head restraint vertical) circuit low
    B2238 LR seat motor #3 (head restraint vertical) circuit high
    B2239 LR seat motor #3 (head restraint vertical) circuit open
    B2240 LR head restraint up switch circuit malfunction
    B2241 LR head restraint up switch circuit range/performance
    B2242 LR head restraint up switch circuit low
    B2243 LR head restraint up switch circuit high
    B2244 LR head restraint up switch circuit open
    B2245 LR head restraint down switch circuit malfunction
    B2246 LR head restraint down switch circuit range/performance
    B2247 LR head restraint down switch circuit low
    B2248 LR head restraint down switch circuit high
    B2249 LR head restraint down switch circuit open
    B2250 LR head restraint forward switch circuit malfunction
    B2251 LR head restraint forward switch circuit range/performance
    B2252 LR head restraint forward switch circuit low
    B2253 LR head restraint forward switch circuit high
    B2254 LR head restraint forward switch circuit open
    B2255 LR head restraint rearward switch circuit malfunction
    B2256 LR head restraint rearward switch circuit range/performance
    B2257 LR head restraint rearward switch circuit low
    B2258 LR head restraint rearward switch circuit high
    B2259 LR head restraint rearward switch circuit open
    B2260 LR seat heater switch #1 (whole system or "low") circuit malfunction
    B2261 LR seat heater switch #1 (whole system or "low") circuit range/performance
    B2262 LR seat heater switch #1 (whole system or "low") circuit low
    B2263 LR seat heater switch #1 (whole system or "low") circuit high
    B2264 LR seat heater switch #1 (whole system or "low") circuit open
    B2265 LR seat heater switch #2 ("high") circuit malfunction
    B2266 LR seat heater switch #2 ("high") circuit range/performance
    B2267 LR seat heater switch #2 ("high") circuit low
    B2268 LR seat heater switch #2 ("high") circuit high
    B2269 LR seat heater switch #2 ("high") circuit open
    B2270 LR seat heater sensor malfunction
    B2271 LR seat heater sensor range/performance
    B2272 LR seat heater sensor low
    B2273 LR seat heater sensor high
    B2274 LR seat heater sensor open
    B2275 LR seat heater feedback circuit malfunction
    B2276 LR seat heater feedback circuit range/performance
    B2277 LR seat heater feedback circuit low
    B2278 LR seat heater feedback circuit high
    B2279 LR seat heater feedback circuit open
    B2280 RR seat assembly forward switch circuit malfunction
    B2281 RR seat assembly forward switch circuit range/performance
    B2282 RR seat assembly forward switch circuit low
    B2283 RR seat assembly forward switch circuit high
    B2284 RR seat assembly forward switch circuit open
    B2285 RR seat assembly rearward switch circuit malfunction
    B2286 RR seat assembly rearward switch circuit range/performance
    B2287 RR seat assembly rearward switch circuit low
    B2288 RR seat assembly rearward switch circuit high
    B2289 RR seat assembly rearward switch circuit open
    B2290 RR seat motor #1 (ass'y. horizontal) circuit malfunction
    B2291 RR seat motor #1 (ass'y. horizontal) circuit range/performance
    B2292 RR seat motor #1 (ass'y. horizontal) circuit low
    B2293 RR seat motor #1 (ass'y. horizontal) circuit high
    B2294 RR seat motor #1 (ass'y. horizontal) circuit open
    B2295 RR seat motor #2 (head restraint horizontal) circuit malfunction
    B2296 RR seat motor #2 (head restraint horizontal) circuit range/performance
    B2297 RR seat motor #2 (head restraint horizontal) circuit low
    B2298 RR seat motor #2 (head restraint horizontal) circuit high
    B2299 RR seat motor #2 (head restraint horizontal) circuit open
    B2300 RR seat motor #3 (head restraint vertical) circuit malfunction
    B2301 RR seat motor #3 (head restraint vertical) circuit range/performance
    B2302 RR seat motor #3 (head restraint vertical) circuit low
    B2303 RR seat motor #3 (head restraint vertical) circuit high
    B2304 RR seat motor #3 (head restraint vertical) circuit open
    B2305 RR head restraint up switch circuit malfunction
    B2306 RR head restraint up switch circuit range/performance
    B2307 RR head restraint up switch circuit low
    B2308 RR head restraint up switch circuit high
    B2309 RR head restraint up switch circuit open
    B2310 RR head restraint down switch circuit malfunction
    B2311 RR head restraint down switch circuit range/performance
    B2312 RR head restraint down switch circuit low
    B2313 RR head restraint down switch circuit high
    B2314 RR head restraint down switch circuit open
    B2315 RR head restraint forward switch circuit malfunction
    B2316 RR head restraint forward switch circuit range/performance
    B2317 RR head restraint forward switch circuit low
    B2318 RR head restraint forward switch circuit high
    B2319 RR head restraint forward switch circuit open
    B2320 RR head restraint rearward switch circuit malfunction
    B2321 RR head restraint rearward switch circuit range/performance
    B2322 RR head restraint rearward switch circuit low
    B2323 RR head restraint rearward switch circuit high
    B2324 RR head restraint rearward switch circuit open
    B2325 RR seat heater switch #1 (whole system or "low") circuit malfunction
    B2326 RR seat heater switch #1 (whole system or "low") circuit range/performance
    B2327 RR seat heater switch #1 (whole system or "low") circuit low
    B2328 RR seat heater switch #1 (whole system or "low") circuit high
    B2329 RR seat heater switch #1 (whole system or "low") circuit open
    B2330 RR seat heater switch #2 ("high") circuit malfunction
    B2331 RR seat heater switch #2 ("high") circuit range/performance
    B2332 RR seat heater switch #2 ("high") circuit low
    B2333 RR seat heater switch #2 ("high") circuit high
    B2334 RR seat heater switch #2 ("high") circuit open
    B2335 RR seat heater sensor malfunction
    B2336 RR seat heater sensor range/performance
    B2337 RR seat heater sensor low
    B2338 RR seat heater sensor high
    B2339 RR seat heater sensor open
    B2340 RR seat heater feedback circuit malfunction
    B2341 RR seat heater feedback circuit range/performance
    B2342 RR seat heater feedback circuit low
    B2343 RR seat heater feedback circuit high
    B2344 RR seat heater feedback circuit open
    B2345 Front seat heater disable malfunction
    B2346 Front seat heater disable range/performance
    B2347 Front seat heater disable low
    B2348 Front seat heater disable high
    B2349 Front seat heater disable open
    B2350 Rear seat heater disable malfunction
    B2351 Rear seat heater disable range/performance
    B2352 Rear seat heater disable low
    B2353 Rear seat heater disable high
    B2354 Rear seat heater disable open
    B2355 LF/Driver front vertical sensor malfunction
    B2356 LF/Driver front vertical sensor range/performance
    B2357 LF/Driver front vertical sensor low
    B2358 LF/Driver front vertical sensor high
    B2359 LF/Driver front vertical sensor open
    B2360 LF/Driver front vertical feedback circuit malfunction
    B2361 LF/Driver front vertical feedback circuit range/performance
    B2362 LF/Driver front vertical feedback circuit low
    B2363 LF/Driver front vertical feedback circuit high
    B2364 LF/Driver front vertical feedback circuit open
    B2365 LF/Driver rear vertical sensor malfunction
    B2366 LF/Driver rear vertical sensor range/performance
    B2367 LF/Driver rear vertical sensor low
    B2368 LF/Driver rear vertical sensor high
    B2369 LF/Driver rear vertical sensor open
    B2370 LF/Driver rear vertical feedback circuit malfunction
    B2371 LF/Driver rear vertical feedback circuit range/performance
    B2372 LF/Driver rear vertical feedback circuit low
    B2373 LF/Driver rear vertical feedback circuit high
    B2374 LF/Driver rear vertical feedback circuit open
    B2375 LF/Driver seat assembly horizontal sensor malfunction
    B2376 LF/Driver seat assembly horizontal sensor range/performance
    B2377 LF/Driver seat assembly horizontal sensor low
    B2378 LF/Driver seat assembly horizontal sensor high
    B2379 LF/Driver seat assembly horizontal sensor open
    B2380 LF/Driver seat assembly horizontal feedback circuit malfunction
    B2381 LF/Driver seat assembly horizontal feedback circuit range/performance
    B2382 LF/Driver seat assembly horizontal feedback circuit low
    B2383 LF/Driver seat assembly horizontal feedback circuit high
    B2384 LF/Driver seat assembly horizontal feedback circuit open
    B2385 RF/Passenger front vertical sensor malfunction
    B2386 RF/Passenger front vertical sensor range/performance
    B2387 RF/Passenger front vertical sensor low
    B2388 RF/Passenger front vertical sensor high
    B2389 RF/Passenger front vertical sensor open
    B2390 RF/Passenger front vertical feedback circuit malfunction
    B2391 RF/Passenger front vertical feedback circuit range/performance
    B2392 RF/Passenger front vertical feedback circuit low
    B2393 RF/Passenger front vertical feedback circuit high
    B2394 RF/Passenger front vertical feedback circuit open
    B2395 RF/Passenger rear vertical sensor malfunction
    B2396 RF/Passenger rear vertical sensor range/performance
    B2397 RF/Passenger rear vertical sensor low
    B2398 RF/Passenger rear vertical sensor high
    B2399 RF/Passenger rear vertical sensor open
    B2400 RF/Passenger rear vertical feedback circuit malfunction
    B2401 RF/Passenger rear vertical feedback circuit range/performance
    B2402 RF/Passenger rear vertical feedback circuit low
    B2403 RF/Passenger rear vertical feedback circuit high
    B2404 RF/Passenger rear vertical feedback circuit open
    B2405 RF/Passenger seat assembly horizontal sensor malfunction
    B2406 RF/Passenger seat assembly horizontal sensor range/performance
    B2407 RF/Passenger seat assembly horizontal sensor low
    B2408 RF/Passenger seat assembly horizontal sensor high
    B2409 RF/Passenger seat assembly horizontal sensor open
    B2410 RF/Passenger seat assembly horizontal feedback circuit malfunction
    B2411 RF/Passenger seat assembly horizontal feedback circuit range/performance
    B2412 RF/Passenger seat assembly horizontal feedback circuit low
    B2413 RF/Passenger seat assembly horizontal feedback circuit high
    B2414 RF/Passenger seat assembly horizontal feedback circuit open
    B2415 LF/Driver seat motor #11 (lumbar, vertical) circuit malfunction
    B2416 LF/Driver seat motor #11 (lumbar, vertical) circuit range/performance
    B2417 LF/Driver seat motor #11 (lumbar, vertical) circuit low
    B2418 LF/Driver seat motor #11 (lumbar, vertical) circuit high
    B2419 LF/Driver seat motor #11 (lumbar, vertical) circuit open
    B2420 RF/Passenger seat motor #11 (lumbar, vertical) circuit malfunction
    B2421 RF/Passenger seat motor #11 (lumbar, vertical) circuit range/performance
    B2422 RF/Passenger seat motor #11 (lumbar, vertical) circuit low
    B2423 RF/Passenger seat motor #11 (lumbar, vertical) circuit high
    B2424 RF/Passenger seat motor #11 (lumbar, vertical) circuit open
    B2425 LF/Driver seat heater (whole seat or cushion) circuit malfunction
    B2426 LF/Driver seat heater (whole seat or cushion) circuit range/performance
    B2427 LF/Driver seat heater (whole seat or cushion) circuit low
    B2428 LF/Driver seat heater (whole seat or cushion) circuit high
    B2429 LF/Driver seat heater (whole seat or cushion) circuit open
    B2430 RF/Passenger seat heater (whole seat or cushion) circuit malfunction
    B2431 RF/Passenger seat heater (whole seat or cushion) circuit range/performance
    B2432 RF/Passenger seat heater (whole seat or cushion) circuit low
    B2433 RF/Passenger seat heater (whole seat or cushion) circuit high
    B2434 RF/Passenger seat heater (whole seat or cushion) circuit open
    B2435 LF/Driver seat back heater sensor malfunction
    B2436 LF/Driver seat back heater sensor range/performance
    B2437 LF/Driver seat back heater sensor low
    B2438 LF/Driver seat back heater sensor high
    B2439 LF/Driver seat back heater sensor open
    B2440 RF/Passenger seat back heater sensor malfunction
    B2441 RF/Passenger seat back heater sensor range/performance
    B2442 RF/Passenger seat back heater sensor low
    B2443 RF/Passenger seat back heater sensor high
    B2444 RF/Passenger seat back heater sensor open
    B2445 LF/Driver thigh bolster sensor malfunction
    B2446 LF/Driver thigh bolster sensor range/performance
    B2447 LF/Driver thigh bolster sensor low
    B2448 LF/Driver thigh bolster sensor high
    B2449 LF/Driver thigh bolster sensor open
    B2450 Cellular phone handset (in-vehicle) circuit malfunction
    B2451 Cellular phone handset (in-vehicle) circuit range/performance
    B2452 Cellular phone handset (in-vehicle) circuit low
    B2453 Cellular phone handset (in-vehicle) circuit high
    B2454 Cellular phone handset (in-vehicle) circuit open
    B2455 Cellular phone microphone circuit malfunction
    B2456 Cellular phone microphone circuit range/performance
    B2457 Cellular phone microphone circuit low
    B2458 Cellular phone microphone circuit high
    B2459 Cellular phone microphone circuit open
    B2460 Navigation antenna selector circuit high current
    B2461 Navigation ECU synchronous signal error
    B2462 GPS signal error
    B2463 Navigation CD player - no disk
    B2464 Navigation CD player - decoding error
    B2465 Navigation CD player - data error
    B2466 Navigation VICS memory error
    B2467 Cellular phone portable handset malfunction
    B2468 Navigation Display Unit malfunction
    B2469 Cellular phone unit malfunction
    B2470 Cellular phone antenna circuit malfunction
    B2471 Automatic dialing malfunction
    B2472 Road assistance request switch circuit malfunction
    B2473 Redundant road assistance request switch circuit malfunction
    B2474 NDH backlighting malfunction
    B2475 NDH auxiliary input malfunction
    B2476 Cellular phone select service switch malfunction
    B2477 Supplemental heater enable circuit malfunction
    B2478 Security system status circuit malfunction
    B2525 Front foglamps circuit malfunction
    B2526 Front foglamps circuit range/performance
    B2527 Front foglamps circuit low
    B2528 Front foglamps circuit high
    B2529 Front foglamps circuit open
    B2530 Front foglamps control circuit malfunction
    B2531 Front foglamps control circuit range/performance
    B2532 Front foglamps control circuit low
    B2533 Front foglamps control circuit high
    B2534 Front foglamps control circuit open
    B2535 Rear foglamps circuit malfunction
    B2536 Rear foglamps circuit range/performance
    B2537 Rear foglamps circuit low
    B2538 Rear foglamps circuit high
    B2539 Rear foglamps circuit open
    B2540 Rear foglamps control circuit malfunction
    B2541 Rear foglamps control circuit range/performance
    B2542 Rear foglamps control circuit low
    B2543 Rear foglamps control circuit high
    B2544 Rear foglamps control circuit open
    B2545 Backup lamps circuit malfunction
    B2546 Backup lamps circuit range/performance
    B2547 Backup lamps circuit low
    B2548 Backup lamps circuit high
    B2549 Backup lamps circuit open
    B2550 Backup lamps control circuit malfunction
    B2551 Backup lamps control circuit range/performance
    B2552 Backup lamps control circuit low
    B2553 Backup lamps control circuit high
    B2554 Backup lamps control circuit open
    B2555 Passenger compartment lamp control circuit malfunction
    B2556 Passenger compartment lamp control circuit range/performance
    B2557 Passenger compartment lamp control circuit low
    B2558 Passenger compartment lamp control circuit high
    B2559 Passenger compartment lamp control circuit open
    B2560 Cargo lamp control circuit malfunction
    B2561 Cargo lamp control circuit range/performance
    B2562 Cargo lamp control circuit low
    B2563 Cargo lamp control circuit high
    B2564 Cargo lamp control circuit open
    B2565 Underhood lamp control circuit malfunction
    B2566 Underhood lamp control circuit range/performance
    B2567 Underhood lamp control circuit low
    B2568 Underhood lamp control circuit high
    B2569 Underhood lamp control circuit open
    B2570 Trunk/hatch lamp control circuit malfunction
    B2571 Trunk/hatch lamp control circuit range/performance
    B2572 Trunk/hatch lamp control circuit low
    B2573 Trunk/hatch lamp control circuit high
    B2574 Trunk/hatch lamp control circuit open
    B2575 Headlamp control circuit malfunction
    B2576 Headlamp control circuit range/performance
    B2577 Headlamp control circuit low
    B2578 Headlamp control circuit high
    B2579 Headlamp control circuit open
    B2580 Headlamp high beam control circuit malfunction
    B2581 Headlamp high beam control circuit range/performance
    B2582 Headlamp high beam control circuit low
    B2583 Headlamp high beam control circuit high
    B2584 Headlamp high beam control circuit open
    B2585 Parklamp control circuit malfunction
    B2586 Parklamp control circuit range/performance
    B2587 Parklamp control circuit low
    B2588 Parklamp control circuit high
    B2589 Parklamp control circuit open
    B2590 LH cornering lamp circuit malfunction
    B2591 LH cornering lamp circuit range/performance
    B2592 LH cornering lamp circuit low
    B2593 LH cornering lamp circuit high
    B2594 LH cornering lamp circuit open
    B2595 RH cornering lamp circuit malfunction
    B2596 RH cornering lamp circuit range/performance
    B2597 RH cornering lamp circuit low
    B2598 RH cornering lamp circuit high
    B2599 RH cornering lamp circuit open
    B2600 Daytime running lamp control #1 (LH or system) circuit malfunction
    B2601 Daytime running lamp control #1 (LH or system) circuit range/performance
    B2602 Daytime running lamp control #1 (LH or system) circuit low
    B2603 Daytime running lamp control #1 (LH or system) circuit high
    B2604 Daytime running lamp control #1 (LH or system) circuit open
    B2605 Daytime running lamp control #2 (RH) circuit malfunction
    B2606 Daytime running lamp control #2 (RH) circuit range/performance
    B2607 Daytime running lamp control #2 (RH) circuit low
    B2608 Daytime running lamp control #2 (RH) circuit high
    B2609 Daytime running lamp control #2 (RH) circuit open
    B2610 Passenger compartment dimming #1 (cluster, etc.) circuit malfunction
    B2611 Passenger compartment dimming #1 (cluster, etc.) circuit range/performance
    B2612 Passenger compartment dimming #1 (cluster, etc.) circuit low
    B2613 Passenger compartment dimming #1 (cluster, etc.) circuit high
    B2614 Passenger compartment dimming #1 (cluster, etc.) circuit open
    B2615 Passenger compartment dimming #2 (dome lamp, etc.) circuit malfunction
    B2616 Passenger compartment dimming #2 (dome lamp, etc.) circuit range/performance
    B2617 Passenger compartment dimming #2 (dome lamp, etc.) circuit low
    B2618 Passenger compartment dimming #2 (dome lamp, etc.) circuit high
    B2619 Passenger compartment dimming #2 (dome lamp, etc.) circuit open
    B2620 Display dimming PWM input circuit malfunction
    B2621 Display dimming PWM input circuit range/performance
    B2622 Display dimming PWM input circuit low
    B2623 Display dimming PWM input circuit high
    B2624 Display dimming PWM input circuit open
    B2625 Display dimming PWM output circuit malfunction
    B2626 Display dimming PWM output circuit range/performance
    B2627 Display dimming PWM output circuit low
    B2628 Display dimming PWM output circuit high
    B2629 Display dimming PWM output circuit open
    B2630 Illuminated entry enable circuit malfunction
    B2631 Illuminated entry enable circuit range/performance
    B2632 Illuminated entry enable circuit low
    B2633 Illuminated entry enable circuit high
    B2634 Illuminated entry enable circuit open
    B2635 Illuminated entry output circuit malfunction
    B2636 Illuminated entry output circuit range/performance
    B2637 Illuminated entry output circuit low
    B2638 Illuminated entry output circuit high
    B2639 Illuminated entry output circuit open
    B2640 Delayed exterior lighting control circuit malfunction
    B2641 Delayed exterior lighting control circuit range/performance
    B2642 Delayed exterior lighting control circuit low
    B2643 Delayed exterior lighting control circuit high
    B2644 Delayed exterior lighting control circuit open
    B2645 Ambient light sensor circuit malfunction
    B2646 Ambient light sensor circuit range/performance
    B2647 Ambient light sensor circuit low
    B2648 Ambient light sensor circuit high
    B2649 Ambient light sensor circuit open
    B2650 LH DRL filament open
    B2651 RH DRL filament open
    B2652 Passenger compartment dimming #3 (dome lamp, etc.) circuit malfunction
    B2653 Passenger compartment dimming #3 (dome lamp, etc.) circuit range/performance
    B2654 Passenger compartment dimming #3 (dome lamp, etc.) circuit low
    B2655 Passenger compartment dimming #3 (dome lamp, etc.) circuit high
    B2656 Passenger compartment dimming #3 (dome lamp, etc.) circuit open
    B2657 Ignition halo lamp output circuit malfunction
    B2658 Ignition halo lamp output circuit range/performance
    B2659 Ignition halo lamp output circuit low
    B2660 Ignition halo lamp output circuit high
    B2661 Ignition halo lamp output circuit open
    B2662 Parklamp switch circuit malfunction
    B2663 Parklamp switch circuit range/performance
    B2664 Parklamp switch circuit low
    B2665 Parklamp switch circuit high
    B2666 Parklamp switch circuit open
    B2667 AHLD LH servo driver terminal #1 circuit malfunction
    B2668 AHLD LH servo driver terminal #1 circuit range/performance
    B2669 AHLD LH servo driver terminal #1 circuit low
    B2670 AHLD LH servo driver terminal #1 circuit high
    B2671 AHLD LH servo driver terminal #1 circuit open
    B2672 AHLD LH servo driver terminal #2 circuit malfunction
    B2673 AHLD LH servo driver terminal #2 circuit range/performance
    B2674 AHLD LH servo driver terminal #2 circuit low
    B2675 AHLD LH servo driver terminal #2 circuit high
    B2676 AHLD LH servo driver terminal #2 circuit open
    B2677 AHLD RH servo driver terminal #1 circuit malfunction
    B2678 AHLD RH servo driver terminal #1 circuit range/performance
    B2679 AHLD RH servo driver terminal #1 circuit low
    B2680 AHLD RH servo driver terminal #1 circuit high
    B2681 AHLD RH servo driver terminal #1 circuit open
    B2682 AHLD RH servo driver terminal #2 circuit malfunction
    B2683 AHLD RH servo driver terminal #2 circuit range/performance
    B2684 AHLD RH servo driver terminal #2 circuit low
    B2685 AHLD RH servo driver terminal #2 circuit high
    B2686 AHLD RH servo driver terminal #2 circuit open
    B2687 AHLD LH position sensor signal circuit malfunction
    B2688 AHLD LH position sensor signal circuit range/performance
    B2689 AHLD LH position sensor signal circuit low
    B2690 AHLD LH position sensor signal circuit high
    B2691 AHLD LH position sensor signal circuit open
    B2692 AHLD LH position sensor supply circuit malfunction
    B2693 AHLD LH position sensor supply circuit range/performance
    B2694 AHLD LH position sensor supply circuit low
    B2695 AHLD LH position sensor supply circuit high
    B2696 AHLD LH position sensor supply circuit open
    B2697 Headlamp washer request circuit malfunction
    B2700 Ignition shift interlock circuit malfunction
    B2701 Ignition shift interlock circuit range/performance
    B2702 Ignition shift interlock circuit low
    B2703 Ignition shift interlock circuit high
    B2704 Ignition shift interlock circuit open
    B2705 Gearshift unlock circuit malfunction
    B2706 Gearshift unlock circuit range/performance
    B2707 Gearshift unlock circuit low
    B2708 Gearshift unlock circuit high
    B2709 Gearshift unlock circuit open
    B2710 Gearshift lock circuit malfunction
    B2711 Gearshift lock circuit range/performance
    B2712 Gearshift lock circuit low
    B2713 Gearshift lock circuit high
    B2714 Gearshift lock circuit open
    B2715 Gearshift override circuit malfunction
    B2716 Gearshift override circuit range/performance
    B2717 Gearshift override circuit low
    B2718 Gearshift override circuit high
    B2719 Gearshift override circuit open
    B2720 Transmission preference switch circuit malfunction
    B2721 Transmission preference switch circuit range/performance
    B2722 Transmission preference switch circuit low
    B2723 Transmission preference switch circuit high
    B2724 Transmission preference switch circuit open
    B2725 ATC mode switch circuit malfunction
    B2726 ATC mode switch circuit range/performance
    B2727 ATC mode switch circuit low
    B2728 ATC mode switch circuit high
    B2729 ATC mode switch circuit open
    B2730 Trunk release switch circuit malfunction
    B2731 Trunk release switch circuit range/performance
    B2732 Trunk release switch circuit low
    B2733 Trunk release switch circuit high
    B2734 Trunk release switch circuit open
    B2735 Fuel door release switch circuit malfunction
    B2736 Fuel door release switch circuit range/performance
    B2737 Fuel door release switch circuit low
    B2738 Fuel door release switch circuit high
    B2739 Fuel door release switch circuit open
    B2740 Foglamp switch circuit malfunction
    B2741 Foglamp switch circuit range/performance
    B2742 Foglamp switch circuit low
    B2743 Foglamp switch circuit high
    B2744 Foglamp switch circuit open
    B2745 Traction control switch circuit malfunction
    B2746 Traction control switch circuit range/performance
    B2747 Traction control switch circuit low
    B2748 Traction control switch circuit high
    B2749 Traction control switch circuit open
    B2750 Horn relay coil circuit malfunction
    B2751 Horn relay coil circuit range/performance
    B2752 Horn relay coil circuit low
    B2753 Horn relay coil circuit high
    B2754 Horn relay coil circuit open
    B2755 LF/Driver memory 1 select switch circuit malfunction
    B2756 LF/Driver memory 1 select switch circuit range/performance
    B2757 LF/Driver memory 1 select switch circuit low
    B2758 LF/Driver memory 1 select switch circuit high
    B2759 LF/Driver memory 1 select switch circuit open
    B2760 LF/Driver memory 2 select switch circuit malfunction
    B2761 LF/Driver memory 2 select switch circuit range/performance
    B2762 LF/Driver memory 2 select switch circuit low
    B2763 LF/Driver memory 2 select switch circuit high
    B2764 LF/Driver memory 2 select switch circuit open
    B2765 LF/Driver memory set switch circuit malfunction
    B2766 LF/Driver memory set switch circuit range/performance
    B2767 LF/Driver memory set switch circuit low
    B2768 LF/Driver memory set switch circuit high
    B2769 LF/Driver memory set switch circuit open
    B2770 LF/Driver memory exit/off switch circuit malfunction
    B2771 LF/Driver memory exit/off switch circuit range/performance
    B2772 LF/Driver memory exit/off switch circuit low
    B2773 LF/Driver memory exit/off switch circuit high
    B2774 LF/Driver memory exit/off switch circuit open
    B2775 RF/Passenger memory 1 select switch circuit malfunction
    B2776 RF/Passenger memory 1 select switch circuit range/performance
    B2777 RF/Passenger memory 1 select switch circuit low
    B2778 RF/Passenger memory 1 select switch circuit high
    B2779 RF/Passenger memory 1 select switch circuit open
    B2780 RF/Passenger memory 2 select switch circuit malfunction
    B2781 RF/Passenger memory 2 select switch circuit range/performance
    B2782 RF/Passenger memory 2 select switch circuit low
    B2783 RF/Passenger memory 2 select switch circuit high
    B2784 RF/Passenger memory 2 select switch circuit open
    B2785 RF/Passenger memory set switch circuit malfunction
    B2786 RF/Passenger memory set switch circuit range/performance
    B2787 RF/Passenger memory set switch circuit low
    B2788 RF/Passenger memory set switch circuit high
    B2789 RF/Passenger memory set switch circuit open
    B2790 RF/Passenger memory exit/off switch circuit malfunction
    B2791 RF/Passenger memory exit/off switch circuit range/performance
    B2792 RF/Passenger memory exit/off switch circuit low
    B2793 RF/Passenger memory exit/off switch circuit high
    B2794 RF/Passenger memory exit/off switch circuit open
    B2795 Suspension control select switch circuit malfunction
    B2796 Suspension control select switch circuit range/performance
    B2797 Suspension control select switch circuit low
    B2798 Suspension control select switch circuit high
    B2799 Suspension control select switch circuit open
    B2800 Suspension control select switch feedback malfunction
    B2801 Suspension control select switch feedback range/performance
    B2802 Suspension control select switch feedback low
    B2803 Suspension control select switch feedback high
    B2804 Suspension control select switch feedback open
    B2805 Steering wheel controls HVAC switch circuit malfunction
    B2806 Steering wheel controls HVAC switch circuit range/performance
    B2807 Steering wheel controls HVAC switch circuit low
    B2808 Steering wheel controls HVAC switch circuit high
    B2809 Steering wheel controls HVAC switch circuit open
    B2810 Steering wheel controls entertainment circuit malfunction
    B2811 Steering wheel controls entertainment circuit range/performance
    B2812 Steering wheel controls entertainment circuit low
    B2813 Steering wheel controls entertainment circuit high
    B2814 Steering wheel controls entertainment circuit open
    B2815 Steering wheel controls illegal resistance value
    B2816 Low tire pressure system reset circuit malfunction
    B2817 Low tire pressure system reset circuit range/performance
    B2818 Low tire pressure system reset circuit low
    B2819 Low tire pressure system reset circuit high
    B2820 Low tire pressure system reset circuit open
    B2821 Trip odometer reset switch circuit malfunction
    B2822 Trip odometer reset switch circuit range/performance
    B2823 Trip odometer reset switch circuit low
    B2824 Trip odometer reset switch circuit high
    B2825 Trip odometer reset switch circuit open
    B2826 DIC fuel info switch circuit malfunction
    B2827 DIC fuel info switch circuit range/performance
    B2828 DIC fuel info switch circuit low
    B2829 DIC fuel info switch circuit high
    B2830 DIC fuel info switch circuit open
    B2831 DIC gage switch circuit malfunction
    B2832 DIC gage switch circuit range/performance
    B2833 DIC gage switch circuit low
    B2834 DIC gage switch circuit high
    B2835 DIC gage switch circuit open
    B2836 DIC reset switch circuit malfunction
    B2837 DIC reset switch circuit range/performance
    B2838 DIC reset switch circuit low
    B2839 DIC reset switch circuit high
    B2840 DIC reset switch circuit open
    B2841 DIC English/Metric switch circuit malfunction
    B2842 DIC English/Metric switch circuit range/performance
    B2843 DIC English/Metric switch circuit low
    B2844 DIC English/Metric switch circuit high
    B2845 DIC English/Metric switch circuit open
    B2846 DIC Trip/Season odometer switch circuit malfunction
    B2847 DIC Trip/Season odometer switch circuit range/performance
    B2848 DIC Trip/Season odometer switch circuit low
    B2849 DIC Trip/Season odometer switch circuit high
    B2850 Telescope forward switch circuit malfunction
    B2851 Telescope forward switch circuit range/performance
    B2852 Telescope forward switch circuit low
    B2853 Telescope forward switch circuit high
    B2854 Telescope forward switch circuit open
    B2855 Telescope rearward switch circuit malfunction
    B2856 Telescope rearward switch circuit range/performance
    B2857 Telescope rearward switch circuit low
    B2858 Telescope rearward switch circuit high
    B2859 Telescope rearward switch circuit open
    B2860 Telescope position sensor malfunction
    B2861 Telescope position sensor range/performance
    B2862 Telescope position sensor low
    B2863 Telescope position sensor high
    B2864 Telescope position sensor open
    B2865 Telescope position feedback circuit malfunction
    B2866 Telescope position feedback circuit range/performance
    B2867 Telescope position feedback circuit low
    B2868 Telescope position feedback circuit high
    B2869 Telescope position feedback circuit open
    B2870 Tilt up switch circuit malfunction
    B2871 Tilt up switch circuit range/performance
    B2872 Tilt up switch circuit low
    B2873 Tilt up switch circuit high
    B2874 Tilt up switch circuit open
    B2875 Tilt down switch circuit malfunction
    B2876 Tilt down switch circuit range/performance
    B2877 Tilt down switch circuit low
    B2878 Tilt down switch circuit high
    B2879 Tilt down switch circuit open
    B2880 Tilt position sensor malfunction
    B2881 Tilt position sensor range/performance
    B2882 Tilt position sensor low
    B2883 Tilt position sensor high
    B2884 Tilt position sensor open
    B2885 Tilt position feedback circuit malfunction
    B2886 Tilt position feedback circuit range/performance
    B2887 Tilt position feedback circuit low
    B2888 Tilt position feedback circuit high
    B2889 Tilt position feedback circuit open
    B2890 Tilt & telescope motor circuit malfunction
    B2891 Tilt & telescope motor circuit range/performance
    B2892 Tilt & telescope motor circuit low
    B2893 Tilt & telescope motor circuit high
    B2894 Tilt & telescope motor circuit open
    B2895 Tilt & telescope motor overcurrent
    B2896 Tilt & telescope motor protection active
    B2897 Steering column lock solenoid/motor circuit malfunction
    B2898 Steering column lock solenoid/motor circuit range/performance
    B2899 Steering column lock solenoid/motor circuit low
    B2900 Steering column lock solenoid/motor circuit high
    B2901 Steering column lock solenoid/motor circuit open
    B2902 Tilt & telescope 4-way position switch circuit malfunction
    B2903 Tilt & telescope 4-way position switch circuit range/performance
    B2904 Tilt & telescope 4-way position switch circuit low
    B2905 Tilt & telescope 4-way position switch circuit high
    B2906 Tilt & telescope 4-way position switch circuit open
    B2925 Security system enable/arm (local) circuit malfunction
    B2926 Security system enable/arm (local) circuit range/performance
    B2927 Security system enable/arm (local) circuit low
    B2928 Security system enable/arm (local) circuit high
    B2929 Security system enable/arm (local) circuit open
    B2930 Security system disable/disarm (local) circuit malfunction
    B2931 Security system disable/disarm (local) circuit range/performance
    B2932 Security system disable/disarm (local) circuit low
    B2933 Security system disable/disarm (local) circuit high
    B2934 Security system disable/disarm (local) circuit open
    B2935 Security system enable/arm (remote) circuit malfunction
    B2936 Security system enable/arm (remote) circuit range/performance
    B2937 Security system enable/arm (remote) circuit low
    B2938 Security system enable/arm (remote) circuit high
    B2939 Security system enable/arm (remote) circuit open
    B2940 Security system disable/disarm (remote) circuit malfunction
    B2941 Security system disable/disarm (remote) circuit range/performance
    B2942 Security system disable/disarm (remote) circuit low
    B2943 Security system disable/disarm (remote) circuit high
    B2944 Security system disable/disarm (remote) circuit open
    B2945 Security system sensor (Passkey/Passlock/etc.) power circuit malfunction
    B2946 Security system sensor (Passkey/Passlock/etc.) power circuit range/performance
    B2947 Security system sensor (Passkey/Passlock/etc.) power circuit low
    B2948 Security system sensor (Passkey/Passlock/etc.) power circuit high
    B2949 Security system sensor (Passkey/Passlock/etc.) power circuit open
    B2950 Security system sensor (Passkey/Passlock/etc.) ground circuit malfunction
    B2951 Security system sensor (Passkey/Passlock/etc.) ground circuit range/performance
    B2952 Security system sensor (Passkey/Passlock/etc.) ground circuit low
    B2953 Security system sensor (Passkey/Passlock/etc.) ground circuit high
    B2954 Security system sensor (Passkey/Passlock/etc.) ground circuit open
    B2955 Security system sensor (Passkey/Passlock/etc.) data circuit malfunction
    B2956 Security system sensor (Passkey/Passlock/etc.) data circuit range/performance
    B2957 Security system sensor (Passkey/Passlock/etc.) data circuit low
    B2958 Security system sensor (Passkey/Passlock/etc.) data circuit high
    B2959 Security system sensor (Passkey/Passlock/etc.) data circuit open
    B2960 Security system sensor (Passkey/Passlock/etc.) data incorrect but valid
    B2961 Key in ignition circuit malfunction
    B2962 Key in ignition circuit range/performance
    B2963 Key in ignition circuit low
    B2964 Key in ignition circuit high
    B2965 Key in ignition circuit open
    B2966 LF door handle switch circuit malfunction
    B2967 LF door handle switch circuit range/performance
    B2968 LF door handle switch circuit low
    B2969 LF door handle switch circuit high
    B2970 LF door handle switch circuit open
    B2971 LF door key switch circuit malfunction
    B2972 LF door key switch circuit range/performance
    B2973 LF door key switch circuit low
    B2974 LF door key switch circuit high
    B2975 LF door key switch circuit open
    B2976 LF door ajar circuit malfunction
    B2977 LF door ajar circuit range/performance
    B2978 LF door ajar circuit low
    B2979 LF door ajar circuit high
    B2980 LF door ajar circuit open
    B2981 RF door handle switch circuit malfunction
    B2982 RF door handle switch circuit range/performance
    B2983 RF door handle switch circuit low
    B2984 RF door handle switch circuit high
    B2985 RF door handle switch circuit open
    B2986 RF door key switch circuit malfunction
    B2987 RF door key switch circuit range/performance
    B2988 RF door key switch circuit low
    B2989 RF door key switch circuit high
    B2990 RF door key switch circuit open
    B2991 RF door ajar circuit malfunction
    B2992 RF door ajar circuit range/performance
    B2993 RF door ajar circuit low
    B2994 RF door ajar circuit high
    B2995 RF door ajar circuit open
    B2996 LR door ajar circuit malfunction
    B2997 LR door ajar circuit range/performance
    B2998 LR door ajar circuit low
    B2999 LR door ajar circuit high
    B3000 LR door ajar circuit open
    B3001 RR door ajar circuit malfunction
    B3002 RR door ajar circuit range/performance
    B3003 RR door ajar circuit low
    B3004 RR door ajar circuit high
    B3005 RR door ajar circuit open
    B3006 Hood ajar circuit malfunction
    B3007 Hood ajar circuit range/performance
    B3008 Hood ajar circuit low
    B3009 Hood ajar circuit high
    B3010 Hood ajar circuit open
    B3011 Trunk/liftglass/hatch ajar circuit malfunction
    B3012 Trunk/liftglass/hatch ajar circuit range/performance
    B3013 Trunk/liftglass/hatch ajar circuit low
    B3014 Trunk/liftglass/hatch ajar circuit high
    B3015 Trunk/liftglass/hatch ajar circuit open
    B3016 Door key switches (LF/RF) circuit malfunction
    B3017 Door key switches (LF/RF) circuit range/performance
    B3018 Door key switches (LF/RF) circuit low
    B3019 Door key switches (LF/RF) circuit high
    B3020 Door key switches (LF/RF) circuit open
    B3021 Fuel enable circuit malfunction
    B3022 Fuel enable circuit range/performance
    B3023 Fuel enable circuit low
    B3024 Fuel enable circuit high
    B3025 Fuel enable circuit open
    B3026 Starter enable circuit malfunction
    B3027 Starter enable circuit range/performance
    B3028 Starter enable circuit low
    B3029 Starter enable circuit high
    B3030 Starter enable circuit open
    B3031 Security system controller in learn mode
    B3032 Security system fail enable entered
    B3033 Security system indicates tamper
    B3034 Security system inoperative
    B3035 Door handle switches (LF/RF) circuit malfunction
    B3036 Door handle switches (LF/RF) circuit range/performance
    B3037 Door handle switches (LF/RF) circuit low
    B3038 Door handle switches (LF/RF) circuit high
    B3039 Door handle switches (LF/RF) circuit open
    B3040 Immobilizer-ECM communication circuit malfunction
    B3041 Immobilizer-ECM communication circuit range/performance
    B3042 Immobilizer-ECM communication circuit low
    B3043 Immobilizer-ECM communication circuit high
    B3044 Immobilizer-ECM communication circuit open
    B3045 DWA-immobilizer circuit malfunction
    B3046 DWA-immobilizer circuit range/performance
    B3047 DWA-immobilizer circuit low
    B3048 DWA-immobilizer circuit high
    B3049 DWA-immobilizer circuit open
    B3050 Immobilizer external relay circuit malfunction
    B3051 Immobilizer external relay circuit range/performance
    B3052 Immobilizer external relay circuit low
    B3053 Immobilizer external relay circuit high
    B3054 Immobilizer external relay circuit open
    B3055 No transponder modulation/no transponder
    B3056 No transponder ID code programmed
    B3057 No security code programmed
    B3058 No secret key programmed
    B3059 No request from ECM/PCM received
    B3060 Unprogrammed transponder ID code received
    B3061 Disturbed transponder ID code received
    B3062 RF/LF door key lock switch circuit malfunction
    B3063 RF/LF door key lock switch circuit range/performance
    B3064 RF/LF door key lock switch circuit low
    B3065 RF/LF door key lock switch circuit high
    B3066 RF/LF door key lock switch circuit open
    B3067 RF/LF door key unlock switch circuit malfunction
    B3068 RF/LF door key unlock switch circuit range/performance
    B3069 RF/LF door key unlock switch circuit low
    B3070 RF/LF door key unlock switch circuit high
    B3071 RF/LF door key unlock switch circuit open
    B3072 Immobilizer request input circuit malfunction
    B3073 Immobilizer request input circuit range/performance
    B3074 Immobilizer request input circuit low
    B3075 Immobilizer request input circuit high
    B3076 Immobilizer request input circuit open
    B3077 Fixcode transponder detected
    B3078 Security system horn output circuit malfunction
    B3079 Security system horn output circuit range/performance
    B3080 Security system horn output circuit low
    B3081 Security system horn output circuit high
    B3082 Security system horn output circuit open
    B3083 Incorrect PCM security password
    B3084 Security system exterior lamps control circuit malfunction
    B3085 Security system exterior lamps control circuit range/performance
    B3086 Security system exterior lamps control circuit low
    B3087 Security system exterior lamps control circuit high
    B3088 Security system exterior lamps control circuit open
    B3089 Content theft system sensor (Shock/Intrusion/etc.) signal circuit malfunction
    B3090 Content theft system sensor (Shock/Intrusion/etc.) signal circuit range/performance
    B3091 Content theft system sensor (Shock/Intrusion/etc.) signal circuit low
    B3092 Content theft system sensor (Shock/Intrusion/etc.) signal circuit high
    B3093 Content theft system sensor (Shock/Intrusion/etc.) signal circuit open
    B3094 No response from ECM/PCM received
    B3095 Content theft system sensor (Shock/Intrusion/etc.) power circuit malfunction
    B3096 Content theft system sensor (Shock/Intrusion/etc.) power circuit range/performance
    B3097 Content theft system sensor (Shock/Intrusion/etc.) power circuit low
    B3098 Content theft system sensor (Shock/Intrusion/etc.) power circuit high
    B3099 Content theft system sensor (Shock/Intrusion/etc.) power circuit open
    B3100 Keyless entry data link circuit malfunction
    B3101 Keyless entry data link circuit range/performance
    B3102 Keyless entry data link circuit low
    B3103 Keyless entry data link circuit high
    B3104 Keyless entry data link circuit open
    B3105 Keyless entry system key fobs not programmed
    B3106 Keyless entry data link parity error
    B3107 Keyless entry invalid transmitter ID
    B3108 Keyless entry transmitter synchronization failure
    B3109 Keyless entry transmitter low battery
    B3125 LF door only unlock circuit malfunction
    B3126 LF door only unlock circuit range/performance
    B3127 LF door only unlock circuit low
    B3128 LF door only unlock circuit high
    B3129 LF door only unlock circuit open
    B3130 All door unlock circuit malfunction
    B3131 All door unlock circuit range/performance
    B3132 All door unlock circuit low
    B3133 All door unlock circuit high
    B3134 All door unlock circuit open
    B3135 All door lock circuit malfunction
    B3136 All door lock circuit range/performance
    B3137 All door lock circuit low
    B3138 All door lock circuit high
    B3139 All door lock circuit open
    B3140 LF unlock switch circuit malfunction
    B3141 LF unlock switch circuit range/performance
    B3142 LF unlock switch circuit low
    B3143 LF unlock switch circuit high
    B3144 LF unlock switch circuit open
    B3145 RF/Passenger unlock switch circuit malfunction
    B3146 RF/Passenger unlock switch circuit range/performance
    B3147 RF/Passenger unlock switch circuit low
    B3148 RF/Passenger unlock switch circuit high
    B3149 RF/Passenger unlock switch circuit open
    B3150 LF lock switch circuit malfunction
    B3151 LF lock switch circuit range/performance
    B3152 LF lock switch circuit low
    B3153 LF lock switch circuit high
    B3154 LF lock switch circuit open
    B3155 RF lock switch circuit malfunction
    B3156 RF lock switch circuit range/performance
    B3157 RF lock switch circuit low
    B3158 RF lock switch circuit high
    B3159 RF lock switch circuit open
    B3160 LF window up switch (at door) circuit malfunction
    B3161 LF window up switch (at door) circuit range/performance
    B3162 LF window up switch (at door) circuit low
    B3163 LF window up switch (at door) circuit high
    B3164 LF window up switch (at door) circuit open
    B3165 LF window down switch (at door) circuit malfunction
    B3166 LF window down switch (at door) circuit range/performance
    B3167 LF window down switch (at door) circuit low
    B3168 LF window down switch (at door) circuit high
    B3169 LF window down switch (at door) circuit open
    B3170 RF window up switch (at door) circuit malfunction
    B3171 RF window up switch (at door) circuit range/performance
    B3172 RF window up switch (at door) circuit low
    B3173 RF window up switch (at door) circuit high
    B3174 RF window up switch (at door) circuit open
    B3175 RF window down switch (at door) circuit malfunction
    B3176 RF window down switch (at door) circuit range/performance
    B3177 RF window down switch (at door) circuit low
    B3178 RF window down switch (at door) circuit high
    B3179 RF window down switch (at door) circuit open
    B3180 LR window up switch (at door) circuit malfunction
    B3181 LR window up switch (at door) circuit range/performance
    B3182 LR window up switch (at door) circuit low
    B3183 LR window up switch (at door) circuit high
    B3184 LR window up switch (at door) circuit open
    B3185 LR window down switch (at door) circuit malfunction
    B3186 LR window down switch (at door) circuit range/performance
    B3187 LR window down switch (at door) circuit low
    B3188 LR window down switch (at door) circuit high
    B3189 LR window down switch (at door) circuit open
    B3190 RR window up switch (at door) circuit malfunction
    B3191 RR window up switch (at door) circuit range/performance
    B3192 RR window up switch (at door) circuit low
    B3193 RR window up switch (at door) circuit high
    B3194 RR window up switch (at door) circuit open
    B3195 RR window down switch (at door) circuit malfunction
    B3196 RR window down switch (at door) circuit range/performance
    B3197 RR window down switch (at door) circuit low
    B3198 RR window down switch (at door) circuit high
    B3199 RR window down switch (at door) circuit open
    B3200 Rear window lockout switch circuit malfunction
    B3201 Rear window lockout switch circuit range/performance
    B3202 Rear window lockout switch circuit low
    B3203 Rear window lockout switch circuit high
    B3204 Rear window lockout switch circuit open
    B3205 LF/Driver window motor circuit malfunction
    B3206 LF/Driver window motor circuit range/performance
    B3207 LF/Driver window motor circuit low
    B3208 LF/Driver window motor circuit high
    B3209 LF/Driver window motor circuit open
    B3210 RF/Passenger window motor circuit malfunction
    B3211 RF/Passenger window motor circuit range/performance
    B3212 RF/Passenger window motor circuit low
    B3213 RF/Passenger window motor circuit high
    B3214 RF/Passenger window motor circuit open
    B3215 LR window motor circuit malfunction
    B3216 LR window motor circuit range/performance
    B3217 LR window motor circuit low
    B3218 LR window motor circuit high
    B3219 LR window motor circuit open
    B3220 RR window motor circuit malfunction
    B3221 RR window motor circuit range/performance
    B3222 RR window motor circuit low
    B3223 RR window motor circuit high
    B3224 RR window motor circuit open
    B3225 LF lock motor circuit malfunction
    B3226 LF lock motor circuit range/performance
    B3227 LF lock motor circuit low
    B3228 LF lock motor circuit high
    B3229 LF lock motor circuit open
    B3230 RF lock motor circuit malfunction
    B3231 RF lock motor circuit range/performance
    B3232 RF lock motor circuit low
    B3233 RF lock motor circuit high
    B3234 RF lock motor circuit open
    B3235 LR lock motor circuit malfunction
    B3236 LR lock motor circuit range/performance
    B3237 LR lock motor circuit low
    B3238 LR lock motor circuit high
    B3239 LR lock motor circuit open
    B3240 RR lock motor circuit malfunction
    B3241 RR lock motor circuit range/performance
    B3242 RR lock motor circuit low
    B3243 RR lock motor circuit high
    B3244 RR lock motor circuit open
    B3245 Cargo door/liftgate lock motor circuit malfunction
    B3246 Cargo door/liftgate lock motor circuit range/performance
    B3247 Cargo door/liftgate lock motor circuit low
    B3248 Cargo door/liftgate lock motor circuit high
    B3249 Cargo door/liftgate lock motor circuit open
    B3250 Power sliding door position circuit malfunction
    B3251 Power sliding door position circuit range/performance
    B3252 Power sliding door position circuit low
    B3253 Power sliding door position circuit high
    B3254 Power sliding door position circuit open
    B3255 Power sliding door sensor circuit malfunction
    B3256 Power sliding door sensor circuit range/performance
    B3257 Power sliding door sensor circuit low
    B3258 Power sliding door sensor circuit high
    B3259 Power sliding door sensor circuit open
    B3260 Power sliding door secondary latch circuit malfunction
    B3261 Power sliding door secondary latch circuit range/performance
    B3262 Power sliding door secondary latch circuit low
    B3263 Power sliding door secondary latch circuit high
    B3264 Power sliding door secondary latch circuit open
    B3265 Trunk release output circuit malfunction
    B3266 Trunk release output circuit range/performance
    B3267 Trunk release output circuit low
    B3268 Trunk release output circuit high
    B3269 Trunk release output circuit open
    B3270 RF/LF door lock/unlock switch circuit malfunction
    B3271 RF/LF door lock/unlock switch circuit range/performance
    B3272 RF/LF door lock/unlock switch circuit low
    B3273 RF/LF door lock/unlock switch circuit high
    B3274 RF/LF door lock/unlock switch circuit open
    B3275 LF window express up/down circuit (at door) malfunction
    B3276 LF window express up/down circuit (at door) range/performance
    B3277 LF window express up/down circuit (at door) low
    B3278 LF window express up/down circuit (at door) high
    B3279 LF window express up/down circuit (at door) open
    B3280 RF window express up/down circuit (at door) malfunction
    B3281 RF window express up/down circuit (at door) range/performance
    B3282 RF window express up/down circuit (at door) low
    B3283 RF window express up/down circuit (at door) high
    B3284 RF window express up/down circuit (at door) open
    B3285 LR window express up/down circuit (at door) malfunction
    B3286 LR window express up/down circuit (at door) range/performance
    B3287 LR window express up/down circuit (at door) low
    B3288 LR window express up/down circuit (at door) high
    B3289 LR window express up/down circuit (at door) open
    B3290 RR window express up/down circuit (at door) malfunction
    B3291 RR window express up/down circuit (at door) range/performance
    B3292 RR window express up/down circuit (at door) low
    B3293 RR window express up/down circuit (at door) high
    B3294 RR window express up/down circuit (at door) open
    B3295 LF window express up circuit (at door) malfunction
    B3296 LF window express up circuit (at door) range/performance
    B3297 LF window express up circuit (at door) low
    B3298 LF window express up circuit (at door) high
    B3299 LF window express up circuit (at door) open
    B3300 RF window express up circuit (at door) malfunction
    B3301 RF window express up circuit (at door) range/performance
    B3302 RF window express up circuit (at door) low
    B3303 RF window express up circuit (at door) high
    B3304 RF window express up circuit (at door) open
    B3305 LR window express up circuit (at door) malfunction
    B3306 LR window express up circuit (at door) range/performance
    B3307 LR window express up circuit (at door) low
    B3308 LR window express up circuit (at door) high
    B3309 LR window express up circuit (at door) open
    B3310 RR window express up circuit (at door) malfunction
    B3311 RR window express up circuit (at door) range/performance
    B3312 RR window express up circuit (at door) low
    B3313 RR window express up circuit (at door) high
    B3314 RR window express up circuit (at door) open
    B3315 LF window express down circuit (at door) malfunction
    B3316 LF window express down circuit (at door) range/performance
    B3317 LF window express down circuit (at door) low
    B3318 LF window express down circuit (at door) high
    B3319 LF window express down circuit (at door) open
    B3320 RF window express down circuit (at door) malfunction
    B3321 RF window express down circuit (at door) range/performance
    B3322 RF window express down circuit (at door) low
    B3323 RF window express down circuit (at door) high
    B3324 RF window express down circuit (at door) open
    B3325 LR window express down circuit (at door) malfunction
    B3326 LR window express down circuit (at door) range/performance
    B3327 LR window express down circuit (at door) low
    B3328 LR window express down circuit (at door) high
    B3329 LR window express down circuit (at door) open
    B3330 RR window express down circuit (at door) malfunction
    B3331 RR window express down circuit (at door) range/performance
    B3332 RR window express down circuit (at door) low
    B3333 RR window express down circuit (at door) high
    B3334 RR window express down circuit (at door) open
    B3335 LR unlock switch circuit malfunction
    B3336 LR unlock switch circuit range/performance
    B3337 LR unlock switch circuit low
    B3338 LR unlock switch circuit high
    B3339 LR unlock switch circuit open
    B3340 RR unlock switch circuit malfunction
    B3341 RR unlock switch circuit range/performance
    B3342 RR unlock switch circuit low
    B3343 RR unlock switch circuit high
    B3344 RR unlock switch circuit open
    B3345 LR lock switch circuit malfunction
    B3346 LR lock switch circuit range/performance
    B3347 LR lock switch circuit low
    B3348 LR lock switch circuit high
    B3349 LR lock switch circuit open
    B3350 RR lock switch circuit malfunction
    B3351 RR lock switch circuit range/performance
    B3352 RR lock switch circuit low
    B3353 RR lock switch circuit high
    B3354 RR lock switch circuit open
    B3355 LF window obstruction sensor supply circuit malfunction
    B3356 LF window obstruction sensor supply circuit range/performance
    B3357 LF window obstruction sensor supply circuit low
    B3358 LF window obstruction sensor supply circuit high
    B3359 LF window obstruction sensor supply circuit open
    B3360 RF window obstruction sensor supply circuit malfunction
    B3361 RF window obstruction sensor supply circuit range/performance
    B3362 RF window obstruction sensor supply circuit low
    B3363 RF window obstruction sensor supply circuit high
    B3364 RF window obstruction sensor supply circuit open
    B3365 LR window obstruction sensor supply circuit malfunction
    B3366 LR window obstruction sensor supply circuit range/performance
    B3367 LR window obstruction sensor supply circuit low
    B3368 LR window obstruction sensor supply circuit high
    B3369 LR window obstruction sensor supply circuit open
    B3370 RR window obstruction sensor supply circuit malfunction
    B3371 RR window obstruction sensor supply circuit range/performance
    B3372 RR window obstruction sensor supply circuit low
    B3373 RR window obstruction sensor supply circuit high
    B3374 RR window obstruction sensor supply circuit open
    B3375 LF window up switch (main cntl) circuit malfunction
    B3376 LF window up switch (main cntl) circuit range/performance
    B3377 LF window up switch (main cntl) circuit low
    B3378 LF window up switch (main cntl) circuit high
    B3379 LF window up switch (main cntl) circuit open
    B3380 LF window down switch (main cntl) circuit malfunction
    B3381 LF window down switch (main cntl) circuit range/performance
    B3382 LF window down switch (main cntl) circuit low
    B3383 LF window down switch (main cntl) circuit high
    B3384 LF window down switch (main cntl) circuit open
    B3385 RF window up switch (main cntl) circuit malfunction
    B3386 RF window up switch (main cntl) circuit range/performance
    B3387 RF window up switch (main cntl) circuit low
    B3388 RF window up switch (main cntl) circuit high
    B3389 RF window up switch (main cntl) circuit open
    B3390 RF window down switch (main cntl) circuit malfunction
    B3391 RF window down switch (main cntl) circuit range/performance
    B3392 RF window down switch (main cntl) circuit low
    B3393 RF window down switch (main cntl) circuit high
    B3394 RF window down switch (main cntl) circuit open
    B3395 LR window up switch (main cntl) circuit malfunction
    B3396 LR window up switch (main cntl) circuit range/performance
    B3397 LR window up switch (main cntl) circuit low
    B3398 LR window up switch (main cntl) circuit high
    B3399 LR window up switch (main cntl) circuit open
    B3400 AHLD RH position sensor signal circuit malfunction
    B3401 AHLD RH position sensor signal circuit range/performance
    B3402 AHLD RH position sensor signal circuit low
    B3403 AHLD RH position sensor signal circuit high
    B3404 AHLD RH position sensor signal circuit open
    B3405 AHLD RH position sensor supply circuit malfunction
    B3406 AHLD RH position sensor supply circuit range/performance
    B3407 AHLD RH position sensor supply circuit low
    B3408 AHLD RH position sensor supply circuit high
    B3409 AHLD RH position sensor supply circuit open
    B3410 AHLD front axle sensor signal circuit malfunction
    B3411 AHLD front axle sensor signal circuit range/performance
    B3412 AHLD front axle sensor signal circuit low
    B3413 AHLD front axle sensor signal circuit high
    B3414 AHLD front axle sensor signal circuit open
    B3415 AHLD front axle sensor supply circuit malfunction
    B3416 AHLD front axle sensor supply circuit range/performance
    B3417 AHLD front axle sensor supply circuit low
    B3418 AHLD front axle sensor supply circuit high
    B3419 AHLD front axle sensor supply circuit open
    B3420 AHLD rear axle sensor signal circuit malfunction
    B3421 AHLD rear axle sensor signal circuit range/performance
    B3422 AHLD rear axle sensor signal circuit low
    B3423 AHLD rear axle sensor signal circuit high
    B3424 AHLD rear axle sensor signal circuit open
    B3425 AHLD rear axle sensor supply circuit malfunction
    B3426 AHLD rear axle sensor supply circuit range/performance
    B3427 AHLD rear axle sensor supply circuit low
    B3428 AHLD rear axle sensor supply circuit high
    B3429 AHLD rear axle sensor supply circuit open
    B3430 AHLD low beam input circuit malfunction
    B3431 AHLD low beam input circuit range/performance
    B3432 AHLD low beam input circuit low
    B3433 AHLD low beam input circuit high
    B3434 AHLD low beam input circuit open
    B3435 AHLD LH servo driver (#1 and/or #2) circuit malfunction
    B3436 AHLD LH servo driver (#1 and/or #2) circuit range/performance
    B3437 AHLD LH servo driver (#1 and/or #2) circuit low
    B3438 AHLD LH servo driver (#1 and/or #2) circuit high
    B3439 AHLD LH servo driver (#1 and/or #2) circuit open
    B3440 AHLD RH servo driver (#1 and/or #2) circuit malfunction
    B3441 AHLD RH servo driver (#1 and/or #2) circuit range/performance
    B3442 AHLD RH servo driver (#1 and/or #2) circuit low
    B3443 AHLD RH servo driver (#1 and/or #2) circuit high
    B3444 AHLD RH servo driver (#1 and/or #2) circuit open
    B3445 Stoplamp circuit malfunction
    B3446 Stoplamp circuit range/performance
    B3447 Stoplamp circuit low
    B3448 Stoplamp circuit high
    B3449 Stoplamp circuit open
    B3450 LR window down switch (main cntl) circuit malfunction
    B3451 LR window down switch (main cntl) circuit range/performance
    B3452 LR window down switch (main cntl) circuit low
    B3453 LR window down switch (main cntl) circuit high
    B3454 LR window down switch (main cntl) circuit open
    B3455 RR window up switch (main cntl) circuit malfunction
    B3456 RR window up switch (main cntl) circuit range/performance
    B3457 RR window up switch (main cntl) circuit low
    B3458 RR window up switch (main cntl) circuit high
    B3459 RR window up switch (main cntl) circuit open
    B3460 RR window down switch (main cntl) circuit malfunction
    B3461 RR window down switch (main cntl) circuit range/performance
    B3462 RR window down switch (main cntl) circuit low
    B3463 RR window down switch (main cntl) circuit high
    B3464 RR window down switch (main cntl) circuit open
    B3465 LF window express up/down circuit (main cntl) malfunction
    B3466 LF window express up/down circuit (main cntl) range/performance
    B3467 LF window express up/down circuit (main cntl) low
    B3468 LF window express up/down circuit (main cntl) high
    B3469 LF window express up/down circuit (main cntl) open
    B3470 RF window express up/down circuit (main cntl) malfunction
    B3471 RF window express up/down circuit (main cntl) range/performance
    B3472 RF window express up/down circuit (main cntl) low
    B3473 RF window express up/down circuit (main cntl) high
    B3474 RF window express up/down circuit (main cntl) open
    B3475 LR window express up/down circuit (main cntl) malfunction
    B3476 LR window express up/down circuit (main cntl) range/performance
    B3477 LR window express up/down circuit (main cntl) low
    B3478 LR window express up/down circuit (main cntl) high
    B3479 LR window express up/down circuit (main cntl) open
    B3480 RR window express up/down circuit (main cntl) malfunction
    B3481 RR window express up/down circuit (main cntl) range/performance
    B3482 RR window express up/down circuit (main cntl) low
    B3483 RR window express up/down circuit (main cntl) high
    B3484 RR window express up/down circuit (main cntl) open
    B3485 LF window express up circuit (main cntl) malfunction
    B3486 LF window express up circuit (main cntl) range/performance
    B3487 LF window express up circuit (main cntl) low
    B3488 LF window express up circuit (main cntl) high
    B3489 LF window express up circuit (main cntl) open
    B3490 RF window express up circuit (main cntl) malfunction
    B3491 RF window express up circuit (main cntl) range/performance
    B3492 RF window express up circuit (main cntl) low
    B3493 RF window express up circuit (main cntl) high
    B3494 RF window express up circuit (main cntl) open
    B3495 LR window express up circuit (main cntl) malfunction
    B3496 LR window express up circuit (main cntl) range/performance
    B3497 LR window express up circuit (main cntl) low
    B3498 LR window express up circuit (main cntl) high
    B3499 LR window express up circuit (main cntl) open
    B3500 RR window express up circuit (main cntl) malfunction
    B3501 RR window express up circuit (main cntl) range/performance
    B3502 RR window express up circuit (main cntl) low
    B3503 RR window express up circuit (main cntl) high
    B3504 RR window express up circuit (main cntl) open
    B3505 LF window express down circuit (main cntl) malfunction
    B3506 LF window express down circuit (main cntl) range/performance
    B3507 LF window express down circuit (main cntl) low
    B3508 LF window express down circuit (main cntl) high
    B3509 LF window express down circuit (main cntl) open
    B3510 RF window express down circuit (main cntl) malfunction
    B3511 RF window express down circuit (main cntl) range/performance
    B3512 RF window express down circuit (main cntl) low
    B3513 RF window express down circuit (main cntl) high
    B3514 RF window express down circuit (main cntl) open
    B3515 LR window express down circuit (main cntl) malfunction
    B3516 LR window express down circuit (main cntl) range/performance
    B3517 LR window express down circuit (main cntl) low
    B3518 LR window express down circuit (main cntl) high
    B3519 LR window express down circuit (main cntl) open
    B3520 RR window express down circuit (main cntl) malfunction
    B3521 RR window express down circuit (main cntl) range/performance
    B3522 RR window express down circuit (main cntl) low
    B3523 RR window express down circuit (main cntl) high
    B3524 RR window express down circuit (main cntl) open
    B3525 Window lockout switch circuit malfunction
    B3526 Window lockout switch circuit range/performance
    B3527 Window lockout switch circuit low
    B3528 Window lockout switch circuit high
    B3529 Window lockout switch circuit open
    B3530 DIC Trip/Season odometer switch circuit open
    B3531 Air flow control #10 (rear) circuit malfunction
    B3532 Air flow control #10 (rear) circuit range/performance
    B3533 Air flow control #10 (rear) circuit low
    B3534 Air flow control #10 (rear) circuit high
    B3535 Air flow control #10 (rear) circuit open
    B3536 Oil life reset switch circuit malfunction
    B3537 Oil life reset switch circuit range/performance
    B3538 Oil life reset switch circuit low
    B3539 Oil life reset switch circuit high
    B3540 Oil life reset switch circuit open
    B3541 DRL filament open
    B3542 LF window obstruction sensor control circuit malfunction
    B3543 LF window obstruction sensor control circuit range/performance
    B3544 LF window obstruction sensor control circuit low
    B3545 LF window obstruction sensor control circuit high
    B3546 LF window obstruction sensor control circuit open
    B3547 RF window obstruction sensor control circuit malfunction
    B3548 RF window obstruction sensor control circuit range/performance
    B3549 RF window obstruction sensor control circuit low
    B3550 RF window obstruction sensor control circuit high
    B3551 RF window obstruction sensor control circuit open
    B3552 LR window obstruction sensor control circuit malfunction
    B3553 LR window obstruction sensor control circuit range/performance
    B3554 LR window obstruction sensor control circuit low
    B3555 LR window obstruction sensor control circuit high
    B3556 LR window obstruction sensor control circuit open
    B3557 RR window obstruction sensor control circuit malfunction
    B3558 RR window obstruction sensor control circuit range/performance
    B3559 RR window obstruction sensor control circuit low
    B3560 RR window obstruction sensor control circuit high
    B3561 RR window obstruction sensor control circuit open
    B3562 DIC mode switch circuit malfunction
    B3563 DIC mode switch circuit range/performance
    B3564 DIC mode switch circuit low
    B3565 DIC mode switch circuit high
    B3566 DIC mode switch circuit open
    B3567 DIC select switch circuit malfunction
    B3568 DIC select switch circuit range/performance
    B3569 DIC select switch circuit low
    B3570 DIC select switch circuit high
    B3571 DIC select switch circuit open
    B3572 Trip odometer A/B (trip odo 1 & 2) select switch circuit malfunction
    B3573 Trip odometer A/B (trip odo 1 & 2) select switch circuit range/performance
    B3574 Trip odometer A/B (trip odo 1 & 2) select switch circuit low
    B3575 Trip odometer A/B (trip odo 1 & 2) select switch circuit high
    B3576 Trip odometer A/B (trip odo 1 & 2) select switch circuit open
    B3577 Suspension control select switch contact malfunction
    B3578 Output air temperature sensor #6 (rear upper) circuit malfunction
    B3579 Output air temperature sensor #6 (rear upper) circuit range/performance
    B3580 Output air temperature sensor #6 (rear upper) circuit low
    B3581 Output air temperature sensor #6 (rear upper) circuit high
    B3582 Output air temperature sensor #6 (rear upper) circuit open
    B3583 Output air temperature sensor #7 (rear lower) circuit malfunction
    B3584 Output air temperature sensor #7 (rear lower) circuit range/performance
    B3585 Output air temperature sensor #7 (rear lower) circuit low
    B3586 Output air temperature sensor #7 (rear lower) circuit high
    B3587 Output air temperature sensor #7 (rear lower) circuit open
    B3588 Rear foglamp switch circuit malfunction
    B3589 Rear foglamp switch circuit range/performance
    B3590 Rear foglamp switch circuit low
    B3591 Rear foglamp switch circuit high
    B3592 Rear foglamp switch circuit open
    B3700 Intermittent wiper delay input circuit malfunction
    B3701 Intermittent wiper delay input circuit range/performance
    B3702 Intermittent wiper delay input circuit low
    B3703 Intermittent wiper delay input circuit high
    B3704 Intermittent wiper delay input circuit open
    B3705 Front washer motor input circuit malfunction
    B3706 Front washer motor input circuit range/performance
    B3707 Front washer motor input circuit low
    B3708 Front washer motor input circuit high
    B3709 Front washer motor input circuit open
    B3710 Rear washer motor input circuit malfunction
    B3711 Rear washer motor input circuit range/performance
    B3712 Rear washer motor input circuit low
    B3713 Rear washer motor input circuit high
    B3714 Rear washer motor input circuit open
    B3715 Front wiper relay drive circuit malfunction
    B3716 Front wiper relay drive circuit range/performance
    B3717 Front wiper relay drive circuit low
    B3718 Front wiper relay drive circuit high
    B3719 Front wiper relay drive circuit open
    B3720 Rear wiper relay drive circuit malfunction
    B3721 Rear wiper relay drive circuit range/performance
    B3722 Rear wiper relay drive circuit low
    B3723 Rear wiper relay drive circuit high
    B3724 Rear wiper relay drive circuit open
    B3725 LF/Driver seat assembly vertical control switch malfunction
    B3726 LF/Driver seat front vertical control switch malfunction
    B3727 LF/Driver seat rear vertical control switch malfunction
    B3728 LF/Driver seat assembly horizontal control switch malfunction
    B3729 LF/Driver seat recline control switch malfunction
    B3730 LF/Driver seat lumbar horizontal control switch malfunction
    B3731 LF/Driver seat lumbar vertical control switch malfunction
    B3732 LF/Driver seat head restraint horizontal control switch malfunction
    B3733 LF/Driver seat head restraint vertical control switch malfunction
    B3734 RF/Passenger seat assembly vertical control switch malfunction
    B3735 RF/Passenger seat front vertical control switch malfunction
    B3736 RF/Passenger seat rear vertical control switch malfunction
    B3737 RF/Passenger seat assembly horizontal control switch malfunction
    B3738 RF/Passenger seat recline control switch malfunction
    B3739 RF/Passenger seat lumbar horizontal control switch malfunction
    B3740 RF/Passenger seat lumbar vertical control switch malfunction
    B3741 RF/Passenger seat head restraint horizontal control switch malfunction
    B3742 RF/Passenger seat head restraint vertical control switch malfunction
    B3750 DIC on/off signal circuit malfunction
    B3751 DIC on/off signal circuit range/performance
    B3752 DIC on/off signal circuit low
    B3753 DIC on/off signal circuit high
    B3754 DIC on/off signal circuit open
    B3755 Air flow control #1 (defrost) feedback circuit malfunction
    B3756 Air flow control #1 (defrost) feedback circuit low
    B3757 Air flow control #1 (defrost) feedback circuit high
    B3758 Air flow control #2 (heater) feedback circuit malfunction
    B3759 Air flow control #2 (heater) feedback circuit low
    B3760 Air flow control #2 (heater) feedback circuit high
    B3761 Air flow control #3 (blend defog/floor) feedback circuit malfunction
    B3762 Air flow control #3 (blend defog/floor) feedback circuit low
    B3763 Air flow control #3 (blend defog/floor) feedback circuit high
    B3764 Air flow control #4 (blend face/floor) feedback circuit malfunction
    B3765 Air flow control #4 (blend face/floor) feedback circuit low
    B3766 Air flow control #4 (blend face/floor) feedback circuit high
    B3767 Air flow control #5 (vent) feedback circuit malfunction
    B3768 Air flow control #5 (vent) feedback circuit low
    B3769 Air flow control #5 (vent) feedback circuit high
    B3770 Air flow control #6 (A/C) feedback circuit malfunction
    B3771 Air flow control #6 (A/C) feedback circuit low
    B3772 Air flow control #6 (A/C) feedback circuit high
    B3773 Air flow control #7 (recirc) feedback circuit malfunction
    B3774 Air flow control #7 (recirc) feedback circuit low
    B3775 Air flow control #7 (recirc) feedback circuit high
    B3776 Air flow control #8 (rear defog airflow) feedback circuit malfunction
    B3777 Air flow control #8 (rear defog airflow) feedback circuit low
    B3778 Air flow control #8 (rear defog airflow) feedback circuit high
    B3779 Air flow control #9 (dual zone) feedback circuit malfunction
    B3780 Air flow control #9 (dual zone) feedback circuit low
    B3781 Air flow control #9 (dual zone) feedback circuit high
    B3782 Air flow control #10 (rear) feedback circuit malfunction
    B3783 Air flow control #10 (rear) feedback circuit low
    B3784 Air flow control #10 (rear) feedback circuit high
    B3785 Blower Motor #1 (main/primary/front) Relay Control Circuit Malfunction
    B3786 Blower Motor #1 (main/primary/front) Relay Control Circuit Range/Performance
    B3787 Blower Motor #1 (main/primary/front) Relay Control Circuit Low
    B3788 Blower Motor #1 (main/primary/front) Relay Control Circuit High
    B3789 Blower Motor #1 (main/primary/front) Relay Control Circuit Open
    B3790 LF/Driver seat side bolster control switch malfunction
    B3791 LF/Driver seat thigh bolster control switch malfunction
    B3792 LF/Driver seat switch circuit malfunction
    B3793 Front wiper speed select circuit malfunction
    B3794 Cruise control function request circuit malfunction
    B3795 Left / right turn signal feedback circuit malfunction
    B3796 Door lock motors circuit malfunction
    B3797 All door dead lock circuit malfunction
    B3798 RF / Passenger door unlock circuit malfunction
    B3799 Front / rear washer rear wiper select circuit malfunction
    B3800 Left / right turn signal request circuit malfunction
    B3801 Passenger compartment lamp request circuit malfunction
    B3802 Parklamps request circuit malfunction
    B3803 All windows up circuit malfunction
    B3804 LF / Driver door handle position invalid
    B3805 All door unlock crash sensor circuit malfunction
    B3806 Headlamps highbeam and flash to pass select circuit malfunction
    B3807 Headlamp position control PWM circuit malfunction
    B3808 Rear door lock relay circuit malfunction
    B3809 Rear door unlock relay circuit malfunction
    B3810 Headlamp washer relay circuit malfunction
    B3811 Rear washer relay circuit malfunction
    B3812 Content theft system sensor (Shock/Intrusion/etc.) ground circuit malfunction
    B3813 Content theft system sensor (Shock/Intrusion/etc.) ground circuit range/performance
    B3814 Content theft system sensor (Shock/Intrusion/etc.) ground circuit low
    B3815 Content theft system sensor (Shock/Intrusion/etc.) ground circuit high
    B3816 Content theft system sensor (Shock/Intrusion/etc.) ground circuit open
    B3817 Door lock status circuit malfunction
    B3818 Door unlock status circuit malfunction
    B3819 Left rear window up control circuit malfunction
    B3820 Left rear window down control circuit malfunction
    B3821 Left rear window relay power circuit malfunction
    B3822 Right rear window up control circuit malfunction
    B3823 Right rear window down control circuit malfunction B3824 Right rear window relay power circuit malfunction
    B3825 Cargo door/liftgate lock request circuit malfunction
    B3826 Cargo door/liftgate unlock request circuit malfunction
    B3827 Front wiper status circuit malfunction
    B3828 LF/Driver belt tower up switch circuit malfunction
    B3829 LF/Driver belt tower down switch circuit malfunction
    B3830 LF/Driver belt tower vertical sensor circuit malfunction
    B3831 LF/Driver belt tower vertical sensor circuit range/performance
    C0000 Vehicle speed information circuit malfunction
    C0001 Vehicle speed information circuit range/performance
    C0002 Vehicle speed information circuit low
    C0003 Vehicle speed information circuit high
    C0004 Vehicle speed information circuit open
    C0005 In "Park" switch circuit malfunction
    C0006 In "Park" switch circuit range/performance
    C0007 In "Park" switch circuit low
    C0008 In "Park" switch circuit high
    C0009 In "Park" switch circuit open
    C0035 LF wheel speed sensor circuit malfunction
    C0036 LF wheel speed sensor circuit range/performance
    C0037 LF wheel speed sensor circuit low
    C0038 LF wheel speed sensor circuit high
    C0039 LF wheel speed sensor circuit open
    C0040 RF wheel speed sensor circuit malfunction
    C0041 RF wheel speed sensor circuit range/performance
    C0042 RF wheel speed sensor circuit low
    C0043 RF wheel speed sensor circuit high
    C0044 RF wheel speed sensor circuit open
    C0045 LR wheel speed sensor circuit malfunction
    C0046 LR wheel speed sensor circuit range/performance
    C0047 LR wheel speed sensor circuit low
    C0048 LR wheel speed sensor circuit high
    C0049 LR wheel speed sensor circuit open
    C0050 RR wheel speed sensor circuit malfunction
    C0051 RR wheel speed sensor circuit range/performance
    C0052 RR wheel speed sensor circuit low
    C0053 RR wheel speed sensor circuit high
    C0054 RR wheel speed sensor circuit open
    C0055 Rear wheel speed sensor (both wheels) circuit malfunction
    C0056 Rear wheel speed sensor (both wheels) circuit range/performance
    C0057 Rear wheel speed sensor (both wheels) circuit low
    C0058 Rear wheel speed sensor (both wheels) circuit high
    C0059 Rear wheel speed sensor (both wheels) circuit open
    C0060 LF ABS solenoid/motor #1 circuit malfunction
    C0061 LF ABS solenoid/motor #1 circuit range/performance
    C0062 LF ABS solenoid/motor/ #1 circuit low
    C0063 LF ABS solenoid/motor #1 circuit high
    C0064 LF ABS solenoid/motor #1 circuit open
    C0065 LF ABS solenoid/motor #2 circuit malfunction
    C0066 LF ABS solenoid/motor #2 circuit range/performance
    C0067 LF ABS solenoid/motor #2 circuit low
    C0068 LF ABS solenoid/motor #2 circuit high
    C0069 LF ABS solenoid/motor #2 circuit open
    C0070 RF ABS solenoid/motor #1 circuit malfunction
    C0071 RF ABS solenoid/motor #1 circuit range/performance
    C0072 RF ABS solenoid/motor #1 circuit low
    C0073 RF ABS solenoid/motor #1 circuit high
    C0074 RF ABS solenoid/motor #1 circuit open
    C0075 RF ABS solenoid/motor #2 circuit malfunction
    C0076 RF ABS solenoid/motor #2 circuit range/performance
    C0077 RF ABS solenoid/motor #2 circuit low
    C0078 RF ABS solenoid/motor #2 circuit high
    C0079 RF ABS solenoid/motor #2 circuit open
    C0080 LR ABS solenoid/motor #1 circuit malfunction
    C0081 LR ABS solenoid/motor #1 circuit range/performance
    C0082 LR ABS solenoid/motor #1 circuit low
    C0083 LR ABS solenoid/motor #1 circuit high
    C0084 LR ABS solenoid/motor #1 circuit open
    C0085 LR ABS solenoid/motor #2 circuit malfunction
    C0086 LR ABS solenoid/motor #2 circuit range/performance
    C0087 LR ABS solenoid/motor #2 circuit low
    C0088 LR ABS solenoid/motor #2 circuit high
    C0089 LR ABS solenoid/motor #2 circuit open
    C0090 RR ABS solenoid/motor #1 circuit malfunction
    C0091 RR ABS solenoid/motor #1 circuit range/performance
    C0092 RR ABS solenoid/motor #1 circuit low
    C0093 RR ABS solenoid/motor #1 circuit high
    C0094 RR ABS solenoid/motor #1 circuit open
    C0095 RR ABS solenoid/motor #2 circuit malfunction
    C0096 RR ABS solenoid/motor #2 circuit range/performance
    C0097 RR ABS solenoid/motor #2 circuit low
    C0098 RR ABS solenoid/motor #2 circuit high
    C0099 RR ABS solenoid/motor #2 circuit open
    C0100 Rear ABS (both wheels) solenoid/motor #1 circuit malfunction
    C0101 Rear ABS (both wheels) solenoid/motor #1 circuit range/performance
    C0102 Rear ABS (both wheels) solenoid/motor #1 circuit low
    C0103 Rear ABS (both wheels) solenoid/motor #1 circuit high
    C0104 Rear ABS (both wheels) solenoid/motor #1 circuit open
    C0105 Rear ABS (both wheels) solenoid/motor #2 circuit malfunction
    C0106 Rear ABS (both wheels) solenoid/motor #2 circuit range/performance
    C0107 Rear ABS (both wheels) solenoid/motor #2 circuit low
    C0108 Rear ABS (both wheels) solenoid/motor #2 circuit high
    C0109 Rear ABS (both wheels) solenoid/motor #2 circuit open
    C0110 Pump motor circuit malfunction
    C0111 Pump motor circuit range/performance
    C0112 Pump motor circuit low
    C0113 Pump motor circuit high
    C0114 Pump motor circuit open
    C0115 Pump motor malfunction
    C0116 Pump motor relay circuit malfunction
    C0117 Pump motor relay circuit range/performance
    C0118 Pump motor relay circuit low
    C0119 Pump motor relay circuit high
    C0120 Pump motor relay circuit open
    C0121 Valve relay circuit malfunction
    C0122 Valve relay circuit range/performance
    C0123 Valve relay circuit low
    C0124 Valve relay circuit high
    C0125 Valve relay circuit open
    C0126 Low brake fluid circuit malfunction
    C0127 Low brake fluid circuit range/performance
    C0128 Low brake fluid circuit low
    C0129 Low brake fluid circuit high
    C0130 Low brake fluid circuit open
    C0131 ABS/TCS system pressure circuit malfunction
    C0132 ABS/TCS system pressure circuit range/performance
    C0133 ABS/TCS system pressure circuit low
    C0134 ABS/TCS system pressure circuit high
    C0135 ABS/TCS system pressure circuit open
    C0136 Base brake system pressure circuit malfunction
    C0137 Base brake system pressure circuit range/performance
    C0138 Base brake system pressure circuit low
    C0139 Base brake system pressure circuit high
    C0140 Base brake system pressure circuit open
    C0141 LH TCS solenoid/motor #1 circuit malfunction
    C0142 LH TCS solenoid/motor #1 circuit range/performance
    C0143 LH TCS solenoid/motor #1 circuit low
    C0144 LH TCS solenoid/motor #1 circuit high
    C0145 LH TCS solenoid/motor #1 circuit open
    C0146 LH TCS solenoid/motor #2 circuit malfunction
    C0147 LH TCS solenoid/motor #2 circuit range/performance
    C0148 LH TCS solenoid/motor #2 circuit low
    C0149 LH TCS solenoid/motor #2 circuit high
    C0150 LH TCS solenoid/motor #2 circuit open
    C0151 RH TCS solenoid/motor #1 circuit malfunction
    C0152 RH TCS solenoid/motor #1 circuit range/performance
    C0153 RH TCS solenoid/motor #1 circuit low
    C0154 RH TCS solenoid/motor #1 circuit high
    C0155 RH TCS solenoid/motor #1 circuit open
    C0156 RH TCS solenoid/motor #2 circuit malfunction
    C0157 RH TCS solenoid/motor #2 circuit range/performance
    C0158 RH TCS solenoid/motor #2 circuit low
    C0159 RH TCS solenoid/motor #2 circuit high
    C0160 RH TCS solenoid/motor #2 circuit open
    C0161 ABS/TCS brake switch circuit malfunction
    C0162 ABS/TCS brake switch circuit range/performance
    C0163 ABS/TCS brake switch circuit low
    C0164 ABS/TCS brake switch circuit high
    C0165 ABS/TCS brake switch circuit open
    C0166 TCS priming line valve circuit malfunction
    C0167 TCS priming line valve circuit range/performance
    C0168 TCS priming line valve circuit low
    C0169 TCS priming line valve circuit high
    C0170 TCS priming line valve circuit open
    C0171 TCS pilot valve circuit malfunction
    C0172 TCS pilot valve circuit range/performance
    C0173 TCS pilot valve circuit low
    C0174 TCS pilot valve circuit high
    C0175 TCS pilot valve circuit open
    C0176 System thermal malfunction
    C0177 System thermal range/performance
    C0178 System thermal low
    C0179 System thermal high
    C0180 System thermal open
    C0181 Throttle reduction motor circuit malfunction
    C0182 Throttle reduction motor circuit range/performance
    C0183 Throttle reduction motor circuit low
    C0184 Throttle reduction motor circuit high
    C0185 Throttle reduction motor circuit open
    C0186 Lateral accelerometer circuit malfunction
    C0187 Lateral accelerometer circuit range/performance
    C0188 Lateral accelerometer circuit low
    C0189 Lateral accelerometer circuit high
    C0190 Lateral accelerometer circuit open
    C0191 4wd/AWD reference accelerometer circuit malfunction
    C0192 4wd/AWD reference accelerometer circuit range/performance
    C0193 4wd/AWD reference accelerometer circuit low
    C0194 4wd/AWD reference accelerometer circuit high
    C0195 4wd/AWD reference accelerometer circuit open
    C0196 Yaw rate circuit malfunction
    C0197 Yaw rate circuit range/performance
    C0198 Yaw rate circuit low
    C0199 Yaw rate circuit high
    C0200 Yaw rate circuit open
    C0201 ABS enable relay contact circuit malfunction
    C0202 ABS enable relay contact circuit range/performance
    C0203 ABS enable relay contact circuit low
    C0204 ABS enable relay contact circuit high
    C0205 ABS enable relay contact circuit open
    C0206 ABS enable relay coil circuit malfunction
    C0207 ABS enable relay coil circuit range/performance
    C0208 ABS enable relay coil circuit low
    C0209 ABS enable relay coil circuit high
    C0210 ABS enable relay coil circuit open
    C0211 LF ESB malfunction
    C0212 LF ESB will not hold motor
    C0213 RF ESB malfunction
    C0214 RF ESB will not hold motor
    C0215 Rear ESB (both wheels) malfunction
    C0216 Rear ESB (both wheels) will not hold motor
    C0217 LF ABS channel will not move
    C0218 RF ABS channel will not move
    C0219 Rear ABS channel will not move
    C0220 LF ABS channel in release too long
    C0221 RF ABS channel in release too long
    C0222 Rear ABS channel in release too long
    C0223 LF ABS channel motor free spins
    C0224 RF ABS channel motor free spins
    C0225 Rear ABS channel motor free spins
    C0226 LF TCS channel will not move
    C0227 RF TCS channel will not move
    C0228 LR ABS channel in release too long
    C0229 RR ABS channel in release too long
    C0230 LF TCS channel motor free spins
    C0231 RF TCS channel motor free spins
    C0232 EBCM turned on red brake warning lamp
    C0233 Open brake switch contacts during deceleration
    C0234 Open brake switch contacts when ABS was required
    C0235 C0233 or C0234 set in previous or current ignition cycle
    C0236 TCS RPM signal circuit malfunction
    C0237 TCS throttle position signal malfunction
    C0238 TCS throttle position sensor comparison malfunction
    C0239 TCS spark retard monitoring malfunction
    C0240 PCM traction control not allowed
    C0241 PCM indicated requested torque malfunction
    C0242 PCM indicated TCS malfunction
    C0243 Engine drag control malfunction
    C0244 PWM delivered torque malfunction
    C0245 Wheel speed sensor frequency error
    C0246 Simultaneous dropout of both front wheel speed sensors
    C0247 MSVA1 actuator fault (ohmic)
    C0248 MSVA1 actuator fault (command vs. feedback current)
    C0249 Left normal force fault
    C0250 Right normal force fault
    C0251 RTD indicated fault
    C0252 ABC sensors uncorrelated
    C0253 Centering fault
    C0254 Steering sensor/lateral accelerometer bias fault
    C0255 TCM to ABS/TC PWM signal malfunction
    C0256 Valve relay contact circuit malfunction
    C0257 Valve relay contact circuit range/performance
    C0258 Valve relay contact circuit low
    C0259 Valve relay contact circuit high
    C0260 Valve relay contact circuit open
    C0261 Valve relay coil circuit malfunction
    C0262 Valve relay coil circuit range/performance
    C0263 Valve relay coil circuit low
    C0264 Valve relay coil circuit high
    C0265 Valve relay coil circuit open
    C0266 Throttle reduction motor controller malfunction
    C0267 Low brake fluid indicated
    C0268 Class 2 data error reported
    C0269 Class 2 data invalid
    C0300 Rear propshaft signal circuit malfunction
    C0301 Rear propshaft signal circuit range/performance
    C0302 Rear propshaft signal circuit low
    C0303 Rear propshaft signal circuit high
    C0304 Rear propshaft signal circuit open
    C0305 Front propshaft speed sensor/system malfunction
    C0306 Motor A/B circuit malfunction
    C0307 Motor A/B circuit range/performance
    C0308 Motor A/B circuit low
    C0309 Motor A/B circuit high
    C0310 Motor A/B circuit open
    C0311 Motor ground circuit malfunction
    C0312 Motor ground circuit range/performance
    C0313 Motor ground circuit low
    C0314 Motor ground circuit high C0315 Motor ground circuit open
    C0316 Motor circuit malfunction
    C0317 Motor circuit range/performance
    C0318 Motor circuit low
    C0319 Motor circuit high
    C0320 Motor circuit open
    C0321 Transfer case lock circuit malfunction
    C0322 Transfer case lock circuit range/performance
    C0323 Transfer case lock circuit low
    C0324 Transfer case lock circuit high
    C0325 Transfer case lock circuit open
    C0326 Transfer case lock system malfunction
    C0327 Encoder circuit malfunction
    C0328 Encoder circuit range/performance
    C0329 Encoder circuit low
    C0330 Encoder circuit high
    C0331 Encoder circuit open
    C0332 Encoder power circuit low
    C0333 Encoder ground circuit high
    C0334 Encoder channel P input circuit malfunction
    C0335 Encoder channel P input circuit range/performance
    C0336 Encoder channel P input circuit low
    C0337 Encoder channel P input circuit high
    C0338 Encoder channel P input circuit open
    C0339 Encoder channel C input circuit malfunction
    C0340 Encoder channel C input circuit range/performance
    C0341 Encoder channel C input circuit low
    C0342 Encoder channel C input circuit high
    C0343 Encoder channel C input circuit open
    C0344 Encoder channel B input circuit malfunction
    C0345 Encoder channel B input circuit range/performance
    C0346 Encoder channel B input circuit low
    C0347 Encoder channel B input circuit high
    C0348 Encoder channel B input circuit open
    C0349 Encoder channel A input circuit malfunction
    C0350 Encoder channel A input circuit range/performance
    C0351 Encoder channel A input circuit low
    C0352 Encoder channel A input circuit high
    C0353 Encoder channel A input circuit open
    C0354 Park switch circuit malfunction
    C0355 Park switch circuit range/performance
    C0356 Park switch circuit low
    C0357 Park switch circuit high
    C0358 Park switch circuit open
    C0359 4LO discrete output circuit malfunction
    C0360 4LO discrete output circuit range/performance
    C0361 4LO discrete output circuit low
    C0362 4LO discrete output circuit high
    C0363 4LO discrete output circuit open
    C0364 Front axle control circuit malfunction
    C0365 Front axle control circuit range/performance
    C0366 Front axle control circuit low
    C0367 Front axle control circuit high
    C0368 Front axle control circuit open
    C0369 ATC relay circuit malfunction
    C0370 ATC relay circuit range/performance
    C0371 ATC relay circuit low
    C0372 ATC relay circuit high
    C0373 ATC relay circuit open
    C0374 General system malfunction
    C0375 Intermittent system malfunction
    C0376 Front/Rear propshaft speed mismatch detected
    C0377 Front/Rear propshaft speed mismatch intermittent
    C0378 Front axle switch circuit malfunction
    C0379 Front axle system malfunction
    C0380 Mode switch power circuit low
    C0381 Motor system malfunction
    C0382 4LO discrete input circuit malfunction
    C0383 4LO discrete input circuit range/performance
    C0384 4LO discrete input circuit low
    C0385 4LO discrete input circuit high
    C0386 4LO discrete input circuit open
    C0387 Unable to complete shift
    C0450 Steering assist control solenoid/motor/actuator circuit malfunction
    C0451 Steering assist control solenoid/motor/actuator circuit range/performance
    C0452 Steering assist control solenoid/motor/actuator circuit low
    C0453 Steering assist control solenoid/motor/actuator circuit high
    C0454 Steering assist control solenoid/motor/actuator circuit open
    C0455 Steering position sensor circuit malfunction
    C0456 Steering position sensor circuit range/performance
    C0457 Steering position sensor circuit low
    C0458 Steering position sensor circuit high
    C0459 Steering position sensor circuit open
    C0460 Steering position sensor malfunction
    C0461 Steering position sensor range/performance
    C0462 Steering position sensor low
    C0463 Steering position sensor high
    C0464 Steering position sensor open
    C0465 Steering rate of change sensor circuit malfunction
    C0466 Steering rate of change sensor circuit range/performance
    C0467 Steering rate of change sensor circuit low
    C0468 Steering rate of change sensor circuit high
    C0469 Steering rate of change sensor circuit open
    C0470 Steering position & rate of change sensor circuit #1 malfunction
    C0471 Steering position & rate of change sensor circuit #1 range/performance
    C0472 Steering position & rate of change sensor circuit #1 low
    C0473 Steering position & rate of change sensor circuit #1 high
    C0474 Steering position & rate of change sensor circuit #1 open
    C0475 Electric steering motor circuit malfunction
    C0476 Electric steering motor circuit range/performance
    C0477 Electric steering motor circuit low
    C0478 Electric steering motor circuit high
    C0479 Electric steering motor circuit open
    C0480 Electric hydraulic steering motor circuit malfunction
    C0481 Electric hydraulic steering motor circuit range/performance
    C0482 Electric hydraulic steering motor circuit low
    C0483 Electric hydraulic steering motor circuit high
    C0484 Electric hydraulic steering motor circuit open
    C0485 Electric hydraulic steering temperature sensor circuit malfunction
    C0486 Electric hydraulic steering temperature sensor circuit range/performance
    C0487 Electric hydraulic steering temperature sensor circuit low
    C0488 Electric hydraulic steering temperature sensor circuit high
    C0489 Electric hydraulic steering temperature sensor circuit open
    C0490 Steering column lock solenoid circuit malfunction
    C0491 Steering column lock solenoid circuit range/performance
    C0492 Steering column lock solenoid circuit low
    C0493 Steering column lock solenoid circuit high
    C0494 Steering column lock solenoid circuit open
    C0495 EVO tracking error
    C0496 Steering assist control solenoid/motor/actuator feed circuit malfunction
    C0497 Steering assist control solenoid/motor/actuator feed circuit range/performance
    C0498 Steering assist control solenoid/motor/actuator feed circuit low
    C0499 Steering assist control solenoid/motor/actuator feed circuit high
    C0500 Steering assist control solenoid/motor/actuator feed circuit open
    C0501 Steering assist control solenoid/motor/actuator return circuit malfunction
    C0502 Steering assist control solenoid/motor/actuator return circuit range/performance
    C0503 Steering assist control solenoid/motor/actuator return circuit low
    C0504 Steering assist control solenoid/motor/actuator return circuit high
    C0505 Steering assist control solenoid/motor/actuator return circuit open
    C0506 Steering position & rate of change sensor circuit #2 malfunction
    C0507 Steering position & rate of change sensor circuit #2 range/performance
    C0508 Steering position & rate of change sensor circuit #2 low
    C0509 Steering position & rate of change sensor circuit #2 high
    C0510 Steering position & rate of change sensor circuit #2 open
    C0511 Steering position & rate of change sensor output circuit #1 malfunction
    C0512 Steering position & rate of change sensor output circuit #1 range/performance
    C0513 Steering position & rate of change sensor output circuit #1 low
    C0514 Steering position & rate of change sensor output circuit #1 high
    C0515 Steering position & rate of change sensor output circuit #1 open
    C0516 Steering position & rate of change sensor output circuit #2 malfunction
    C0517 Steering position & rate of change sensor output circuit #2 range/performance
    C0518 Steering position & rate of change sensor output circuit #2 low
    C0519 Steering position & rate of change sensor output circuit #2 high
    C0520 Steering position & rate of change sensor output circuit #2 open
    C0521 Steering position & rate of change sensors uncorrelated
    C0550 ECU malfunction
    C0551 Option configuration error
    C0552 Improper shutdown
    C0554 KAM reset
    C0563 Calibration ROM checksum error
    C0564 Program ROM checksum error
    C0565 VIN information error
    C0575 LF solenoid/motor/actuator circuit malfunction
    C0576 LF solenoid/motor/actuator circuit range/performance
    C0577 LF solenoid/motor/actuator circuit low
    C0578 LF solenoid/motor/actuator circuit high
    C0579 LF solenoid/motor/actuator circuit open
    C0580 RF solenoid/motor/actuator circuit malfunction
    C0581 RF solenoid/motor/actuator circuit range/performance
    C0582 RF solenoid/motor/actuator circuit low
    C0583 RF solenoid/motor/actuator circuit high
    C0584 RF solenoid/motor/actuator circuit open
    C0585 LR solenoid/motor/actuator circuit malfunction
    C0586 LR solenoid/motor/actuator circuit range/performance
    C0587 LR solenoid/motor/actuator circuit low
    C0588 LR solenoid/motor/actuator circuit high
    C0589 LR solenoid/motor/actuator circuit open
    C0590 RR solenoid/motor/actuator circuit malfunction
    C0591 RR solenoid/motor/actuator circuit range/performance
    C0592 RR solenoid/motor/actuator circuit low
    C0593 RR solenoid/motor/actuator circuit high
    C0594 RR solenoid/motor/actuator circuit open
    C0595 LF accelerometer circuit malfunction
    C0596 LF accelerometer circuit range/performance
    C0597 LF accelerometer circuit low
    C0598 LF accelerometer circuit high
    C0599 LF accelerometer circuit open
    C0600 RF accelerometer circuit malfunction
    C0601 RF accelerometer circuit range/performance
    C0602 RF accelerometer circuit low
    C0603 RF accelerometer circuit high
    C0604 RF accelerometer circuit open
    C0605 LR accelerometer circuit malfunction
    C0606 LR accelerometer circuit range/performance
    C0607 LR accelerometer circuit low
    C0608 LR accelerometer circuit high
    C0609 LR accelerometer circuit open
    C0610 RR accelerometer circuit malfunction
    C0611 RR accelerometer circuit range/performance
    C0612 RR accelerometer circuit low
    C0613 RR accelerometer circuit high
    C0614 RR accelerometer circuit open
    C0615 LF position sensor circuit malfunction
    C0616 LF position sensor circuit range/performance
    C0617 LF position sensor circuit low
    C0618 LF position sensor circuit high
    C0619 LF position sensor circuit open
    C0620 RF position sensor circuit malfunction
    C0621 RF position sensor circuit range/performance
    C0622 RF position sensor circuit low
    C0623 RF position sensor circuit high
    C0624 RF position sensor circuit open
    C0625 LR position sensor circuit malfunction
    C0626 LR position sensor circuit range/performance
    C0627 LR position sensor circuit low
    C0628 LR position sensor circuit high
    C0629 LR position sensor circuit open
    C0630 RR position sensor circuit malfunction
    C0631 RR position sensor circuit range/performance
    C0632 RR position sensor circuit low
    C0633 RR position sensor circuit high
    C0634 RR position sensor circuit open
    C0635 LF normal force circuit malfunction
    C0636 LF normal force circuit range/performance
    C0637 LF normal force circuit low
    C0638 LF normal force circuit high
    C0639 LF normal force circuit open
    C0640 RF normal force circuit malfunction
    C0641 RF normal force circuit range/performance
    C0642 RF normal force circuit low
    C0643 RF normal force circuit high
    C0644 RF normal force circuit open
    C0645 LR normal force circuit malfunction
    C0646 LR normal force circuit range/performance
    C0647 LR normal force circuit low
    C0648 LR normal force circuit high
    C0649 LR normal force circuit open
    C0650 RR normal force circuit malfunction
    C0651 RR normal force circuit range/performance
    C0652 RR normal force circuit low
    C0653 RR normal force circuit high
    C0654 RR normal force circuit open
    C0655 Level control compressor circuit malfunction
    C0656 Level control compressor circuit range/performance
    C0657 Level control compressor circuit low
    C0658 Level control compressor circuit high
    C0659 Level control compressor circuit open
    C0660 Level control exhaust valve circuit malfunction
    C0661 Level control exhaust valve circuit range/performance
    C0662 Level control exhaust valve circuit low
    C0663 Level control exhaust valve circuit high
    C0664 Level control exhaust valve circuit open
    C0665 Lift/dive signal circuit malfunction
    C0666 Lift/dive signal circuit range/performance
    C0667 Lift/dive signal circuit low
    C0668 Lift/dive signal circuit high
    C0669 Lift/dive signal circuit open
    C0670 LF combination accel/position sensor circuit malfunction
    C0671 LF combination accel/position sensor circuit range/performance
    C0672 LF combination accel/position sensor circuit low
    C0673 LF combination accel/position sensor circuit high
    C0674 LF combination accel/position sensor circuit open
    C0675 RF combination accel/position sensor circuit malfunction
    C0676 RF combination accel/position sensor circuit range/performance
    C0677 RF combination accel/position sensor circuit low
    C0678 RF combination accel/position sensor circuit high
    C0679 RF combination accel/position sensor circuit open
    C0680 LR combination accel/position sensor circuit malfunction
    C0681 LR combination accel/position sensor circuit range/performance
    C0682 LR combination accel/position sensor circuit low
    C0683 LR combination accel/position sensor circuit high
    C0684 LR combination accel/position sensor circuit open
    C0685 RR combination accel/position sensor circuit malfunction
    C0686 RR combination accel/position sensor circuit range/performance
    C0687 RR combination accel/position sensor circuit low
    C0688 RR combination accel/position sensor circuit high
    C0689 RR combination accel/position sensor circuit open
    C0690 Damper control relay circuit malfunction
    C0691 Damper control relay circuit range/performance
    C0692 Damper control relay circuit low
    C0693 Damper control relay circuit high
    C0694 Damper control relay circuit open
    C0695 Position sensor overcurrent (8 volt supply)
    C0696 Position sensor overcurrent (5 volt supply)
    C0697 Level control accessory inflator switch circuit malfunction
    C0698 Level control accessory inflator switch circuit range/performance
    C0699 Level control accessory inflator switch circuit low
    C0700 Level control accessory inflator switch circuit high
    C0701 Level control accessory inflator switch circuit open
    C0702 Level control accessory valve circuit malfunction
    C0703 Level control accessory valve circuit range/performance
    C0704 Level control accessory valve circuit low
    C0705 Level control accessory valve circuit high
    C0706 Level control accessory valve circuit open
    C0707 Excessive compressor activity
    C0708 Excessive compressor exhaust valve activity
    C0709 Excessive compressor activity, vehicle moving
    C0710 Steering position signal malfunction
    C0711 Level control air pressure sensor circuit malfunction
    C0750 LF low tire pressure sensor malfunction
    C0751 LF low tire pressure sensor range/performance
    C0752 LF low tire pressure sensor low
    C0753 LF low tire pressure sensor high
    C0754 LF low tire pressure sensor circuit open
    C0755 RF low tire pressure sensor malfunction
    C0756 RF low tire pressure sensor range/performance
    C0757 RF low tire pressure sensor low
    C0758 RF low tire pressure sensor high
    C0759 RF low tire pressure sensor circuit open
    C0760 LR low tire pressure sensor malfunction
    C0761 LR low tire pressure sensor range/performance
    C0762 LR low tire pressure sensor low
    C0763 LR low tire pressure sensor high
    C0764 LR low tire pressure sensor circuit open
    C0765 RR low tire pressure sensor malfunction
    C0766 RR low tire pressure sensor range/performance
    C0767 RR low tire pressure sensor low
    C0768 RR low tire pressure sensor high
    C0769 RR low tire pressure sensor circuit open
    C0770 LF tire pressure low
    C0771 RF tire pressure low
    C0772 LR tire pressure low
    C0773 RR tire pressure low
    C0774 Low tire pressure system malfunction
    C0775 Low tire pressure system sensors not programmed
    C0776 Low tire pressure system transmitter synchronization failure
    C0777 Low tire pressure system transmitter ID invalid
    C0778 TIM switch circuit malfunction
    C0779 TIM signal fault
    C0800 Device power #1 (low current #1) circuit malfunction
    C0801 Device power #1 (low current #1) circuit range/performance
    C0802 Device power #1 (low current #1) circuit low
    C0803 Device power #1 (low current #1) circuit high
    C0804 Device power #1 (low current #1) circuit open
    C0805 Device power #2 (low current #2) circuit malfunction
    C0806 Device power #2 (low current #2) circuit range/performance
    C0807 Device power #2 (low current #2) circuit low
    C0808 Device power #2 (low current #2) circuit high
    C0809 Device power #2 (low current #2) circuit open
    C0810 Device power #3 (high current #1) circuit malfunction
    C0811 Device power #3 (high current #1) circuit range/performance
    C0812 Device power #3 (high current #1) circuit low
    C0813 Device power #3 (high current #1) circuit high
    C0814 Device power #3 (high current #1) circuit open
    C0815 Device power #4 (high current #2) circuit malfunction
    C0816 Device power #4 (high current #2) circuit range/performance
    C0817 Device power #4 (high current #2) circuit low
    C0818 Device power #4 (high current #2) circuit high
    C0819 Device power #4 (high current #2) circuit open
    C0820 Device ground #1 (chassis gnd #1) circuit malfunction
    C0821 Device ground #1 (chassis gnd #1) circuit range/performance
    C0822 Device ground #1 (chassis gnd #1) circuit low
    C0823 Device ground #1 (chassis gnd #1) circuit high
    C0824 Device ground #1 (chassis gnd #1) circuit open
    C0825 Device ground #2 (chassis gnd #2) circuit malfunction
    C0826 Device ground #2 (chassis gnd #2) circuit range/performance
    C0827 Device ground #2 (chassis gnd #2) circuit low
    C0828 Device ground #2 (chassis gnd #2) circuit high
    C0829 Device ground #2 (chassis gnd #2) circuit open
    C0830 Device ground #3 (signal gnd #1) circuit malfunction
    C0831 Device ground #3 (signal gnd #1) circuit range/performance
    C0832 Device ground #3 (signal gnd #1) circuit low
    C0833 Device ground #3 (signal gnd #1) circuit high
    C0834 Device ground #3 (signal gnd #1) circuit open
    C0835 Device ground #4 (signal gnd #2) circuit malfunction
    C0836 Device ground #4 (signal gnd #2) circuit range/performance
    C0837 Device ground #4 (signal gnd #2) circuit low
    C0838 Device ground #4 (signal gnd #2) circuit high
    C0839 Device ground #4 (signal gnd #2) circuit open
    C0840 Device ignition 0 (UNLOCK/ON/START) circuit malfunction
    C0841 Device ignition 0 (UNLOCK/ON/START) circuit range/performance
    C0842 Device ignition 0 (UNLOCK/ON/START) circuit low
    C0843 Device ignition 0 (UNLOCK/ON/START) circuit high
    C0844 Device ignition 0 (UNLOCK/ON/START) circuit open
    C0845 Device ignition 1 (ON/START) circuit malfunction
    C0846 Device ignition 1 (ON/START) circuit range/performance
    C0847 Device ignition 1 (ON/START) circuit low
    C0848 Device ignition 1 (ON/START) circuit high
    C0849 Device ignition 1 (ON/START) circuit open
    C0850 Device ignition 3 (ON) circuit malfunction
    C0851 Device ignition 3 (ON) circuit range/performance
    C0852 Device ignition 3 (ON) circuit low
    C0853 Device ignition 3 (ON) circuit high
    C0854 Device ignition 3 (ON) circuit open
    C0855 Device ignition ACC circuit malfunction
    C0856 Device ignition ACC circuit range/performance
    C0857 Device ignition ACC circuit low
    C0858 Device ignition ACC circuit high
    C0859 Device ignition ACC circuit open
    C0860 Device ignition START circuit malfunction
    C0861 Device ignition START circuit range/performance
    C0862 Device ignition START circuit low
    C0863 Device ignition START circuit high
    C0864 Device ignition START circuit open
    C0865 Device voltage reference input #1 circuit malfunction
    C0866 Device voltage reference input #1 circuit range/performance
    C0867 Device voltage reference input #1 circuit low
    C0868 Device voltage reference input #1 circuit high
    C0869 Device voltage reference input #1 circuit open
    C0870 Device voltage reference output #1 circuit malfunction
    C0871 Device voltage reference output #1 circuit range/performance
    C0872 Device voltage reference output #1 circuit low
    C0873 Device voltage reference output #1 circuit high
    C0874 Device voltage reference output #1 circuit open
    C0875 Device voltage reference input #2 circuit malfunction
    C0876 Device voltage reference input #2 circuit range/performance
    C0877 Device voltage reference input #2 circuit low
    C0878 Device voltage reference input #2 circuit high
    C0879 Device voltage reference input #2 circuit open
    C0880 Device voltage reference output #2 circuit malfunction
    C0881 Device voltage reference output #2 circuit range/performance
    C0882 Device voltage reference output #2 circuit low
    C0883 Device voltage reference output #2 circuit high
    C0884 Device voltage reference output #2 circuit open
    C0885 Device voltage reference input #3 circuit malfunction
    C0886 Device voltage reference input #3 circuit range/performance
    C0887 Device voltage reference input #3 circuit low
    C0888 Device voltage reference input #3 circuit high
    C0889 Device voltage reference input #3 circuit open
    C0890 Device voltage reference output #3 circuit malfunction
    C0891 Device voltage reference output #3 circuit range/performance
    C0892 Device voltage reference output #3 circuit low
    C0893 Device voltage reference output #3 circuit high
    C0894 Device voltage reference output #3 circuit open
    C0895 Device voltage malfunction
    C0896 Device voltage range/performance
    C0897 Device power moding malfunction
    C0898 Device power and/or ground circuit malfunction
    C0899 Device #1 voltage low
    C0900 Device #1 voltage high
    C0901 Device #2 voltage low
    C0902 Device #2 voltage high
    C0903 Ignition-switched power relay #1 circuit malfunction
    C0904 Ignition-switched power relay #1 circuit range/performance
    C0905 Ignition-switched power relay #1 circuit low
    C0906 Ignition-switched power relay #1 circuit high
    C0907 Ignition-switched power relay #1 circuit open
    C0908 Ignition-switched power relay #2 circuit malfunction
    C0909 Ignition-switched power relay #2 circuit range/performance
    C0910 Ignition-switched power relay #2 circuit low
    C0911 Ignition-switched power relay #2 circuit high
    C0912 Ignition-switched power relay #2 circuit open
    C0913 Intermittent device voltage range/performance
    U1000 Class 2 Data Link Malfunction
    U1001 Lost communications with Powertrain Multiple Control System
    U1002 Lost communications with Powertrain Multiple Control System
    U1003 Lost communications with Powertrain Multiple Control System
    U1004 Lost communications with Powertrain Multiple Control System
    U1005 Lost communications with Powertrain Multiple Control System
    U1006 Lost communications with Powertrain Multiple Control System
    U1007 Lost communications with Powertrain Multiple Control System
    U1008 Lost communications with Powertrain Multiple Control System
    U1009 Lost communications with Powertrain Multiple Control System
    U1010 Lost communications with Powertrain Multiple Control System
    U1011 Lost communications with Powertrain Multiple Control System
    U1012 Lost communications with Powertrain Multiple Control System
    U1013 Lost communications with Powertrain Multiple Control System
    U1014 Lost communications with Powertrain Multiple Control System
    U1015 Lost communications with Powertrain Multiple Control System
    U1016 Lost communications with Engine Control System
    U1017 Lost communications with Engine Control System
    U1018 Lost communications with Engine Control System
    U1019 Lost communications with Engine Control System
    U1020 Lost communications with Engine Control System
    U1021 Lost communications with Engine Control System
    U1022 Lost communications with Engine Control System
    U1023 Lost communications with Engine Control System
    U1024 Lost communications with Transmission Control System
    U1025 Lost communications with Transmission Control System
    U1026 Lost communications with Transmission Control System
    U1027 Lost communications with Transmission Control System
    U1028 Lost communications with Transmission Control System
    U1029 Lost communications with Transmission Control System
    U1030 Lost communications with Transmission Control System
    U1031 Lost communications with Transmission Control System
    U1032 Lost communications with Chassis Multiple Control System
    U1033 Lost communications with Chassis Multiple Control System
    U1034 Lost communications with Chassis Multiple Control System
    U1035 Lost communications with Chassis Multiple Control System
    U1036 Lost communications with Chassis Multiple Control System
    U1037 Lost communications with Chassis Multiple Control System
    U1038 Lost communications with Chassis Multiple Control System
    U1039 Lost communications with Chassis Multiple Control System
    U1040 Lost communications with Brake/Traction Control System
    U1041 Lost communications with Brake/Traction Control System
    U1042 Lost communications with Brake/Traction Control System
    U1043 Lost communications with Brake/Traction Control System
    U1044 Lost communications with Brake/Traction Control System
    U1045 Lost communications with Brake/Traction Control System
    U1046 Lost communications with Brake/Traction Control System
    U1047 Lost communications with Brake/Traction Control System
    U1048 Lost communications with Steering Control System
    U1049 Lost communications with Steering Control System
    U1050 Lost communications with Steering Control System
    U1051 Lost communications with Steering Control System
    U1052 Lost communications with Steering Control System
    U1053 Lost communications with Steering Control System
    U1054 Lost communications with Steering Control System
    U1055 Lost communications with Steering Control System
    U1056 Lost communications with Suspension Control System
    U1057 Lost communications with Suspension Control System
    U1058 Lost communications with Suspension Control System
    U1059 Lost communications with Suspension Control System
    U1060 Lost communications with Suspension Control System
    U1061 Lost communications with Suspension Control System
    U1062 Lost communications with Suspension Control System
    U1063 Lost communications with Suspension Control System
    U1064 Lost communications with Body Multiple Control System
    U1065 Lost communications with Body Multiple Control System
    U1066 Lost communications with Body Multiple Control System
    U1067 Lost communications with Body Multiple Control System
    U1068 Lost communications with Body Multiple Control System
    U1069 Lost communications with Body Multiple Control System
    U1070 Lost communications with Body Multiple Control System
    U1071 Lost communications with Body Multiple Control System
    U1072 Lost communications with Body Multiple Control System
    U1073 Lost communications with Body Multiple Control System
    U1074 Lost communications with Body Multiple Control System
    U1075 Lost communications with Body Multiple Control System
    U1076 Lost communications with Body Multiple Control System
    U1077 Lost communications with Body Multiple Control System
    U1078 Lost communications with Body Multiple Control System
    U1079 Lost communications with Body Multiple Control System
    U1080 Lost communications with Body Multiple Control System
    U1081 Lost communications with Body Multiple Control System
    U1082 Lost communications with Body Multiple Control System
    U1083 Lost communications with Body Multiple Control System
    U1084 Lost communications with Body Multiple Control System
    U1085 Lost communications with Body Multiple Control System
    U1086 Lost communications with Body Multiple Control System
    U1087 Lost communications with Body Multiple Control System
    U1088 Lost communications with Restraints Control System
    U1089 Lost communications with Restraints Control System
    U1090 Lost communications with Restraints Control System
    U1091 Lost communications with Restraints Control System
    U1092 Lost communications with Restraints Control System
    U1093 Lost communications with Restraints Control System
    U1094 Lost communications with Restraints Control System
    U1095 Lost communications with Restraints Control System
    U1096 Lost communications with Driver Information & Displays Control System
    U1097 Lost communications with Driver Information & Displays Control System
    U1098 Lost communications with Driver Information & Displays Control System
    U1099 Lost communications with Driver Information & Displays Control System
    U1100 Lost communications with Driver Information & Displays Control System
    U1101 Lost communications with Driver Information & Displays Control System
    U1102 Lost communications with Driver Information & Displays Control System
    U1103 Lost communications with Driver Information & Displays Control System
    U1104 Lost communications with Driver Information & Displays Control System
    U1105 Lost communications with Driver Information & Displays Control System
    U1106 Lost communications with Driver Information & Displays Control System
    U1107 Lost communications with Driver Information & Displays Control System
    U1108 Lost communications with Driver Information & Displays Control System
    U1109 Lost communications with Driver Information & Displays Control System
    U1110 Lost communications with Driver Information & Displays Control System
    U1111 Lost communications with Driver Information & Displays Control System
    U1112 Lost communications with Lighting Control System
    U1113 Lost communications with Lighting Control System
    U1114 Lost communications with Lighting Control System
    U1115 Lost communications with Lighting Control System
    U1116 Lost communications with Lighting Control System
    U1117 Lost communications with Lighting Control System
    U1118 Lost communications with Lighting Control System
    U1119 Lost communications with Lighting Control System
    U1120 Lost communications with Lighting Control System
    U1121 Lost communications with Lighting Control System
    U1122 Lost communications with Lighting Control System
    U1123 Lost communications with Lighting Control System
    U1124 Lost communications with Lighting Control System
    U1125 Lost communications with Lighting Control System
    U1126 Lost communications with Lighting Control System
    U1127 Lost communications with Lighting Control System
    U1128 Lost communications with Entertainment/Audio Control System
    U1129 Lost communications with Entertainment/Audio Control System
    U1130 Lost communications with Entertainment/Audio Control System
    U1131 Lost communications with Entertainment/Audio Control System
    U1132 Lost communications with Entertainment/Audio Control System
    U1133 Lost communications with Entertainment/Audio Control System
    U1134 Lost communications with Entertainment/Audio Control System
    U1135 Lost communications with Entertainment/Audio Control System
    U1136 Lost communications with Entertainment/Audio Control System
    U1137 Lost communications with Entertainment/Audio Control System
    U1138 Lost communications with Entertainment/Audio Control System
    U1139 Lost communications with Entertainment/Audio Control System
    U1140 Lost communications with Entertainment/Audio Control System
    U1141 Lost communications with Entertainment/Audio Control System
    U1142 Lost communications with Entertainment/Audio Control System
    U1143 Lost communications with Entertainment/Audio Control System
    U1144 Lost communications with Mobile Communications Control System
    U1145 Lost communications with Mobile Communications Control System
    U1146 Lost communications with Mobile Communications Control System
    U1147 Lost communications with Mobile Communications Control System
    U1148 Lost communications with Mobile Communications Control System
    U1149 Lost communications with Mobile Communications Control System
    U1150 Lost communications with Mobile Communications Control System
    U1151 Lost communications with Mobile Communications Control System
    U1152 Lost communications with HVAC Control System
    U1153 Lost communications with HVAC Control System
    U1154 Lost communications with HVAC Control System
    U1155 Lost communications with HVAC Control System
    U1156 Lost communications with HVAC Control System
    U1157 Lost communications with HVAC Control System
    U1158 Lost communications with HVAC Control System
    U1159 Lost communications with HVAC Control System
    U1160 Lost communications with Convenience Control System
    U1161 Lost communications with Convenience Control System
    U1162 Lost communications with Convenience Control System
    U1163 Lost communications with Convenience Control System
    U1164 Lost communications with Convenience Control System
    U1165 Lost communications with Convenience Control System
    U1166 Lost communications with Convenience Control System
    U1167 Lost communications with Convenience Control System
    U1168 Lost communications with Convenience Control System
    U1169 Lost communications with Convenience Control System
    U1170 Lost communications with Convenience Control System
    U1171 Lost communications with Convenience Control System
    U1172 Lost communications with Convenience Control System
    U1173 Lost communications with Convenience Control System
    U1174 Lost communications with Convenience Control System
    U1175 Lost communications with Convenience Control System
    U1176 Lost communications with Convenience Control System
    U1177 Lost communications with Convenience Control System
    U1178 Lost communications with Convenience Control System
    U1179 Lost communications with Convenience Control System
    U1180 Lost communications with Convenience Control System
    U1181 Lost communications with Convenience Control System
    U1182 Lost communications with Convenience Control System
    U1183 Lost communications with Convenience Control System
    U1184 Lost communications with Convenience Control System
    U1185 Lost communications with Convenience Control System
    U1186 Lost communications with Convenience Control System
    U1187 Lost communications with Convenience Control System
    U1188 Lost communications with Convenience Control System
    U1189 Lost communications with Convenience Control System
    U1190 Lost communications with Convenience Control System
    U1191 Lost communications with Convenience Control System
    U1192 Lost communications with Security Control System
    U1193 Lost communications with Security Control System
    U1194 Lost communications with Security Control System
    U1195 Lost communications with Security Control System
    U1196 Lost communications with Security Control System
    U1197 Lost communications with Security Control System
    U1198 Lost communications with Security Control System
    U1199 Lost communications with Security Control System
    U1300 Class 2 Data Link Low
    U1301 Class 2 Data Link High
    U1302 Programming request not received
    U1303 Programming mode active message not received
    U1304 Lost communications with UART system(s)
    U1305 Class 2 Data Link Low or High
    U1400 AD Link Malfunction
    U1401 Lost communications between AD and ADG
    U1500 Inter-device dedicated bus malfunction
    U1601 Restraint system dedicated bus #1 malfunction (Suppression system bus)
    U1602 Restraint system dedicated bus #2 malfunction (EFS system bus)
    U1603 Restraint system dedicated bus #3 malfunction (SDM #2 system bus)
    U1650 Chassis system dedicated bus controller malfunction
    U1651 Chassis system dedicated bus sensor #1 malfunction
    U1652 Chassis system dedicated bus sensor #2 malfunction
    U2000 Invalid BFC transmitted SPI data
    U2001 Invalid IPC transmitted SPI data
    U2002 SPI data in low
    U2003 SPI data in high
    U2004 SPI data out low
    U2005 SPI data out high
    U2006 SPI clock out low
    U2007 SPI clock out high
    U2008 General SPI malfunction
    U2050 SIR PPS/CPS Communications Link Malfunction
    U2100 CAN bus communication malfunction
    U2101 Maximum list of control modules not programmed
    U2102 More controllers on bus than programmed
    U2103 Fewer controllers on bus than programmed
    U2104 CAN bus reset counter overrun
    U2105 Lost communications with Engine Control System
    U2106 Lost communications with Transmission Control System
    U2107 Lost communications with Body Control System
    U2108 Lost communications with ABS/TCS Control System
    U2109 Lost communications with Powertrain Multiple Control System
    U2110 Lost communications with Chassis Multiple Control System
    U2111 Lost communications with Steering Control System U2112 Lost communications with Suspension Control System
    U2113 Lost communications with Restraints Control (SDM) System
    U2114 Lost communications with Restraints Control (PPS/CPS) System
    U2115 Lost communications with Restraints Control (TBD) System
    U2116 Lost communications with Driver Information & Displays Control (IPC) System
    U2117 Lost communications with Driver Information & Displays Control (DIC) System
    U2118 Lost communications with Driver Information & Displays Control (TBD) System
    U2119 Lost communications with Lighting Control (DRL) System
    U2120 Lost communications with Lighting Control (AHLD) System
    U2121 Lost communications with Lighting Control (TBD) System
    U2122 Lost communications with Entertainment/Audio Control (Radio) System
    U2123 Lost communications with Entertainment/Audio Control (CDX) System
    U2124 Lost communications with Entertainment/Audio Control (TBD) System
    U2125 Lost communications with Mobile Communications Control (TBD) System
    U2126 Lost communications with Mobile Communications Control (TBD) System
    U2127 Lost communications with HVAC Control (front) System
    U2128 Lost communications with HVAC Control (rear) System
    U2129 Lost communications with Convenience Control (RFA) System
    U2130 Lost communications with Convenience Control (DDM) System
    U2131 Lost communications with Convenience Control (DSM) System
    U2132 Lost communications with Convenience Control (PDM) System
    U2133 Lost communications with Convenience Control (PSM) System
    U2134 Lost communications with Convenience Control (RDM) System
    U2135 Lost communications with Convenience Control (RIM) System
    U2136 Lost communications with Convenience Control (MMM) System
    U2137 Lost communications with Security Control (VTD) System
    U2138 Lost communications with Security Control (TBD) System
    U2139 Lost communications with Body Control (CIM) System
    U2140 Lost communications with Body Control (UEC) System
    U2141 Lost communications with Body Control (REC) System
    U2142 Lost communications with Chassis Control (YRS) System
    U2143 Lost communications with Steering Control (SAS) System
    U2144 Lost communications with Powertrain Control (ACC) System
    U2145 Lost communications with Convenience Control (PAS) System
    U2150 Navigation ECU Gateway Communications Malfunction
    U2151 Navigation ECU Communications Malfunction
    U2152 Navigation Bus Request Line Circuit Low
    U2153 Navigation ECU - VICS communication circuit malfunction
    Note that this listing is a guideline only--not to be substituted for real Tech2 scanner
    diagnostics.
  2. #2
    05-11-2005
    Bridgend
    Age
    29
    5,698
    we havent got computer to get these codes well i havent anyways
  3. #3
    13-08-2007
    Chesterfield
    Age
    31
    1,619
    not everyone has access to get thecodes themselves i know, but if they do then atleast theres a reference for them
  4. #4
    21-01-2007
    Darlington, NE
    Age
    23
    6,543
    Make this a sticky !! Or in mechanical tutorials or summit !
  5. #5
    13-08-2007
    Chesterfield
    Age
    31
    1,619
    couldnt put in tutorials as im to tight to pay extra membership
    usefull info as i found out, thought id share the love......
  6. #6
    05-11-2005
    Bridgend
    Age
    29
    5,698
    cheers fella always usefull
  7. #7
    12-08-2007
    Northallerton
    Age
    23
    8,795
    thats beaut, now i need to find a tech2
    top job matey!
  8. #8
    17-04-2008
    Age
    28
    1
    excellent find mate, iv been looking all over the net for these. where did you manage to get them from?
    thanks again
  9. #9
    23-12-2007
    8
    No need for Tech 2 or any sort of code readers and Most of Vauxhall dealers don’t know about this....
    Want to read the Code well first
    Take a deep breath get your car keys and get a pen and paper
    When you get into the car you know the key has 3 clicks first on for whatever it is second the dash comes on third the starter kicks in
    before you put the key into the ignition Make sure that you Press the Break and the Throttle to the Floor ( max
    Then turn the key on until The dash board come on and DONT START THE CAR
    Wait 2 sec and keep the pedals Down to the floor
    the service light under the management light should start flashing
    it will flash 4 times leaving 2 second space representing each number
    Zero gets 10 flashes
    for exampleP0110
    the light will flash ten times Break (2sec Or 1 not sure) then once, (2sec) once again, then ten
    if you have more than one code it will stop for a break then gives the next code
    its not a very useful way but helps when you dont want to go to the dealer for a lose socket
    this is for Corsa C the Newer models have even better way to tell you the code i think which is on your Mileage Display It will show ECN0 XXXX
    which is error code Number forget the zero and the last four digits is what you want
    and this works for an astra Too
    ive tested this on my own corsa and worked Very well
    however if you don’t have any code stored it will start Flashing and keeps on flashing until you release the paddles
  10. #10
    13-08-2007
    Chesterfield
    Age
    31
    1,619
    this does work......
    although i had to get in the car, close door, lock then unlock before it would do it though....
    come up with 2 codes, which both matched to a tech 2.... only problem is you cant clear them..
    still, good work!
  11. #11
    Extra Member corsa_mark's Avatar
    01-08-2006
    Derby
    Age
    25
    8,587
    and to tell if you haven't got any codes stored.........
    switch on ignition and see if the EML goes out. If it stays on then you've got a problem somewhere.
  12. #12
    13-01-2006
    Nottingham
    Age
    25
    4,524
    Quote Originally Posted by Dan_RSi View Post
    still, good work!
    OMG asif you never knew that trick dan, should of just asked
  13. #13
    13-08-2007
    Chesterfield
    Age
    31
    1,619
    Quote Originally Posted by nyzrox View Post
    funny that, you didnt know when i rung ya to tell ya!!!!!
  14. #14
    28-07-2008
    Age
    26
    20
    Trust my code not to be there. I've done this and got 1523. Anyone know what this one means?
    Cheers.
  15. #15
    13-01-2006
    Nottingham
    Age
    25
    4,524
    Google'd it
    P1523 - Idle speed control auxilary inputs, Manf. Ctrl. Vehicle Speed
    1523 may point to cam sensor
  16. #16
    28-07-2008
    Age
    26
    20
    Hi,
    Took it to the garage and it wasn't that.
    I got the fault code correct - 1523 but that means "Throttle out of position" or something along those lines. Was nothing much, just something that had been knocked in the bonnet.
  17. #17
    28-07-2008
    Age
    26
    20
    Hello again, got some more fault codes, I have 2, both are '0170'. Which means either:
    Rich Exhaust C-30 or Lean Exhaust C-30.
    Anyone know what this could mean??
    Cheers, Mark
  18. #18
    31-05-2008
    West London, Southall
    Age
    24
    1,146
    right i have the same problem with mine and i think it means the air mass flow meter needs to be replaced. its the one connects on between the induction kit and the pipe following into the throttle body.
    do you get symptoms from the car such as sluggish performance when starting and the car dying out sometime or trying to keep itself going when revs drop significantly?
  19. #19
    13-08-2007
    Chesterfield
    Age
    31
    1,619
    0170 could be the MAF yes...... if its reading incorrect air temp and level the it will over/under fuel accordingly......
    im guessin you guys have induction kits???
    direct engine bay hot air + oiled filter = constant MAF failure!!!
    ditch the cone's, green cotton panel filter and de-restrict the airbox..... same performance gains
  20. #20
    Banned User
    19-06-2006
    Timbuktoo
    22,211
    C0265??
    confused.com
  21. #21
    31-05-2008
    Age
    24
    1,146
    yh i have a full direct green cotton induction kit, erm i think the MAF is gone as when i took the Flow meter off the car was revving properly not cutting out when i'll slow down and push down the clutch. common problem after buying aftermarket induction kits.
  22. #22
    28-07-2008
    Age
    26
    20
    Hey, I took mine to the garage and got them to look at it. Obviously they get a better and more detailed description than our code descriptions with their machine so found out it wasn't anything to do with MAF.
    It was just some water had hit something when I was driving, which would make sense as it came on on motorway in the pouring rain. So just had the Fault light reset. I do admit it feels a little sluggish but they checked the MAF and said its in perfect working order.
  23. #23
    18-02-2006
    Doncaster
    Age
    27
    1,009
    I have 2 codes...
    0110 - Intake Air temp high/low
    0100 Mass/Volume Air Flow High/Low
    I'm guessing my MAF is totally ****ed.. ther mite be light in the tunnel afterwards, hopefully not talking to fast as I hope it'll be covered by warrenty still... they're funny buggers at VX/Masterfit as the engine has been changed - the floods last year (basically either £550 excess and a claim on insurance, or £250 for engine from 06 corsa, exactly same 1.2 sxi twinport z12xep) you can guess which I did..
  24. #24
    27-05-2008
    Age
    24
    7
    Fault codes
    Has anyone seen on their clock/radio/temp/time etc display a "display safe" message??
    when i start the car, it display's the station and song title etc like normal for about 20 seconds, then comes up with this "display safe". I took this back a Holden Parts and Service place to have a look at (yeah i am in Australia where i drive a Barina.. not a corsa ). they charged me $165 to tell me that they didnt know what was wrong with it, suggested a faulty board and to get it replaced ($550 brand new). I refuse to pay that much for it! Can anyone help!! PLEAAAASSEEE!!
  25. #25
    24-03-2007
    9,928
    Quote Originally Posted by lanie$Ri View Post
    Does your cd player work? that normally comes up where you type in the radio code so you can listen to the cd player
Closed Thread
