1.7 Cdti Timing Belt
User Tag List
Closed Thread
Results 1 to 21 of 21
Thread: 1.7 Cdti Timing Belt
    10-11-2007
    Caerphilly
    Age
    29
    747
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Does anyone know when the timing belt on a 1.7 cdti should be changed, I have heard its 100k, ive also heard its 60k which is concerning as mine is on 70k!
    My dads' 1.9cdti 8v snapped at 100500 lol!
    Also i have just had the boost pressure sensor replaced and the car is a little slow on pickup, it may need to bed in or something?!
    Ooh and there is a terrible howling coming from somewhere which i think may be the wheelbearing! Any way to know for sure as it could be tyre noise, but it is pretty bad!
    oooh and, how much would brake discs and pads would cost?!
    Thankyouuuu
  2. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  3. #2
    24-06-2006
    Wherever my caravan fits
    Age
    34
    4,396
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Super-Dan View Post
    Thankyouuuu
    Break disks and pads are ALOT cheaper if you order the kit instead of the parts on there own, also order the meriva/astra set as they are the same but cheaper
  4. #3
    DarkBahamut
    Thankyouuuu
    Vauxhall have told me a number of times that the belt is due at 100,000 miles. However, the service booklet clearly says 65,000 miles or 10 years for the Z17DTH, so i'm sticking to that.
    I have heard 60,000 too, but i'm going with my booklet
  5. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  6. #4
    10-11-2007
    Caerphilly
    Age
    29
    747
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I will be popping up the garage where my dads car is being repaired as he has a system that tells you when it should be changed, how much should i spend on the change if it is needed?
  7. #5
    10-11-2007
    Caerphilly
    Age
    29
    747
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    the new astra or the one before it?
  8. #6
    06-05-2008
    Biddulph, Stoke-on-Trent
    Age
    34
    56
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Z17DTH is every 60,000 - My Corsa-C 1.7CDTi was done on saturday for its MoT & Service at 59,000miles. Ive got the print-out from the AutoData software in my glovebox from the garage my old man works at!
  9. #7
    10-11-2007
    Caerphilly
    Age
    29
    747
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine is booked in now with 69k which is worrying, and ive still got to drive to Derby in it! RAC will tow me home if needs be!
  10. #8
    DarkBahamut
    Right, so if its 60,000 then i better get mine booked in
    63,500
  11. #9
    Missing_pilot's Avatar
    04-01-2007
    Northamptonshyite
    Age
    30
    28,339
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    mine was done when i had my fuel pump changed @ 52k
    but its every 60k as thats what the hand book says.. might last to 100k but
    If stupidity got me into this, it can get me out of this as wel!!! :twisted:
    Astra 1.9 CDTi SRi XP
    "Loads of torque - good for dredging canals" - My beloved C
  12. #10
    10-11-2007
    Caerphilly
    Age
    29
    747
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Got 71k now lol, being changed tommorrow tho :-)
  13. #11
    DarkBahamut
    I got mine done on Friday. 62,600 miles .
    £129.50. Not too bad i don't think!
  14. #12
    10-11-2007
    Caerphilly
    Age
    29
    747
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    wow where did you get that done? i was quoted £230
  15. #13
    DarkBahamut
    Just a local garage by where i work.
    It was £129.50 for the cambelt or £212 if i had the cambelt and water pump done together, but they said the water pump isn't really in the same area as the cambelt on these engines so isn't worth doing unless its going. They checked it anyway but it was fine.
    To be honest i was expecting it to be more!
  16. #14
    06-05-2008
    Age
    34
    56
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine was about £60ish inc. MoT... but my old man's a mechanic
  17. #15
    10-11-2007
    Caerphilly
    Age
    29
    747
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine was £233 but the crank shaft sensor seal and Oil pump seals needed replacing, there was oil all over my timing belt. Nice
  18. #16
    29-12-2011
    Lincolnshire
    233
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So I'm viewing a car that's 78,000 on the clock, and ain't even had a cambelt change,
  19. #17
    29-08-2010
    guildford, surrey
    Age
    27
    30,368
    Mentioned
    20 Post(s)
    Tagged
    1 Thread(s)
    you do know you just pointless bumped a 4 year old thread?
  20. #18
    29-12-2011
    Lincolnshire
    233
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    And your point is?
  21. #19
    15-11-2009
    Newport, South Wales
    Age
    27
    31,476
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by CorsaCally View Post
    4 year bump
    Try and knock some money off then.
  22. #20
    29-08-2010
    guildford, surrey
    Age
    27
    30,368
    Mentioned
    20 Post(s)
    Tagged
    1 Thread(s)
    my point is GLWS
    it's kinda obvious you should get them to add in a change of belt to the purchase
  23. #21
    04-01-2007
    Northamptonshyite
    Age
    30
    28,339
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    as above.. dont bump a thread thats more then 6 months old, post up a new thread with the link of this thread in it to show you've searched
Closed Thread
