1.3 Cdti Problem
User Tag List
+ Reply to Thread
Results 1 to 9 of 9
Thread: 1.3 Cdti Problem
    10-09-2007
    Norfolk
    Age
    55
    53
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    1.3 Cdti Problem
    Hi everyone,I have a 2005 cdti 1.3 and have a problem,when you start up in the morning I get a load of smoke with a smell of burning in it,very light blue/white in colour,now the yurbo has been replaced as has the intercooler,still does it,does not really do it during the day as such mostly on first start up and not always everyday,any ideas chaps please.
  2. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  3. #2
    10-09-2007
    Norfolk
    Age
    55
    53
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Has nobody had this sort of problem
  4. #3
    03-08-2007
    Upholland
    Age
    29
    12,005
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    sounds like oil getting in, oil seal?
  5. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  6. #4
    12-07-2008
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    my 2003 does exactly the same,but only when the engine is cold. Absolutely fine once its been running for a few minuites. Did read somewhere that they are quite smokey on initial start up from cold,may be its just the way they are.
  7. #5
    10-09-2007
    Norfolk
    Age
    55
    53
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    corsa
    Quote Originally Posted by paul2200 View Post
    Yes this is when cold but not all the time,its going in for a EGR valve so we will see if this is it
  8. #6
    Premier Member ultimawhistler's Avatar
    02-04-2008
    Stevenage
    21,818
    Mentioned
    92 Post(s)
    Tagged
    0 Thread(s)
    Mine does it only on cold but only until it warms up. I had the EGR valve done and its still the same. I took my car into VX for a tech2 test ( another matter ) and they re-called it in for an ABS mod and an ECU re-program, all under warranty. They said that if the ECU is not reprogrammed with the latest software you will be replacing EGR valves about every 30k miles. The new software forces the value to "Self clean" when the engine is started and stopped, to stop it coking up.
  9. #7
    10-09-2007
    Norfolk
    Age
    55
    53
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    cdti
    well vauxhall could not find out the problems so they have replaced it with a another model.
  10. #8
    06-04-2008
    Plymouth
    Age
    28
    2,788
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i think they all do that m8 mine does...my dads does and so does pretyy much every other diesel...somethin bout carbon left in the exhaust or sumthin...not sure just wot i herd
  11. #9
    08-08-2008
    663
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    mine does it to.
+ Reply to Thread
