+ Reply to Thread
Results 1 to 3 of 3
Thread: Removing Battery
    19-10-2008
    Near portsmouth
    Age
    23
    603
    Removing Battery
    Anyone know how? can seem to see how to remove the plastic above it.
  2. #2
    02-04-2008
    Belgium
    Age
    30
    533
    Remove the screw on the left and the one in the middle of the plastic then slide it to the left and pull it forward. Might have to bend it a bit near the edge so u can get it out. You'll see when you try
  3. #3
    21-01-2006
    1,828
    to quote myself................................. as per usual on here..........................
    take off the rubber weather strip
    1 screw under the scuttle facing forward by the passenger wing T20/25
    pull the rain deflector up and pull it foward and it should come off
    unclip the cables running running across the scuttle (under the water deflector youve just removed)
    remove the screw at the top by where the deflector was
    lift up the scuttle start at the brake resivor end
    pull the bit of plastic that sits on top of the battery
    then its just a case of pulling the scuttle forward and up (sort of twists upwards)(bit above the battery)
    Doing the above just gives enough room to lift and twist the battery out (battery is held in place by a 13mm bolt that goes through the clamp)
+ Reply to Thread
