My Central locking has decided not to work properly..
Basically, when I open it, the locks come up and then go immediately back down.
If I open the driver's door manually then I can open the passenger's using the central locking.
It works fine when locking the car
I thought it could of been the battery but it works when locking the car?
get in the car turn the ignition on and press the lock button just as u have switched on the engine and it should reset it and work fine after that
i have done it and it has been working fine ever since
Instead of making a new thread I thought I'd bump this one, do you just have to press the lock button straight after you start the engine? How do you know of it's done anything?
Yer I'm a bit worried becuase I won't be able to unlock the petrol cap. It's o ly happened when I changed my door handles to colour coded ones so I'm not sure if something has come loose.
Umm haven't tried that, but when I open it with the key once it opens fine and then I can press the unlock button to iBook everything, would that suggest it's just a problem the drivers door?
im sure theyre controlled by a relay. try that, could be swicthing when its not meant to
