+ Reply to Thread
Results 1 to 12 of 12
Thread: Sub and Amp Advice Please Read First
    Koolaid_guy
    Right many threads are popping up now im after a sub and amp etc on budgets hopefully this should help with giving you advice on a budget sub and amp or choosing your own setup
    Choosing the correct subwoofer
    Choosing the subwoofer is important as is choosing everything else In an audio system
    When working on budgets you need to find the best power for price
    When choosing a sub most spec will consists of these headings
    ·Frequency Response
    ·Sensitivity/efficiency
    ·Impedance
    ·Power Handling, Peak
    ·Power Handling, RMS
    ·Mounting Depth
    Frequency Response
    The Frequency Response is the input signal of the subwoofer and what it can handle
    The response rating is from lowest and the highest of the subwoofer.
    The sensitivity is the measure of how loud the subwoofer is along side the efficiently of the sub woofer, so the higher the sensitivity the better the sub will as it will be more efficient in theory so if a sub has 89db and then a different sub has 93 the sub with 93 will be more efficient
    Impedance
    The impedance is the subs resistance, this is measured in ohms, (and reading ohms law will be very helpful). this is the current of the sub when wiring to an amp which is very important so if a amp is 4 ohm stable then the sub has to be 4 ohm stable as you CANT wire into 2 ohm as this means to much current will be fed to the sub and knacker your equipment.
    The peak power of the sub woofer is the maximum the sub can take at any given time.
    Power Handling, RMS
    This is the continuous power of the sub woofer, this is a rated power that the sub can handle so the higher the RMS the power powerful the sub is.
    Mounting Depth
    This is the depth the sub needs when being mounted in a enclosure
    Subwoofer wiring
    You can get 2 different types of subwoofer single voice coil and dual voice coil subs
    Single voice coil have one set of terminals
    Dual voice coil have two sets of terminals
    This means you can wire the dual voice coils in more ways than a single voice coil sub.
    Subwoofer Enclosures
    Right there are different types of enclosures these are
    ·Sealed
    ·Ported
    ·Bandbass
    The generic information about these boxes’s
    ·Sealed box — sealed box are a enclosure which are airtight. These are recommend for music that will require tight and accurate bass. Some say that a sealed box requires the sub to work harder which means it will require more power as there is no airflow to the sub
    ·Ported box — Ported box these a box with a vent (port) in them, this will allow are to move in and out of the enclosure. This air flow ,means that it can reinforce low bass response swell as getting more output from the enclosure.
    ·Bandpass box — Bandpass box’s these a a ported box designed for maximum performance. The sub is mounted inside the box where there is two sections inside a sealed and ported sections. The sound is forced from the sealed part into the port this can be configure to require frequencies.
    Selecting your amplifier
    When looking at sub and amp combos you need to make sure your amp will be able to power your sub at the given power ratings
    In my opinion monoblock is the best amp for powering subwoofers as these are designed to give out mono signals.
    A monoblock amp can power more than one sub, so in theory you can run two subs or more of one monoblock amp
    Basically then when looking at an amp you need to make sure it can power sub at a given RMS power
    You need to look for the correct impedance between the sub and amp
    So if the amp will support 4 ohm or 2 ohm loads then it would be best to get a sub that can be wired into on of these impedances.
    Ideas for budget subs and amps and suggestions here is some I have used/ seen recommended but at the end of the day it us you using the equipment and your choice on what you by these are just ideas
    http://caraudiosecurity.com/shop/product/products_id/4027.html
    http://caraudiosecurity.com/shop/product/products_id/3891.html
    http://caraudiosecurity.com/shop/product/products_id/4250.html
    This is a guide and if anything goes wrong when fitting or anything ever went wrong with a brand suggested this is a guide and suggestion therefore you are at your own risk, I am not liable to anything it is only a guide, if you are in doubt, ask/search around
    This can be left open for suggestions/discussions if i have missed anything let me know
    Cheers
    Mike
  2. #2
    17-02-2008
    Bath and sussex
    Age
    24
    1,795
    what about subwoofer sizing? i myself am actually curious, as to what size would handle what type of music better?
  3. #3
    15-02-2009
    Gourock
    Age
    22
    3,628
    Frequency Response
    The Frequency Response is the input OUTPUT? signal of the subwoofer and what it can handle
    The response rating is from lowest FREQUENCY? and the highest FREQUENCY? of the subwoofer.
    dont forget the use of the word frequency, confuses alot of folk
    and the response is the subs output, not input
  4. #4
    15-06-2010
    Grimsby
    Age
    20
    130
    How easy is it to wire a sub and amp up? Have the money to spend on a fairly decent set up just don't won't to blow the boat if I won't be able to do it.
  5. #5
    Koolaid_guy
    make a seperate thread buddy so can help further
  6. #6
    31-10-2011
    Blackpool
    Age
    21
    179
    if your after a budget sub go to a polish person...i can get a sub amp cd and wired up for 130 and its all top stuff but i already have an amazing sub
  7. #7
    Premier Member Corders's Avatar
    29-08-2010
    guildford, surrey
    Age
    23
    28,136
    Quote Originally Posted by joldrid View Post
    epic bump AND story bro
  8. #8
    Koolaid_guy
    what an idiot
  9. #9
    North West Organiser holtt's Avatar
    26-08-2009
    Cheshire/Leeds
    Age
    21
    17,839
    poles? do you build conservatories?
  10. #10
    07-03-2013
    Age
    21
    18
    What foes the LPF dial do on edge amplifiers
  11. #11
    Banned User
    23-03-2010
    Kent
    20,175
    Quote Originally Posted by Coops200691 View Post
    Nice bump
    I would make a new thread
  12. #12
    14-09-2010
    near Hindhead/Haslemere
    Age
    22
    3,645
    No point in using it on edge amps or subs tbh
+ Reply to Thread
