how do ya d the pedal test
User Tag List
+ Reply to Thread
Results 1 to 6 of 6
Thread: how do ya d the pedal test
    20-02-2009
    Bedlington near newcastle
    Age
    29
    151
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    as above how do u do it propley?? cheers
  2. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  3. #2
    12-09-2005
    in the trees
    Age
    30
    26,854
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by goodland View Post
    No need for Tech 2 or any sort of code readers and Most of Vauxhall dealers don’t know about this....
    Want to read the Code well first
    Take a deep breath get your car keys and get a pen and paper
    When you get into the car you know the key has 3 clicks first on for whatever it is second the dash comes on third the starter kicks in
    before you put the key into the ignition Make sure that you Press the Break and the Throttle to the Floor ( max
    Then turn the key on until The dash board come on and DONT START THE CAR
    Wait 2 sec and keep the pedals Down to the floor
    the service light under the management light should start flashing
    it will flash 4 times leaving 2 second space representing each number
    Zero gets 10 flashes
    for exampleP0110
    the light will flash ten times Break (2sec Or 1 not sure) then once, (2sec) once again, then ten
    if you have more than one code it will stop for a break then gives the next code
    its not a very useful way but helps when you dont want to go to the dealer for a lose socket
    this is for Corsa C the Newer models have even better way to tell you the code i think which is on your Mileage Display It will show ECN0 XXXX
    which is error code Number forget the zero and the last four digits is what you want
    and this works for an astra Too
    ive tested this on my own corsa and worked Very well
    however if you don’t have any code stored it will start Flashing and keeps on flashing until you release the paddles
    Then look at http://www.corsa-c.co.uk/forum/showthread.php?t=134139 to check the code.
  4. #3
    20-02-2009
    Age
    29
    151
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ty mate thats mint
  5. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  6. #4
    27-11-2009
    Age
    31
    6
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hi all ive just tried this on my misses 55plate corsa 1.3cdti and it wont work any ideas??
    i know there is a fault because if you floor it though all the gears in 3rd 4th and 5th completely random which gear it dose it in the service or management light will come on and the turbo won't boost..
  7. #5
    28-02-2009
    manchester
    2,267
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    it will work. press acccelerater and brake and hold them on and turn ignition on and count the flashes. if it doesnt get it code read
  8. #6
    27-11-2009
    Age
    31
    6
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    still not working?? ive tried it loads of times any reason why it wont work?
+ Reply to Thread
