How To De-Rubstrip/De-Badge...
67K views 153 replies 88 participants last post by  Itzkyky
#1 · (Edited)
There seems to be a billion threads on people wondering how to take off there rub strips and badges. Its pretty simple. There is already a tutorial on how to take off the badges on the back so I won't really go in to much detail regarding how to de-badge.
I CANNOT STRESS THIS ENOUGH, PLEASE HAVE PATIENCE WHILST DOING THIS AND DO NOT RUSH ANYTHING I LEARNT THE HARD WAY.
What you will need:
A hairdryer/heat gun (be careful with a heat gun however as this may damage your paint work),
Autoglym Intensive Bug and Tar Remover (£5.99ish),
A cloth or a rag of some sort,
A credit/debit card of some sort.
Firstly you want to be heating the rub strip with the hair dryer or whatever you are using. I normally heat it for about a minute but you can for up to about three minutes although be careful that you will not be damaging your paintwork. Get your card and place it behind the rub strip, pry it and hopefully the first bit of the rub strip will want to come off. Whilst heating it continue all the way down til you have done the whole strip you are taking off. TAKE YOUR TIME AS IF YOU PULL IT OFF WITH FORCE IT MAY RIP YOUR PAINTWORK APART.
You will now be left with glue residue. I tend to soak the glue residue in the bug and tar remover for about five minutes. This makes it so much easier to get the glue off. Just keeping going at it with your cloth and the remover and in time it will be gone. People may also choose to use vinegar, WD-40, petrol etc.
You may then notice that after you have taken the rub strip off and taken off all the glue residue it leaves you with a shade of white. This is condensation don't worry you have not damaged your paint. Pouring boiling water over it solves it eventually. Basically you want to apply heat to it by using a hair dryer or using the water. This will go within time as it is just condensation so if you want to call it a day you can. This does not happen over night however and may take weeks depending on the weather.
After all this you may still be able to see where the badges and/or the strips were, a good polishing of your car should sort it.
This tutorial can be applied for badges as well however there will be no condensation marks under your badges. Under the Vauxhall Griffin there will be two holes so be aware that you will have to fill these in if you choose to take off your griffin. Your rub strips and your other badges will not have anything under them.
Please take your time doing your rub strips as they have been known to rip paint off if done rapidly.
Some people also find that there cars have not been painted under the rub strips or that there are basically paint defects under there rub strips. This is a problem that can't really be sorted by yourself as it was previously painted wrong. A door will have to be replaced for around £70 second hand or a respray of about £150 professionally. Costly. An alternative method is to get new rub strips and colour code them to the same colour as your car. Thus protecting your door again and will be less noticeable however people may not find it as appealing.
Hope this helps, take you time doing your rub strips, heat the glue well before applying force to remove the rub strips.
Let me know if I have missed something.
See less See more
#10 ·
haha yeh thats why i did mine today (monday) so there werent so many people about while i was siting there with the hairdryer to it haha. couldnt believe how easy it was, i de-rubstripped mine about a month or so ago and just left it then last week i thought i would try the kettle but it didnt really do much then with the haridryer today you can litterally see it going as you do it :)
#37 ·
Yeah. They will be more vulnerable everywhere, not just in car parks. Just got to be careful when opening the doors and stuff.
thinking bout debadging and de-rubbing is it a long process have bought 5 hours to get them off and get all glue off wanna make it a thorough job so i just heat them up with a hairdryer and get a old crebit card under them to peel them off then get the glue off and polish like **** lol
5 hours should be enough haha.
hi im a girl so can i check b4 trying i cando it on a 2003 sri? shall i keep the sri badge? xx
Can do it on any car however there could be paint defects under the rub strips of certain cars.
to get the glue off within minutes, instead of using tar remover etc etc. use a fudge wheel; tool from snapon and other companys, a friend of mine knew i was having trouble. after an hour of trying i got half of the first strip off, he came round with it and within 5 minutes, it was all completely gone, wasn't left with any condensation :)
Thanks ;).
I assume it will be immediately obvious once you start de-rubstripping if there is no paint underneath? So I can just start a tiny bit on one side, and if it's clear there's no paint under there I can just leave it yes?
Yep. Just fix it back in place.
Arghhhh, been at it for at least two hours now and still have over a foot of glue to remove from one side. Havent even started on the other side yet!!!
Hahah. Takes a while!
You have insufficient privileges to reply here.
