Heater Blower only works on 4!
User Tag List
+ Reply to Thread
Results 1 to 12 of 12
Thread: Heater Blower only works on 4!
    15-08-2010
    4
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi can any help? We have a 04 corsa 1.0 energy and the heater blower only works on no.4.
    I have already bought a new heater resistor from vauxhall and after couple of months it blew again. I have managed to get this repaired and same has happened again. Not quite sure where to go now and what is causing the resistor to keep blowing! Could it be the heater motor wearing out?
    Any thoughts would be helpfull please!!
  2. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  3. #2
    24-03-2007
    Arlesey
    Age
    27
    898
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    replacement heater matrix?
  4. #3
    14-08-2008
    Mudflaps
    Age
    27
    17,392
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Hulbert99 View Post
    ouwch relativley expensive but sounds about right
  5. #4
    20-05-2007
    Milton Keynes
    Age
    33
    6,373
    Mentioned
    11 Post(s)
    Tagged
    0 Thread(s)
    Fail no, resistor packs gone much much cheaper and easier to replace!
  6. #5
    24-03-2007
    Arlesey
    Age
    27
    898
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Legoman View Post
    ahh yeh try that first! lol
  7. #6
    14-08-2008
    Mudflaps
    Age
    27
    17,392
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ah thats good news
  8. #7
    15-08-2010
    4
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    if the heater matrix has gone would it not leak? no sign of leaks. Bit relluctant to replace resistor again if its just going to blow again because of another fault.
  9. #8
    27-04-2007
    essex
    Age
    28
    364
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    could well be a faulty motor checked the wiring ?
  10. #9
    15-07-2009
    Age
    25
    342
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Got it
    It will be the resister pack, as speed 1,2 & 3 run through a resistor, whereas speed 4 is direct.
    Generally if its gone only speed 4 will work.
  11. #10
    15-08-2010
    4
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    bit relluctant to just put in another resistor pack as this will be the third pack! will check wiring to make sure nothing is shorting out causing resistor to blow again but think that is ok. have had a squealing noise coming from blower motor occasionally?
  12. #11
    28-02-2009
    manchester
    2,269
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    motor is seizeing causing the motor to draw too much current which is blowing the resistor/meliting the wires
  13. #12
    15-08-2010
    4
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Think need to strip out motor then!!! relatively easy???
+ Reply to Thread
