Vauxhall fault codes
User Tag List
+ Reply to Thread
Results 1 to 4 of 4
Thread: Vauxhall fault codes
    28-05-2008
    Stockport
    139
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I know there is already a post with these on but i have found a few more
    P1031 Heated Oxygen Sensor (HO2S) Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1
    P1032 Heated Oxygen Sensor (HO2S) Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1
    P1101 Actual measured airflow from MAF, MAP, EGR, and TP is not within range of the calculated airflow
    P1105 Secondary Vacuum Sensor Circuit
    P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
    P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
    P1108 BARO to MAP Sensor Comparison Too High
    P1109 Secondary Port Throttle System
    P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
    P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
    P1113 Intake Resonance Switchover Solenoid Control Circuit
    P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
    P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
    P1116 ECT Signal Unstable or Intermittent
    P1117 Engine Coolant Temp. Signal Out-Of-Range Low
    P1118 Engine Coolant Temp. Signal Out-Of-Range High
    P1119 ECT Signal Out-Of-Range With TFT Sensor
    P1120 Throttle Position (TP) Sensor 1 Circuit
    P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
    P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
    P1125 Accelerator Pedal Position (APP) System
    P1130 Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 1
    P1131 Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 2
    P1132 Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 2 Sensor 1
    P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
    P1134 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1
    P1135 Heated Oxygen Sensor (HO2S) Lean Mean Bank 1 Sensor 1
    P1136 Heated Oxygen Sensor (HO2S) Rich Mean Bank 1 Sensor 1
    P1137 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Lean System or Low Voltage
    P1138 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Rich or High Voltage
    P1139 Heated Oxygen Sensor (HO2S) Insuff. Switching Bank 1 Sensor 2
    P1140 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 2
    P1141 Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
    P1143 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Lean System or Low Voltage
    P1144 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Rich or High Voltage
    P1145 Heated Oxygen Sensor (HO2S) Cross Counts Bank 1 Sensor 3
    P1153 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
    P1154 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
    P1155 Heated Oxygen Sensor (HO2S) Lean Mean Bank 2 Sensor 1
    P1156 Heated Oxygen Sensor (HO2S) Rich Mean Bank 2 Sensor 1
    P1157 Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Lean System or Low Voltage
    P1158 Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Rich or High Voltage
    P1159 Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 2
    P1161 Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 2 Sensor 2
    P1163 Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Lean System or Low Voltage
    P1164 Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Rich or High Voltage
    P1165 Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 3
    P1170 Bank to Bank Fuel Trim Offset
    P1171 Fuel System Lean During Acceleration
    P1172 Fuel Transfer Pump Flow Insufficient
    P1185 Engine Oil Temperature Circuit
    P1186 EOT Circuit Performance
    P1187 EOT Sensor Circuit Low Voltage
    P1188 EOT Sensor Circuit High Voltage
    P1189 Engine Oil Pressure (EOP) Switch Circuit
    P1190 Engine Vacuum Leak
    P1191 Intake Air Duct Air Leak
    P1200 Injector Control Circuit
    P1201 (Alt. Fuel) Gas Mass Sensor Circuit Range/Performance
    P1202 (Alt. Fuel) Gas Mass Sensor Circuit Low Frequency
    P1203 (Alt. Fuel) Gas Mass Sensor Circuit High Frequency
    P1211 Mass Air Flow Circuit Intermittent High
    P1212 Mass Air Flow Circuit Intermittent Low
    P1214 Injection Pump Timing Offset
    P1215 Ground Fault Detection Indicated
    P1216 Fuel Solenoid Response Time Too Short
    P1217 Fuel Solenoid Response Time Too Long
    P1218 Injection Pump Calibration Circuit
    P1219 Throttle Position Sensor Reference Voltage
    P1220 Throttle Position (TP) Sensor 2 Circuit
    P1221 Fuel Pump Secondary Circuit Low
    P1222 Injector Control Circuit Intermittent
    P1225 Injector Circuit Cylinder 2 Intermittent
    P1228 Injector Circuit Cylinder 3 Intermittent
    P1231 Injector Circuit Cylinder 4 Intermittent
    P1234 Injector Circuit Cylinder 5 Intermittent
    P1237 Injector Circuit Cylinder 6 Intermittent
    P1240 Injector Circuit Cylinder 7 Intermittent
    P1243 Injector Circuit Cylinder 8 Intermittent
    P1245 Intake Plenum Switchover Valve
    P1250 Early Fuel Evaporation Heater Circuit
    P1257 Supercharger System Overboost
    P1258 Engine Coolant Overtemperature - above 268°F - Protection Mode Active
    P1260 Last Test Failed Failed SCC ENTER:More Info.
    P1270 Accelerator Pedal Position Sensor A/D Converter Error
    P1271 Accelerator Pedal Position (APP) Sensor 1-2 Correlation
    P1272 Accelerator Pedal Position Sensor 2
    P1273 Accelerator Pedal Position Sensor 1
    P1274 Injectors Wired Incorrectly
    P1275 Accelerator Pedal Position (APP) Sensor 1 Circuit
    P1276 Accelerator Pedal Position Sensor 1 Circuit Performance
    P1277 Accelerator Pedal Position Sensor 1 Circuit Low Voltage
    P1278 Accelerator Pedal Position Sensor 1 Circuit High Voltage
    P1280 Accelerator Pedal Position (APP) Sensor 2 Circuit
    P1281 Accelerator Pedal Position Sensor 2 Circuit Performance
    P1282 Accelerator Pedal Position Sensor 2 Circuit Low Voltage
    P1283 Accelerator Pedal Position Sensor 2 Circuit High Voltage
    P1285 Accelerator Pedal Position Sensor 3 Circuit
    P1286 Accelerator Pedal Position Sensor 3 Circuit Performance
    P1287 Accelerator Pedal Position Sensor 3 Circuit Low Voltage
    P1288 Accelerator Pedal Position Sensor 3 Circuit High Voltage
    P1300 Ignitor Circuit
    P1305 Ignition Coil 2 Primary Feedback Circuit
    P1310 Ignition Coil 3 Primary Feedback Circuit
    P1315 Ignition Coil 4 Primary Feedback Circuit
    P1320 IC 4X Reference Circuit Intermittent
    P1321 Electronic Ignition System Fault Line
    P1322 EI System or Ignition Control Extra or Missing
    P1323 IC 24X Reference Circuit Low Frequency
    P1324 Crank RPM Too Low
    P1325 CKP Circuit
    P1336 Crankshaft Position (CKP) System Variation Not Learned
    P1345 Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
    P1346 Intake Camshaft Position [CMP] Sensor System Performance
    P1350 Ignition Control System
    P1351 Ignition Coil Control Circuit High Voltage
    P1352 IC Output High/Pulse Detected when GND_Cyl. 2
    P1353 IC Output High/Pulse Detected when GND_Cyl. 3
    P1354 IC Output High/Pulse Detected when GND_Cyl. 4
    P1355 IC Output High/Pulse Detected when GND_Cyl. 5
    P1356 IC Output High/Pulse Detected when GND_Cyl. 6
    P1357 IC Output High/Pulse Detected when GND_Cyl. 7
    P1358 IC Output High/Pulse Detected when GND_Cyl. 8
    P1359 Ignition Coil Group 1 Control Circuit
    P1360 Ignition Coil Group 2 Control Circuit
    P1361 Ignition Coil Control Circuit Low Voltage
    P1362 IC Cylinder 2 Not Toggling After Enable
    P1363 IC Cylinder 3 Not Toggling After Enable
    P1364 IC Cylinder 4 Not Toggling After Enable
    P1365 IC Cylinder 5 Not Toggling After Enable
    P1366 IC Cylinder 6 Not Toggling After Enable
    P1367 IC Cylinder 7 Not Toggling After Enable
    P1368 IC Cylinder 8 Not Toggling After Enable
    P1370 IC 4X Reference Circuit Too Many Pulses
    P1371 IC 4X Reference Circuit Too Few Pulses
    P1372 Crankshaft Position (CKP) Sensor A-B Correlation
    P1374 3X Reference Circuit
    P1375 IC 24X Reference Circuit High Voltage
    P1376 Ignition Ground Circuit
    P1377 IC Cam Pulse To 4X Reference Pulse
    P1380 Misfire Detected - Rough Road Data Not Available
    P1381 Misfire Detected - No Communication with Brake Control Module
    P1390 Wheel Speed Sensor 1 - G - Sensor Circuit
    P1391 Wheel Speed Sensor 1 - G - Sensor Circuit Performance
    P1392 Wheel Speed Sensor 1 - G - Sensor Circuit Low Voltage
    P1393 Wheel Speed Sensor 1 - G - Sensor Circuit High Voltage
    P1394 Wheel Speed Sensor 1 - G - Sensor Circuit Intermittent
    P1395 Wheel Speed Sensor 2 - G - Sensor Circuit
    P1396 Wheel Speed Sensor 2 - G - Sensor Circuit Performance
    P1397 Wheel Speed Sensor 2 - G - Sensor Circuit Low Voltage
    P1398 Wheel Speed Sensor 2 - G - Sensor Circuit High Voltage
    P1399 Wheel Speed Sensor 2 - G - Sensor Circuit Intermittent
    P1403 Exhaust Gas Recirculation System Valve 1
    P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
    P1405 Exhaust Gas Recirculation System Valve 3
    P1406 EGR Valve Pintle Position Circuit
    P1407 EGR Air Intrusion in Exhaust Supply to EGR Valve
    P1408 Intake Manifold Pressure Sensor Circuit
    P1409 EGR Vacuum System Leak
    P1410 Fuel Tank Pressure System
    P1415 Secondary Air Injection (AIR) System Bank 1
    P1416 Secondary Air Injection (AIR) System Bank 2
    P1418 Secondary Air Injection System Relay A Control Circuit High
    P1420 Intake Air Low Pressure Switch Circuit Low Voltage
    P1421 Intake Air Low Pressure Switch Circuit High Voltage
    P1423 Intake Air High Pressure Switch Circuit High Voltage
    P1431 Fuel Level Sensor 2 Circuit Performance
    P1432 Fuel Level Sensor 2 Circuit Low Voltage
    P1433 Fuel Level Sensor 2 Circuit High Voltage
    P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
    P1442 EVAP Vacuum Sw. High Voltage During Ign. On
    P1450 Barometric Pressure Sensor Circuit
    P1451 Barometric Press. Sensor Performance
    P1460 Cooling Fan Control System
    P1480 Cooling Fan 1 Control Circuit High
    P1481 Cooling Fan Speed Sensor Circuit
    P1482 Cooling Fan Speed Output Circuit
    P1483 Engine Cooling System Performance
    P1484 Cooling Fan System Performance
    P1500 Starter Signal Circuit
    P1501 Theft Deterrent System
    P1502 Vehicle Speed Sensor Circuit Intermittent
    P1503 Theft Deterrent Fuel Enable Signal Not Received
    P1504 Theft Deterrent Fuel Enable Signal Not Correct
    P1505 Vehicle Speed Output Circuit
    P1508 Idle Speed Low - Idle Air Control (IAC) System Not Responding
    P1509 Idle Speed High - Idle Air Control (IAC) System Not Responding
    P1510 Throttle Control System Performance - Throttle Limitation Active
    P1511 Throttle Control System - Backup System Performance
    P1514 Airflow to TP Sensor Correlation High
    P1515 Electronic Throttle System Throttle Position
    P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
    P1517 Electronic Throttle Module
    P1518 Electronic Throttle Module to PCM Communication
    P1519 Throttle Actuator Control (TAC) Module Internal Circuit
    P1520 Transmission Range Switch Circuit
    P1521 Transmission Engaged at High Throttle Angle
    P1522 Park/Neutral to Drive/Reverse at High RPM
    P1523 Throttle Closed Position Performance
    P1524 Throttle Closed Position Performance
    P1525 Throttle Body ServiceRequired
    P1526 Minimum Throttle Position Not Learned
    P1527 Transmission Range to Pressure Switch Correlation
    P1528 Governor
    P1529 Heated Windshield Request Problem
    P1530 Throttle Actuator Control (TAC) Module Internal Circuit
    P1531 A/C Low Side Temperature Sensor Fault
    P1532 A/C Evaporator Temp. Sens. Circuit Low Voltage
    P1533 A/C Evaporator Temp. Sens. Circuit High Voltage
    P1534 A/C High Side Temp. Sensor Low Voltage
    P1535 A/C High Side Temperature Sensor Circuit
    P1536 Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled
    P1537 A/C Request Circuit Low Voltage
    P1538 A/C Request Circuit High Voltage
    P1539 A/C Clutch Status Circuit High Voltage
    P1540 Air Conditioning (A/C) Refrigerant Overpressure - Air Conditioning (A/C) Disabled
    P1541 A/C High Side Over Temperature
    P1542 A/C System High Pressure High Temperature
    P1543 A/C System Performance
    P1544 A/C Refrigerant Condition Very Low
    P1545 Air Conditioning (A/C) Clutch Relay Control Circuit
    P1546 A/C Clutch Status Circuit Low Voltage
    P1547 A/C System Performance Degraded
    P1548 A/C Recirculation Circuit
    P1551 Throttle Valve Rest Position Not Reached During Learn
    P1554 Cruise Control Feedback Circuit
    P1555 Electronic Variable Orifice Output
    P1558 Cruise Control Servo Indicates Low
    P1559 Cruise Control Power Management Mode
    P1560 Transaxle Not in Drive - Cruise Control Disabled
    P1561 Cruise Vent Solenoid
    P1562 Cruise Vacuum Solenoid
    P1563 Cruise Vehicle Speed/Set Speed Difference Too High
    P1564 Vehicle Acceleration Too High - Cruise Control Disabled
    P1565 Cruise Servo Position Sensor
    P1566 Engine RPM Too High - Cruise Control Disabled
    P1567 Active Banking Control Active - Cruise Control Disabled
    P1568 Cruise Servo Stroke Greater than Commanded in Cruise
    P1569 Cruise Servo Stroke High While not in Cruise
    P1570 Traction Control Active - Cruise Control Disabled
    P1571 Traction Control Torque Request Circuit
    P1572 ASR Active Circuit Low Too Long
    P1573 PCM/EBTCM Serial Data Circuit
    P1574 Stoplamp Switch Circuit
    P1575 Extended Travel Brake Switch Circuit
    P1576 BBV Sensor Circuit High Voltage
    P1577 BBV Sensor Circuit Low Voltage
    P1578 BBV Sensor Circuit Low Vacuum
    P1579 P/N to D/R at High Throttle Angle - Power Reduction Mode Active
    P1580 Cruise Move Circuit Low Voltage
    P1581 Cruise Move Circuit High Voltage
    P1582 Cruise Direction Circuit Low Voltage
    P1583 Cruise Direction CircuitHigh Voltage
    P1584 Cruise Control Disabled
    P1585 Cruise Control Inhibit Output Circuit
    P1586 Cruise Control Brake Switch 2 Circuit
    P1587 Cruise Control Clutch Control Circuit Low
    P1588 Cruise Control Clutch Control Circuit High
    P1599 Engine Stall or Near Stall Detected
    P1600 TCM Internal Watchdog Operation
    P1601 Serial Comm. Problem With Device 1
    P1602 Knock Sensor (KS) Module Performance
    P1603 Loss of SDM Serial Data
    P1604 Loss of IPC Serial Data
    P1605 Loss of HVAC Serial Data
    P1606 Serial Communication Problem With Device 6
    P1607 Serial Communication Problem With Device 7
    P1608 Serial Communication Problem With Device 8
    P1609 Loss Of TCS Serial Data
    P1610 Loss of PZM Serial Data
    P1611 Loss of CVRTD Serial Data
    P1612 Loss of IPM Serial Data
    P1613 Loss of DIM Serial Data
    P1614 Loss of RIM Serial Data
    P1615 Loss of VTD Serial Data
    P1617 Engine Oil Level Switch Circuit
    P1619 Engine Oil Life Monitor Reset Circuit
    P1620 Low Coolant Circuit
    P1621 Control Module Long Term Memory Performance
    P1622 Cylinder Select
    P1623 Transmission Temp Pull-Up Resistor
    P1624 Customer Snapshot Requested - Data Available
    P1625 TCM System Reset
    P1626 Theft Deterrent Fuel Enable Signal Not Received
    P1627 A/D Performance
    P1628 ECT Pull-Up Resistor
    P1629 Theft Deterrent System - Cranking Signal
    P1630 Theft Deterrent Learn Mode Active
    P1631 Theft Deterrent Start Enable Signal Not Correct
    P1632 Theft Deterrent Fuel Disable Signal Received
    P1633 Ignition 0 Switch Circuit
    P1634 Ignition 1 Switch Circuit
    P1635 5 Volt Reference Circuit
    P1636 PCM Stack Overrun
    P1637 Generator L-Terminal Circuit
    P1638 Generator F-Terminal Circuit
    P1639 5 Volt Reference 2 Circuit
    P1640 Driver-1-Input High Voltage
    P1641 Malfunction Indicator Lamp (MIL) Control Circuit
    P1642 Vehicle Speed Output Circuit
    P1643 Engine Speed Output Circuit
    P1644 Traction Control Delivered Torque Output Circuit
    P1645 Evaporative Emission (EVAP) Vent Solenoid Contorl Circuit
    P1646 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
    P1647 Driver 1 Line 7
    P1650 Control Module Output B Circuit
    P1651 Fan 1 Relay Control Circuit
    P1652 Powertrain Induced Chassis Pitch Output Circuit
    P1653 Oil Level Lamp Control Circuit
    P1654 Cruise Control Inhibit Output Circuit
    P1655 EVAP Purge Solenoid Control Circuit
    P1656 Driver 2 Line 6
    P1657 1-4 Upshift Solenoid Control Circuit
    P1658 Starter Enable Relay Control Circuit
    P1660 Cooling Fan Control Circuits
    P1661 MIL Control Circuit
    P1662 Cruise Lamp Control Circuit
    P1663 Oil Life Lamp Control Circuit
    P1664 1-4 Upshift Lamp Control Circuit
    P1665 Driver 3 Line 5
    P1666 Driver 3 Line 6
    P1667 Reverse Inhibit Solenoid Control Circuit
    P1669 ABS Unit Expected
    P1670 Driver 4
    P1671 Driver 4 Line 1
    P1672 Low Engine Oil Level Lamp Control Circuit
    P1673 Engine Hot Lamp Control Circuit
    P1674 Tachometer Control Circuit
    P1675 EVAP Vent Solenoid Control Circuit
    P1676 Driver 4 Line 6
    P1677 Driver 4 Line 7
    P1680 Driver 5 (ECU Malfunction)
    P1681 Driver 5 Line 1
    P1682 Driver 5 Line 2
    P1683 Driver 5 Line 3
    P1684 Driver 5 Line 4
    P1685 Driver 5 Line 5
    P1686 Driver 5 Line 6
    P1687 Driver 5 Line 7
    P1689 Delivered Torque Circuit Fault
    P1690 ECM Loop Overrun
    P1691 Coolant Gage Circuit Low Voltage
    P1692 Coolant Gage Circuit High Voltage
    P1693 Tachometer Circuit Low Voltage
    P1694 Tachometer Circuit High Voltage
    P1695 Remote Keyless Entry Circuit Low
    P1696 Remote Keyless Entry Voltage High
    P1700 Transmission Control Module (TCM) Requested MIL Illumination
    P1701 Trans. MIL Request Circuit
    P1705 P/N Signal Output Circuit
    P1719 Incorrect Shifting Detected (TCM)
    P1740 Torque Reduction Signal Circuit
    P1743 TP Signal from ECM
    P1760 TCM Supply Voltage Interrupted
    P1779 Engine Torque Delivered to TCM Signal
    P1780 Park/Neutral Position [PNP] Switch Circuit
    P1781 Engine Torque Signal Circuit
    P1790 Transmission Control Module Checksum
    P1791 Transmission Control Module Loop
    P1791 Throttle/Pedal Position Signal (2000+)
    P1792 Transmission Control Module Reprogrammable Memory
    P1792 ECM to TCM Engine Coolant Signal
    P1792 Transmission Control Module Stack Overrun
    P1793 Wheel Speed Signal (2000+)
    P1795 CAN Bus - Throttle Body Position
    P1800 TCM Power Relay Control Circuit
    P1801 Performance Selector Switch Failure
    P1804 Ground Control Relay
    P1810 TFP Valve Position Switch Circuit
    P1811 Maximum Adapt and Long Shift
    P1812 Transmission Over Temperature Condition
    P1813 Torque Control
    P1814 Torque Converter Overstressed
    P1815 Transmission Range Switch - Start In Wrong Range
    P1816 TFP Valve Position Sw. - Park/Neu. With Drive Ratio
    P1817 TFP Valve Position Sw. - Reverse With Drive Ratio
    P1818 TFP Valve Position Sw. - Drive Without Drive Ratio
    P1819 Internal Mode Switch - No Start\Wrong Range
    P1820 Internal Mode Switch Circuit A Low
    P1822 Internal Mode Switch Circuit B High
    P1823 Internal Mode Switch Circuit P Low
    P1825 Internal Mode Switch - Invalid Range
    P1826 Internal Mode Switch Circuit C - High
    P1831 Pressure Control (PC) Solenoid Power Circuit - Low Voltage
    P1832 Pressure Control (PC)/Shift Lock Solenoid Control Circuit High Voltage
    P1833 A/T Solenoids Power Circuit - Low Voltage
    P1834 Torque Converter Clutch (TCC)/Shift Solenoid (SS) Control Circuit High Voltage
    P1835 Kick-Down Switch Circuit
    P1836 Kick-Down Switch Failed Open
    P1837 Kick-Down Switch Failed Short
    P1842 1-2 Shift Solenoid Circuit Low Voltage
    P1843 1-2 Shift Solenoid Circuit High Voltage
    P1844 Torque Reduction Signal Circuit Desired By TCM
    P1845 2-3 Shift Solenoid Circuit Low Voltage
    P1847 2-3 Shift Solenoid Circuit High Voltage
    P1850 Brake Band Apply Solenoid Circuit
    P1851 Brake Band Apply Solenoid Performance
    P1852 Brake Band Apply SolenoidLow Voltage
    P1853 Brake Band Apply Solenoid High Voltage
    P1860 TCC PWM Solenoid Circuit Electrical
    P1864 Torque Converter Clutch Circuit
    P1865 4-5 Shift Solenoid (SS) Valve Control Circuit High Voltage
    P1866 Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit Low Voltage
    P1867 Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit High Voltage
    P1868 Transmission Fluid Life
    P1870 Transmission Component Slipping
    P1871 Undefined Gear Ratio
    P1873 TCC Stator Temp. Switch Circuit Low
    P1874 TCC Stator Temp. Switch Circuit High
    P1875 4WD Low Switch Circuit Electrical
    P1884 TCC Enable/Shift Light Circuit
    P1886 Shift Timing Solenoid
    P1887 TCC Release Switch Circuit
    P1890 ECM Data Input Circuit
    P1890 Throttle Position Signal Input
    P1891 Throttle Position Sensor PWM Signal Low
    P1892 Throttle Position Sensor PWM Signal High
    P1893 Engine Torque Signal Low Voltage
    P1894 Engine Torque Signal High Voltage
    P1895 TCM to ECM Torque Reduction Circuit
    P2008 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit
    P2009 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit Low Voltage
    P2010 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit High Voltage
    P2066 Fuel Level Sensor 2 Performance
    P2067 Fuel Level Sensor 2 Circuit Low Voltage
    P2068 Fuel Level Sensor 2 Circuit High Voltage
    P2096 Post Catalyst Fuel Trim System Low Limit
    P2097 Post Catalyst Fuel Trim System High Limit
    P2098 Post Catalyst Fuel Trim System Low Limit
    P2099 Post Catalyst Fuel Trim System High Limit
    P2100 Throttle Actuator Control (TAC) Motor Control Circuit
    P2101 Control Module Throttle Actuator Position Performance
    P2105 Throttle Actuator Control (TAC) System - Forced Engine Shutdown
    P2107 Throttle Actuator Control (TAC) Module Internal Circuit
    P2108 Throttle Actuator Control (TAC) Module Performance
    P2119 Throttle Closed Position Performance
    P2120 Accelerator Pedal Position (APP) Sensor 1 Circuit
    P2121 Accelerator Pedal Position (APP) Sensor 1 Performance
    P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
    P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
    P2125 Accelerator Pedal Position (APP) Sensor 2 Circuit
    P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
    P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage
    P2135 Throttle Position (TP) Sensor 1-2 Correlation
    P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation
    P2176 Minimum Throttle Position Not Learned
    P2500 Generator L-Terminal Circuit Low Voltage
    P2501 Generator L-Terminal Circuit High Voltage
    P2535 Ignition 1 Switch Circuit High Voltage (PCM)
    P2610 ECU Malfunction
    P2763 Short to voltage in the TCC Solenoid
    P2764 Open or Short to ground in the TCC PWM solenoid valve circuit
    P2A00 HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 1 (PCM)
    P2A01 HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 2 (PCM)
    P3000 Hacking AWH Data
  2. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  3. #2
    Wales Organiser mike0491's Avatar
    24-08-2009
    Costa Del Swansea
    Age
    26
    50,216
    Mentioned
    22 Post(s)
    Tagged
    0 Thread(s)
    Basically just the more awkward way of reading the other thread.
    South Wales Regional Organiser
    Xbox GT: mike0491
    Corsa C 1.0 Life - 2009-2011 | Corsa C 1.2 SXi twinport - 2011-2012 | Corsa C 1.8 SRi - 2012-2013 | Astra G 2.0DTi Dec 2012 lol | Astra GSi Turbo - 2013 - 2014 | Corsa C 1.8 SRi again 2014 - present | Astra H VXR - 2016 - present
  4. #3
    28-05-2008
    Stockport
    139
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    'Basically' not more awkward, just more info
  5. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  6. #4
    27-09-2010
    Madrid
    Age
    48
    9
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for that - I get 1607 and 1731 back from Opel - You list above outlines what P1607 is but I dont know about P1731??? any ideas? Cheers
+ Reply to Thread
