Rebuilding Hydraulic Lifter
User Tag List
+ Reply to Thread
Results 1 to 3 of 3
Thread: Rebuilding Hydraulic Lifter
    03-10-2010
    Age
    24
    13
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Took the hydraulic lifters out of my 1.4 corsa engine.
    Wanted to no if they can be taken apart and cleaned
    Also, when they are put back into the engine do they need to be soaked in oil before they go in the engine etc.
  2. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  3. #2
    17-02-2010
    Stevenage
    1,657
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you can,t take them apart, just pump them/ compress them to get rid of old oil, then imerse them in clean oil and pump them to fill them up and let them soak overnight then replace in engine , they will be fully primed with clean oil .
  4. #3
    27-05-2009
    Stirling, Scotland
    Age
    26
    5,394
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Manually pump the engine over a fewtimes so it has some oil lubrication before firing so it doesn't seize
+ Reply to Thread
