vauxhall fault codes
User Tag List
+ Reply to Thread
Results 1 to 4 of 4
Thread: vauxhall fault codes
    05-09-2010
    Age
    28
    38
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i know there is a list on here which i have copied but i just wondered if anyone has or knows of any more
    also any other makes
    thanks
  2. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  3. #2
    27-10-2006
    Audi A3 2.0
    Age
    30
    23,049
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    P0030 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 1) C-29
    P0036 O2 Sensor Heater Circuit Range/Performance (Bank 1 Sensor 2) C-31
    P0100 Mass or volume air flow circuit high input C-10
    P0100 Mass or volume air flow circuit low input C-10
    P0110 Intake Air Temperature Circuit High Input C-12
    P0110 Intake Air Temperature Circuit Low Input C-12
    P0115 Engine Coolant Temperature Circuit High Input C-11
    P0115 Engine Coolant Temperature Circuit Low Input C-11
    P0115 Engine coolant temperature circuit malfunction C-11
    P0120 Throttle Position Sensor (TPS) Circuit 1 Voltage High C-09
    P0120 Throttle Position Sensor (TPS) Circuit 1 Voltage Low C-09
    P0120 Throttle Position Sensor 1-2 Correlation C-09
    P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) C-30
    P0130 O2 Sensor 1 Circuit Voltage Low C-30
    P0130 O2 Sensor 1 Open Circuit C-30
    P0130 O2 Sensor 1 Incorrect Signal C-30
    P0134 O2 Sensor Circuit Open (Bank 1 Sensor 1) C-30
    P0135 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) C-29
    P0135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) C-29
    P0135 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) C-29
    P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-32
    P0136 O2 Sensor 2 Circuit Voltage Low C-32
    P0136 O2 Sensor 2 Open Circuit C-32
    P0139 O2 Sensor 1 Incorrect Signal C-30
    P0140 O2 Sensor 2 Incorrect Signal C-32
    P0141 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2) C-31
    P0141 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) C-31
    P0141 O2 Sensor Heater Circuit Open (Bank 1 Sensor 2) C-31
    P0170 Rich Exhaust C-30
    P0170 Lean Exhaust C-30
    P0201 Cylinder 1 injector circuit high C-23
    P0201 Cylinder 1 injector circuit low C-23
    P0201 Cylinder 1 Injector Circuit Open C-23
    P0202 Cylinder 2 injector circuit high C-24
    P0202 Cylinder 2 injector circuit low C-24
    P0202 Cylinder 2 Injector Circuit Open C-24
    P0203 Cylinder 3 injector circuit high C-25
    P0203 Cylinder 3 injector circuit low C-25
    P0203 Cylinder 3 Injector Circuit Open C-25
    P0204 Cylinder 4 injector circuit high C-26
    P0204 Cylinder 4 injector circuit low C-26
    P0204 Cylinder 4 Injector Circuit Open C-26
    P0219 Engine overspeed condition C-43
    P0220 Throttle Position Sensor (TPS) Circuit 2 Voltage High C-09
    P0220 Throttle Position Sensor (TPS) Circuit 2 Voltage Low C-09
    P0220 Throttle Position Sensor 1-2 Correlation C-09
    P0230 Fuel pump secondary circuit high C-07
    P0230 Fuel Pump Relay Open Circuit C-07
    P0300 Misfire Unidentified Cylinder Detected B-21
    P0301 Cylinder 1 Misfire Detected B-22
    P0302 Cylinder 2 Misfire Detected B-22
    P0303 Cylinder 3 Misfire Detected B-22
    P0304 Cylinder 4 Misfire Detected B-22
    P0325 Knock Sensor 1 Circuit no Signal C-27
    P0335 Crankshaft Sensor Incorrect Signal C-06
    P0335 Crankshaft Sensor Open Circuit C-06
    P0340 Camshaft Position Sensor Circuit No Signal C-13
    P0340 Camshaft Sensor Incorrect Signal C-13
    P0351 Ignition Coil 1 High Input B-23
    P0351 Ignition Coil 1 Incorrect Signal B-23
    P0352 Ignition Coil 2 High Input B-23
    P0352 Ignition Coil 2 Incorrect Signal B-23
    P0353 Ignition Coil 3 High Input B-23
    P0353 Ignition Coil 3 Incorrect Signal B-23
    P0354 Ignition Coil 4 High Input B-23
    P0354 Ignition Coil 4 Incorrect Signal B-23
    P0420 Catalyst Efficiency Above Threshold C-31
    P0443 Evaporative emission control system purge control valve circuit shorted C-28
    P0443 Evaporative emission control system purge control valve circuit open C-28
    P0460 Fuel Level Sensor Circuit High Input C-14
    P0460 Fuel Level Sensor Circuit Low Input C-14
    P0460 Purge flow sensor circuit malfunction C-14
    P0500 Vehicle speed sensor malfunction B-10
    P0530 A/C Refrigerant Pressure Sensor Circuit High Input Air Conditioning System B-05
    P0530 A/C Refrigerant Pressure Sensor Circuit Open Air Conditioning System B-05
    P0560 System Voltage High Input C-04
    P0560 System Voltage Low Input C-04
    P0565 Cruise Control SET and RESUME active C-17
    P0566 Cruise Control Off Signal Circuit no or Incorrect Signal C-17
    P0567 Cruise Control Resume Signal High Input C-17
    P0568 Cruise Control Set Signal Circuit High Input C-17
    P0571 Brake Switch Circuit Low Input C-15
    P0602 Powertrain Control Module Not Programmed C-02
    P0602 Security Code Not Programmed C-02
    P0602 Vehicle Identification Number Not Programmed C-02
    P0602 Variant-Coding Not Programmed C-02
    P0606 Control Unit Re-Initialisation C-02
    P0650 Malfunction Indicator (MI) Control Circuit High C-36
    P0650 Malfunction Indicator (MI) Control Circuit Open C-36
    P0700 EOBD Error stored by Transmission Control (TC) Modul B-06
    P0700 MIL request from Transmission Control (TC) Modul B-06
    P0704 Clutch Switch Input Circuit High Input C-16
    P1110 Variable Intake Manifold Signal High C-33
    P1110 Variable Intake Manifold Signal Low C-33
    P1110 Variable Intake Manifold Open Circuit C-33
    P1120 Accelerator Pedal Position Sensor 1 High Input C-08
    P1120 Accelerator Pedal Position Sensor 1 Low Input C-08
    P1120 Accelerator Pedal Position Sensor 1-2 Correlation C-08
    P1122 Accelerator Pedal Position Sensor 2 High Input C-08
    P1122 Accelerator Pedal Position Sensor 2 Low Input C-08
    P1130 O2 Sensor 1 Signal Out of Range C-30
    P1130 O2 Sensor 1 Signal no Activity detected C-30
    P1130 O2 Sensor 1 Signal Switching Time Error C-30
    P1170 System too rich (Bank 1) C-30
    P1170 System too lean (Bank 1) C-30
    P1230 Main Relay Circuit Voltage High C-03
    P1230 Main Relay Open Circuit C-03
    P1326 Knock Control Maximum Spark Limit Cylinder 1 C-27
    P1327 Knock Control Maximum Spark Limit Cylinder 2 C-27
    P1328 Knock Control Maximum Spark Limit Cylinder 3 C-27
    P1329 Knock Control Maximum Spark Limit Cylinder 4 C-27
    P1372 Crankshaft Sensor Segment Error C-06
    P1372 Crankshaft Sensor Adaption Error C-06
    P1481 Fan Relay 1 Circuit High C-34
    P1481 Fan Relay 1 Signal Low / Open Circuit C-34
    P1482 Fan Relay 2 Circuit High C-34
    P1482 Fan Relay 2 Signal Low / Open Circuit C-34
    P1500 Electronic Throttle Control Motor Failure C-09
    P1520 Powerstage Currentless C-02
    P1525 Limp Home Position Error C-09
    P1526 Throttle Position Adaption Error C-09
    P1526 Throttle Position no Adaption C-09
    P1526 Limp Home Adaption Error C-09
    P1526 Lower Limit Adaption Error C-09
    P1530 A/C Relay Voltage High Air Conditioning System B-10
    P1530 A/C Relay Circuit Open Air Conditioning System B-10
    P1540 Air Conditioning Pressure Invalid Signal Air Conditioning System B-10
    P1540 Air Conditioning Pressure Signal High Input Air Conditioning System B-05
    P1540 Air Conditioning Pressure Signal Low Input Air Conditioning System B-10
    P1540 Air Conditioning Pressure Open Circuit Air Conditioning System B-05
    P1550 Electronic Throttle Control Reduced Power C-09
    P1550 Electronic Throttle Control Forced Idle C-09
    P1550 Electronic Throttle Control Power Management C-09
    P1550 Electronic Throttle Control Engine Stop C-09
    P1551 Engine Torque Always Higher Than Expected C-02
    P1555 Throttle Position Sensor (TPS) Load Signal not Plausible with Engine Load C-09
    P1600 Reprogram or Replace Electronic Control Unit (ECU) C-02
    P1606 Replace Electronic Control Unit (ECU) C-02
    P1610 Security Code Not Programmed Immobiliser B-07
    P1611 Wrong Security Code Entered Immobiliser C-02
    P1612 Immobiliser No Or Wrong Signal Immobiliser C-05
    P1613 Immobiliser No Or Wrong Signal Immobiliser C-05
    P1614 Wrong Security Code received Immobiliser C-06
    P1615 Wrong Vehicle ID from Body Control Module C-40
    P1616 Wrong Vehicle ID from Instrument Control Module C-40
    P1650 Service Vehicle Soon Light Voltage High C-37
    P1650 Service Vehicle Soon Light Voltage Low C-37
    P1700 SVS request via CAN B-06
    U2100 CAN-BUS Malfunction C-05
    U2101 CAN-BUS Maximum Configuration List not Programmed C-05
    U2104 CAN-BUS reset counter overrun C-05
    U2106 CAN-BUS no Communication with TCM B-05
    U2108 CAN-BUS no Communication with ABS/TC B-08
  4. #3
    05-09-2010
    Age
    28
    38
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    these are the ones i have but thanks anyway
    are there any more ?
  5. #4
    21-04-2006
    Coventry
    Age
    30
    46,422
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Those arn't vauxhall codes anyway. they are generic canbus codes.
    http://www.obd-codes.com/
+ Reply to Thread
