Torque settings
User Tag List
+ Reply to Thread
Results 1 to 22 of 22
Thread: Torque settings
    27-05-2008
    6
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Torque settings
    Hi,
    Can anybody tell me the torque settings for the following components on a 52plate 1.2
    lower wishbone/hub pinch bolt???
    track rod end???
    brake carrier to hub (torx)???
    brake calliper to carrier???
    Droplink to strut???
    I also need these, I think I have found some of them already if anybody could confirm them that would be great.
    Upper strut mounting nut: 50Nm
    Strut to hub bolts: Stage 1 80Nm - Stage 2 60 degrees - Stage 3 15 degrees.
    Front hub nut: 120Nm -> Loosen -> 20Nm -> 90 degrees
    Thanks in advance
  2. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  3. #2
    27-05-2008
    6
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Anybody?
  4. #3
    27-07-2007
    King's Lynn
    Age
    28
    1,205
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've been a mechanic for 7 years and the only thing I torque up is cylinder head bolts. Just do them tight mate
  5. #4
    19-03-2010
    17,306
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by SRi_G View Post
    Never taking my car to your garage
  6. #5
    27-07-2007
    King's Lynn
    Age
    28
    1,205
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Never had anything fall off
  7. #6
    19-03-2010
    17,306
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That all of them?
  8. #7
    28-02-2009
    manchester
    2,269
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    this. but i torque wheels aswell
  9. #8
    15-11-2006
    Clacton,Essex
    11,360
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ive worked in or alongside many garages and as stated above headbolts are about the only thing that gets torqued up to a required setting.
    We dont do mechanics though just for the record.
  10. #9
    23-08-2010
    West London
    Age
    26
    520
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Making good use of the pdf I see
  11. #10
    19-03-2010
    17,306
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Vulture View Post
  12. #11
    27-07-2007
    King's Lynn
    Age
    28
    1,205
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MancMark View Post
    Air gun on 2, tighten them till it stops
  13. #12
    27-07-2007
    King's Lynn
    Age
    28
    1,205
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  14. #13
    27-05-2008
    6
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lawis, thanks for your help, that is ideal! In the end due to time constraints I had to go ahead and take a guesstimate on the wishbone and droplink, and I picked 70Nm so that's not so bad, but good to have it confirmed anyway. Just put in two new wheel bearings and [yet another] spring, bit odd for a car that has only done 50k, but I'm told they like their springs.
    As for torquing bolts, joking aside, it is fairly crucial, especially on suspension and braking components. A lot of design and testing goes in to selecting the correct torque figure for a bolt, based on the type of bolt, thickness, hardness, yeild, and purpose. Not really the sort of thing you want to be just guessing if you can help it.
    Obviously not very important when it comes to securing bits of trim or bodywork, but for instance things like main bearing caps will actually stretch the bolts under normal operation, there is a finite range at which the fastener is elastic enough to accommodate the stresses and yet secure enough not to come loose.
    Alloy wheels are another good example of something that should be torqued, seen quite a few sheered studs and bolts and broken locking nuts as a result of airwrench use. Certainly stuffs anybody changing their wheel at the side of the road in an emergency.
  15. #14
    29-05-2008
    Stirlingshire
    Age
    26
    7,602
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    get yourself a haynes manual bud, everythings in there
  16. #15
    30-09-2010
    Letchworth
    4,647
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just hand tighten my alloys then jump on the bar
  17. #16
    27-07-2007
    King's Lynn
    Age
    28
    1,205
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lol at you telling me to torque things up.
  18. #17
    27-05-2008
    6
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Lockeh
    I'm actually hoping to sell the car shortly, so hopefully won't be needed. I used to have autodata, but I tend to only concentrate on one brand thesedays (not vauxhalls ) and use the factory workshop manuals which I find better than they Haynes. I'm guessing Lawis's scan looks like one for the Corsa C.
    Its not been a bad little runabout really but time to move on I think.
    lol, well somebody has to
  19. #18
    19-03-2010
    17,306
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've got a PDF of a haynes manual, PM me if you want it
  20. #19
    04-09-2011
    Parkgate
    Age
    39
    100
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Lawis. View Post
    That all of them?
    Just what I was looking for!! Fitting a new hub to my wee C
  21. #20
    05-02-2010
    middlesbrough
    Age
    30
    1,207
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have fitted hundreds If not thousands of drop links, arms, pinch bolts etc... Over the years as I'm a mechanic myself and you don't need to torque the bolts just make sure they are tight. I don't know any garage small or main dealers that would.
  22. #21
    27-03-2012
    middlesbrough
    Age
    49
    7,825
    Mentioned
    30 Post(s)
    Tagged
    0 Thread(s)
    Same here.
  23. #22
    20-05-2012
    Oxford
    Age
    44
    686
    Mentioned
    18 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by null_byte View Post
    I agree with this.
    that's why the rest of you who don't torque fasteners up are just stuck being mechanic's
+ Reply to Thread
