Immobiliser problem
User Tag List
+ Reply to Thread
Results 1 to 13 of 13
Thread: Immobiliser problem
    27-06-2011
    WS10
    Age
    26
    13
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Immobiliser problem
    At no specific time or under any specific circumstances my immobiliser is kicking in, car starts runs for a few seconds and cuts out, then won't start afterwards. I have to get out the car lock it, wait for the immobiliser to reset about 15 minutes and get back in and starts fine. Fuel pumps are priming and everything.
    Noticed I've been using the second key so now have both keys with me just incase it happens again.
    Anybody got any ideas?
    Car is 03 plate 1.8 sri
  2. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  3. #2
    22-03-2008
    hartford, northwich
    1,375
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    have you had your battery tested?
  4. #3
    27-06-2011
    WS10
    Age
    26
    13
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not as of yet it only starting happening yesterday. The battery doesn't seem to sound like it's being drained when the starter motor is turning over
  5. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  6. #4
    22-03-2008
    hartford, northwich
    1,375
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    when you say it doesnt start back up is there any sounds/noices?
  7. #5
    27-06-2011
    WS10
    Age
    26
    13
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well it's the starter motor is turning over but the engine isn't starting,which is u believe what happens when the immobiliser is engaged( cuts fuel supply off)
  8. #6
    14-07-2009
    Chesterfield/Sheffield.
    8,679
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It may be the battery in your Key? when was it last changed?
  9. #7
    14-02-2011
    Preston
    530
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That's not the immobiliser. Unless it's aftermarket.
    Factory immobiliser allows the engine to run for a couple of seconds then cuts the ignition if it doesn't detect the right key, you also get a flashing warning light on the dash.
  10. #8
    27-06-2011
    WS10
    Age
    26
    13
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by reggit View Post
    That's what's happening. Then I have to lock car up for about 15 minutes then try again...
  11. #9
    Wales Organiser mike0491's Avatar
    24-08-2009
    Costa Del Swansea
    Age
    25
    50,214
    Mentioned
    22 Post(s)
    Tagged
    0 Thread(s)
    Your speedo clocks is loose.
    (as bizarre as it sounds, that's why)
    South Wales Regional Organiser
    Xbox GT: mike0491
    Corsa C 1.0 Life - 2009-2011 | Corsa C 1.2 SXi twinport - 2011-2012 | Corsa C 1.8 SRi - 2012-2013 | Astra G 2.0DTi Dec 2012 lol | Astra GSi Turbo - 2013 - 2014 | Corsa C 1.8 SRi again 2014 - present | Astra H VXR - 2016 - present
  12. #10
    27-06-2011
    WS10
    Age
    26
    13
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mike0491 View Post
    Is that why every now and again the alternator light comes on and the speedo and rev counter stop working until I turn the car off and try again?
  13. #11
    24-08-2009
    Costa Del Swansea
    Age
    25
    50,214
    Mentioned
    22 Post(s)
    Tagged
    0 Thread(s)
    That could also be related to the crankshaft sensor being faulty
    but the car cutting out and taking time to restart is definitely the clocks loose. Had the problem on my old C and sometimes you would drive and the clocks would drop to zero.
    Xbox GT: mike0491
  14. #12
    16-06-2010
    1,684
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ^^ push your clocks in, thumb at the bottom of the glass index finger at approx 7000 rpm and gently push you will hear a CLICK.
    then see if you get any more problems.
  15. #13
    22-03-2008
    hartford, northwich
    1,375
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You fixed it mate?
+ Reply to Thread
