**MOT Failure- Headlight adjustment**
User Tag List
+ Reply to Thread
Results 1 to 4 of 4
Thread: **MOT Failure- Headlight adjustment**
    06-08-2011
    Plymouth
    269
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi all,
    Not been on here in aaaages due to starting a new business venture My C recently failed MOT and I have rectified all the problems apart from the failure of the headlights, saying they're aimed/adjusted as to dazzle other drivers, this has happened before but I left it to the garage to do but this time I've done it all myself so was just wondering how to adjust the headlights to fix this problem so it's ready for MOT? It's a pre-face with non-projector lights
  2. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  3. #2
    13-07-2007
    Portsmouth
    Age
    27
    19,633
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Unless you have anothe Corsa that you can copy the beam pattern of Take it to a garage and ask them to align you headlights. They have a beam tester so will be able to do it more accuratly than you could
    Sent from my Desire HD
  4. #3
    Banned User
    18-02-2010
    Southampton
    Age
    25
    1,891
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    theres just a screw on the top of the headlights, if you can set the beam to be just under horizontal to the bulb at about 3 ft away or so (use a wall and mark horizontal from the bulb) it will more than likely pass
    google it and there are loads of tutorials how to set horizonal and vertical beams
  5. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  6. #4
    06-08-2011
    Plymouth
    269
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    All sorted now guys, turns out the garage I was using, they had a beam tester also changed the handbrake cables too, what a pain in the a55 they are to get the small ends back into the metal clips!! Cut my fingers to shreds with pliers etc, only to find that all I had to do was use the pliers to 'clamp' the end into the holder
+ Reply to Thread
