need help! (petrol cap)
User Tag List
+ Reply to Thread
Results 1 to 18 of 18
Thread: need help! (petrol cap)
    22-09-2011
    Age
    24
    76
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i have an 02 corsa c comfort with remote locking.
    recently i lost my only set of key and have bought a standard non remote locking key.
    in the past the door lock barrel has been changed and so doesn't work with the correct key, hence at the moment having to leave the car unlocked all the time.
    i realised today that i cannot open the fuel cap as it is locked shut... is there a button inside the car? or anyway of unlocking the petrol cap and opening it?
    the locks are getting changed tomorrow but i really need to put petrol in the car!
    thanks
  2. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  3. #2
    01-12-2009
    Sheffield
    Age
    27
    9,268
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    your ****ed
    I'm not sure what would happen if u ragged it off either
  4. #3
    13-07-2007
    Portsmouth
    Age
    27
    19,634
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    There are no buttons in the car for it.
    The only way is to open it using a key fob or door lock.
  5. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  6. #4
    Administrator
    Trusted Seller
    Pugh125k's Avatar
    02-12-2005
    near ludlow
    26,158
    Mentioned
    184 Post(s)
    Tagged
    2 Thread(s)
    Does it not unlock if you pull up the door pin in the drivers door
    You could try pulling the petrol cap very hard breaking the plastic pin inside it's not easy tho
    This may break what the pin goes into as well on the petrol cap
    Then replace with new pin and if you need to new fuel petrol cap
    That's what I did with the laguna when the petrol cap wouldn't unlock with the central locking
    Sent from my iPhone 4
    Do you need a new key part/complete new key or does it need repairing i do also have flip keys/standard cases for sale please feel free to pm me for a quote(s)
  7. #5
    Premier Member ultimawhistler's Avatar
    02-04-2008
    Stevenage
    21,818
    Mentioned
    92 Post(s)
    Tagged
    0 Thread(s)
    Get an opcom or tech2 to pop the central locking
    Creator of the Omega Bonnet Lifter mod - which failed
    Creator of the bin bag headlight tint mod
    Creator of the vectra cup holder mod !!
    Progress thread : http://www.corsa-c.co.uk/forum/showthread.php?263283
    If you can remove it from the car I can paint it.
  8. #6
    08-07-2012
    Watford
    Age
    30
    488
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Drill a hole in the middle of it, then pry it open with screw driver thru the hole. Will **** the flap big time tho.
  9. #7
    13-07-2007
    Portsmouth
    Age
    27
    19,634
    Mentioned
    4 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by dcy View Post
    Won't.
    My gf's petrol cap doesn't lock and it's fine when driving
  10. #8
    25-11-2009
    York
    Age
    24
    8,597
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Take off the speaker trim in the boot (side with the petrol flap) then you can reach in and pull the petrol flap lock out (follow the wiring loom from the boot side of the petrol flap
  11. #9
    22-09-2011
    Age
    24
    76
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by grezza112 View Post
    thanks for all the advice. i will try out grezzas method as i really don't want to break it and end up paying to refix it. cheers
  12. #10
    15-07-2012
    West Yorkshire
    Age
    23
    143
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm in the same situation and it's easy, all you do is put the key in the door, unlock it, then do it as though youre unlocking the car again and the pin will go back making the fuel cap accessible, try it it should work
  13. #11
    28-07-2011
    Bicester
    Age
    22
    3,093
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sam_ View Post
    Didnt read
    His key doesnt match the door lock, so if you dont want to break anything do what grezza said and go from the inside and unlock it manually
  14. #12
    22-09-2011
    Age
    24
    76
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    the previous owner before me changed the lock within the door and so the key doesn't work, its all explained above
  15. #13
    25-12-2007
    6,357
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Opcom
  16. #14
    15-07-2012
    West Yorkshire
    Age
    23
    143
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Oops! Sorry my bad i didn't read properly!
  17. #15
    28-07-2011
    Bicester
    Age
    22
    3,093
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    I forgive you
  18. #16
    North West Organiser M1K3Y B's Avatar
    06-04-2009
    Blackpool
    Age
    26
    47,022
    Mentioned
    18 Post(s)
    Tagged
    1 Thread(s)
    Dont you need to unscrew it from the outside first?
    Pew = Dead To Me
  19. #17
    06-06-2010
    Stoke
    Age
    25
    928
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by M1K3Y B View Post
    just run power through it to release it
  20. #18
    15-07-2012
    West Yorkshire
    Age
    23
    143
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Luigi View Post
    I forgive you
+ Reply to Thread
