fault codes
User Tag List
+ Reply to Thread
Results 1 to 2 of 2
Thread: fault codes
    17-02-2010
    Stevenage
    1,657
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    fault codes
    borrowed from corsasport, Z20LEL Z20LER Z20LEH
    P0070 Ambient Air Temperature Sensor Malfunction B-025
    P0100 Mass Or Volume Air Flow Circuit High Input C-007
    P0100 Mass Or Volume Air Flow Circuit Low Input C-007
    P0100 Mass Or Volume Air Flow Circuit Malfunction C-007
    P0110 Intake Air Temperature Sensor Circuit Low Input C-008
    P0110 Intake Air Temperature Sensor Circuit High Input C-008
    P0115 Engine Coolant Temperature Sensor Circuit Range/Performance Engine Cooling B-010
    P0115 Engine Coolant Temperature Circuit Low Input Engine Cooling B-010
    P0115 Engine Coolant Temperature Circuit High Input Engine Cooling B-010
    P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input C-005
    P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input C-005
    P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem C-005
    P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1) C-019
    P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) C-019
    P0130 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1) B-026
    P0130 No Plausibility between O2 Sensor 1 Bank 1 and O2 Sensor 2 Bank 1 B-021
    P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) B-021
    P0135 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) B-012
    P0135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) B-012
    P0135 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1) B-029
    P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) B-012
    P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) C-023
    P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2) C-023
    P0136 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 2) B-027
    P0136 No Plausibility between O2 Sensor 1 Bank 1 and O2 Sensor 2 Bank 1 B-028
    P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) B-028
    P0141 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2) B-013
    P0141 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) B-013
    P0141 O2 Sensor Heater Circuit Open (Bank 1 Sensor 2) B-030
    P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) B-013
    P0170 Fuel Trim Malfunction (Bank 1) B-016
    P0201 Cylinder 1 Injector Circuit High B-011
    P0201 Cylinder 1 Injector Circuit Low B-011
    P0201 Cylinder 1 Injector Circuit Open B-011
    P0202 Cylinder 2 Injector Circuit High B-011
    P0202 Cylinder 2 Injector Circuit Low B-011
    P0202 Cylinder 2 Injector Circuit Open B-011
    P0203 Cylinder 3 Injector Circuit High B-011
    P0203 Cylinder 3 Injector Circuit Low B-011
    P0203 Cylinder 3 Injector Circuit Open B-011
    P0204 Cylinder 4 Injector Circuit High B-011
    P0204 Cylinder 4 Injector Circuit Low B-011
    P0204 Cylinder 4 Injector Circuit Open B-011
    P0219 Engine Overspeed Condition C-025
    P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input C-005
    P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input C-005
    P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem C-005
    P0230 Fuel Pump Primary Circuit Low B-010
    P0230 Fuel Pump Primary Circuit High B-010
    P0235 Boost Pressure Sensor Circuit Low Input C-031
    P0235 Boost Pressure Sensor Circuit High Input C-031
    P0243 Boost Pressure Valve High Voltage C-032
    P0243 Boost Pressure Valve Low Voltage C-032
    P0243 Boost Pressure Valve Circuit Open C-032
    P0300 Random/Multiple Cylinder Misfire Detected B-022
    P0301 Cylinder 1 Misfire Detected B-022
    P0302 Cylinder 2 Misfire Detected B-022
    P0303 Cylinder 3 Misfire Detected B-022
    P0304 Cylinder 4 Misfire Detected B-022
    P0313 Misfire Detected at Low Fuel Level B-022
    P0325 Knock Sensor 1 Circuit High Input (Bank 1 Or Single Sensor) B-023
    P0325 Knock Sensor 1 Circuit Low Input (Bank 1 Or Single Sensor) B-023
    P0335 Crankshaft Sensor Circuit Range/Performance C-002
    P0335 Crankshaft Sensor Incorrect Signal C-002
    P0340 Camshaft Position Sensor Circuit Low Input C-009
    P0340 Camshaft Position Sensor Circuit High Input C-009
    P0340 Camshaft Position Sensor Circuit Open C-009
    P0340 Camshaft Position Sensor Circuit Range/Performance C-009
    P0340 Camshaft Position Sensor Circuit Malfunction C-009
    P0420 Catalyst System Efficiency Below Threshold (Bank 1) B-017
    P0441 Evaporative Emission Control System Incorrect Purge Flow B-014
    P0443 Fuel Tank Ventilation Valve Voltage High B-014
    P0443 Fuel Tank Ventilation Valve Voltage Low B-014
    P0443 Fuel Tank Ventilation Open Circuit B-014
    P0460 Fuel Level Sensor Circuit Range/Performance IPC (Instrument) B-013
    P0500 Vehicle Speed Signal Range/Performance B-024
    P0501 Vehicle Speed Signal Range/Performance B-024
    P0520 Engine Oil Pressure Sensor/Switch Circuit Range/Performance IPC (Instrument) C-018
    P0530 A/C Pressure Sensor Circuit High Input Heating, Ventilation and Air Conditioning System C-009
    P0530 A/C Pressure Sensor Circuit Low Input Heating, Ventilation and Air Conditioning System C-009
    P0571 Brake Light Switch Circuit Malfunction Exterior Lighting/Turn Indicator System B-014
    P0607 Knock Control Module; Replace ECU B-023
    P0607 Knock Sensor Circuit Malfunction B-023
    P0621 Generator Lamp "L" Control Circuit Malfunction IPC (Instrument) C-021
    P0650 Malfunction Indicator (MI) Circuit Malfunction IPC (Instrument) B-008
    P0704 Clutch Switch Input Circuit Malfunction CRC (Electronic Cruise Control) B-010
    P1105 Barometric Pressure Sensor Circuit Low Input C-030
    P1105 Barometric Pressure Sensor Circuit High Input C-030
    P1106 Boost Pressure Sensor Circuit Range/Performance B-018
    P1120 Accelerator Pedal Position Sensor 1 High Input C-004
    P1120 Accelerator Pedal Position Sensor 1 Low Input C-004
    P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio C-004
    P1122 Accelerator Pedal Position Sensor 2 High Input C-004
    P1122 Accelerator Pedal Position Sensor 2 Low Input C-004
    P1230 Main Relay Malfunction Power Supply and Communication C-013
    P1243 Turbocharger Bypass Solenoid Valve Circuit High Voltage C-033
    P1243 Turbocharger Bypass Solenoid Valve Circuit Low Voltage C-033
    P1243 Turbocharger Bypass Solenoid Valve Circuit Open C-033
    P1243 Turbocharger Bypass Valve Range/Performance C-033
    P1481 Fan Control 1 Circuit High Voltage Engine Cooling B-004
    P1481 Fan Control 1 Circuit Low Voltage Engine Cooling B-004
    P1481 Fan Control 1 Circuit Open Engine Cooling B-004
    P1482 Fan Control 2 Circuit High Voltage Engine Cooling B-004
    P1482 Fan Control 2 Circuit Low Voltage Engine Cooling B-004
    P1482 Fan Control 2 Circuit Open Engine Cooling B-004
    P1483 Fan Control 3 Circuit High Voltage Engine Cooling B-004
    P1483 Fan Control 3 Circuit Low Voltage Engine Cooling B-004
    P1483 Fan Control 3 Circuit Open Engine Cooling B-004
    P1490 Additional Coolant Pump Circuit High Voltage B-015
    P1490 Additional Coolant Pump Circuit Low Voltage B-015
    P1490 Additional Coolant Pump Circuit Open B-015
    P1500 Electronic Throttle Control Malfunction C-006
    P1523 Throttle Actuator Control Return Performance C-006
    P1526 Throttle Control Lower Position not Learned C-006
    P1530 A/C Relay Voltage High Heating, Ventilation and Air Conditioning System B-017
    P1530 A/C Relay Voltage Low Heating, Ventilation and Air Conditioning System B-017
    P1530 A/C Relay Circuit Open Heating, Ventilation and Air Conditioning System B-017
    P1565 Cruise Control Interface Malfunction CRC (Electronic Cruise Control) B-006
    P1600 Engine Torque not plausible B-031
    P1606 Engine Torque not plausible B-031
    P1610 Immobiliser Function not Programmed Immobiliser B-009
    P1610 Immobiliser Malfunction Immobiliser B-009
    P1611 Wrong Security Code Entered Immobiliser B-015
    P1613 Immobiliser No Or Wrong Signal Immobiliser B-008
    P1614 Immobiliser Wrong Signal Received Immobiliser B-008
    P1614 Wrong Transponder Key Immobiliser B-006
    P1615 ECM (Engine Control Module) Identification Failed Immobiliser B-006
    P1616 CIM (Steering Column Module) Wrong Environment Identifier Immobiliser B-006
    P1811 Torque Signal Malfunction (CAN) ABS/TC/ESP (Vehicle Dynamic System) C-011
    P1814 Invalid Signal from ECC (Electronic Climate Control) ECC/SAC (Electronic Climate Control) B-032
  2. Remove Advertisements
    Corsa-C.co.uk
    Advertisements
  3. #2
    19-04-2005
    Bmouth
    14,089
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Good find :yes:
    I personally hate these with a passion!!
+ Reply to Thread
