The Clio; February 2020 - April 2020
Mechanical
So, once I had bought the Clio, the first thing was to get it checked over, and remedy any issues. So, we knew about the squeaky belt, which turned out to be brand new, but covered in grease, causing the noise, but not accessible enough to clean, so we left it. The wheel bearing was indeed worn, so we got it replaced, along with a broken coil spring and an idle speed sensor which was causing the car to stall when cold. Next came an ABS fault which was a rear ABS sensor, and then the auto selector stopped working, turning out to be the linkage came apart. With all that done we've spent about £200 and got the car to a pretty good standard. I then finally got around to giving the engine bay a good clean...
We also found the number plate light was yellow and bodged, so we found an eBay replacement for that too.
Interior
Despite having spent a decent amount of time on the interior already, I found more to do. Under the passenger seat is a piece of plastic trim, apparently to put bottles in... I guess the French like their wine so much they need a place to safely store it in their car. Held in by one bolt, I removed it and cleaned underneath.
The plastic trim surrounding the handbrake could also be removed easily, revealing a few years of Staffordshire bull terrier fur.
After cleaning those, the interior got another once over to remove any last stray hairs from the previous owners.
Next, I cleaned the door shuts...
With the interior clean, we wanted to do something to brighten up the overall grey, dull look, so we found some cheap tatty pinstriping trim on Wish and fitted it around the interior light and the door pullers.
It's not much but it livens it up a little at least. Last for the interior, it's not the quietest car once at speed, and the spare wheel would rattle around over bumps. So, I stuffed a pile of that foam-wrapping stuff you only ever get in Amazon parcels underneath the spare and around the jacking kit, I put a thick carpet cut to size over the top, under the boot floor, and for the dog, we put a blue tarp down to keep it tidy, and some fancy dog bed down to keep our little waste of space comfortable.
Next will be finally giving the exterior a good once-over. Also in the pipeline is a roof spoiler for the Combo...
