Hey all
Didn't really want my first post to be asking for help, but I seem to have got myself in a bad situation. I bought my car a couple of weeks ago, did about 500 miles in it including about 150 miles on a motorway and it ran perfectly, then one journey it just cut out. Was doing about 50 and the engine just stopped making power. It didn't want to immediately restart, but after 30 seconds, it started as normal, ran fine for a few minutes, then the same thing happened. Got home after about 8 mini breakdowns, now it won't run for more than a couple of minutes at a time.
I've tried doing some searching, this problem always seems to be the crank position sensor. Replaced it, problem is still there. Also replaced the fuel filter in case it was a low pressure cutoff and ran with the MAF unplugged, both give the same result of running perfect for a few minutes then stalling. It's the strangest thing, it's like someone just turns the key off, no coughing or struggling, just cleanly switches itself off with no fault codes stored (either using the pedal test or an OBD reader)
Anyone have any ideas? It was a nice driving car when it was running so it feels likely to be some stupid electronic component acting up but I've no idea what to try next.
