1 - 1 of 1 Posts
Towards the end of last year my nearside front brake disc developed a judder under heavy braking. About 2 months ago I changed both front discs (didn’t want to just change 1 on its own) and for about a month after that it cured the problem.
However the judder has started to slowly come back and now it is exactly the same again, loads of judder from the nearside when heavy braking
The nearside wheel bearing was replaced only last September as it was an MOT failure so that’s not the issue. The hub face and the back of the wheel is clean enough with no visible damage
Starting to wonder if the caliper might be a bit dodgy?
1 - 1 of 1 Posts
