The drivers door opens manually but none of the other doors will open, not even from inside with the buttons lifted up. The key will turn to manually and open the drivers door, but even by turning it again the other doors and the petrol flap won’t open. The rear doors and passenger doors won't even open from the inside with the buttons lifted up. It seems that the doors are deadlocked and probably happened when the battery was dead for a time. I think that the BCM is locked. Is there a way to fix this?
Corsa C 2004 z10xep
Check the drivers side door module ( door lock from inside) and the door wire between puller A and the door. If fault with central locking start there if fuses ok. Signal goes to drivers door then to the rest of lock if this lock opens or closes. If signal is not getting to door ie from the wires broken in the rubber sleeve the locks won’t work.
