1 - 3 of 3 Posts
Hi, at the mo i have a 1.2 sxi on the standard 15" wheels, this is probably going to be a daft question but if i was to buy exclusiv alloys and put them on, because they are 16" does that make the speedo go out of sync?
Also is it just a strait swap? dont need different bolts or anything?
Thanks
Thanks
Yes, Yes & Not sure, would imagine you'd maybe need different locking nuts ;)
Exclusives are fine for the nuts... as for the speedo it should also be fine.. generally they are 2-3mph out when comparing the GPS to the clock speed.. clock displays higher so you should be fine. I may be corrected shortly however.
1 - 3 of 3 Posts
