Any way to tell if it is compatible with a w203ri? interested if compatible as i was looking to install an sri wheel in my 1.7di but only if the buttons could be made to work with my current head unit.
The spec says it'll work with steering controls but doesn't mention the MFD display, you could always try emailing them as that's what I did before buying it but if you aren't bothered about the MFD and just the controls then you should be fine
As long as your headunit has what looks like an AUX in in the back of it but is not actually for use with an AUX cable then this literally just plugs in and that's your steering controls working, it says it should so don't see why not
Ok matey I would imagine it does cause like mine you normally need to use the Bluetooth interface bit if you want to use AUX in or vice versa so if there looks like there's an AUX connection it's gonna be for the steering controls instead (if that makes sense)
Installed it yesterday there seen the connector you were talking about, so looks like it should work ok.. do you want to pm your PayPal addy? Happy enough with 40 posted?
Related Threads
Vauxhall Corsa-C Forum
7.7M posts
79.9K members
Since 2004
