Astra G Grab handle Lights on a C
Has anyone ever fitted Astra G rear grab handle lights to their Corsa? Got myself a 5 door and the handles are bolted in with 2 torx screws but the ones from the astra are just held in by a plastic clip. Would you have to cut the roof in order to get them in right?
Wiring should be easy. Need a permanent live going to one connection on the switch and a interior light wired to the other and ground to earth.
https://gyazo.com/31367474b6887de9a41f1b31172c6943
https://gyazo.com/76e74433468c6c3cdeefd7f9b47758b8
Hello. I had the same idea about few months ago and i realized that it cannot be done. Then a friend of mine came with the solution. To fit led band in the door handle. I had to cut outin the handle just enough to fit the band. I had wired to the lamp in the back of the car and it turns on when the door opens. I will try put some pictures to understand better.
Yes it's led strip a tiny one. At corsa c the handle ist's empty inside.. It can be cut at the interior to fit the led strip. I'll make some picture later.
