I'll convert them for you if you want to remove them, should have them done in less than an hour and returned the next day, £3 for a single switch and £4 for a double.
Just for info the single switch is a normal dome type LED and the double are surface mounted diodes which you need to unsolder from the circuit board, if your clumsy you'll ruin your switch.
I have some coming in a few days, I'll do an exchage basis if that's more convienient
