1 - 2 of 2 Posts
Hi guys,
I have just had to swap out the brake master cylinder in my 1.2 litre, twinport 55 plate corsa C, it seems that this website (below) is pretty good for parts but the ones listed Don’t exactly match what I need. I need a master cylinder with two m10 oil connections but on this website, the only ones with two m10s specify that they are for disc brakes at the back only and I have drum brakes at the rear, any help would be appreciated, thank you.
I often use autodoc, if not to buy at least to check. Parts can be compared to OEM part numbers pretty easily and diagrams are often handy. I've linked the 1.2 twinport page for you but also try the reg number search (doesn't work for me as mine's replated)
1 - 2 of 2 Posts
