I bought my 2001 Corsa C 1.7 DI (Y17DTL) back in dec. 2019. and car is just amazing for my needs and it's quite responsive for its 65hp.
But for the last 2-3 months, I've been experiencing really strange behaviour. Car used to have that "kick" when you cross boost threshold around 2000rpm which was very useful for overtaking and uphill drives (I don't know if it's just turbo or ECU gives it more fuel at that moment). Now, it has that surge of power only when the engine is cold (or so I thought).
What I found out after hours of staring at diagnostic data is that car loses that kick at exact moment that coolant temperature hits 70°C.
It still has turbo power, turbo reaches commanded pressure without any issue, it just loses that "kick" or "power surge" that it had around 2000rpm when it needs it the most (It's just a flat line).
Now for the weird part.
For my test, I warmed up the car to operating temperature (between 85°C and 90°C), tried it, no power. Then, I removed connector from coolant temperature sensor and plugged a resistor in it. When I turned the car back on, diagnostic software reported coolant temperature of around 30°C. I started driving and it drove beautifully! That power surge was back and it was nimble and quick.
So I don't even know if its mechanical or electrical problem anymore, obviously, I can't and won't drive the car with resistor plugged in it instead of a real temperature sensor, I even replaced that sensor even tough I knew it wouldn't fix it, and it didn't. As far as my mechanic and diagnostic software are concerned, car is a 100%, It passed every OPCOM test, every valve and solenoid opens and closes. I'm out of ideas.
If anyone ever encountered this or has any idea what could've caused it, I would be very happy to hear it!
Other things I tired:
I thought maybe it was plugged catalytic converter, so I removed entire exhaust, nothing.
Cleaned the EGR just cause, nothing.
