Battery isn’t charging and I cleaned all the wiring of and comtacy point so was trying cheap to more expensive and don’t know where to go from here apart from new alternatorThey don't have one for charging, the red cable is connected to the battery from the starter main power and the blue/white trigger wire comes from the BCM once key is on.
What is the issue?
i have 12.9 volt some times but that’s it every now and then it will work so I’m thinking it must be something else amd no haven’t seen blue and white wire I’ll check it soon and let u noDid you check the plug where the wiring goes through the bulk head in front of the brake servo? There should be 12V on the blue/white wire here with key on.
It may well be the alternator has failed if you don't have 13.5V at battery with engine running and all loads on.
