G
Guest
·Whats the best way to do this.....
Mines filthy.... Instructions please
:lol: truediddon said:get some auto glym stuff and start poilishing, will require some hard work so you may not be able to do it yourself :lol:
don't you have to cover anything with all the electrics in the cChewy said:get an old spray bottle and fill it with paraffin,go down the local jetwash and then soak the whole engine and bay with the parrafin..use a paintbrush to scrub the tuff bits then jetwash the whole lot off.drive back home this should dry the engine off a bit. then use plastic and vinyl cleaner to polish it all up...job done
the big plastic bit in the middle the bit you colour coded (but before you coded it what did you use) think it's the rocker cover but don't quote me :lol:Chewy said:which bit david??
