Evening gang. I've noticed a loud click when I push the clutch pedal. It almost sounds like a loud microswitch click!! Any ideas? Cheers
Sounds like the clutch pedal is about to snap. It happened on mine. Have a looks were it connects to the master cylinder and you will see a white plastic colar on the clutch rod. This sits inside a box welded to the pedal. Check this box for cracks. You will probably find its cracked and bent. Its pretty hard to see. I used a endoscooe connected to my mobile to inspect mine. Eventually the metal fracture and you end up with no clutch as the rod exits the other side of the welded box on the pedal.
Vx sell a updated version which is a much better design which will stop it ever happening again.
Look at post 351
Look at post 351
Cheers mate
