To do this you must use your master fob (the one with all the options on)
1. un arm your car
2. press the cifford nutton 3 times
3. press the * button once - will beep after you do this
4. press the ** button once - will beep again after you do this
next step is basically trial and error
5. if you press the boot open button it will beep at a high pitch, the more you press it the higher pitch the sound and the more sensitive you make the proxy sensor
6. press the * button and you will hear the pitch getting lower and very flat, turning down the sensitivity of the proxy sensor
7. when you think you are happy press the arm button - should beep a few times
8. press the arm button again - should beep again
9. the next time you press arm this should now arm the car, wait 30seconds and then walk around the car to text the proxy sensor
10. if you're happy you've made it more/less sensitive (whatever you wanted to do) then great stuff, if not start again and increase/decrease the sensitivity, then test it again
Smiffie
:salute:
