Hi can anyone provide the correct part number for a compatible crank sensor to use with a nodiz pro. It’s a X20xev engine. Thanks a lot
Does the manufacture not give you part numbers for Bosch or Siemens crank sensors? Fitment is the same as the 20xe and c20xe.
i have heard now it is supposed to be one from an early red top I gather is a 20xe. So far I’ve had 3 sensors from a X20xev with no luck 🤦‍♂️
Sounds about right. My DTA S40Pro ECU used a crank sensor from the early X20XEV or early 20XE. That was pre internet days and before I had a computer of any kind so not info saved as I sold all the paperwork with the engine kit complete.
MK1 Astra GTE 2.0 16V
So from my research the compatible crank sensors are feb27177 and 0261210030 and non of the 3 I have used are either of these so hopefully I’m on to a winner after purchasing one of these. If anyone could confirm I’d be over the moon!!
