Hello all. The Astra problem I solved. Seems tech 2 goes directly on to learn gear box parameters, after clutch bleed, doesn't give you the chance to clear all the fault codes. So I did a full scan of the whole car, and deleted all the fault codes I could, TWICE. Then went in to the gearbox...
www.corsa-c.co.uk
