1 - 3 of 3 Posts
Not sure if in correct section ...:geek:
Any idea's for somewhere to source a MODULATOR,BRAKE,LOAD SENSING,REAR,M12 - its the load valve fitted to a 6way splitter block on the NSF wing .... here's mine on the LEFT with white chalk.
I have replaced rear wheel cylinders - shoe's - all handbrake cables and now i have no NSR FOOT BRAKE.
The hand brake works fine and im suspecting this load valve is this issue - its the unit with M12 thread :cool:
36543
The 2 round parts hanging down are you rear brake restrictors. They are just a metering orifice but can get blocked.
Also check for failing rear rubber flexi hose. I have seen a few cars where the inside of the hose falls apart and blocks the pipe.
1 - 3 of 3 Posts
