Hi all,
I have a Corsa 2005 1.2 twinport and there are two oil filters available on eurocarparts.
One is
Height mm87
Inner Diameter mm28
Outer Diameter mm59
The other is:
Height 103mm
Inner Diameter mm21
Outer Diameter mm54
Does anyone know which one it is?
Cheers!
I went with a Bosch oil filter, measuring 88.5 mm in height, 27.6 in inner diameter, 62.6 in outer (available on Autodoc). In your case, I would go with the first one, as it is closest to the dimensions of the Bosch filter.
