21 - 38 of 38 Posts
Discussion Starter · #21 ·
Is this it now? I followed the instructions for copy and paste. I have named it Alex car video corsa-c-co-uk and the name is Declan Murphy
The engine sounds like it's got compression and all even. Do the pedal trick and read the codes as your car spanner lights on so there is a fault code there. Try that and post back. Does your rpm need move to around 200rpm when cranking or not.
I think it's now clear for you that start motor was ok. Why I say was, because it's madness to crank it for full 40 seconds. If the car does not start in 10 seconds, stop! Probably start motor it's on it way out, FRIED.
Is the engine management lamp blinking with contact on? While cranking, is the rpm needle going a bit up?
Discussion Starter · #29 ·
Is that a difficult job, or do I get a mechanic? Thank you so much for what you've done for me so far. I truly appreciate all your help. You've all been remarkably patient and very knowledgeable.
Discussion Starter · #32 ·
I fitted a new sensor today and it went first turn. :) A 2 minute job if it was easier to access. Thank you all so much for all your help and patience, it is very much appreciated. I'll spend some time reading some of the other threads now. Thanks Again
Good news to hear, Alex. One of the 1st things I read about when I got a Renault Modus is that this sensor is almost always the cause of a starting problem. Dead easy to access, but the corollary is that it gunks up quite regularly. I'd see Modi on ebay "won't start, want rid, £250" and I'd tell them to spend £20 (unlike the C, a Modus doesn't seem to mind the cheaper ones) and ten minutes to either solve the problem or sell for a better price. Invariably, I'd get the reply "Cheers mate, but CBA" and it would sell for peanuts.
Glad you sorted your problem mate, I'm having an issue with mine too. I've changed the crank sensor for a genuine one, cold starts it fires up straight away no issues. After driving it for 10/20 minutes, I leave the engine off for a few minutes then the crank just clicks once, I have to keep trying it over and over until it goes. Sometimes it sounds like it wants to go but is super slow. This is even worse when the weather in really warm outside. Could it be the battery? Got a lion 063 currently fitted had it for 3 years now could it be the starter motor ? Any help at all would be massively appreciated
21 - 38 of 38 Posts
