1 - 2 of 2 Posts
Hi, the light of engine management light ,abs and check engine are not displayed. Only the battery, hand brake and oil are displayed. The car doesn't start. 1.7dti engine. The battery is OK
Thanks for your help
It sounds like you have a broken wire or bad connection somewhere? ABS pump or ECU maybe? Or even on the back of the dash itself?
Also check all the fuses and relays are good, if the ECU is not powering up you will get the same faults.
1 - 2 of 2 Posts
