Hi all, for a few months now my dashboard has been flickering all warning lights at the same time, including fog light and petrol. (I believe only the lights on the right side of the speedo are actually flickering. It happens randomly, even with the keys out of the ignition.
- The battery is new, terminals are also clean and secure. Disconnected for 30 mins and it still happens when reconnected.
- Alternator was tested a few months ago by the RAC and it was good
- Pressed down on the speedo, pulled it out and reconnected when I changed the milage bulb
Would I be right to think the ignition switch has had moisture in it? Or the bcm been exposed to moisture when I had the bcm lid leak?
Many thanks
Many thanks
