I want to take the vauxhall,corsa and 1.2 badges off my car and i just wundering if it leaves bad marks. like you can see where its been?
Does t-cut bring it out?
as my dad thinks it will leave marks!
HELP!
plz write back
mine was fine no marks just be gentle with it and use a bit of plastic held at a angel. if your going to take off the vauxhall badge then you need to get the pin hole filled too.
when i did mine there was glue left on all i did was hot water and my whsmith clubcard and then trust t-cut now u wd neva no there was anything there
well worth it looks well better after
hi, is the black sills down the side of the car(on the back quatre and the door) just stuck on with glue? if i remove it will it leave holes on the side of the car?
