was painting my calipers yesturday and noticed that the drive shaft boot (think its called that) is split and i'v lost alot of greese.
where can i buy them from and how much are they to buy
if i got the name wrong, correct me please
cheers Jay
It's called a CV Boot Mate so you wernt really wrong.
You can buy them obviously from Vaux,Ebay,A cheap parts warehouse shop if you have one in your area?Just have a search on the Internet.Im not sure how much one will cost i wouldnt imagine it would be much TBH so maybe try Vaux first.
Ask if they do a kit though not just the Boot,As you will need some Grease which is special stuff and some metal clips Etc.
You will need to take the driveshaft out to fit it and knock the whole joint of the end of the driveshaft then swop all the bits over Etc.They can be a pain in the arse to fit and it's a very messy job so if your not that Mechanical minded i would ask a few garages how much they would charge.
just found out its called the inner CV boot :)
can get the part, greese and clips for £20 so not to bad
Just found out its called the inner CV boot :)
Can get the part, greese and clips for £20 so not to bad
Oh it's the Inner one i just assumed it was the outer one with it being closest to the Calliper Etc.
Yeah i didnt think they where much,£20 is oright.
