1 - 3 of 3 Posts
I have a problem with the Easytronic. It is possible start and drive like normal. Occasionally when I slow down (I want stop the car) and there if F on gearbox display. Sometimes I can restart the car after the incident, sometimes it is not possible and ‘‘F‘‘ don’t disappear. Maybe it is related with rainy weather or cleaning the car with water. Maybe water can damage somethink. Any ideas?
Opel Combo Engine 1.3 cdti
I have this fault codes:
Engine 1 problems exist
1.P1700 Service Vehicle Soon Request From Transmission Control
Module
Not Present
AF 13-II/17/20/22 CAN 10 problems exist
1.U2107-C CAN-Bus No Communication With IPC (Instrument) Or
BCM (Body Control Module)
Not Present
2.84,00,17,22(P1722) Please refer to manual
3.P0725-C CAN-Bus No Communication With ECM (Engine Control
Module)
Not Present
4.U2108 CAN-BUS No Communication With ABS/TC Not Present
5.P1895 Limp home - Limited Performance Or Engine Torque Signal
Range/Performance Or Invalid Data From ECM
Not Present
6.P1120 Accelerator Pedal Position Sensor 1(and 2)
Not Present
7.U2105-0 CAN-Bus No Communication With ECM (Engine Control
Module).
Not Present
8.P1703-C Brake Light Switch Signal CAN-Bus Malfunction Not Present
9.P1560 Switched System Voltage (Ignition ON) Circuit Malfunction Not Present
10.84,00,16,07(P1607) Please refer to manual
Easytronic(MTA) 10 problems exist
1.U2107-4 CAN-Bus no Communication with Body Control Module Not Present
2.P1722-0 Gear Selector Serial Data Not Present
3.P0725-4 Engine Speed Signal CAN-Bus Malfunction Not Present
4.U2108-4 CAN-Bus No Communication with ABS (Anti-Lock Brake
System)
Not Present
5.P1895-4 Engine Torque Signal CAN-Bus Malfunction Not Present
6.P1120-4 Accelerator Pedal Position Signal CAN-Bus Malfunction Not Present
7.U2105-4 CAN-Bus no Communication with ECM (Engine Control
Module)
Not Present
8.P1703-4 Brake Light Switch Signal CAN-Bus Malfunction Not Present
9.P1560-6 Switched System Voltage (Ignition ON) Circuit
Malfunction
Not Present
10.P1607-0 Clutch Actuator Position Control Error Not Present
The following systems are OK:
1.ABS8/ESP8 (Anti-lock Braking System/Electronic Stability Program)
2.ABS-5.3/5.4(+TC) (Anti-lock Braking System)
3.PSCM (Power Steering Control Module)
4.BCM (Body Control Module)
5.IC (Instrument Cluster)
6.IMMO (Immobiliser)
7.DIS (Info Display TID,BID,GID,CID)
I have completely different engine (Z10XEP) but also have the easytronic gearbox. When I had this problem (F on dash) I had to send the gearbox actuator module off to ecu testing.com to be reckoned. £160 it costs all in and got it back in 2-3days.
1 - 3 of 3 Posts
