1 - 6 of 6 Posts
Hi i have a Corsa C 1.6L The problem I have is when the car heats up I loose accelerator pedal completely ie the car only idles without any response from the accelerator pedal.also the yellow spanner light comes on.If I switch the engine off and let the car cool down then it starts up normally.I have changed the accelerator pedal already.I opened the ecu and cannot see any loose connections.any help would be appreciated.
thanks
They didnt make a 1.6 corsa but sounds like dead ecu to me. Common on the 1.4 engine and also the 1.8.
Im in Australia its a Holden Combo XC 2004 over here.Runs perfect until temperature gauge goes to half way then yellow light turns on and I lose the gas pedal just idles
I looked up repair videos on these on youtube I opened the ecu and checked all the wired solder joints under a magnifying glass no broken wires found.are you saying its the ecu hardware of software problem in your opinions Thanks
1 - 6 of 6 Posts
