1 - 3 of 3 Posts
Hi,
I have an 08 diesel Corsavan with the Fiat Z13DTJ engine. I love it but just recently I find that if I accelerate hard, particularly when cold, the engine stutters momentarily and the engine fault light flashes but doesn't stay on. After that the engine recovers at a somewhat reduced performance. I can reset the performance by stopping and turning off the ignition. I have a micky-mouse fault code reader but it finds nothing. If I do the 'pedal' test it appears to flash 10-1-10-8, which I believe is the code 0108. Any ideas what this might indicate?
Thanks in anticipation
peterc
As far as my diesel knowledge goes, high boost pressure will send the engine into safe mode in order not to destroy the pistons- thats why you have reduced performance. It could be faulty MAP sensor or blow-off valve.
1 - 3 of 3 Posts
