1 - 9 of 9 Posts
Hello and please could someone help?
My daughter has a 1.0 litre Corsa C, 2006 model with the Z10XEP engine. She has had the vehicle for 6 months and absolutely no issues until yesterday. Symptoms of the issue was lumpy idling, loss of power and cutting out. Car has only done 50k genuine miles and was serviced and MOT'd on purchase. I did not realise until yesterday that the Engine Management Light was not working. I did the pedal test and found out straight away that there was 2 error codes relating to a faulty crankshaft sensor and also the No. 2 CO sensor. I purchased new parts from Euro Car Parts and fitted them yesterday and the issue was soon resolved.
However, I'm concerned that the EML is not working and suspect (but can't prove it) that a previous owner disabled the lamp (LED) by making a disconnection somewhere. I very much doubt that the LED has failed but before dismantling to investigate further, I have a simple question:
Does anyone have a wiring diagram that they can share showing the circuitry from the Engine Management Unit to the Engine Management Light within the instrument cluster? Even to know the colour code of the wire would be a big help at this stage. I can then go hunting and find the source of this issue and hopefully get the EML working again.
Thanks in advance, Ian.
There isn't a direct connection from the engine ECU to the EML. If it's not working then it was disabled in the instrument cluster.
Thanks Mr drew - that’s a great pointer and I’ll take a look at the instrument cluster and try and establish what the cause of this issue is.
2005 Corsa C 1.0 Life
Instrument cluster is a piece of cake to remove, couple screws to get the shroud off and then it unscrews from the mounts
My guess is that they've pulled the dials and taped over the lamp, it's fairly common from what I've heard
Hi and thanks for your response. What you have suggested sounded exactly what I was expecting but having removed the cluster this evening and dismantled it, I can find nothing obviously wrong. All the LED's appear to be intact and it does not look like it has been interfered with but I could be wrong.
Unfortunately for me though the ribbon cable which attaches the mileage display has now become detached so I will probably drop the instrument cluster off to a local repair specialist. Thanks again.
Honestly it would be cheaper to replace the entire instrument cluster, they're about a tenner if you keep your eyes peeled, needs Tech2 or OpCom but you'll want those for the Corsa anyway
Judging by the diagrams, EML lamp is connected directly from the ECU to the instrument cluster. Wire color should be brown-blue.
This info is from Autodata diagrams so take it with a grain of salt, I don't have access to the TIS2000 currently. :/
can anyone suggest me a good car battery company?
Yuasa, Bosch, Varta
As long as you get one with a warranty you should be fine
1 - 9 of 9 Posts
