To make an engine, a single engineer does not work, nor a computer, nor 10, nor 20, the whole plant works to develop a 0 engine, components guide it to where the car is sought and seek the maximum possible performance for minimum consumption If you change parameters, change reliability, you risk increasing the efforts of connecting rods, pistons, cylinder head ... everything An atmospheric engine works with little air, that is why it does not suffer as much variation as a turbo diesel, which needs a lot of air pressure, that is why diesels emit more black smoke, due to lack of air, than a gasoline, which uses less or nothing because doesn't need much air With which, if you can fit X in the conbustion chamber, you cannot put Y, because you break the stoichiometric relationship so that it works well, so with a repro you only win 5 horses up or down The only thing you can do is help the piston to suck the air into the chamber more easily, with intake manifold, wide and short intake, high flow filters ... and help it to expel the gases, exhaust line, collectors, catalyst high flow ... everything else, put more gasoline, repro, chips, or high octane gasoline if the manufacturer does not recommend it, is silly. That is why it is more recommended to install another motor according to what has been studied A f1 engine, without going any further, gives so much power because they are not made to last, if it breaks after two hours to the trash, and if it lasts three then three A car has to make sure that you have reliability under any use, that's why you have 75 and not 130, because 130 would not reach 10 years or 5 do not do experiments, neither you nor a reprogrammer, put collectors and exhaust line, but you will not get to half a second or one in a circuit.
