1 - 13 of 13 Posts
Is it just a case of undoing the clamp, removing from rubbers and pulling??
Yeah, just a good pull is needed, can be quite tricky if you've not got a ramp. if the car is older then it gets really stuck on with the heat
You don't need a ramp, as your car aint that old and should fly off mate, and yes btw it's as simple as that. Mine took a bit of a beating due to it being on there for over three years!
Cheat and cut the old ones off! Get a stanley knife with a new blade and slice away!
Did you not get new ones with your new one? I did!
You did buy an Irmscher one new didn't you? They come with a thicker heavier set of mounting rubbers compaerd to the standard ones, cos it's a heavier BB
Strange, they should come in a bloody big box with a set of rubber mounts, an adapter to fit the 1L, two new clamps, instructions and certificate.
Make sure you have the clamp undone first and move the box towards the back of the car to lift off the two hooks first, then go backwards to lift it off the back one. Twist and turn the box whilst pulling to get it off the mid-pipe.
I had problems twisting, as the heat had stuck the ipes together tight, but the mounts were a breeze
just take to yoiuir local exhaust place! mine got fitted for a fiver, drive it in 10 mins later its done and my hands diodnt even get dirty :lol:
Discussion Starter #13
Gonna do that tomorrow Chaz, but my hands did get dirty :lol:
1 - 13 of 13 Posts
