1 - 9 of 9 Posts
i woz jst wonderin whether or not alloys that used 2 b on my mk 1 clio would fit my corsa c, the alloys are 4 stud but i aint got a clue bout offsets and whether or not il need spacers :?
Spacers would only make the prolem worse!!!
No corsa require spacers as the vauxhall offset is so high! you would only need spacers if they were hitting the callipers which is unusual.
They should be Ok, the only problem you may have is that low offfset rims on a corsa can rub on the arches.
The best way to find out is to try a wheel on and ask a few m8s to jump in the back.
Kash is corred about the offset stamp. Have a look for it. Although it has been my experience that some wheels are not stamped.
Try em on, but I reckon they'll stick out from the arches, meaning lots of work. Gie it a try and see is the best way :wink:
1 - 9 of 9 Posts
