couple questions for ya yoda green 😎 my fuel pump wire colours are blue/black and brown/white so which one is live? And also my cars crank sensor colours are black, brown and brown/blue but my crank sensor on the engine is black, red and yellow so do you know what goes where. I may aswell directly ask you 🤣 cheers mateYes it is 1 of the 2 purple relays in the front fuse box. You will just have to add a trigger as it would be triggered from the ECU normally.
A computer hacker that owns a tractor 🤣 thanks a lot mate. Well all I know is it’s an XEV from an auto omega and obv my van is RA03PBV but I genuinely don’t expect you to go to those lengths mate judging by my previous experiences with you this stuffs stored in ya brain 🧠Blue/black is live. Brown/white is earth.
General rule with Vauxhalls is Red = 12V, Black = ignition switched 12V, Brown = earth. so any wire with a red trace is switched live, brown trace is earth switched. other trace wires are usually switched from a control unit.
I would need to know what car the engine came from and it's age and the same for the Vans crank sensor then I could look it up on TIS (Vauxhalls wiring schematics) as I have a pirate copy on a very old computer (windows XP) take ages to load the program and to screen shot you only get small images and no detail. I have to take screen shots, load on a usb the import to my new laptop in order to share but it is poor quality images.
thanks I appreciate that mate but I just wanted to know how to take it out mate. CheersThis Floatless Fuel Sender utilizes an internal pressure transducer to measure the amount of fuel in a tank. The concept behind this sender is hydraulics and pressure. The part of the sender that sticks into the fuel is a hollow tube that fills up to the level of fuel in the tank.
Forpc.onl jiofi.local.html
thanks mate. That’s why I wrote ‘assembly’ I.e the cradle it all sits in. Sorted now anyway but thanksA Fuel tank sending unit is a term for the mechanical assembly inside your fuel tank which measures the level of liquid in the tank, then reports its findings to the fuel gauge on your instrument cluster
