How little I can stand without forums, I wanted to ask you in the C phase 1 how to eliminate the slack that the lever takes in the gearbox, with the use it takes slack of millimeters and is annoying, so it is a bushing on the lever, years ago I saw how they fixed it with a piece of plastic but I no longer remember, any idea how to fix it or do you know how to replace it? greetings from spain in "as rias baixas"
As I see on the internet it is the piece on top of the box, is it from there basically? not coming from the lever inside?
un saludo, jewels. The C has a plastic gear linkage rod that is a cheap General Motors weak part. There are a lot of threads here on CCUK and a metal replacement is commonly available on ebay UK. I would be confident that it can be sourced in Spain, also.
